  2. Bug Reports
  3. [solved] RFM69 based nodes unable to report Lib Version
51 Posts 8 Posters 24.8k Views 5 Watching
  • korttomaK
    korttomaK
    korttoma
    It is alive :D
    I managed to get a W5100 RFM69 Gateway working.
    I wanted minimal change to the w5100.h so I just added the cli(); and sei(); macros.
    (I would still like to see your sketch @jpaulin to compare)
    There are some random failures in the RF communication but these might be because of the breadboard setup. I just have one temp sensor sending in some value now to test with.
    • Tomas
    J 1 Reply Last reply
    • korttomaK korttoma
      It is alive :D
      J
      J
      jpaulin
      @korttoma
      Here's my sketch. It's an MQTT GW with LEDs.
       * Version 1.0 - Henrik Ekblad
       * The W5100 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
       * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
       * LED purposes:
       * - RX (yellow) - blink fast on radio message recieved. In inclusion mode will blink fast only on presentation received
       * - TX (green) - blink fast on radio message transmitted. In inclusion mode will blink slowly
       * - ERR (red) - fast blink on error during transmission error or receive crc error
      //#define MY_RADIO_NRF24
      #define MY_RADIO_RFM69
      #define MY_RFM69_FREQUENCY   RF69_433MHZ
      #define MY_MQTT_PUBLISH_TOPIC_PREFIX "my_RFM69_gw1-out"
      #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "my_RFM69_gw1-in"
      // Set MQTT client id
      #define MY_MQTT_CLIENT_ID "mysensors_RFM69-1"
      //#define MY_W5100_SPI_EN 4
      // Enable these if your MQTT broker requires username/password
      #define MY_IP_ADDRESS 192,168,1,93
      #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 90
      #define MY_PORT 1883
      // Set blinking period
      #define MY_DEFAULT_LED_BLINK_PERIOD 50
      // Flash leds on rx/tx/err
      #define MY_DEFAULT_ERR_LED_PIN A3  // Error led pin
      #define MY_DEFAULT_RX_LED_PIN  A2  // Receive led pin
      #define MY_DEFAULT_TX_LED_PIN  A0  // Transmit led pin
      #include <Ethernet.h>    // modified for W5500 module and with CS pin = D7 (Default CS pin D10 is already used by RFM69W module)
      korttomaK 1 Reply Last reply
        #29
        little side note about the rfm69 driver : it will use spitransaction which should solve this, with some noint/int should be ok. (https://www.arduino.cc/en/Tutorial/SPITransaction)
        • J jpaulin
          @korttoma
           * LED purposes:
          korttomaK
          korttomaK
          korttoma
          @jpaulin Thanks, not much different from my sketch I see:
          #define MY_RF69_SPI_CS 9
          #define MY_GATEWAY_W5100
          #define MY_IP_ADDRESS 192,168,1,25   // If this is disabled, DHCP is used to retrieve address
          #define MY_PORT 5003
          //#define MY_LEDS_BLINKING_FEATURE
          // Enable inclusion mode
          //#define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
          #if defined(MY_USE_UDP)
            #include <EthernetUdp.h>
          void setup(){
          It has been running for a few hours now without issues. Gona try adding the buttons and relays tomorrow.
          • Tomas
          • korttomaK
            korttomaK
            korttoma
            #31
            Adding the relays and buttons seems to work fine also. I will go with this setup now until there is a "Official" solution for the GatewayW5100RFM69.
             * Version 1.0 - Henrik EKblad
             * LED purposes:
            #define SN "EthGW/RFM69 Rele Button"
            #define SV "1.0"
            //#define MY_W5100_SPI_EN 10
            // radio on the same spi bus.
            // Enable to UDP
            //#define MY_USE_UDP
            #define RELAY_ON 0                      // switch around for ACTIVE LOW / ACTIVE HIGH relay
            #define RELAY_OFF 1
            #define noRelays 4                     //2-4
            const int relayPin[] = {14, 15, 16, 17};       //  switch around pins to your desire
            const int buttonPin[] = {6, 7, 4, 5};   //  switch around pins to your desire
            class Relay             // relay class, store all relevant data (equivalent to struct)
              public:
                int buttonPin;                   // physical pin number of button
                int relayPin;             // physical pin number of relay
                boolean relayState;               // relay status (also stored in EEPROM)
            Relay Relays[noRelays];
            Bounce debouncer[noRelays];
            MyMessage msg[noRelays];
              wait(100);
              for (int i = 0; i < noRelays; i++) {
                Relays[i].buttonPin = buttonPin[i];              // assign physical pins
                msg[i].type = V_LIGHT;
                wait(100);
                Relays[i].relayState = loadState(i);                               // retrieve last values from EEPROM
                digitalWrite(Relays[i].relayPin, Relays[i].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
                send(msg[i].set(Relays[i].relayState ? true : false));                 // make controller aware of last status
                wait(50);
                debouncer[i].interval(30);
                wait(50);
              sendSketchInfo(SN, SV);
              wait(100);
                present(i, S_LIGHT);                               // present sensor to gateway
              wait(100);
              for (byte i = 0; i < noRelays; i++) {
                if (debouncer[i].update()) {
                  if ( value == LOW) {
                    // save sensor state in EEPROM (location == sensor number)
                    saveState( i, Relays[i].relayState );
              //wait(20);
                if (message.sensor < noRelays) {          // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
                  digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
                  saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
              wait(20);
            • Tomas
            J 2 Replies Last reply
               * LED purposes:
              #define SV "1.0"
              // Enable to UDP
              #define RELAY_OFF 1
                public:
                wait(100);
                  wait(100);
                  wait(50);
                  wait(50);
                wait(100);
                wait(100);
                //wait(20);
                wait(20);
              J
              J
              jpaulin
              @korttoma Excellent news. So now we are at least two with a stable RFM69-Ethernet-GW. :smiley:
                 * LED purposes:
                #define SV "1.0"
                // Enable to UDP
                #define RELAY_OFF 1
                  public:
                  wait(100);
                    wait(100);
                    wait(50);
                    wait(50);
                  wait(100);
                  wait(100);
                  //wait(20);
                  wait(20);
                J
                J
                jpaulin
                wrote on last edited by jpaulin
                #33
                @korttoma Sharing a pair of photos of my gw. Became pretty neat, I think. It's parked permanently beside the WiFi Router.
                • korttomaK
                  korttomaK
                  korttoma
                  I've seen pictures of your GW in another thread, it is very nice and professional @jpaulin
                  I stil have some parts missing from my GW build so I only have the breadboard setup right now.
                  • Tomas
                    #35
                    @TimO
                    Hi.
                    Sorry for delay, so much projects.
                    As you tried to make a push, when you'll have some time, could you tell me if SOFTSPI is working please ? i'm a bit lazy to make a w5100 setup, as i'm not using it.
                    https://github.com/scalz/Mysensors/tree/rfm69_update
                    Set of defines is
                    #define MY_RFM69_FREQUENCY   RFM69_868MHZ // RFM69_433MHZ for 433MHz, RFM69_868MHZ for default 868MHz or RF69_915MHZ for 915MHz
                    //#define MY_IS_RFM69HW // uncomment this if you're running the RFM69HW model
                    //#define MY_RFM69_TX_POWER_DBM (5) // default
                    //#define MY_RFM69_ATC_TARGET_RSSI_DBM	(-80) // default
                    //#define MY_RFM69_ATC_MODE_DISABLED
                    //#define MY_RFM69_NETWORKID     100  // default
                    //#define MY_RFM69_RST_PIN 9
                    //#define MY_RFM69_IRQ_PIN 5
                    //#define MY_RFM69_SPI_CS 23
                    // For Advanced users
                    //#define MY_RFM69_SPI_MAX_SPEED (4000000ul)
                    //#define MY_RFM69_BITRATE_MSB RFM69_BITRATEMSB_55555  // Bitrate is for users who knows what they're doing as it can impact your network reliabilty, and read the datasheet/registers.h file to get the right bitrate.
                    //#define MY_RFM69_BITRATE_LSB RFM69_BITRATELSB_55555  // So bitrates are hardwritten values
                    // Before radio sending, random delay, to be sure that two nodes which were waiting for free channel, doesn't send at same time and collide
                    // delay = MY_RFM69_CSMA_ADD_DELAY_BASE * random(1,MY_RFM69_CSMA_ADD_DELAY_COUNT)
                    //#define MY_RFM69_CSMA_ADD_DELAY_BASE 50  // default 50ms
                    //#define MY_RFM69_CSMA_ADD_DELAY_COUNT 10 // default max 10 counts
                    Note these are my defines for my ATSAM gw.
                    You can also send RSSI and powerlevel as internal msg by doing, like sendBattery function works.
                    Example:
                    Function: sendRadioStats
                    Purpose : Sends radio rssi and powerlevel values
                    Input   : - force : Forces transmission of a value (even if it's the same as previous measurement)
                                   - ack : boolean. true if ack needed
                    Output  : - true if transmission occured
                    Comments:
                    bool sendRadioStats(bool force, bool ack)
                       static int16_t lastRssi=0;
                       int16_t rssiVal = transportGetRSSI();
                       uint8_t txPower = transportGetTxPower();
                       if (abs(lastRssi - rssiVal) >= 10 || force == true) {
                          force = sendSignalStrength(rssiVal, ack);
                          force |= sendTXPowerLevel(txPower, ack);
                          lastRssi = rssiVal;
                       return force;
                    • scalzS scalz
                      @TimO
                      Hi.
                      Set of defines is
                      Example:
                      Comments:
                            lastRssi = rssiVal;
                         return force;
                      TimO
                      Hey @scalz !
                      My last test a few days ago was not successful with SoftSPI but I did not have the time to debug it. I'll give it another try!
                        @TimO
                        oki thx. Perhaps it was because of the w5100 CS define? i'll take a look.
                        • scalzS scalz
                          @TimO
                          TimO
                          @scalz
                          Okay, I found a little bit time to test and to check the wiring I've build a breadboard version.
                          Here's my sketch:
                          // signing
                          //#define MY_SIGNING_SOFT
                            #define MY_SOFTSPI
                            #define MY_SOFT_SPI_SCK_PIN A0
                            #define MY_SOFT_SPI_MISO_PIN A2
                            #define MY_SOFT_SPI_MOSI_PIN A1
                          #define MY_RF69_SPI_CS 5
                          #define MY_RF69_IRQ_PIN 2
                          // Enable to UDP
                          #define MY_IP_ADDRESS 192,168,2,222   // If this is disabled, DHCP is used to retrieve address
                          #define MY_MAC_ADDRESS 0xDF, 0xCD, 0xCD, 0xAF, 0xFE, 0xED
                          Nothing that fancy. Some defines are using RFM69 while others use RF69 (IRQ, CS PIN).
                          The init is not working. I've inserted a serial print to see where it stops working. Here's the serial output:
                          0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGA--,VER=2.1.0-beta
                          0;255;3;0;9;TSM:INIT
                          0;255;3;0;9;TSF:WUR:MS=0
                          before
                          0;255;3;0;9;TSM:FAIL:CNT=1
                          0;255;3;0;9;TSM:FAIL:PDT
                          0;255;3;0;9;TSM:FAIL:RE-INIT
                          It stops there. No more retries, nothing more.
                          Here's were the error seems to occure (line 116 of RFM69.cpp):
                          setHighPower(_isRFM69HW); // called regardless if it's a RFM69W or RFM69HW
                          	setMode(RF69_MODE_STANDBY);
                          	start = millis();
                          		Serial.println("before");
                          	while (((readReg(REG_IRQFLAGS1) & RF_IRQFLAGS1_MODEREADY) == 0x00) && millis()-start < timeout) {
                          		yield();
                          	} // wait for ModeReady
                          	if (millis()-start >= timeout) {
                          		return false;
                          		Serial.println("after");
                          	attachInterrupt(_interruptNum, RFM69::isr0, RISING);
                          	selfPointer = this;
                          	_address = nodeID;
                          	return true;
                          The second debug output "after" is never reached.
                          If I disable RFM69 in the sketch and upload it, the ethernet part comes up just fine. The gateway is reachable per ping and telnet.
                          I've tested against my initial implementation: https://github.com/tobof/MySensors
                          The gateway comes up and is able to receive messages.
                          Here's the debug:
                          0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGA--,VER=2.0.1-beta
                          0;255;3;0;9;TSM:INIT:TSP OK
                          0;255;3;0;9;TSM:INIT:GW MODE
                          0;255;3;0;9;TSM:READY
                          IP: 192.168.2.222
                          0;255;3;0;9;MCO:BGN:STP
                          0;255;3;0;9;MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
                          0;255;3;0;9;TSF:MSG:READ,111-111-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                          0;255;3;0;9;TSF:MSG:BC
                          0;255;3;0;9;TSF:MSG:FPAR REQ,ID=111
                          0;255;3;0;9;TSF:CKU:OK,FCTRL
                          0;255;3;0;9;TSF:MSG:GWL OK
                          0;255;3;0;9;TSF:MSG:SEND,0-0-111-111,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                          0;255;3;0;9;TSF:MSG:READ,111-111-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                          0;255;3;0;9;TSF:MSG:PINGED,ID=111,HP=1
                          0;255;3;0;9;TSF:MSG:SEND,0-0-111-111,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                          0;255;3;0;9;TSF:MSG:READ,111-111-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
                          0;255;3;0;9;TSF:MSG:SEND,0-0-111-111,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                          0;255;3;0;9;TSF:MSG:READ,111-111-0,s=255,c=0,t=18,pt=0,l=5,sg=0:2.0.0
                          0;255;3;0;9;TSF:MSG:READ,111-111-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                          0;255;3;0;9;TSF:MSG:READ,111-111-0,s=255,c=3,t=11,pt=0,l=5,sg=0:Relay
                          0;255;3;0;9;TSF:MSG:READ,111-111-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                          0;255;3;0;9;TSF:MSG:READ,111-111-0,s=1,c=0,t=3,pt=0,l=0,sg=0:
                          0;255;3;0;9;TSF:MSG:READ,111-111-0,s=2,c=0,t=3,pt=0,l=0,sg=0:
                          0;255;3;0;9;TSF:MSG:READ,111-111-0,s=3,c=0,t=3,pt=0,l=0,sg=0:
                          0;255;3;0;9;TSF:MSG:READ,111-111-0,s=4,c=0,t=3,pt=0,l=0,sg=0:
                          0;255;3;0;9;TSF:MSG:READ,111-111-0,s=5,c=0,t=3,pt=0,l=0,sg=0:
                          0;255;3;0;9;TSF:MSG:READ,111-111-0,s=6,c=0,t=3,pt=0,l=0,sg=0:
                          0;255;3;0;9;TSF:MSG:READ,111-111-0,s=7,c=0,t=3,pt=0,l=0,sg=0:
                          0;255;3;0;9;TSF:MSG:READ,111-111-0,s=8,c=0,t=3,pt=0,l=0,sg=0:
                          0;255;3;0;9;TSF:MSG:READ,111-111-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                          0;255;3;0;9;TSF:MSG:SEND,0-0-111-111,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                          0;255;3;0;9;TSF:PNG:SEND,TO=0
                          So I suppose the wiring is okay. I hope this helps!
                            #39
                            @TimO
                            Your screenshots are based on the old driver ;)
                            You need to use "rfm69_update branch" on my repo. the whole repo. It's based on dev branch, few days ago, with the latest driver.
                            Thx for your tests and feedbacks :)
                            • scalzS scalz
                              @TimO
                              TimO
                              @scalz dammit! :-(
                              Okay, so this time the compiler is throwing errors.
                              Here are the ones I ruled out:
                              diff --git a/drivers/RFM69/RFM69.cpp b/drivers/RFM69/RFM69.cpp
                              index 10d8369..f068ef1 100644
                              --- a/drivers/RFM69/RFM69.cpp
                              +++ b/drivers/RFM69/RFM69.cpp
                              @@ -79,16 +79,20 @@ LOCAL void RFM69_prepareSPITransaction(void)
                                  // set RFM69 SPI settings
                              +   #if !defined(MY_SOFTSPI) && defined(SPI_HAS_TRANSACTION)
                                  _SPI.setDataMode(RFM69_SPI_DATA_MODE);
                                  _SPI.setBitOrder(RFM69_SPI_DATA_ORDER);
                                  _SPI.setClockDivider(RFM69_SPI_MAX_SPEED); // decided to slow down from DIV2 after SPI stalling in some instances, especially visible on mega1284p when RFM69 and FLASH chip both present
                              +   #endif
                               LOCAL void RFM69_concludeSPITransaction(void)
                              -#ifdef SPI_HAS_TRANSACTION
                              -   _SPI.endTransaction();
                              +#ifdef SPI_HAS_TRANSACTION
                              +      _SPI.endTransaction();
                              +   #endif
                                  // restore SPI settings to what they were before talking to RFM69
                               #if defined (SPCR) && defined (SPSR)
                              @@ -199,7 +203,9 @@ LOCAL bool RFM69_initialise(const float frequency)
                                  // IRQ
                                  pinMode(RFM69_IRQ_DIO_PIN, INPUT);
                               #if defined (SPI_HAS_TRANSACTION) && !defined (ESP8266)
                              -   _SPI.usingInterrupt(digitalPinToInterrupt(RFM69_IRQ_DIO_PIN));
                              +      _SPI.usingInterrupt(digitalPinToInterrupt(RFM69_IRQ_DIO_PIN));
                              +   #endif
                                  attachInterrupt(digitalPinToInterrupt(RFM69_IRQ_DIO_PIN), RFM69_interruptHandler, RISING);
                              @@ -1120,4 +1126,4 @@ void readAllRegs(void)
                              \ No newline at end of file
                              diff --git a/drivers/RFM69/RFM69.h b/drivers/RFM69/RFM69.h
                              index 433d6e1..8326f6e 100644
                              --- a/drivers/RFM69/RFM69.h
                              +++ b/drivers/RFM69/RFM69.h
                              @@ -78,11 +78,13 @@
                               #define RFM69_SPI_CS		(SS)
                              +#define RFM69_SPI_DATA_MODE		SPI_MODE0		//!< SPI mode
                               // SPI settings
                               #if defined (ARDUINO) && !defined (__arm__) && !defined (_SPI)
                               #if defined(MY_SOFTSPI)
                              -SoftSPI<MY_SOFT_SPI_MISO_PIN, MY_SOFT_SPI_MOSI_PIN, MY_SOFT_SPI_SCK_PIN, MY_RFM69_SPI_DATA_MODE> _SPI;
                              +SoftSPI<MY_SOFT_SPI_MISO_PIN, MY_SOFT_SPI_MOSI_PIN, MY_SOFT_SPI_SCK_PIN, RFM69_SPI_DATA_MODE> _SPI;
                               #define _SPI SPI
                              @@ -100,7 +102,7 @@ extern HardwareSPI SPI;		//!< SPI
                               #define RFM69_SPI_DATA_ORDER	MSBFIRST		//!< SPI data order
                              -#define RFM69_SPI_DATA_MODE		SPI_MODE0		//!< SPI mode
                               #if !defined(MY_RFM69_SPI_MAX_SPEED)
                               #define RFM69_SPI_MAX_SPEED		(2000000ul)	//!< SPI speed
                              @@ -524,4 +526,4 @@ void readAllRegs(void);
                              (I only have time for a diff, sorry)
                              After the changes it gets stuck here:
                              In file included from /home/toberfoe/Arduino/libraries/MySensors/MySensors.h:306:0,
                                               from /home/toberfoe/ownCloud/workspace/Testumgebung/Gateway-5100-RFM69/GatewayW5100/GatewayW5100.ino:100:
                              /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp:25:1: error: 'RFM69' does not name a type
                               RFM69 _radio(MY_RF69_SPI_CS, MY_RF69_IRQ_PIN, MY_RFM69HW, MY_RF69_IRQ_NUM);
                              /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp: In function 'bool transportInit()':
                              /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp:32:6: error: '_radio' was not declared in this scope
                                if (_radio.initialize(MY_RFM69_FREQUENCY, _address, MY_RFM69_NETWORKID)) {
                              /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp: In function 'void transportSetAddress(uint8_t)':
                              /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp:47:2: error: '_radio' was not declared in this scope
                                _radio.setAddress(address);
                              /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp: In function 'bool transportSend(uint8_t, const void*, uint8_t)':
                              /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp:57:9: error: '_radio' was not declared in this scope
                                return _radio.sendWithRetry(to,data,len);
                              /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp: In function 'bool transportAvailable()':
                              /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp:62:9: error: '_radio' was not declared in this scope
                                return _radio.receiveDone();
                              /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp: In function 'uint8_t transportReceive(void*)':
                              /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp:73:28: error: '_radio' was not declared in this scope
                                memcpy(data,(const void *)_radio.DATA, _radio.DATALEN);
                              /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp: In function 'void transportPowerDown()':
                              /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp:85:2: error: '_radio' was not declared in this scope
                                _radio.sleep();
                              exit status 1
                              I have no time to investigate it further till saturday. :-/
                                this is because you have not completely updated your Mysensors folder.
                                The driver only is not enough because there are changes in others files like MyTransportRFM69.cpp, MyConfig etc..
                                T J 2 Replies Last reply
                                • scalzS scalz
                                  TimO
                                  @scalz I'm using a clone of your github repo and changed to rfm69_update branch. I have not replaced single files.
                                    #43
                                    @TimO
                                    Oh my bad!
                                    I didn't update MyTransportRFM69.cpp on my git (because i've two branch locally, and forgot about this one..). I've just pushed it. Downloaded my repo again, and it compiles fine now ;)
                                    sorry for waste of time, pff :blush:
                                    Also, if someone wants to try using W5100 and RFM69 on the same SPI bus (so not in softspi mode). I'm interested to know if it's working. As W5100 and the new RFM69 are using SPI transactions, and in RFM69 it now uses the spi.usinginterrupts , so it might work.
                                    Note: as it's hardwritten in w5100 lib (not cool!), easier for tests to use
                                    • D10 for your w5100 SPI CS
                                    • what you want for your RFM69 SPI CS. example for D6, using #define MY_RFM69_SPI_CS 6
                                    korttomaK J 2 Replies Last reply
                                    • T
                                      TimO
                                      Okay, so next run. :D
                                      I've pulled your repo and tested with the sketch above. The compile does not work for the GatewayW5100 example sketch either.
                                      I have to apply the diff I've posted above to make it compile. With the diff applied the gateway starts, is pingable and reachable via telnet but does not receive any packets via RFM69.
                                      My guess: SoftSPI has no methods "usingInterrupt()", "beginTransaction()", and "endTransaction()" and that's the reason why no packets are received. In the current implementation these methods were not used.
                                      I suppose there needs to be an implementation without transactions for SoftSPI?
                                      Here's the output of the compile without the diff applied:
                                      n file included from /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp:36:0,
                                                       from /home/toberfoe/Arduino/libraries/MySensors/MySensors.h:305,
                                                       from /tmp/arduino_modified_sketch_920203/GatewayW5100.ino:116:
                                      /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.h:85:74: error: 'MY_RFM69_SPI_DATA_MODE' was not declared in this scope
                                      /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.h:85:96: error: template argument 4 is invalid
                                      /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.h:85:102: error: invalid type in declaration before ';' token
                                      In file included from /home/toberfoe/Arduino/libraries/MySensors/MySensors.h:305:0,
                                      /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp: In function 'void RFM69_prepareSPITransaction()':
                                      /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp:82:9: error: request for member 'setDataMode' in '_SPI', which is of non-class type 'int'
                                      /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp:83:9: error: request for member 'setBitOrder' in '_SPI', which is of non-class type 'int'
                                      /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp:84:9: error: request for member 'setClockDivider' in '_SPI', which is of non-class type 'int'
                                      /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp: In function 'void RFM69_concludeSPITransaction()':
                                      /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp:91:9: error: request for member 'endTransaction' in '_SPI', which is of non-class type 'int'
                                      /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp: In function 'uint8_t RFM69_spiMultiByteTransfer(uint8_t, uint8_t*, uint8_t, bool)':
                                      /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp:114:18: error: request for member 'transfer' in '_SPI', which is of non-class type 'int'
                                          status = _SPI.transfer(cmd);
                                      /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp:117:24: error: request for member 'transfer' in '_SPI', which is of non-class type 'int'
                                                status = _SPI.transfer((uint8_t)0x00);
                                      /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp:122:24: error: request for member 'transfer' in '_SPI', which is of non-class type 'int'
                                                status = _SPI.transfer(*current++);
                                      /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp: In function 'bool RFM69_initialise(float)':
                                      /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp:190:9: error: request for member 'begin' in '_SPI', which is of non-class type 'int'
                                          _SPI.begin();
                                      /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp:202:9: error: request for member 'usingInterrupt' in '_SPI', which is of non-class type 'int'
                                      /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp: In function 'void RFM69_interruptHandler()':
                                      /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp:232:15: error: request for member 'transfer' in '_SPI', which is of non-class type 'int'
                                                _SPI.transfer(RFM69_REG_FIFO & RFM69_READ_REGISTER);
                                      /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp:239:31: error: request for member 'transfer' in '_SPI', which is of non-class type 'int'
                                                   *current++ = _SPI.transfer((uint8_t)0x00);
                                      exit status 1
                                      Fehler beim Kompilieren für das Board Arduino Nano.
                                      • scalzS scalz
                                        @TimO
                                        Oh my bad!
                                        korttomaK
                                        korttomaK
                                        korttoma
                                        @scalz both @jpaulin and I have had success with using W5100 and RFM69 on the same SPI bus. You can read about it earlier in this thread. I thing I will use this solution because I need the extra IO pins for local relays and buttons on the GW.
                                        • Tomas
                                        • scalzS scalz
                                          @TimO
                                          Oh my bad!
                                          J
                                          J
                                          jpaulin
                                          #46
                                          @scalz I downloaded your testbed and loaded a node with a basic script. It compiles ok, but I can't reach my gateway any longer. Do I have to update the gw as well? I'm using an ATmega328 with an RFM69W, CS=D10 and IRQ=D2 (Anarduino).
                                          Looks inspiring with ATC, debug_verbose, getRSSI() and other improvements.
                                          Script used:
                                          // Enable debug prints
                                          #define MY_RFM69_FREQUENCY   RFM69_433MHZ  // Note. New format
                                          #define MY_NODE_ID 7
                                          unsigned long SLEEP_TIME = 5000;         // Sleep time between reads (in milliseconds)
                                          #define CHILD_ID 1
                                          MyMessage msg(CHILD_ID, V_VAR1);
                                          int count = 0;
                                            sendSketchInfo("Test", "1.0");
                                            present(CHILD_ID, S_CUSTOM);
                                              send(msg.set(count));
                                              count++;
                                              if (count > 1000) {
                                                count=0;
                                            wait(SLEEP_TIME);                       //sleep a bit.
                                          Debug dump:
                                          0 MCO:BGN:INIT NODE,CP=RRNNA--,VER=2.1.0-beta
                                          4 TSM:INIT
                                          4 TSF:WUR:MS=0
                                          6 RFM69:INIT
                                          7 RFM69:IRQ PIN=2,CS PIN=10
                                          10 RFM69:PTX:LEVEL=5 dBm,reg=23
                                          13 TSM:INIT:TSP OK
                                          15 TSM:INIT:STATID=7
                                          16 TSF:SID:OK,ID=7
                                          18 TSM:FPAR
                                          19 RFM69:SWR:Sending,to=255,retry=0
                                          275 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          2282 !TSM:FPAR:NO REPLY
                                          2284 TSM:FPAR
                                          2285 RFM69:SWR:Sending,to=255,retry=0
                                          2691 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          4698 !TSM:FPAR:NO REPLY
                                          4700 TSM:FPAR
                                          4701 RFM69:SWR:Sending,to=255,retry=0
                                          5007 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          7014 !TSM:FPAR:NO REPLY
                                          7016 TSM:FPAR
                                          7017 RFM69:SWR:Sending,to=255,retry=0
                                          7173 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          9180 !TSM:FPAR:FAIL
                                          9181 TSM:FAIL:CNT=1
                                          9183 TSM:FAIL:PDT
                                          9185 RFM69:power down
