  3. MH-Z14A CO2 sensor
MH-Z14A CO2 sensor
25 Posts 5 Posters 20.1k Views 6 Watching
  • FotoFieberF FotoFieber
    @korttoma
    It is working like a charme for me. Important is, to have 5V for voltage and 3.3 V on the logical level. Here is a graf, the green "Badezimmer" line is the mysensors sensor with MH-Z14A, the others are from netatmo. The mysensors sensor is in the bathroom and therefore it will have usually less CO2.
    korttomaK
    korttomaK
    korttoma
    @FotoFieber My new sensor is giving me the exact same behaivour. Could it be that the problem is that I'm using a 5V Pro Mini?
    • Tomas
    • FotoFieberF
      FotoFieberF
      FotoFieber
      Yes. You have to use a 3.3V arduino and power the sensor with 5V (seperate voltage). The sensor may break with a 5V arduino. I use a 3.3V 8 MHz pro mini.
      korttomaK 1 Reply Last reply
        korttomaK
        korttomaK
        korttoma
        @FotoFieber
        So the symptom I see as the sensor constantly reporting the value 562 could be because it is already broken?
        Or would a broken sensor just stop communicating via serial?
        • Tomas
        • korttomaK korttoma
          @FotoFieber
          FotoFieberF
          FotoFieberF
          FotoFieber
          @korttoma
          As I do not have a broken sensor, I can not tell you.
          If I were you, I would try to fix the voltage issues and check, if it is working then.
          The sensor requires a preheat. Have you used my sketch from above?
            @korttoma
            korttomaK
            korttomaK
            korttoma
            @FotoFieber I swapped out the 5V Pro Mini with a 3.3V Pro Mini yesterday and I'm afraid it did not help at all. If the Sensor would have had a problem with the 5V on the serial pins I bet it would no longer communicate.
            I used some parts of your sketch but since I use an Si7021 and a different radio I had to do some modifications:
             *  MH-Z14 CO2 sensor
             *  Wiring:
             *   Pad 1, Pad 5: Vin (Voltage input 4.5V-6V)
             *   Pad 2, Pad 3, Pad 12: GND
             *   Pad 6: PWM output ==> pin 6
             *  From: http://davidegironi.blogspot.fr/2014/01/co2-meter-using-ndir-infrared-mh-z14.html
             *    MH-Z14 has a PWM output, with a sensitivity range of 0ppm to 2000ppm CO2, an accurancy of ±200ppm.
             *    The cycle is 1004ms±5%, given the duty cicle Th (pulse high), Tl is 1004-Th, we can convert it to CO2 value using the formula:
             *    CO2ppm = 2000 * (Th - 2ms) /(Th + Tl - 4ms)
             *  From: http://airqualityegg.wikispaces.com/Sensor+Tests
             *    - response time is less than 30 s
             *   - 3 minute warm up time
             *  datasheet:
            * Contributor: epierre
            #define MY_NODE_ID  6
            #define SN "AIQ CO2 MH-Z14 TxRx"
            #define SV "2.1"
            #define MY_BAUD_RATE  9600
            #include <MyConfig.h>
            #include <SI7021.h>
            #include <RunningAverage.h>
            #include <SoftwareSerial.h>
            // Define a static node address, remove if you want auto address assignment
            SoftwareSerial mySerial(6, 7); // RX, TX
            byte cmd[9] = {0xFF, 0x01, 0x86, 0x00, 0x00, 0x00, 0x00, 0x00, 0x79};
            char response[9];
            // Child sensor ID's
            #define CHILD_ID_AIQ 1
            #define CHILD_ID_HUM   2
            #define CHILD_ID_TEMP  3
            //#define AIQ_SENSOR_ANALOG_PIN 5
            #define AVERAGES 2
            float valAIQ =0.0;
            float lastAIQ =0.0;
            unsigned int loop_round = 0;
            int lastppm = 0;
            boolean preheat = true;  // wait TEMP_HUM_ROUNDS for preheat
            SI7021 humiditySensor;
            MyMessage msg(CHILD_ID_AIQ, V_LEVEL);
            MyMessage msg2(CHILD_ID_AIQ, V_UNIT_PREFIX);
            // Global settings
            boolean isMetric = true;
            float lastTemperature = -100;
            int lastHumidity = -100;
              mySerial.begin(9600);
              humiditySensor.begin();
              sleep(SLEEP_TIME);
              //pinMode(AIQ_SENSOR_ANALOG_PIN, INPUT);
              isMetric = getConfig().isMetric;
              Serial.print(F("isMetric: ")); Serial.println(isMetric);
              raHum.clear();
                 wait(200);
              send(msg2.set("ppm"));
              sendSketchInfo(SN, SV);
              present(CHILD_ID_AIQ, S_AIR_QUALITY);
              present(CHILD_ID_TEMP,S_TEMP);
              present(CHILD_ID_HUM,S_HUM);
              wait(200);
                mySerial.write(cmd, 9);
              mySerial.readBytes(response, 9);
              int responseHigh = (int) response[2];
              int responseLow = (int) response[3];
              int co2ppm = (256 * responseHigh) + responseLow;
              Serial.print(F("c02ppm :"));Serial.println(co2ppm);
              if ( (abs(co2ppm - lastppm) >= 10)) {
                  send(msg.set(co2ppm));
                  lastppm = co2ppm;
              raHum.addValue(data.humidityPercent);
              float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths)/100.0);
              Serial.print(F("TempDiff :"));Serial.println(diffTemp);
              Serial.print(F("HumDiff  :"));Serial.println(diffHum);
              if (diffTemp > TEMP_TRANSMIT_THRESHOLD) {
                float temperature = (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0;
                Serial.print("T: ");Serial.println(temperature);
                send(msgTemp.set(temperature,1));
              if (diffHum > HUMI_TRANSMIT_THRESHOLD) {
                Serial.print("H: ");Serial.println(humidity);
                send(msgHum.set(humidity));
                lastHumidity = humidity;
              //Serial.println();
              // Power down the radio.  Note that the radio will get powered back up
              // on the next write() call.
              sleep(SLEEP_TIME); //sleep for: sleepTime
            I hope I made a mistake in the sketch since I'm running out of ideas and I don't want the sensors to be broken.
            From where did you buy your sensor? I got them from aliexpress...
            • Tomas
            • FotoFieberF
              FotoFieberF
              FotoFieber
              @korttoma
              Where is the preheat logic in your sketch?
              Values in the preheat time could be wrong....
                @korttoma
                korttomaK
                korttomaK
                korttoma
                @FotoFieber Yeah, I don't have preheat logic but that would only account for values when I first plug it in. I get the strange values even if it has been running for weeks. I will try to get a graph of what I see this evening so you can see what I mean. I'm seriously considering to just exclude the value 562 from being sent to the controller.
                • Tomas
                alexsh1A 1 Reply Last reply
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @korttoma Sounds like you have a faulty sensor. Did you try analogue output? This is just to make sure the sensor is working.
                  There are PWM or UART.
                  Did you try both of them? I am using 5V Arduino Nano with no problem.
                  The digital pins communicate via PWM or UART. Output (and input for UART) of these ports work on 3.3 Volts - this means you should change the ARef of your Arduino - or rescale your values
                  • korttomaK
                    korttomaK
                    korttoma
                    • Tomas
                    • alexsh1A
                      alexsh1A
                      alexsh1
                      @korttoma try to put it outside for some time to recalibrate. If it does not help, you may need to calibrate it.
                      Or you just got a bad one.
                      • alexsh1A alexsh1
                        korttomaK
                        korttomaK
                        korttoma
                        @alexsh1 Will the sensor really recalibrate by itself if I put it outside?
                        I could send a "zero calibration" command via serial but then I would need to "input Nitrogen gas for 5 minutes when make zero calibration. "
                        Instead of exposing it to nitrogen gas could I just like you said put it outside and then send the "zero calibration" command?
                        To do the " span calibration" I would need to know what kind of values to send to it and I have no idea.
                        btw, here are some values I read now via serial at the office (I do not get the 562 value so far) but does these values seem reasonable for a well ventilated office?
                        HiResp :3
                        LoResp :-21
                        Tem.channel :63
                        c02ppm :747
                        HiResp :3
                        LoResp :124
                        Tem.channel :63
                        c02ppm :892
                        HiResp :3
                        LoResp :21
                        Tem.channel :63
                        c02ppm :789
                        HiResp :2
                        LoResp :-57
                        Tem.channel :63
                        c02ppm :455
                        HiResp :2
                        LoResp :-110
                        Tem.channel :63
                        c02ppm :402
                        HiResp :2
                        LoResp :99
                        Tem.channel :63
                        c02ppm :611
                        HiResp :2
                        LoResp :51
                        Tem.channel :63
                        c02ppm :563
                        HiResp :2
                        LoResp :20
                        Tem.channel :63
                        c02ppm :532
                        HiResp :1
                        LoResp :-2
                        Tem.channel :63
                        c02ppm :254
                        HiResp :1
                        LoResp :-32
                        Tem.channel :63
                        c02ppm :224
                        HiResp :1
                        LoResp :-55
                        Tem.channel :63
                        c02ppm :201
                        HiResp :1
                        LoResp :-68
                        Tem.channel :63
                        c02ppm :188
                        HiResp :1
                        LoResp :-75
                        Tem.channel :63
                        c02ppm :181
                        HiResp :1
                        LoResp :-79
                        Tem.channel :63
                        c02ppm :177
                        HiResp :1
                        LoResp :-98
                        Tem.channel :63
                        c02ppm :158
                        HiResp :1
                        LoResp :-102
                        Tem.channel :63
                        c02ppm :154
                        HiResp :1
                        LoResp :-109
                        Tem.channel :63
                        c02ppm :147
                        HiResp :1
                        LoResp :-116
                        Tem.channel :63
                        c02ppm :140
                        HiResp :1
                        LoResp :-125
                        Tem.channel :63
                        c02ppm :131
                        HiResp :1
                        LoResp :-124
                        Tem.channel :63
                        c02ppm :132
                        HiResp :1
                        LoResp :111
                        Tem.channel :63
                        c02ppm :367
                        HiResp :1
                        LoResp :115
                        Tem.channel :63
                        c02ppm :371
                        HiResp :1
                        LoResp :121
                        Tem.channel :63
                        c02ppm :377
                        HiResp :1
                        LoResp :114
                        Tem.channel :63
                        c02ppm :370
                        HiResp :1
                        LoResp :-62
                        Tem.channel :63
                        c02ppm :194
                        HiResp :1
                        LoResp :-7
                        Tem.channel :63
                        c02ppm :249
                        HiResp :1
                        LoResp :-53
                        Tem.channel :63
                        c02ppm :203
                        HiResp :1
                        LoResp :-68
                        Tem.channel :63
                        c02ppm :188
                        HiResp :1
                        LoResp :-96
                        Tem.channel :63
                        c02ppm :160
                        HiResp :1
                        LoResp :-111
                        Tem.channel :63
                        c02ppm :145
                        HiResp :1
                        LoResp :-121
                        Tem.channel :63
                        c02ppm :135
                        HiResp :1
                        LoResp :-127
                        Tem.channel :63
                        c02ppm :129
                        HiResp :1
                        LoResp :-124
                        Tem.channel :63
                        c02ppm :132
                        HiResp :1
                        LoResp :-126
                        Tem.channel :63
                        c02ppm :130
                        HiResp :1
                        LoResp :-126
                        Tem.channel :63
                        c02ppm :130
                        HiResp :1
                        LoResp :-110
                        Tem.channel :63
                        c02ppm :146
                        HiResp :1
                        LoResp :-110
                        Tem.channel :63
                        c02ppm :146
                        HiResp :1
                        LoResp :-60
                        Tem.channel :63
                        c02ppm :196
                        HiResp :1
                        LoResp :-69
                        Tem.channel :63
                        c02ppm :187
                        HiResp :1
                        LoResp :-101
                        Tem.channel :63
                        c02ppm :155
                        HiResp :1
                        LoResp :-104
                        Tem.channel :63
                        c02ppm :152
                        HiResp :1
                        LoResp :-114
                        Tem.channel :63
                        c02ppm :142
                        HiResp :1
                        LoResp :-128
                        Tem.channel :63
                        c02ppm :128
                        HiResp :1
                        LoResp :-122
                        Tem.channel :63
                        c02ppm :134
                        HiResp :1
                        LoResp :122
                        Tem.channel :63
                        c02ppm :378
                        HiResp :1
                        LoResp :119
                        Tem.channel :63
                        c02ppm :375
                        HiResp :1
                        LoResp :-128
                        Tem.channel :63
                        c02ppm :128
                        HiResp :1
                        LoResp :-86
                        Tem.channel :63
                        c02ppm :170
                        HiResp :1
                        LoResp :-110
                        Tem.channel :63
                        c02ppm :146
                        HiResp :1
                        LoResp :-123
                        Tem.channel :63
                        c02ppm :133
                        HiResp :1
                        LoResp :-101
                        Tem.channel :63
                        c02ppm :155
                        HiResp :1
                        LoResp :-75
                        Tem.channel :63
                        c02ppm :181
                        HiResp :1
                        LoResp :-92
                        Tem.channel :63
                        c02ppm :164
                        HiResp :1
                        LoResp :-101
                        Tem.channel :63
                        c02ppm :155
                        HiResp :1
                        LoResp :-123
                        Tem.channel :63
                        c02ppm :133
                        HiResp :1
                        LoResp :-114
                        Tem.channel :63
                        c02ppm :142
                        HiResp :1
                        LoResp :-127
                        Tem.channel :63
                        c02ppm :129
                        HiResp :1
                        LoResp :-120
                        Tem.channel :63
                        c02ppm :136
                        HiResp :1
                        LoResp :126
                        Tem.channel :63
                        c02ppm :382
                        HiResp :1
                        LoResp :118
                        Tem.channel :63
                        c02ppm :374
                        HiResp :1
                        LoResp :-127
                        Tem.channel :63
                        c02ppm :129
                        HiResp :1
                        LoResp :118
                        Tem.channel :63
                        c02ppm :374
                        HiResp :1
                        LoResp :120
                        Tem.channel :63
                        c02ppm :376
                        HiResp :1
                        LoResp :118
                        Tem.channel :63
                        c02ppm :374
                        HiResp :1
                        LoResp :115
                        Tem.channel :63
                        c02ppm :371
                        HiResp :1
                        LoResp :124
                        Tem.channel :63
                        c02ppm :380
                        HiResp :1
                        LoResp :120
                        Tem.channel :63
                        c02ppm :376
                        HiResp :1
                        LoResp :-119
                        Tem.channel :63
                        c02ppm :137
                        HiResp :1
                        LoResp :-126
                        Tem.channel :63
                        c02ppm :130
                        HiResp :1
                        LoResp :-127
                        Tem.channel :63
                        c02ppm :129
                        HiResp :1
                        LoResp :-124
                        Tem.channel :63
                        c02ppm :132
                        HiResp :1
                        LoResp :121
                        Tem.channel :63
                        c02ppm :377
                        HiResp :1
                        LoResp :114
                        Tem.channel :63
                        c02ppm :370
                        HiResp :1
                        LoResp :108
                        Tem.channel :63
                        c02ppm :364
                        HiResp :1
                        LoResp :108
                        Tem.channel :63
                        c02ppm :364
                        HiResp :1
                        LoResp :119
                        Tem.channel :63
                        c02ppm :375
                        HiResp :1
                        LoResp :-110
                        Tem.channel :63
                        c02ppm :146
                        HiResp :1
                        LoResp :124
                        Tem.channel :63
                        c02ppm :380
                        HiResp :1
                        LoResp :127
                        Tem.channel :63
                        c02ppm :383
                        HiResp :1
                        LoResp :-43
                        Tem.channel :63
                        c02ppm :213
                        HiResp :1
                        LoResp :-72
                        Tem.channel :63
                        c02ppm :184
                        HiResp :1
                        LoResp :-77
                        Tem.channel :63
                        c02ppm :179
                        HiResp :1
                        LoResp :-63
                        Tem.channel :63
                        c02ppm :193
                        HiResp :1
                        LoResp :-92
                        Tem.channel :63
                        c02ppm :164
                        HiResp :1
                        LoResp :-105
                        Tem.channel :63
                        c02ppm :151
                        HiResp :1
                        LoResp :-116
                        Tem.channel :63
                        c02ppm :140
                        HiResp :2
                        LoResp :41
                        Tem.channel :63
                        c02ppm :553
                        HiResp :2
                        LoResp :47
                        Tem.channel :63
                        c02ppm :559
                        HiResp :2
                        LoResp :26
                        Tem.channel :63
                        c02ppm :538
                        HiResp :2
                        LoResp :-107
                        Tem.channel :63
                        c02ppm :405
                        HiResp :2
                        LoResp :-76
                        Tem.channel :63
                        c02ppm :436
                        HiResp :2
                        LoResp :-97
                        Tem.channel :63
                        c02ppm :415
                        HiResp :2
                        LoResp :-109
                        Tem.channel :63
                        c02ppm :403
                        HiResp :2
                        LoResp :106
                        Tem.channel :63
                        c02ppm :618
                        HiResp :2
                        LoResp :-96
                        Tem.channel :63
                        c02ppm :416
                        HiResp :2
                        LoResp :80
                        Tem.channel :63
                        c02ppm :592
                        HiResp :2
                        LoResp :69
                        Tem.channel :63
                        c02ppm :581
                        HiResp :2
                        LoResp :40
                        Tem.channel :63
                        c02ppm :552
                        HiResp :2
                        LoResp :84
                        Tem.channel :63
                        c02ppm :596
                        HiResp :2
                        LoResp :45
                        Tem.channel :63
                        c02ppm :557
                        HiResp :2
                        LoResp :3
                        Tem.channel :63
                        c02ppm :515
                        HiResp :1
                        LoResp :-30
                        Tem.channel :63
                        c02ppm :226
                        HiResp :1
                        LoResp :-62
                        Tem.channel :63
                        c02ppm :194
                        HiResp :1
                        LoResp :-73
                        Tem.channel :63
                        c02ppm :183
                        HiResp :1
                        LoResp :-75
                        Tem.channel :63
                        c02ppm :181
                        HiResp :1
                        LoResp :-96
                        Tem.channel :63
                        c02ppm :160
                        HiResp :1
                        LoResp :-89
                        Tem.channel :63
                        c02ppm :167
                        HiResp :1
                        LoResp :-101
                        Tem.channel :63
                        c02ppm :155
                        HiResp :1
                        LoResp :-112
                        Tem.channel :63
                        c02ppm :144
                        HiResp :1
                        LoResp :-107
                        Tem.channel :63
                        c02ppm :149
                        HiResp :1
                        LoResp :-112
                        Tem.channel :63
                        c02ppm :144
                        HiResp :1
                        LoResp :-110
                        Tem.channel :63
                        c02ppm :146
                        HiResp :1
                        LoResp :-124
                        Tem.channel :63
                        c02ppm :132
                        HiResp :1
                        LoResp :-120
                        Tem.channel :63
                        c02ppm :136
                        HiResp :1
                        LoResp :-75
                        Tem.channel :63
                        c02ppm :181
                        Some of the values seem a bit low to me. Especially while the HiResp is 1 or the LoResp is negative.
                        I will do this test again at home when I get the chance.
                        • Tomas
                        • FotoFieberF
                          FotoFieberF
                          FotoFieber
                          @korttoma
                          In the technical specification I only find the calibration with nitrogen. I don't think, that putting it outside, will help, as it is usually at around 400 ppm at the moment. (AFAIK netatmo sets the lowest measured value in the last one or two weeks to 400 for calibration).
                          • alexsh1A
                            alexsh1A
                            alexsh1
                            #21
                            @korttoma values are completely off. Co2 cannot go down below 300 level. This is a value of co2 outside (300-400).
                            You have to calibrate it regularly. Zero calibration (this is what you are talking about) is different.
                            8.1 The sensor should be calibrated regularly. The cycle time is better to be no more than 6 months. 8.2 Do not use the sensor in the high dusty environment for long time.
                            8.3 Please use the sensor with correct power supply.
                            8.4 Forbidden to cut the sensor pin.
                            Try to put it outside for 10mins and then short pins 8 and 12 (see the photo below). This worked for me when I had some weird readings
                              @korttoma
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @FotoFieber Netatmo is using index also cannot be compared with mh-z14a.
                              I think the idea putting the sensor outside is to stabilise it - the reading is in the range of 300-400
                              • alexsh1A alexsh1
                                korttomaK
                                korttomaK
                                korttoma
                                Where did you get this kind of information from? The MH-Z14.pdg I found online does not mention anything about this.
                                • Tomas
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @korttoma It was recommended by an Aliexpress seller who sold me the sensor.
                                  Let's agree that Chinese documentation is not always comprehensive :)
                                  • korttomaK
                                    korttomaK
                                    korttoma
                                    I finally found some time to really look in to this 562 issue. I looked at the raw data in DataMine2 and I noticed that the 562 value appeared every 10 minutes on the minute.
                                    Then I knew that this value cannot possibly come from the sensor. I search around in my Vera device for a bit and I found some lua code that copied the "Variable1" value from the sensor to the "CurrentLevel" every 10 minutes. Then I remembered that in the previous version of this sensor the value was reported via V_VAR1 and I had to copy it to another variable in Vera to be able to draw any graph. The current version of the sensor reports the value directly to the "CurrentLevel" variable and the value 562 that was still in the old variable was copied over the "real" value every 10 minutes.
                                    I also previously had some really low values from time to time from the sensor mostly when responseHigh = 1 and responseLow = negative value
                                    so I forced the responseLow to always be a positive value like this:
                                    int responseLow = abs((int) response[3]);
                                    I will keep an eye on the behavior of the sensor now that I have finally removed the confusing 562 value.
                                    • Tomas
