  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 676.6k Views 99 Watching
  • undeeU
    undeeU
    undee
    @TimO Can you say anything regarding the autoupdate=false option yet? It would be useful to separate the UI user action from the status displayed by the UI. Rollershutters for example can show the percentage of how much the shutters are down. This conflicts with the autoupdate=true behaviour which sets the value to 0 as soon as the UP button is pushed.
    • T TimO
      @ben999 had a chat @Jic right now who has exactly the same problem.
      There is still something wrong! :-(
      I'll keep searching!
      JicJ
      JicJ
      Jic
      @TimO I have reviewed all my steps, and seems that I had not updated correctly the binding.
      So later update Openhab2 to latest snapshot, the latest org.openhab.binding.mysensors-2.0.0-SNAPSHOT.jar now it working right.
      thank you very much
      • T TimO
        ben999B
        ben999B
        ben999
        @TimO
        Will do as @Jic said and will start fresh tonight (europe) with latest OH2 and all on a fresh SD Card
        There might be old files and bugs on this really messed up install...
        Thanks again for your time and effort
        • T
          TimO
          @Jic I'm glad it worked out finally, thank you for your feedback!
          @ben999 Please do so and ensure you install the latest snapshot of OH2.
          At least I think we found the guilty one:
          "The methods ThingHandler.bridgeHandlerInitialized() and ThingHandler.bridgeHandlerDisposed() are removed. This breaks the API."
          PR LINK
          The most annoying part is: I don't see a way to keep up backward compatibility with the current testing release (beta4).
          ben999B 1 Reply Last reply
          • undeeU undee
            TimO
            @undee I'm not able to find a hint, that it is already implemented in OH2, do you have more information for me?
            Defining:
            Switch light01  "light01"       { autoupdate=false, channel="mysensors:light:gateway:light01:status" }
            Returns:
            [.e.s.m.i.i.GenericItemProvider:385  ] - Couldn't find ItemFactory for item 'channel' of type 'false'
            Does not look like OH2 already knows what it means.
            undeeU 1 Reply Last reply
            • T TimO
              Defining:
              Returns:
              undeeU
              undeeU
              undee
              @TimO The MQTT binding might be helpful. It is possible to implement the following behaviour with MQTT when autoupdate is set to false:
              When you touch a switch, the defined message is published to an MQTT topic, but the button status remains unchanged. Then, for example, the device processes the message and publishes a status message which then causes the update to the visible status of the button.
              The same can be implemented with shutters. When you push the button to move the shutters up, with autoupdate=true the icon is immediately set to reflect 0%. With autoupdate=false, you can show the current position by updating the position while it is in motion.
              I can't do this with the MySensors binding yet because pushing a button always updates the status automatically.
              • T TimO
                PR LINK
                ben999B
                ben999B
                ben999
                @TimO
                :crown: you deserve that one :)
                All working fine, no trouble
                Very clean OH2 log file
                Happy man i am!
                Thanks again for time, effort and availability
                Please let me know if i can help in any way
                pi@raspberrypi:/usr/share/openhab2 $ ./start.sh
                Launching the openHAB runtime...
                                          __  _____    ____
                  ____  ____  ___  ____  / / / /   |  / __ )
                 / __ \/ __ \/ _ \/ __ \/ /_/ / /| | / __  |
                / /_/ / /_/ /  __/ / / / __  / ___ |/ /_/ /
                \____/ .___/\___/_/ /_/_/ /_/_/  |_/_____/
                    /_/                        2.0.0-SNAPSHOT
                                               Build #609
                Hit '<tab>' for a list of available commands
                and '[cmd] --help' for help on a specific command.
                Hit '<ctrl-d>' or type 'system:shutdown' or 'logout' to shutdown openHAB.
                openhab> log:set DEBUG org.openhab.binding.mysensors
                openhab> log:tail
                21:42:00.387 [DEBUG] [org.openhab.binding.mysensors       ] - BundleEvent STARTING - org.openhab.binding.mysensors
                21:42:00.403 [DEBUG] [org.openhab.binding.mysensors       ] - BundleEvent STARTED - org.openhab.binding.mysensors
                21:42:00.523 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={component.name=org.openhab.binding.mysensors.internal.factory.MySensorsHandlerFactory, component.id=0, service.id=106, service.bundleid=10, service.scope=bundle} - org.openhab.binding.mysensors
                21:42:14.666 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.things'
                21:42:14.994 [INFO ] [smarthome.event.ThingAddedEvent     ] - Thing 'mysensors:bridge-eth:gateway' has been added.
                21:42:15.002 [INFO ] [smarthome.event.ThingAddedEvent     ] - Thing 'mysensors:humidity:gateway:bathHum01' has been added.
                21:42:15.006 [INFO ] [smarthome.event.ThingAddedEvent     ] - Thing 'mysensors:temperature:gateway:bathTemp01' has been added.
                21:42:15.433 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=230, service.bundleid=10, service.scope=singleton} - org.openhab.binding.mysensors
                21:42:15.451 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-eth:gateway' changed from UNINITIALIZED to INITIALIZING
                21:42:15.453 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
                21:42:15.464 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:humidity:gateway:bathHum01' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
                21:42:15.474 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:temperature:gateway:bathTemp01' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
                21:42:15.507 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Set skip check on startup to: false
                21:42:15.508 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Enabling connection watchdog
                21:42:15.517 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Connecting to IP bridge [127.0.0.1:5003]
                21:42:15.532 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
                21:42:15.534 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache (given_ids) content: [1]
                21:42:15.540 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
                21:42:15.541 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;14;Gateway startup complete.
                21:42:15.548 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;14;Gateway startup complete.
                21:42:15.552 [INFO ] [smarthome.event.ItemAddedEvent      ] - Item 'mysensors_humidity_gateway_bathHum01_hum' has been added.
                21:42:15.554 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;0;0;18;2.0.1-beta
                21:42:15.556 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'mysensors_humidity_gateway_bathHum01_hum-mysensors:humidity:gateway:bathHum01:hum' has been added.
                21:42:15.555 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;0;0;18;2.0.1-beta
                21:42:15.559 [INFO ] [smarthome.event.ItemAddedEvent      ] - Item 'mysensors_humidity_gateway_bathHum01_lastupdate' has been added.
                21:42:15.562 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'mysensors_humidity_gateway_bathHum01_lastupdate-mysensors:humidity:gateway:bathHum01:lastupdate' has been added.
                21:42:15.565 [INFO ] [smarthome.event.ItemAddedEvent      ] - Item 'mysensors_temperature_gateway_bathTemp01_lastupdate' has been added.
                21:42:15.569 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'mysensors_temperature_gateway_bathTemp01_lastupdate-mysensors:temperature:gateway:bathTemp01:lastupdate' has been added.
                21:42:15.571 [INFO ] [smarthome.event.ItemAddedEvent      ] - Item 'mysensors_temperature_gateway_bathTemp01_temp' has been added.
                21:42:15.573 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'mysensors_temperature_gateway_bathTemp01_temp-mysensors:temperature:gateway:bathTemp01:temp' has been added.
                21:42:15.729 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                21:42:15.743 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;2;2.0.1-beta
                21:42:15.744 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Good,Gateway is up and running! (Ver:2.0.1-beta)
                21:42:15.745 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;2;2.0.1-beta
                21:42:15.749 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-eth:gateway' changed from INITIALIZING to ONLINE
                21:42:15.759 [INFO ] [al.protocol.ip.MySensorsIpConnection] - Successfully connected to MySensors Bridge.
                21:42:15.761 [WARN ] [al.protocol.ip.MySensorsIpConnection] - Network Sanity Checker thread disabled from bridge configuration
                21:42:15.788 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 1, chiledId: 1, revertState: false
                21:42:15.789 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 1-1 not registered yet, registering...
                21:42:15.789 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 1, chiledId: 0, revertState: false
                21:42:15.790 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 1-0 not registered yet, registering...
                21:42:15.794 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:temperature:gateway:bathTemp01' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
                21:42:15.796 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:humidity:gateway:bathHum01' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
                21:42:15.797 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:temperature:gateway:bathTemp01' changed from INITIALIZING to ONLINE
                21:42:15.799 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:humidity:gateway:bathHum01' changed from INITIALIZING to ONLINE
                21:42:17.115 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
                21:42:17.453 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
                21:42:17.949 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /ui
                21:42:18.125 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
                21:42:25.762 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                21:42:35.763 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                21:42:45.765 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                21:42:55.766 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                21:43:05.768 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                21:43:13.988 [DEBUG] [rs.internal.protocol.MySensorsReader] - 1;0;1;0;1;62.5
                21:43:14.005 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 1 to 2016-11-23T21:43:13.995+0000
                21:43:14.010 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 1 to 2016-11-23T21:43:14.006+0000
                21:43:14.016 [DEBUG] [rs.internal.protocol.MySensorsReader] - 1;0;1;0;1;62.5
                21:43:14.022 [INFO ] [marthome.event.ItemStateChangedEvent] - mysensors_temperature_gateway_bathTemp01_lastupdate changed from NULL to 2016-11-23T21:43:13.995+0000
                21:43:14.037 [INFO ] [marthome.event.ItemStateChangedEvent] - mysensors_humidity_gateway_bathHum01_lastupdate changed from NULL to 2016-11-23T21:43:14.006+0000
                21:43:14.040 [INFO ] [marthome.event.ItemStateChangedEvent] - mysensors_humidity_gateway_bathHum01_hum changed from NULL to 62.5
                21:43:15.769 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                21:43:25.771 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                21:43:35.772 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                21:43:45.775 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                21:43:55.778 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                21:44:05.779 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                21:44:15.780 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                21:44:20.330 [DEBUG] [rs.internal.protocol.MySensorsReader] - 1;1;1;0;0;18.9
                21:44:20.340 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 1 to 2016-11-23T21:44:20.333+0000
                21:44:20.348 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 1 to 2016-11-23T21:44:20.342+0000
                21:44:20.349 [DEBUG] [rs.internal.protocol.MySensorsReader] - 1;1;1;0;0;18.9
                21:44:20.352 [DEBUG] [rs.internal.protocol.MySensorsReader] - 1;0;1;0;1;62.0
                21:44:20.362 [DEBUG] [rs.internal.protocol.MySensorsReader] - 1;0;1;0;1;62.0
                21:44:20.364 [INFO ] [marthome.event.ItemStateChangedEvent] - mysensors_temperature_gateway_bathTemp01_lastupdate changed from 2016-11-23T21:43:13.995+0000 to 2016-11-23T21:44:20.333+0000
                21:44:20.370 [INFO ] [marthome.event.ItemStateChangedEvent] - mysensors_temperature_gateway_bathTemp01_temp changed from NULL to 18.9
                21:44:20.381 [INFO ] [marthome.event.ItemStateChangedEvent] - mysensors_humidity_gateway_bathHum01_lastupdate changed from 2016-11-23T21:43:14.006+0000 to 2016-11-23T21:44:20.342+0000
                21:44:20.387 [INFO ] [marthome.event.ItemStateChangedEvent] - mysensors_humidity_gateway_bathHum01_hum changed from 62.5 to 62.0
                21:44:25.783 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                21:44:35.785 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                21:44:45.786 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                21:44:55.788 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                21:45:05.789 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                21:45:15.792 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                • ben999B ben999
                  @TimO
                  Happy man i am!
                                            __  _____    ____
                      /_/                        2.0.0-SNAPSHOT
                                                 Build #609
                  openhab> log:tail
                  TimO
                  @ben999 Thank you for your kind words and for your patience! :-)
                  I'm glad it is working now. As it is quiet for a day now, I suppose the problem is solved.
                  JicJ 1 Reply Last reply
                  • T TimO
                    JicJ
                    JicJ
                    Jic
                    @TimO thanks to you. My Sensor seems working right since a week. :)
                    But I have noticed a beahaviour that I think it's anomal.
                    I have a Door Sensor, their lastupdate attribute upate their value almost each 10 minuts approximately. I think it should be updated when the state of the tripped value changes, or not?
                    Also, if the tripped value change quickly, the lastupdate attribute not change.
                    I'm triying that the lastupdate value is the last time the door was open or close, but I don't find the way to do that. Is this a bug? I have reviewed my skecht and I don't see any posible error in it.
                    Thanks in advance
                    • T
                      TimO
                      @Jic Do you have a corresponding log for me?
                      My last update value only updates if a update is received. If I don't get an update for hours the last update variable won't change.
                      Maybe you receive a not tripped from the motion sensor? That will update the last update variable.
                      JicJ 2 Replies Last reply
                      • T TimO
                        JicJ
                        JicJ
                        Jic
                        @TimO right now, I have only one Door sensor.
                        my logs are
                        2016-12-01 23:02:43.047 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                        2016-12-01 23:02:53.049 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                        2016-12-01 23:02:53.909 [DEBUG] [rs.internal.protocol.MySensorsReader] - 10;1;1;0;16;1
                        2016-12-01 23:02:53.923 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 10 to 2016-12-01T23:02:53.913+0100
                        2016-12-01 23:02:53.990 [DEBUG] [rs.internal.protocol.MySensorsReader] - 10;255;3;0;22;100788
                        2016-12-01 23:03:03.051 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                        2016-12-01 23:03:13.053 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                        2016-12-01 23:07:03.111 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                        2016-12-01 23:07:05.190 [DEBUG] [rs.internal.protocol.MySensorsReader] - 10;255;3;0;21;0
                        2016-12-01 23:07:05.203 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 10 to 2016-12-01T23:07:05.193+0100
                        ==> events.log <==
                        2016-12-01 23:07:05.229 [ItemStateChangedEvent     ] - mysensors_door_gateway_Door_10_1_lastupdate changed from 2016-12-01T23:02:53.913+0100 to 2016-12-01T23:07:05.193+0100
                        2016-12-01 23:07:05.264 [ItemStateChangedEvent     ] - Cancela01time changed from 2016-12-01T23:02:53.913+0100 to 2016-12-01T23:07:05.193+0100
                        You can see last event is at 23:07, however in the following snapshot the time is 11:17
                        No more events, but the lastupdate change
                        • T TimO
                          JicJ
                          JicJ
                          Jic
                          @TimO ok, I have discovered that my "tail" command doesn't work rigth, sorry
                          My logs are
                          2016-12-01 23:17:05.248 [DEBUG] [rs.internal.protocol.MySensorsReader] - 10;255;3;0;21;0
                          2016-12-01 23:27:05.326 [DEBUG] [rs.internal.protocol.MySensorsReader] - 10;255;3;0;21;0
                          2016-12-01 23:37:05.409 [DEBUG] [rs.internal.protocol.MySensorsReader] - 10;255;3;0;21;0
                          2016-12-01 23:47:05.486 [DEBUG] [rs.internal.protocol.MySensorsReader] - 10;255;3;0;21;0
                          2016-12-01 23:57:05.562 [DEBUG] [rs.internal.protocol.MySensorsReader] - 10;255;3;0;21;0
                          2016-12-02 00:07:05.639 [DEBUG] [rs.internal.protocol.MySensorsReader] - 10;255;3;0;21;0
                          I don't understand why am I reciving this message?
                          • JicJ Jic
                            My logs are
                            TimO
                            @Jic According to the serial API this is a I_DISCOVER_RESPONSE, but why is it sent? This seeems to update the lastUpdate channel.
                            I see it this way: "lastUpdate" is the last time the node has sent something, so everything is working as expected. :D
                            • T TimO
                              JicJ
                              JicJ
                              Jic
                              @TimO
                              Thanks. I don't know why is it sending a I_DISCOVER_RESPONSE message. Any Idea?
                              • JicJ Jic
                                @TimO
                                TimO
                                @Jic No sorry, I've no idea. :-/
                                • T TimO
                                  @bentrik said:
                                  I managed to find an addons directory in /usr/share/openhab2/addons, but I can´t find a way to copy the .jar file there, as I get permission denied both through WinSCP in sudo mode and terminal ssh. The folder has permission 0775.
                                  That is the correct directory if you installed OH2 via .deb. Seems like you are using a user in WinSCP that is not allowed to write to the directory above. To circumvent this:
                                  1. Copy the binding jar to /tmp.
                                  2. Login via ssh and execute:
                                  sudo cp /tmp/org.openhab.binding.mysensors-2.0.0-SNAPSHOT.jar /usr/share/openhab2/addons/
                                  and
                                  sudo chmod openhab.openhab /usr/share/openhab2/addons/org.openhab.binding.mysensors-2.0.0-SNAPSHOT.jar
                                  OH2 is started/stopped/restarted with
                                  service openhab2 start/stop/restart
                                  To log into the karaf console do:
                                  ssh openhab@localhost -p 8101
                                  Password is: habopen
                                  Follow the guide/wiki from:
                                  In the console enter feature:install openhab-transport-serial
                                  P
                                  P
                                  patrick schaerer
                                  and
                                  I have installed openhab with the openhabian image. I could start the mysensors gateway too.
                                  I followed the github-openhab2 installation instructions.
                                  To this point
                                  I read a lot of posts on this thread but on get this error:
                                  openhab> install openhab-transport-serial
                                  Bundle IDs:
                                  Error executing command: Error installing bundles:
                                  	Unable to install bundle openhab-transport-serial
                                  the chmod line posted above doesn't work neither. chmod does not accept openhab.openhab
                                  I dont have any clue how to install the binding for openhab2 ... why isn't that possible from paperui :-(
                                  • tademetT
                                    tademetT
                                    tademet
                                    I have install the addon and am getting the error:
                                    17:49:40.745 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Connecting to IP bridge [null:1883]
                                    17:49:40.745 [ERROR] [al.protocol.ip.MySensorsIpConnection] - IP must be not null/empty
                                    17:49:40.752 [ERROR] [al.protocol.ip.MySensorsIpConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:46)
                                    17:49:40.753 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Disconnecting from IP bridge ...
                                    MySensors does not show up as a binding in HabMin or PaperUI.
                                    Where do I configure the MySensors binding if it doesn't show up in the UI?
                                    jogantJ 1 Reply Last reply
                                    • tademetT tademet
                                      jogantJ
                                      jogantJ
                                      jogant
                                      @tademet
                                      as stated in the configuration wiki https://github.com/tobof/openhab2-addons/wiki/Configuration you have to define the bridge in your thing-configuration, depending on the type of your gateway serial or ethernet.
                                      tademetT 1 Reply Last reply
                                      • jogantJ jogant
                                        @tademet
                                        tademetT
                                        tademetT
                                        tademet
                                        wrote on last edited by tademet
                                        #334
                                        @jogant
                                        I have added the config to the thing file.
                                        Bridge mysensors:bridge-eth:gateway [ ipAddress:"10.9.167.116", tcpPort=5003, sendDelay=200, imperial=true] {
                                        But still getting the error:
                                        08:10:25.214 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Connecting to IP bridge [null:5003]
                                        08:10:25.215 [ERROR] [al.protocol.ip.MySensorsIpConnection] - IP must be not null/empty
                                        08:10:25.216 [ERROR] [al.protocol.ip.MySensorsIpConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:3)
                                        08:10:25.217 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Disconnecting from IP bridge ...
                                        I changed the port and it recognized that change but is not recognizing ipAddress. Am I misspelling this?
                                        • tademetT tademet
                                          @jogant
                                          TimO
                                          @tademet there's a ":" instead of a "=" between ipAddress and the IP adress.
