  3. MH-Z14A CO2 sensor
MH-Z14A CO2 sensor
25 Posts 5 Posters 20.3k Views 6 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    I am glad you work it out yourself
    I think when it comes to this sensor everything is well documented or available in the Internet
    • FotoFieberF
      FotoFieberF
      FotoFieber
      wrote on last edited by FotoFieber
      The sensor is really simple to use, when attached via serial-ttl (3.3V) and powered with 5 volt.
      https://www.youtube.com/watch?v=Vk4oQpy98sc
      You get the values directly from the sensor and don't need to make calculations. Here is what I use:
         DESCRIPTION
          MH-Z14 CO2 sensor via rx/tx serial
      //#define MY_RADIO_NRF24
      #define MY_RADIO_RFM69
      #define MY_RFM69_FREQUENCY RF69_868MHZ
      #define MY_RFM69_NETWORKID 13
      #define MY_RFM69_ENABLE_ENCRYPTION
      #define MY_IS_RFM69HW
      #include <SoftwareSerial.h>
      #include "Adafruit_HTU21DF.h"
      SoftwareSerial mySerial(A0, A1); // RX, TX соответственно
      Adafruit_HTU21DF htu = Adafruit_HTU21DF();
      byte cmd[9] = {0xFF, 0x01, 0x86, 0x00, 0x00, 0x00, 0x00, 0x00, 0x79};
      char response[9];
      #define CHILD_ID_AIQ 0
      #define CHILD_ID_TEMP  1
      #define CHILD_ID_HUM   2
      unsigned long SLEEP_TIME = 30 * 1000; // Sleep time between reads (in milliseconds)
      unsigned int TEMP_HUM_ROUNDS = 5; // wait 5 rounds for sending TEMP_HUM
      unsigned int loop_round = 0;
      boolean preheat = true;  // wait TEMP_HUM_ROUNDS for preheat
      int lastppm = 0;
      MyMessage msg(CHILD_ID_AIQ, V_LEVEL);
      MyMessage msg2(CHILD_ID_AIQ, V_UNIT_PREFIX);
      boolean isMetric = true;
        mySerial.begin(9600);
        isMetric = getConfig().isMetric;
        if (!htu.begin()) {
          Serial.println("Couldn't find sensor htu21!");
        sendSketchInfo("AIQ Sensor CO2 MH-Z14 Serial, HTU21 Temp Hum", "1.0");
        present(CHILD_ID_AIQ, S_AIR_QUALITY);
        send(msg2.set("ppm"));
        present(CHILD_ID_HUM, S_HUM);
        mySerial.write(cmd, 9);
        mySerial.readBytes(response, 9);
        int responseHigh = (int) response[2];
        int responseLow = (int) response[3];
        int ppm = (256 * responseHigh) + responseLow;
        if ((loop_round == 0) || (abs(ppm - lastppm) >= 10)) {
          if (!preheat) {
            send(msg.set(ppm));
            lastppm = ppm;
        if (loop_round == 0) {
          float temp = htu.readTemperature();
          if (!isMetric) {
            temp = temp * 9 / 5 + 32; // convert to farenheit
          send(msgTemp.set(temp, 1));
          float hum = htu.readHumidity();
          send(msgHum.set(hum, 1));
        loop_round++;
        if (loop_round >= TEMP_HUM_ROUNDS) {
          loop_round = 0;
          preheat = false;
        // Power down the radio.  Note that the radio will get powered back up
        // on the next write() call.
        sleep(SLEEP_TIME); //sleep for: sleepTime
      • korttomaK
        korttomaK
        korttoma
        Thanks @FotoFieber for providing the information how to read the MH-Z14 via serial communication.
        Works like a charm.
        • Tomas
        • korttomaK
          korttomaK
          korttoma
          Seems like my MH-Z14 sensor is faulty after all. My problem was that the sensor reported the value 562 like 80% of the time. I was hoping I could solve this by using the serial method to read the value from the sensor but I stil had the same problem. Luckily I just received another MH-Z14 so I could replace it. Now it seems to work better.
          • Tomas
          • korttomaK korttoma
            FotoFieberF
            FotoFieberF
            FotoFieber
            @korttoma
            It is working like a charme for me. Important is, to have 5V for voltage and 3.3 V on the logical level. Here is a graf, the green "Badezimmer" line is the mysensors sensor with MH-Z14A, the others are from netatmo. The mysensors sensor is in the bathroom and therefore it will have usually less CO2.
            korttomaK 1 Reply Last reply
            • FotoFieberF FotoFieber
              @korttoma
              korttomaK
              korttomaK
              korttoma
              @FotoFieber My new sensor is giving me the exact same behaivour. Could it be that the problem is that I'm using a 5V Pro Mini?
              • Tomas
              • FotoFieberF
                FotoFieberF
                FotoFieber
                Yes. You have to use a 3.3V arduino and power the sensor with 5V (seperate voltage). The sensor may break with a 5V arduino. I use a 3.3V 8 MHz pro mini.
                  korttomaK
                  korttomaK
                  korttoma
                  @FotoFieber
                  So the symptom I see as the sensor constantly reporting the value 562 could be because it is already broken?
                  Or would a broken sensor just stop communicating via serial?
                  • Tomas
                    @FotoFieber
                    FotoFieberF
                    FotoFieberF
                    FotoFieber
                    @korttoma
                    As I do not have a broken sensor, I can not tell you.
                    If I were you, I would try to fix the voltage issues and check, if it is working then.
                    The sensor requires a preheat. Have you used my sketch from above?
                      @korttoma
                      korttomaK
                      korttomaK
                      korttoma
                      @FotoFieber I swapped out the 5V Pro Mini with a 3.3V Pro Mini yesterday and I'm afraid it did not help at all. If the Sensor would have had a problem with the 5V on the serial pins I bet it would no longer communicate.
                      I used some parts of your sketch but since I use an Si7021 and a different radio I had to do some modifications:
                       *  MH-Z14 CO2 sensor
                       *  Wiring:
                       *   Pad 1, Pad 5: Vin (Voltage input 4.5V-6V)
                       *   Pad 2, Pad 3, Pad 12: GND
                       *   Pad 6: PWM output ==> pin 6
                       *  From: http://davidegironi.blogspot.fr/2014/01/co2-meter-using-ndir-infrared-mh-z14.html
                       *    MH-Z14 has a PWM output, with a sensitivity range of 0ppm to 2000ppm CO2, an accurancy of ±200ppm.
                       *    The cycle is 1004ms±5%, given the duty cicle Th (pulse high), Tl is 1004-Th, we can convert it to CO2 value using the formula:
                       *    CO2ppm = 2000 * (Th - 2ms) /(Th + Tl - 4ms)
                       *  From: http://airqualityegg.wikispaces.com/Sensor+Tests
                       *    - response time is less than 30 s
                       *   - 3 minute warm up time
                       *  datasheet:
                      * Contributor: epierre
                      #define MY_NODE_ID  6
                      #define SN "AIQ CO2 MH-Z14 TxRx"
                      #define SV "2.1"
                      #define MY_BAUD_RATE  9600
                      #include <MyConfig.h>
                      #include <SI7021.h>
                      #include <RunningAverage.h>
                      // Define a static node address, remove if you want auto address assignment
                      SoftwareSerial mySerial(6, 7); // RX, TX
                      char response[9];
                      // Child sensor ID's
                      #define CHILD_ID_AIQ 1
                      #define CHILD_ID_TEMP  3
                      //#define AIQ_SENSOR_ANALOG_PIN 5
                      #define AVERAGES 2
                      float valAIQ =0.0;
                      float lastAIQ =0.0;
                      int lastppm = 0;
                      SI7021 humiditySensor;
                      // Global settings
                      float lastTemperature = -100;
                      int lastHumidity = -100;
                        humiditySensor.begin();
                        sleep(SLEEP_TIME);
                        //pinMode(AIQ_SENSOR_ANALOG_PIN, INPUT);
                        Serial.print(F("isMetric: ")); Serial.println(isMetric);
                        raHum.clear();
                           wait(200);
                        sendSketchInfo(SN, SV);
                        present(CHILD_ID_TEMP,S_TEMP);
                        present(CHILD_ID_HUM,S_HUM);
                        wait(200);
                        int co2ppm = (256 * responseHigh) + responseLow;
                        Serial.print(F("c02ppm :"));Serial.println(co2ppm);
                        if ( (abs(co2ppm - lastppm) >= 10)) {
                            send(msg.set(co2ppm));
                            lastppm = co2ppm;
                        raHum.addValue(data.humidityPercent);
                        float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths)/100.0);
                        Serial.print(F("TempDiff :"));Serial.println(diffTemp);
                        Serial.print(F("HumDiff  :"));Serial.println(diffHum);
                        if (diffTemp > TEMP_TRANSMIT_THRESHOLD) {
                          float temperature = (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0;
                          Serial.print("T: ");Serial.println(temperature);
                          send(msgTemp.set(temperature,1));
                        if (diffHum > HUMI_TRANSMIT_THRESHOLD) {
                          Serial.print("H: ");Serial.println(humidity);
                          send(msgHum.set(humidity));
                          lastHumidity = humidity;
                        //Serial.println();
                      I hope I made a mistake in the sketch since I'm running out of ideas and I don't want the sensors to be broken.
                      From where did you buy your sensor? I got them from aliexpress...
                      • Tomas
                      • FotoFieberF
                        FotoFieberF
                        FotoFieber
                        @korttoma
                        Where is the preheat logic in your sketch?
                        Values in the preheat time could be wrong....
                          @korttoma
                          korttomaK
                          korttomaK
                          korttoma
                          @FotoFieber Yeah, I don't have preheat logic but that would only account for values when I first plug it in. I get the strange values even if it has been running for weeks. I will try to get a graph of what I see this evening so you can see what I mean. I'm seriously considering to just exclude the value 562 from being sent to the controller.
                          • Tomas
                          alexsh1A 1 Reply Last reply
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @korttoma Sounds like you have a faulty sensor. Did you try analogue output? This is just to make sure the sensor is working.
                            There are PWM or UART.
                            Did you try both of them? I am using 5V Arduino Nano with no problem.
                            The digital pins communicate via PWM or UART. Output (and input for UART) of these ports work on 3.3 Volts - this means you should change the ARef of your Arduino - or rescale your values
                            • korttomaK
                              korttomaK
                              korttoma
                              • Tomas
                              • alexsh1A
                                alexsh1A
                                alexsh1
                                @korttoma try to put it outside for some time to recalibrate. If it does not help, you may need to calibrate it.
                                Or you just got a bad one.
                                • alexsh1A alexsh1
                                  korttomaK
                                  korttomaK
                                  korttoma
                                  @alexsh1 Will the sensor really recalibrate by itself if I put it outside?
                                  I could send a "zero calibration" command via serial but then I would need to "input Nitrogen gas for 5 minutes when make zero calibration. "
                                  Instead of exposing it to nitrogen gas could I just like you said put it outside and then send the "zero calibration" command?
                                  To do the " span calibration" I would need to know what kind of values to send to it and I have no idea.
                                  btw, here are some values I read now via serial at the office (I do not get the 562 value so far) but does these values seem reasonable for a well ventilated office?
                                  HiResp :3
                                  LoResp :-21
                                  Tem.channel :63
                                  c02ppm :747
                                  HiResp :3
                                  LoResp :124
                                  Tem.channel :63
                                  c02ppm :892
                                  HiResp :3
                                  LoResp :21
                                  Tem.channel :63
                                  c02ppm :789
                                  HiResp :2
                                  LoResp :-57
                                  Tem.channel :63
                                  c02ppm :455
                                  HiResp :2
                                  LoResp :-110
                                  Tem.channel :63
                                  c02ppm :402
                                  HiResp :2
                                  LoResp :99
                                  Tem.channel :63
                                  c02ppm :611
                                  HiResp :2
                                  LoResp :51
                                  Tem.channel :63
                                  c02ppm :563
                                  HiResp :2
                                  LoResp :20
                                  Tem.channel :63
                                  c02ppm :532
                                  HiResp :1
                                  LoResp :-2
                                  Tem.channel :63
                                  c02ppm :254
                                  HiResp :1
                                  LoResp :-32
                                  Tem.channel :63
                                  c02ppm :224
                                  HiResp :1
                                  LoResp :-55
                                  Tem.channel :63
                                  c02ppm :201
                                  HiResp :1
                                  LoResp :-68
                                  Tem.channel :63
                                  c02ppm :188
                                  HiResp :1
                                  LoResp :-75
                                  Tem.channel :63
                                  c02ppm :181
                                  HiResp :1
                                  LoResp :-79
                                  Tem.channel :63
                                  c02ppm :177
                                  HiResp :1
                                  LoResp :-98
                                  Tem.channel :63
                                  c02ppm :158
                                  HiResp :1
                                  LoResp :-102
                                  Tem.channel :63
                                  c02ppm :154
                                  HiResp :1
                                  LoResp :-109
                                  Tem.channel :63
                                  c02ppm :147
                                  HiResp :1
                                  LoResp :-116
                                  Tem.channel :63
                                  c02ppm :140
                                  HiResp :1
                                  LoResp :-125
                                  Tem.channel :63
                                  c02ppm :131
                                  HiResp :1
                                  LoResp :-124
                                  Tem.channel :63
                                  c02ppm :132
                                  HiResp :1
                                  LoResp :111
                                  Tem.channel :63
                                  c02ppm :367
                                  HiResp :1
                                  LoResp :115
                                  Tem.channel :63
                                  c02ppm :371
                                  HiResp :1
                                  LoResp :121
                                  Tem.channel :63
                                  c02ppm :377
                                  HiResp :1
                                  LoResp :114
                                  Tem.channel :63
                                  c02ppm :370
                                  HiResp :1
                                  LoResp :-62
                                  Tem.channel :63
                                  c02ppm :194
                                  HiResp :1
                                  LoResp :-7
                                  Tem.channel :63
                                  c02ppm :249
                                  HiResp :1
                                  LoResp :-53
                                  Tem.channel :63
                                  c02ppm :203
                                  HiResp :1
                                  LoResp :-68
                                  Tem.channel :63
                                  c02ppm :188
                                  HiResp :1
                                  LoResp :-96
                                  Tem.channel :63
                                  c02ppm :160
                                  HiResp :1
                                  LoResp :-111
                                  Tem.channel :63
                                  c02ppm :145
                                  HiResp :1
                                  LoResp :-121
                                  Tem.channel :63
                                  c02ppm :135
                                  HiResp :1
                                  LoResp :-127
                                  Tem.channel :63
                                  c02ppm :129
                                  HiResp :1
                                  LoResp :-124
                                  Tem.channel :63
                                  c02ppm :132
                                  HiResp :1
                                  LoResp :-126
                                  Tem.channel :63
                                  c02ppm :130
                                  HiResp :1
                                  LoResp :-126
                                  Tem.channel :63
                                  c02ppm :130
                                  HiResp :1
                                  LoResp :-110
                                  Tem.channel :63
                                  c02ppm :146
                                  HiResp :1
                                  LoResp :-110
                                  Tem.channel :63
                                  c02ppm :146
                                  HiResp :1
                                  LoResp :-60
                                  Tem.channel :63
                                  c02ppm :196
                                  HiResp :1
                                  LoResp :-69
                                  Tem.channel :63
                                  c02ppm :187
                                  HiResp :1
                                  LoResp :-101
                                  Tem.channel :63
                                  c02ppm :155
                                  HiResp :1
                                  LoResp :-104
                                  Tem.channel :63
                                  c02ppm :152
                                  HiResp :1
                                  LoResp :-114
                                  Tem.channel :63
                                  c02ppm :142
                                  HiResp :1
                                  LoResp :-128
                                  Tem.channel :63
                                  c02ppm :128
                                  HiResp :1
                                  LoResp :-122
                                  Tem.channel :63
                                  c02ppm :134
                                  HiResp :1
                                  LoResp :122
                                  Tem.channel :63
                                  c02ppm :378
                                  HiResp :1
                                  LoResp :119
                                  Tem.channel :63
                                  c02ppm :375
                                  HiResp :1
                                  LoResp :-128
                                  Tem.channel :63
                                  c02ppm :128
                                  HiResp :1
                                  LoResp :-86
                                  Tem.channel :63
                                  c02ppm :170
                                  HiResp :1
                                  LoResp :-110
                                  Tem.channel :63
                                  c02ppm :146
                                  HiResp :1
                                  LoResp :-123
                                  Tem.channel :63
                                  c02ppm :133
                                  HiResp :1
                                  LoResp :-101
                                  Tem.channel :63
                                  c02ppm :155
                                  HiResp :1
                                  LoResp :-75
                                  Tem.channel :63
                                  c02ppm :181
                                  HiResp :1
                                  LoResp :-92
                                  Tem.channel :63
                                  c02ppm :164
                                  HiResp :1
                                  LoResp :-101
                                  Tem.channel :63
                                  c02ppm :155
                                  HiResp :1
                                  LoResp :-123
                                  Tem.channel :63
                                  c02ppm :133
                                  HiResp :1
                                  LoResp :-114
                                  Tem.channel :63
                                  c02ppm :142
                                  HiResp :1
                                  LoResp :-127
                                  Tem.channel :63
                                  c02ppm :129
                                  HiResp :1
                                  LoResp :-120
                                  Tem.channel :63
                                  c02ppm :136
                                  HiResp :1
                                  LoResp :126
                                  Tem.channel :63
                                  c02ppm :382
                                  HiResp :1
                                  LoResp :118
                                  Tem.channel :63
                                  c02ppm :374
                                  HiResp :1
                                  LoResp :-127
                                  Tem.channel :63
                                  c02ppm :129
                                  HiResp :1
                                  LoResp :118
                                  Tem.channel :63
                                  c02ppm :374
                                  HiResp :1
                                  LoResp :120
                                  Tem.channel :63
                                  c02ppm :376
                                  HiResp :1
                                  LoResp :118
                                  Tem.channel :63
                                  c02ppm :374
                                  HiResp :1
                                  LoResp :115
                                  Tem.channel :63
                                  c02ppm :371
                                  HiResp :1
                                  LoResp :124
                                  Tem.channel :63
                                  c02ppm :380
                                  HiResp :1
                                  LoResp :120
                                  Tem.channel :63
                                  c02ppm :376
                                  HiResp :1
                                  LoResp :-119
                                  Tem.channel :63
                                  c02ppm :137
                                  HiResp :1
                                  LoResp :-126
                                  Tem.channel :63
                                  c02ppm :130
                                  HiResp :1
                                  LoResp :-127
                                  Tem.channel :63
                                  c02ppm :129
                                  HiResp :1
                                  LoResp :-124
                                  Tem.channel :63
                                  c02ppm :132
                                  HiResp :1
                                  LoResp :121
                                  Tem.channel :63
                                  c02ppm :377
                                  HiResp :1
                                  LoResp :114
                                  Tem.channel :63
                                  c02ppm :370
                                  HiResp :1
                                  LoResp :108
                                  Tem.channel :63
                                  c02ppm :364
                                  HiResp :1
                                  LoResp :108
                                  Tem.channel :63
                                  c02ppm :364
                                  HiResp :1
                                  LoResp :119
                                  Tem.channel :63
                                  c02ppm :375
                                  HiResp :1
                                  LoResp :-110
                                  Tem.channel :63
                                  c02ppm :146
                                  HiResp :1
                                  LoResp :124
                                  Tem.channel :63
                                  c02ppm :380
                                  HiResp :1
                                  LoResp :127
                                  Tem.channel :63
                                  c02ppm :383
                                  HiResp :1
                                  LoResp :-43
                                  Tem.channel :63
                                  c02ppm :213
                                  HiResp :1
                                  LoResp :-72
                                  Tem.channel :63
                                  c02ppm :184
                                  HiResp :1
                                  LoResp :-77
                                  Tem.channel :63
                                  c02ppm :179
                                  HiResp :1
                                  LoResp :-63
                                  Tem.channel :63
                                  c02ppm :193
                                  HiResp :1
                                  LoResp :-92
                                  Tem.channel :63
                                  c02ppm :164
                                  HiResp :1
                                  LoResp :-105
                                  Tem.channel :63
                                  c02ppm :151
                                  HiResp :1
                                  LoResp :-116
                                  Tem.channel :63
                                  c02ppm :140
                                  HiResp :2
                                  LoResp :41
                                  Tem.channel :63
                                  c02ppm :553
                                  HiResp :2
                                  LoResp :47
                                  Tem.channel :63
                                  c02ppm :559
                                  HiResp :2
                                  LoResp :26
                                  Tem.channel :63
                                  c02ppm :538
                                  HiResp :2
                                  LoResp :-107
                                  Tem.channel :63
                                  c02ppm :405
                                  HiResp :2
                                  LoResp :-76
                                  Tem.channel :63
                                  c02ppm :436
                                  HiResp :2
                                  LoResp :-97
                                  Tem.channel :63
                                  c02ppm :415
                                  HiResp :2
                                  LoResp :-109
                                  Tem.channel :63
                                  c02ppm :403
                                  HiResp :2
                                  LoResp :106
                                  Tem.channel :63
                                  c02ppm :618
                                  HiResp :2
                                  LoResp :-96
                                  Tem.channel :63
                                  c02ppm :416
                                  HiResp :2
                                  LoResp :80
                                  Tem.channel :63
                                  c02ppm :592
                                  HiResp :2
                                  LoResp :69
                                  Tem.channel :63
                                  c02ppm :581
                                  HiResp :2
                                  LoResp :40
                                  Tem.channel :63
                                  c02ppm :552
                                  HiResp :2
                                  LoResp :84
                                  Tem.channel :63
                                  c02ppm :596
                                  HiResp :2
                                  LoResp :45
                                  Tem.channel :63
                                  c02ppm :557
                                  HiResp :2
                                  LoResp :3
                                  Tem.channel :63
                                  c02ppm :515
                                  HiResp :1
                                  LoResp :-30
                                  Tem.channel :63
                                  c02ppm :226
                                  HiResp :1
                                  LoResp :-62
                                  Tem.channel :63
                                  c02ppm :194
                                  HiResp :1
                                  LoResp :-73
                                  Tem.channel :63
                                  c02ppm :183
                                  HiResp :1
                                  LoResp :-75
                                  Tem.channel :63
                                  c02ppm :181
                                  HiResp :1
                                  LoResp :-96
                                  Tem.channel :63
                                  c02ppm :160
                                  HiResp :1
                                  LoResp :-89
                                  Tem.channel :63
                                  c02ppm :167
                                  HiResp :1
                                  LoResp :-101
                                  Tem.channel :63
                                  c02ppm :155
                                  HiResp :1
                                  LoResp :-112
                                  Tem.channel :63
                                  c02ppm :144
                                  HiResp :1
                                  LoResp :-107
                                  Tem.channel :63
                                  c02ppm :149
                                  HiResp :1
                                  LoResp :-112
                                  Tem.channel :63
                                  c02ppm :144
                                  HiResp :1
                                  LoResp :-110
                                  Tem.channel :63
                                  c02ppm :146
                                  HiResp :1
                                  LoResp :-124
                                  Tem.channel :63
                                  c02ppm :132
                                  HiResp :1
                                  LoResp :-120
                                  Tem.channel :63
                                  c02ppm :136
                                  HiResp :1
                                  LoResp :-75
                                  Tem.channel :63
                                  c02ppm :181
                                  Some of the values seem a bit low to me. Especially while the HiResp is 1 or the LoResp is negative.
                                  I will do this test again at home when I get the chance.
                                  • Tomas
                                  • FotoFieberF
                                    FotoFieberF
                                    FotoFieber
                                    @korttoma
                                    In the technical specification I only find the calibration with nitrogen. I don't think, that putting it outside, will help, as it is usually at around 400 ppm at the moment. (AFAIK netatmo sets the lowest measured value in the last one or two weeks to 400 for calibration).
                                    • alexsh1A
                                      alexsh1A
                                      alexsh1
                                      #21
                                      @korttoma values are completely off. Co2 cannot go down below 300 level. This is a value of co2 outside (300-400).
                                      You have to calibrate it regularly. Zero calibration (this is what you are talking about) is different.
                                      8.1 The sensor should be calibrated regularly. The cycle time is better to be no more than 6 months. 8.2 Do not use the sensor in the high dusty environment for long time.
                                      8.3 Please use the sensor with correct power supply.
                                      8.4 Forbidden to cut the sensor pin.
                                      Try to put it outside for 10mins and then short pins 8 and 12 (see the photo below). This worked for me when I had some weird readings
                                        @korttoma
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        @FotoFieber Netatmo is using index also cannot be compared with mh-z14a.
                                        I think the idea putting the sensor outside is to stabilise it - the reading is in the range of 300-400
                                        • alexsh1A alexsh1
                                          korttomaK
                                          korttomaK
                                          korttoma
                                          Where did you get this kind of information from? The MH-Z14.pdg I found online does not mention anything about this.
                                          • Tomas
