  3. MH-Z14A CO2 sensor
MH-Z14A CO2 sensor
25 Posts 5 Posters 20.1k Views 6 Watching
  • FotoFieberF FotoFieber
    @korttoma
    As I do not have a broken sensor, I can not tell you.
    If I were you, I would try to fix the voltage issues and check, if it is working then.
    The sensor requires a preheat. Have you used my sketch from above?
    korttomaK
    korttomaK
    korttoma
    @FotoFieber I swapped out the 5V Pro Mini with a 3.3V Pro Mini yesterday and I'm afraid it did not help at all. If the Sensor would have had a problem with the 5V on the serial pins I bet it would no longer communicate.
    I used some parts of your sketch but since I use an Si7021 and a different radio I had to do some modifications:
     *  MH-Z14 CO2 sensor
     *  Wiring:
     *   Pad 1, Pad 5: Vin (Voltage input 4.5V-6V)
     *   Pad 2, Pad 3, Pad 12: GND
     *   Pad 6: PWM output ==> pin 6
     *  From: http://davidegironi.blogspot.fr/2014/01/co2-meter-using-ndir-infrared-mh-z14.html
     *    MH-Z14 has a PWM output, with a sensitivity range of 0ppm to 2000ppm CO2, an accurancy of ±200ppm.
     *    The cycle is 1004ms±5%, given the duty cicle Th (pulse high), Tl is 1004-Th, we can convert it to CO2 value using the formula:
     *    CO2ppm = 2000 * (Th - 2ms) /(Th + Tl - 4ms)
     *  From: http://airqualityegg.wikispaces.com/Sensor+Tests
     *    - response time is less than 30 s
     *   - 3 minute warm up time
     *  datasheet:
    * Contributor: epierre
    #define MY_NODE_ID  6
    #define SN "AIQ CO2 MH-Z14 TxRx"
    #define SV "2.1"
    #define MY_BAUD_RATE  9600
    #include <MyConfig.h>
    #include <SI7021.h>
    #include <RunningAverage.h>
    #include <SoftwareSerial.h>
    // Define a static node address, remove if you want auto address assignment
    SoftwareSerial mySerial(6, 7); // RX, TX
    byte cmd[9] = {0xFF, 0x01, 0x86, 0x00, 0x00, 0x00, 0x00, 0x00, 0x79};
    char response[9];
    // Child sensor ID's
    #define CHILD_ID_AIQ 1
    #define CHILD_ID_HUM   2
    #define CHILD_ID_TEMP  3
    //#define AIQ_SENSOR_ANALOG_PIN 5
    #define AVERAGES 2
    float valAIQ =0.0;
    float lastAIQ =0.0;
    unsigned int loop_round = 0;
    int lastppm = 0;
    boolean preheat = true;  // wait TEMP_HUM_ROUNDS for preheat
    SI7021 humiditySensor;
    MyMessage msg(CHILD_ID_AIQ, V_LEVEL);
    MyMessage msg2(CHILD_ID_AIQ, V_UNIT_PREFIX);
    // Global settings
    boolean isMetric = true;
    float lastTemperature = -100;
    int lastHumidity = -100;
      mySerial.begin(9600);
      humiditySensor.begin();
      sleep(SLEEP_TIME);
      //pinMode(AIQ_SENSOR_ANALOG_PIN, INPUT);
      isMetric = getConfig().isMetric;
      Serial.print(F("isMetric: ")); Serial.println(isMetric);
      raHum.clear();
         wait(200);
      send(msg2.set("ppm"));
      sendSketchInfo(SN, SV);
      present(CHILD_ID_AIQ, S_AIR_QUALITY);
      present(CHILD_ID_TEMP,S_TEMP);
      present(CHILD_ID_HUM,S_HUM);
      wait(200);
        mySerial.write(cmd, 9);
      mySerial.readBytes(response, 9);
      int responseHigh = (int) response[2];
      int responseLow = (int) response[3];
      int co2ppm = (256 * responseHigh) + responseLow;
      Serial.print(F("c02ppm :"));Serial.println(co2ppm);
      if ( (abs(co2ppm - lastppm) >= 10)) {
          send(msg.set(co2ppm));
          lastppm = co2ppm;
      raHum.addValue(data.humidityPercent);
      float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths)/100.0);
      Serial.print(F("TempDiff :"));Serial.println(diffTemp);
      Serial.print(F("HumDiff  :"));Serial.println(diffHum);
      if (diffTemp > TEMP_TRANSMIT_THRESHOLD) {
        float temperature = (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0;
        Serial.print("T: ");Serial.println(temperature);
        send(msgTemp.set(temperature,1));
      if (diffHum > HUMI_TRANSMIT_THRESHOLD) {
        Serial.print("H: ");Serial.println(humidity);
        send(msgHum.set(humidity));
        lastHumidity = humidity;
      //Serial.println();
      // Power down the radio.  Note that the radio will get powered back up
      // on the next write() call.
      sleep(SLEEP_TIME); //sleep for: sleepTime
    I hope I made a mistake in the sketch since I'm running out of ideas and I don't want the sensors to be broken.
    From where did you buy your sensor? I got them from aliexpress...
    • Tomas
    • FotoFieberF
      FotoFieberF
      FotoFieber
      @korttoma
      Where is the preheat logic in your sketch?
      Values in the preheat time could be wrong....
      korttomaK 1 Reply Last reply
        @korttoma
        korttomaK
        korttomaK
        korttoma
        @FotoFieber Yeah, I don't have preheat logic but that would only account for values when I first plug it in. I get the strange values even if it has been running for weeks. I will try to get a graph of what I see this evening so you can see what I mean. I'm seriously considering to just exclude the value 562 from being sent to the controller.
        • Tomas
        alexsh1A 1 Reply Last reply
        • korttomaK korttoma
          alexsh1A
          alexsh1A
          alexsh1
          @korttoma Sounds like you have a faulty sensor. Did you try analogue output? This is just to make sure the sensor is working.
          There are PWM or UART.
          Did you try both of them? I am using 5V Arduino Nano with no problem.
          The digital pins communicate via PWM or UART. Output (and input for UART) of these ports work on 3.3 Volts - this means you should change the ARef of your Arduino - or rescale your values
          • korttomaK
            korttomaK
            korttoma
            • Tomas
            • alexsh1A
              alexsh1A
              alexsh1
              @korttoma try to put it outside for some time to recalibrate. If it does not help, you may need to calibrate it.
              Or you just got a bad one.
              • alexsh1A alexsh1
                korttomaK
                korttomaK
                korttoma
                @alexsh1 Will the sensor really recalibrate by itself if I put it outside?
                I could send a "zero calibration" command via serial but then I would need to "input Nitrogen gas for 5 minutes when make zero calibration. "
                Instead of exposing it to nitrogen gas could I just like you said put it outside and then send the "zero calibration" command?
                To do the " span calibration" I would need to know what kind of values to send to it and I have no idea.
                btw, here are some values I read now via serial at the office (I do not get the 562 value so far) but does these values seem reasonable for a well ventilated office?
                HiResp :3
                LoResp :-21
                Tem.channel :63
                c02ppm :747
                HiResp :3
                LoResp :124
                Tem.channel :63
                c02ppm :892
                HiResp :3
                LoResp :21
                Tem.channel :63
                c02ppm :789
                HiResp :2
                LoResp :-57
                Tem.channel :63
                c02ppm :455
                HiResp :2
                LoResp :-110
                Tem.channel :63
                c02ppm :402
                HiResp :2
                LoResp :99
                Tem.channel :63
                c02ppm :611
                HiResp :2
                LoResp :51
                Tem.channel :63
                c02ppm :563
                HiResp :2
                LoResp :20
                Tem.channel :63
                c02ppm :532
                HiResp :1
                LoResp :-2
                Tem.channel :63
                c02ppm :254
                HiResp :1
                LoResp :-32
                Tem.channel :63
                c02ppm :224
                HiResp :1
                LoResp :-55
                Tem.channel :63
                c02ppm :201
                HiResp :1
                LoResp :-68
                Tem.channel :63
                c02ppm :188
                HiResp :1
                LoResp :-75
                Tem.channel :63
                c02ppm :181
                HiResp :1
                LoResp :-79
                Tem.channel :63
                c02ppm :177
                HiResp :1
                LoResp :-98
                Tem.channel :63
                c02ppm :158
                HiResp :1
                LoResp :-102
                Tem.channel :63
                c02ppm :154
                HiResp :1
                LoResp :-109
                Tem.channel :63
                c02ppm :147
                HiResp :1
                LoResp :-116
                Tem.channel :63
                c02ppm :140
                HiResp :1
                LoResp :-125
                Tem.channel :63
                c02ppm :131
                HiResp :1
                LoResp :-124
                Tem.channel :63
                c02ppm :132
                HiResp :1
                LoResp :111
                Tem.channel :63
                c02ppm :367
                HiResp :1
                LoResp :115
                Tem.channel :63
                c02ppm :371
                HiResp :1
                LoResp :121
                Tem.channel :63
                c02ppm :377
                HiResp :1
                LoResp :114
                Tem.channel :63
                c02ppm :370
                HiResp :1
                LoResp :-62
                Tem.channel :63
                c02ppm :194
                HiResp :1
                LoResp :-7
                Tem.channel :63
                c02ppm :249
                HiResp :1
                LoResp :-53
                Tem.channel :63
                c02ppm :203
                HiResp :1
                LoResp :-68
                Tem.channel :63
                c02ppm :188
                HiResp :1
                LoResp :-96
                Tem.channel :63
                c02ppm :160
                HiResp :1
                LoResp :-111
                Tem.channel :63
                c02ppm :145
                HiResp :1
                LoResp :-121
                Tem.channel :63
                c02ppm :135
                HiResp :1
                LoResp :-127
                Tem.channel :63
                c02ppm :129
                HiResp :1
                LoResp :-124
                Tem.channel :63
                c02ppm :132
                HiResp :1
                LoResp :-126
                Tem.channel :63
                c02ppm :130
                HiResp :1
                LoResp :-126
                Tem.channel :63
                c02ppm :130
                HiResp :1
                LoResp :-110
                Tem.channel :63
                c02ppm :146
                HiResp :1
                LoResp :-110
                Tem.channel :63
                c02ppm :146
                HiResp :1
                LoResp :-60
                Tem.channel :63
                c02ppm :196
                HiResp :1
                LoResp :-69
                Tem.channel :63
                c02ppm :187
                HiResp :1
                LoResp :-101
                Tem.channel :63
                c02ppm :155
                HiResp :1
                LoResp :-104
                Tem.channel :63
                c02ppm :152
                HiResp :1
                LoResp :-114
                Tem.channel :63
                c02ppm :142
                HiResp :1
                LoResp :-128
                Tem.channel :63
                c02ppm :128
                HiResp :1
                LoResp :-122
                Tem.channel :63
                c02ppm :134
                HiResp :1
                LoResp :122
                Tem.channel :63
                c02ppm :378
                HiResp :1
                LoResp :119
                Tem.channel :63
                c02ppm :375
                HiResp :1
                LoResp :-128
                Tem.channel :63
                c02ppm :128
                HiResp :1
                LoResp :-86
                Tem.channel :63
                c02ppm :170
                HiResp :1
                LoResp :-110
                Tem.channel :63
                c02ppm :146
                HiResp :1
                LoResp :-123
                Tem.channel :63
                c02ppm :133
                HiResp :1
                LoResp :-101
                Tem.channel :63
                c02ppm :155
                HiResp :1
                LoResp :-75
                Tem.channel :63
                c02ppm :181
                HiResp :1
                LoResp :-92
                Tem.channel :63
                c02ppm :164
                HiResp :1
                LoResp :-101
                Tem.channel :63
                c02ppm :155
                HiResp :1
                LoResp :-123
                Tem.channel :63
                c02ppm :133
                HiResp :1
                LoResp :-114
                Tem.channel :63
                c02ppm :142
                HiResp :1
                LoResp :-127
                Tem.channel :63
                c02ppm :129
                HiResp :1
                LoResp :-120
                Tem.channel :63
                c02ppm :136
                HiResp :1
                LoResp :126
                Tem.channel :63
                c02ppm :382
                HiResp :1
                LoResp :118
                Tem.channel :63
                c02ppm :374
                HiResp :1
                LoResp :-127
                Tem.channel :63
                c02ppm :129
                HiResp :1
                LoResp :118
                Tem.channel :63
                c02ppm :374
                HiResp :1
                LoResp :120
                Tem.channel :63
                c02ppm :376
                HiResp :1
                LoResp :118
                Tem.channel :63
                c02ppm :374
                HiResp :1
                LoResp :115
                Tem.channel :63
                c02ppm :371
                HiResp :1
                LoResp :124
                Tem.channel :63
                c02ppm :380
                HiResp :1
                LoResp :120
                Tem.channel :63
                c02ppm :376
                HiResp :1
                LoResp :-119
                Tem.channel :63
                c02ppm :137
                HiResp :1
                LoResp :-126
                Tem.channel :63
                c02ppm :130
                HiResp :1
                LoResp :-127
                Tem.channel :63
                c02ppm :129
                HiResp :1
                LoResp :-124
                Tem.channel :63
                c02ppm :132
                HiResp :1
                LoResp :121
                Tem.channel :63
                c02ppm :377
                HiResp :1
                LoResp :114
                Tem.channel :63
                c02ppm :370
                HiResp :1
                LoResp :108
                Tem.channel :63
                c02ppm :364
                HiResp :1
                LoResp :108
                Tem.channel :63
                c02ppm :364
                HiResp :1
                LoResp :119
                Tem.channel :63
                c02ppm :375
                HiResp :1
                LoResp :-110
                Tem.channel :63
                c02ppm :146
                HiResp :1
                LoResp :124
                Tem.channel :63
                c02ppm :380
                HiResp :1
                LoResp :127
                Tem.channel :63
                c02ppm :383
                HiResp :1
                LoResp :-43
                Tem.channel :63
                c02ppm :213
                HiResp :1
                LoResp :-72
                Tem.channel :63
                c02ppm :184
                HiResp :1
                LoResp :-77
                Tem.channel :63
                c02ppm :179
                HiResp :1
                LoResp :-63
                Tem.channel :63
                c02ppm :193
                HiResp :1
                LoResp :-92
                Tem.channel :63
                c02ppm :164
                HiResp :1
                LoResp :-105
                Tem.channel :63
                c02ppm :151
                HiResp :1
                LoResp :-116
                Tem.channel :63
                c02ppm :140
                HiResp :2
                LoResp :41
                Tem.channel :63
                c02ppm :553
                HiResp :2
                LoResp :47
                Tem.channel :63
                c02ppm :559
                HiResp :2
                LoResp :26
                Tem.channel :63
                c02ppm :538
                HiResp :2
                LoResp :-107
                Tem.channel :63
                c02ppm :405
                HiResp :2
                LoResp :-76
                Tem.channel :63
                c02ppm :436
                HiResp :2
                LoResp :-97
                Tem.channel :63
                c02ppm :415
                HiResp :2
                LoResp :-109
                Tem.channel :63
                c02ppm :403
                HiResp :2
                LoResp :106
                Tem.channel :63
                c02ppm :618
                HiResp :2
                LoResp :-96
                Tem.channel :63
                c02ppm :416
                HiResp :2
                LoResp :80
                Tem.channel :63
                c02ppm :592
                HiResp :2
                LoResp :69
                Tem.channel :63
                c02ppm :581
                HiResp :2
                LoResp :40
                Tem.channel :63
                c02ppm :552
                HiResp :2
                LoResp :84
                Tem.channel :63
                c02ppm :596
                HiResp :2
                LoResp :45
                Tem.channel :63
                c02ppm :557
                HiResp :2
                LoResp :3
                Tem.channel :63
                c02ppm :515
                HiResp :1
                LoResp :-30
                Tem.channel :63
                c02ppm :226
                HiResp :1
                LoResp :-62
                Tem.channel :63
                c02ppm :194
                HiResp :1
                LoResp :-73
                Tem.channel :63
                c02ppm :183
                HiResp :1
                LoResp :-75
                Tem.channel :63
                c02ppm :181
                HiResp :1
                LoResp :-96
                Tem.channel :63
                c02ppm :160
                HiResp :1
                LoResp :-89
                Tem.channel :63
                c02ppm :167
                HiResp :1
                LoResp :-101
                Tem.channel :63
                c02ppm :155
                HiResp :1
                LoResp :-112
                Tem.channel :63
                c02ppm :144
                HiResp :1
                LoResp :-107
                Tem.channel :63
                c02ppm :149
                HiResp :1
                LoResp :-112
                Tem.channel :63
                c02ppm :144
                HiResp :1
                LoResp :-110
                Tem.channel :63
                c02ppm :146
                HiResp :1
                LoResp :-124
                Tem.channel :63
                c02ppm :132
                HiResp :1
                LoResp :-120
                Tem.channel :63
                c02ppm :136
                HiResp :1
                LoResp :-75
                Tem.channel :63
                c02ppm :181
                Some of the values seem a bit low to me. Especially while the HiResp is 1 or the LoResp is negative.
                I will do this test again at home when I get the chance.
                • Tomas
                • FotoFieberF
                  FotoFieberF
                  FotoFieber
                  @korttoma
                  In the technical specification I only find the calibration with nitrogen. I don't think, that putting it outside, will help, as it is usually at around 400 ppm at the moment. (AFAIK netatmo sets the lowest measured value in the last one or two weeks to 400 for calibration).
                  • alexsh1A
                    alexsh1A
                    alexsh1
                    #21
                    @korttoma values are completely off. Co2 cannot go down below 300 level. This is a value of co2 outside (300-400).
                    You have to calibrate it regularly. Zero calibration (this is what you are talking about) is different.
                    8.1 The sensor should be calibrated regularly. The cycle time is better to be no more than 6 months. 8.2 Do not use the sensor in the high dusty environment for long time.
                    8.3 Please use the sensor with correct power supply.
                    8.4 Forbidden to cut the sensor pin.
                    Try to put it outside for 10mins and then short pins 8 and 12 (see the photo below). This worked for me when I had some weird readings
                      @korttoma
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @FotoFieber Netatmo is using index also cannot be compared with mh-z14a.
                      I think the idea putting the sensor outside is to stabilise it - the reading is in the range of 300-400
                      • alexsh1A alexsh1
                        korttomaK
                        korttomaK
                        korttoma
                        Where did you get this kind of information from? The MH-Z14.pdg I found online does not mention anything about this.
                        • Tomas
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @korttoma It was recommended by an Aliexpress seller who sold me the sensor.
                          Let's agree that Chinese documentation is not always comprehensive :)
                          • korttomaK
                            korttomaK
                            korttoma
                            I finally found some time to really look in to this 562 issue. I looked at the raw data in DataMine2 and I noticed that the 562 value appeared every 10 minutes on the minute.
                            Then I knew that this value cannot possibly come from the sensor. I search around in my Vera device for a bit and I found some lua code that copied the "Variable1" value from the sensor to the "CurrentLevel" every 10 minutes. Then I remembered that in the previous version of this sensor the value was reported via V_VAR1 and I had to copy it to another variable in Vera to be able to draw any graph. The current version of the sensor reports the value directly to the "CurrentLevel" variable and the value 562 that was still in the old variable was copied over the "real" value every 10 minutes.
                            I also previously had some really low values from time to time from the sensor mostly when responseHigh = 1 and responseLow = negative value
                            so I forced the responseLow to always be a positive value like this:
                            int responseLow = abs((int) response[3]);
                            I will keep an eye on the behavior of the sensor now that I have finally removed the confusing 562 value.
                            • Tomas
