  3. [Solved]Radio Error on Sensor
17 Posts 3 Posters 4.6k Views 3 Watching
    martim
    I tried this already but no differences (tried 4,7 uF until 47uF). Below I have the start log where something is about an CHKID fail:
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSP:MSG:READ 0-0-255 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSP:MSG:PAR OK (ID=0, dist=1)
    TSM:FPAR:OK
    TSM:ID
    TSP:MSG:SEND 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
    TSM:ID
    TSM:ID
    TSM:ID
    !TSM:CHKID:FAIL (ID=255)
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE```
    tekkaT 1 Reply Last reply
    • M martim
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR:OK
      TSM:ID
      TSM:ID
      TSM:ID
      TSM:ID
      !TSM:FAILURE
      TSM:PDT
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      !TSM:FPAR:FAIL
      !TSM:FAILURE```
      tekkaT
      tekkaT
      tekka
      @martim That looks already better:
      (1) make sure to add a large cap on both, GW and node
      (2) your controller software does not appear to assign IDs (hence the CHKID:FAIL) - set a static ID using:
      #define NODE_ID 123
      • tekkaT tekka
        #define NODE_ID 123
        martim
        @tekka
        Thanks for helping!
        I already have this in my code. This is the code for my Node:
        #define MY_BAUD_RATE 115200
        // Enable debug prints
        #define OPEN 1
        #define CLOSE 0
        #define NODE_ID 123
        MyMessage msg(NODE_ID, V_TRIPPED);
        uint8_t value = OPEN;
          sendSketchInfo("Dummy sensor", "1.0");
           present(NODE_ID, S_DOOR);
            value = value == OPEN ? CLOSE : OPEN;
            send(msg.set(value));
            sleep(10000);
        and it still gives this message? Can this be an error in the Gateway?
        • M martim
          @tekka
          Thanks for helping!
          #define OPEN 1
          #define CLOSE 0
          #define NODE_ID 123
              sleep(10000);
          @martim
          #define NODE_ID 123
          must be done before
            @martim
            #define NODE_ID 123
            must be done before
            martim
            @mfalkvidd said:
            @martim
            #define NODE_ID 123
            must be done before
            thanks. But still same error!?!
            • M martim
              @mfalkvidd said:
              @martim
              #define NODE_ID 123
              must be done before
              @martim and you followed tekka's recommendation on adding capacitors?
                martim
                wrote on last edited by martim
                @mfalkvidd
                Yes I did. 47uF
                • M martim
                  @mfalkvidd
                  Yes I did. 47uF
                  tekkaT
                  tekkaT
                  tekka
                  wrote on last edited by tekka
                  @martim Please post the full debug log from your GW and node.
                    martim
                    GW:
                    0;255;3;0;9;TSM:INIT
                    0;255;3;0;9;TSM:RADIO:OK
                    0;255;3;0;9;TSM:GW MODE
                    0;255;3;0;9;TSM:READY
                    scandone
                    f 0, scandone
                    state: 0 -> 2 (b0)
                    state: 2 -> 3 (0)
                    state: 3 -> 5 (10)
                    add 0
                    aid 11
                    cnt
                    connected with CycloneIT, channel 11
                    dhcp client start...
                    ...ip:192.168.10.218,mask:255.255.255.0,gw:192.168.10.1
                    .IP: 192.168.10.218
                    pm open,type:2 0
                    0;255;3;0;9;TSP:MSG:READ 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                    0;255;3;0;9;TSP:MSG:BC
                    0;255;3;0;9;TSP:MSG:FPAR REQ (sender=255)
                    0;255;3;0;9;TSP:CHKUPL:OK
                    0;255;3;0;9;TSP:MSG:GWL OK
                    0;255;3;0;9;TSP:MSG:SEND 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=bc:0
                    0;255;3;0;9;TSP:MSG:READ 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
                    0;255;3;0;9;TSP:SANCHK:OK
                    Node:
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSM:FPAR
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:ID
                    TSM:ID
                    TSM:ID
                    !TSM:FAILURE
                    TSM:PDT
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:ID
                    TSM:ID
                    TSM:ID
                    !TSM:FAILURE
                    TSM:PDT
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:ID
                    TSM:ID
                    TSM:ID
                    !TSM:FAILURE
                    TSM:PDT
                    • M martim
                      GW:
                      scandone
                      f 0, scandone
                      state: 0 -> 2 (b0)
                      state: 2 -> 3 (0)
                      state: 3 -> 5 (10)
                      add 0
                      aid 11
                      cnt
                      .IP: 192.168.10.218
                      pm open,type:2 0
                      Node:
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSM:FPAR
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR:OK
                      TSM:ID
                      TSM:ID
                      TSM:ID
                      TSM:ID
                      !TSM:FAILURE
                      TSM:PDT
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSM:FPAR:OK
                      TSM:ID
                      TSM:ID
                      TSM:ID
                      TSM:ID
                      !TSM:FAILURE
                      TSM:PDT
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR:OK
                      TSM:ID
                      TSM:ID
                      TSM:ID
                      TSM:ID
                      !TSM:FAILURE
                      TSM:PDT
                      @martim the node is still requesting an ID. Are you sure you moved the #define NODE_ID 123 ?
                        martim
                        My Sensor code:
                           REVISION HISTORY
                           Version 1.0 - Henrik EKblad
                           DESCRIPTION
                           This sketch provides an example how to implement a distance sensor using HC-SR04
                           http://www.mysensors.org/build/distance
                        #define OPEN 1
                        #define CLOSE 0
                        #define NODE_ID 123
                            sleep(10000);
                        • M martim
                          My Sensor code:
                             REVISION HISTORY
                             DESCRIPTION
                          #define OPEN 1
                          #define CLOSE 0
                          #define NODE_ID 123
                              sleep(10000);
                          tekkaT
                          tekkaT
                          tekka
                          @martim uupps, my bad - should be MY_NODE_ID instead of NODE_ID
                          • tekkaT tekka
                            martim
                            @tekka
                            That was indeed the trick :joy: :thumbsup: This is really awesome.
                            Final question. The Node register know with the GW if I am correct. And when I change a port how fast is this send to the gateway?
                            I would like to connect a doorbell and use an interrupt when someone is pressing on the doorbell.
                            • M martim
                              @tekka
                              @martim the current code sleeps 10 seconds. So it might take up to 10 seconds before a press is registered. The sleep can be modified to wake on interrupt instead. See https://www.mysensors.org/download/sensor_api_20#sleeping for general i formation about the sleep function and https://www.mysensors.org/build/motion for an example that wakes on interrupt.
                                martim
                                @mfalkvidd
                                Thanks! Some study to do :)
                                12.5k
