  3. Serial gateway error???
4 Posts 2 Posters 847 Views 2 Watching
  • speedieS Offline
    speedieS Offline
    speedie
    Strange behavior of serial gateway.
    I already build it and used it with Pimatic and it works.
    Now i want to use it with Domotics but it did not work.
    Whem i look in the serial monitoring I see this error?
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;!TSM:RADIO:FAIL
    0;255;3;0;9;!TSM:FAILURE
    0;255;3;0;9;TSM:PDT
    dbemowskD 1 Reply Last reply
    • speedieS speedie
      0;255;3;0;9;TSM:PDT
      dbemowskD Offline
      dbemowskD Offline
      @speedie Radio failures are usually due to not havin, or having the wrong value capacitor on your radio. Put the capacitor right next to, or directly on top of the radio header connector on the incoming power line.
      • speedieS Offline
        speedieS Offline
        speedie
        Hello @dbemowsk ,
        But it worked in Pimatic,
        Seems to me that then the serialgateway was working?
        • speedieS speedie
          Hello @dbemowsk ,
          dbemowskD Offline
          dbemowskD Offline
          @speedie It still could be a capacitor issue. Another thing, check your solder joints and wires to the radio. The first gateway I built worked intermittently and a bad connection was the cause.
          11.8k
          113.2k
