  2. Bug Reports
  3. [solved] RFM69 based nodes unable to report Lib Version
51 Posts 8 Posters 24.8k Views 5 Watching
  • korttomaK
    korttomaK
    korttoma
    #31
    Adding the relays and buttons seems to work fine also. I will go with this setup now until there is a "Official" solution for the GatewayW5100RFM69.
     * Version 1.0 - Henrik EKblad
     * LED purposes:
    #define SN "EthGW/RFM69 Rele Button"
    #define SV "1.0"
    //#define MY_RADIO_NRF24
    #define MY_RADIO_RFM69
    #define MY_RF69_SPI_CS 9
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 10
    // radio on the same spi bus.
    // Enable to UDP
    //#define MY_USE_UDP
    #define MY_IP_ADDRESS 192,168,1,25   // If this is disabled, DHCP is used to retrieve address
    #define MY_PORT 5003
    // Flash leds on rx/tx/err
    //#define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // Enable inclusion mode
    //#define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
    #if defined(MY_USE_UDP)
      #include <EthernetUdp.h>
    #include <Ethernet.h>
    #define RELAY_ON 0                      // switch around for ACTIVE LOW / ACTIVE HIGH relay
    #define RELAY_OFF 1
    #define noRelays 4                     //2-4
    const int relayPin[] = {14, 15, 16, 17};       //  switch around pins to your desire
    const int buttonPin[] = {6, 7, 4, 5};   //  switch around pins to your desire
    class Relay             // relay class, store all relevant data (equivalent to struct)
      public:
        int buttonPin;                   // physical pin number of button
        int relayPin;             // physical pin number of relay
        boolean relayState;               // relay status (also stored in EEPROM)
    Relay Relays[noRelays];
    Bounce debouncer[noRelays];
    MyMessage msg[noRelays];
      wait(100);
      for (int i = 0; i < noRelays; i++) {
        Relays[i].buttonPin = buttonPin[i];              // assign physical pins
        msg[i].type = V_LIGHT;
        wait(100);
        Relays[i].relayState = loadState(i);                               // retrieve last values from EEPROM
        digitalWrite(Relays[i].relayPin, Relays[i].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
        send(msg[i].set(Relays[i].relayState ? true : false));                 // make controller aware of last status
        wait(50);
        debouncer[i].interval(30);
        wait(50);
      sendSketchInfo(SN, SV);
      wait(100);
        present(i, S_LIGHT);                               // present sensor to gateway
      wait(100);
      for (byte i = 0; i < noRelays; i++) {
        if (debouncer[i].update()) {
          if ( value == LOW) {
            // save sensor state in EEPROM (location == sensor number)
            saveState( i, Relays[i].relayState );
      //wait(20);
        if (message.sensor < noRelays) {          // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
          digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
          saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
      wait(20);
    • Tomas
    J 2 Replies Last reply
    • korttomaK korttoma
       * LED purposes:
      #define SV "1.0"
      // Enable to UDP
      #define RELAY_OFF 1
        public:
        wait(100);
          wait(100);
          wait(50);
          wait(50);
        wait(100);
        wait(100);
        //wait(20);
        wait(20);
      J
      J
      jpaulin
      @korttoma Excellent news. So now we are at least two with a stable RFM69-Ethernet-GW. :smiley:
         * LED purposes:
        #define SV "1.0"
        // Enable to UDP
        #define RELAY_OFF 1
          public:
          wait(100);
            wait(100);
            wait(50);
            wait(50);
          wait(100);
          wait(100);
          //wait(20);
          wait(20);
        J
        J
        jpaulin
        wrote on last edited by jpaulin
        #33
        @korttoma Sharing a pair of photos of my gw. Became pretty neat, I think. It's parked permanently beside the WiFi Router.
        • korttomaK
          korttomaK
          korttoma
          I've seen pictures of your GW in another thread, it is very nice and professional @jpaulin
          I stil have some parts missing from my GW build so I only have the breadboard setup right now.
          • Tomas
            #35
            @TimO
            Hi.
            Sorry for delay, so much projects.
            As you tried to make a push, when you'll have some time, could you tell me if SOFTSPI is working please ? i'm a bit lazy to make a w5100 setup, as i'm not using it.
            https://github.com/scalz/Mysensors/tree/rfm69_update
            Set of defines is
            #define MY_RFM69_FREQUENCY   RFM69_868MHZ // RFM69_433MHZ for 433MHz, RFM69_868MHZ for default 868MHz or RF69_915MHZ for 915MHz
            //#define MY_IS_RFM69HW // uncomment this if you're running the RFM69HW model
            //#define MY_RFM69_TX_POWER_DBM (5) // default
            //#define MY_RFM69_ATC_TARGET_RSSI_DBM	(-80) // default
            //#define MY_RFM69_ATC_MODE_DISABLED
            //#define MY_RFM69_NETWORKID     100  // default
            //#define MY_RFM69_RST_PIN 9
            //#define MY_RFM69_IRQ_PIN 5
            //#define MY_RFM69_SPI_CS 23
            // For Advanced users
            //#define MY_RFM69_SPI_MAX_SPEED (4000000ul)
            //#define MY_RFM69_BITRATE_MSB RFM69_BITRATEMSB_55555  // Bitrate is for users who knows what they're doing as it can impact your network reliabilty, and read the datasheet/registers.h file to get the right bitrate.
            //#define MY_RFM69_BITRATE_LSB RFM69_BITRATELSB_55555  // So bitrates are hardwritten values
            // Before radio sending, random delay, to be sure that two nodes which were waiting for free channel, doesn't send at same time and collide
            // delay = MY_RFM69_CSMA_ADD_DELAY_BASE * random(1,MY_RFM69_CSMA_ADD_DELAY_COUNT)
            //#define MY_RFM69_CSMA_ADD_DELAY_BASE 50  // default 50ms
            //#define MY_RFM69_CSMA_ADD_DELAY_COUNT 10 // default max 10 counts
            Note these are my defines for my ATSAM gw.
            You can also send RSSI and powerlevel as internal msg by doing, like sendBattery function works.
            Example:
            Function: sendRadioStats
            Purpose : Sends radio rssi and powerlevel values
            Input   : - force : Forces transmission of a value (even if it's the same as previous measurement)
                           - ack : boolean. true if ack needed
            Output  : - true if transmission occured
            Comments:
            bool sendRadioStats(bool force, bool ack)
               static int16_t lastRssi=0;
               int16_t rssiVal = transportGetRSSI();
               uint8_t txPower = transportGetTxPower();
               if (abs(lastRssi - rssiVal) >= 10 || force == true) {
                  force = sendSignalStrength(rssiVal, ack);
                  force |= sendTXPowerLevel(txPower, ack);
                  lastRssi = rssiVal;
               return force;
            • scalzS scalz
              @TimO
              Hi.
              Set of defines is
              Example:
              Comments:
                    lastRssi = rssiVal;
                 return force;
              TimO
              Hey @scalz !
              My last test a few days ago was not successful with SoftSPI but I did not have the time to debug it. I'll give it another try!
                @TimO
                oki thx. Perhaps it was because of the w5100 CS define? i'll take a look.
                • scalzS scalz
                  @TimO
                  TimO
                  @scalz
                  Okay, I found a little bit time to test and to check the wiring I've build a breadboard version.
                  Here's my sketch:
                  // signing
                  //#define MY_SIGNING_SOFT
                  //#define MY_W5100_SPI_EN 4
                    #define MY_SOFTSPI
                    #define MY_SOFT_SPI_SCK_PIN A0
                    #define MY_SOFT_SPI_MISO_PIN A2
                    #define MY_SOFT_SPI_MOSI_PIN A1
                  #define MY_RF69_SPI_CS 5
                  #define MY_RF69_IRQ_PIN 2
                  // Enable to UDP
                  #define MY_IP_ADDRESS 192,168,2,222   // If this is disabled, DHCP is used to retrieve address
                  #define MY_MAC_ADDRESS 0xDF, 0xCD, 0xCD, 0xAF, 0xFE, 0xED
                  Nothing that fancy. Some defines are using RFM69 while others use RF69 (IRQ, CS PIN).
                  The init is not working. I've inserted a serial print to see where it stops working. Here's the serial output:
                  0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGA--,VER=2.1.0-beta
                  0;255;3;0;9;TSM:INIT
                  0;255;3;0;9;TSF:WUR:MS=0
                  before
                  0;255;3;0;9;TSM:FAIL:CNT=1
                  0;255;3;0;9;TSM:FAIL:PDT
                  0;255;3;0;9;TSM:FAIL:RE-INIT
                  It stops there. No more retries, nothing more.
                  Here's were the error seems to occure (line 116 of RFM69.cpp):
                  setHighPower(_isRFM69HW); // called regardless if it's a RFM69W or RFM69HW
                  	setMode(RF69_MODE_STANDBY);
                  	start = millis();
                  		Serial.println("before");
                  	while (((readReg(REG_IRQFLAGS1) & RF_IRQFLAGS1_MODEREADY) == 0x00) && millis()-start < timeout) {
                  		yield();
                  	} // wait for ModeReady
                  	if (millis()-start >= timeout) {
                  		return false;
                  		Serial.println("after");
                  	attachInterrupt(_interruptNum, RFM69::isr0, RISING);
                  	selfPointer = this;
                  	_address = nodeID;
                  	return true;
                  The second debug output "after" is never reached.
                  If I disable RFM69 in the sketch and upload it, the ethernet part comes up just fine. The gateway is reachable per ping and telnet.
                  I've tested against my initial implementation: https://github.com/tobof/MySensors
                  The gateway comes up and is able to receive messages.
                  Here's the debug:
                  0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGA--,VER=2.0.1-beta
                  0;255;3;0;9;TSM:INIT:TSP OK
                  0;255;3;0;9;TSM:INIT:GW MODE
                  0;255;3;0;9;TSM:READY
                  IP: 192.168.2.222
                  0;255;3;0;9;MCO:BGN:STP
                  0;255;3;0;9;MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
                  0;255;3;0;9;TSF:MSG:READ,111-111-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  0;255;3;0;9;TSF:MSG:BC
                  0;255;3;0;9;TSF:MSG:FPAR REQ,ID=111
                  0;255;3;0;9;TSF:CKU:OK,FCTRL
                  0;255;3;0;9;TSF:MSG:GWL OK
                  0;255;3;0;9;TSF:MSG:SEND,0-0-111-111,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                  0;255;3;0;9;TSF:MSG:READ,111-111-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                  0;255;3;0;9;TSF:MSG:PINGED,ID=111,HP=1
                  0;255;3;0;9;TSF:MSG:SEND,0-0-111-111,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                  0;255;3;0;9;TSF:MSG:READ,111-111-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
                  0;255;3;0;9;TSF:MSG:SEND,0-0-111-111,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                  0;255;3;0;9;TSF:MSG:READ,111-111-0,s=255,c=0,t=18,pt=0,l=5,sg=0:2.0.0
                  0;255;3;0;9;TSF:MSG:READ,111-111-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                  0;255;3;0;9;TSF:MSG:READ,111-111-0,s=255,c=3,t=11,pt=0,l=5,sg=0:Relay
                  0;255;3;0;9;TSF:MSG:READ,111-111-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                  0;255;3;0;9;TSF:MSG:READ,111-111-0,s=1,c=0,t=3,pt=0,l=0,sg=0:
                  0;255;3;0;9;TSF:MSG:READ,111-111-0,s=2,c=0,t=3,pt=0,l=0,sg=0:
                  0;255;3;0;9;TSF:MSG:READ,111-111-0,s=3,c=0,t=3,pt=0,l=0,sg=0:
                  0;255;3;0;9;TSF:MSG:READ,111-111-0,s=4,c=0,t=3,pt=0,l=0,sg=0:
                  0;255;3;0;9;TSF:MSG:READ,111-111-0,s=5,c=0,t=3,pt=0,l=0,sg=0:
                  0;255;3;0;9;TSF:MSG:READ,111-111-0,s=6,c=0,t=3,pt=0,l=0,sg=0:
                  0;255;3;0;9;TSF:MSG:READ,111-111-0,s=7,c=0,t=3,pt=0,l=0,sg=0:
                  0;255;3;0;9;TSF:MSG:READ,111-111-0,s=8,c=0,t=3,pt=0,l=0,sg=0:
                  0;255;3;0;9;TSF:MSG:READ,111-111-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                  0;255;3;0;9;TSF:MSG:SEND,0-0-111-111,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                  0;255;3;0;9;TSF:PNG:SEND,TO=0
                  So I suppose the wiring is okay. I hope this helps!
                    #39
                    @TimO
                    Your screenshots are based on the old driver ;)
                    You need to use "rfm69_update branch" on my repo. the whole repo. It's based on dev branch, few days ago, with the latest driver.
                    Thx for your tests and feedbacks :)
                    • scalzS scalz
                      @TimO
                      TimO
                      @scalz dammit! :-(
                      Okay, so this time the compiler is throwing errors.
                      Here are the ones I ruled out:
                      diff --git a/drivers/RFM69/RFM69.cpp b/drivers/RFM69/RFM69.cpp
                      index 10d8369..f068ef1 100644
                      --- a/drivers/RFM69/RFM69.cpp
                      +++ b/drivers/RFM69/RFM69.cpp
                      @@ -79,16 +79,20 @@ LOCAL void RFM69_prepareSPITransaction(void)
                          // set RFM69 SPI settings
                      +   #if !defined(MY_SOFTSPI) && defined(SPI_HAS_TRANSACTION)
                          _SPI.setDataMode(RFM69_SPI_DATA_MODE);
                          _SPI.setBitOrder(RFM69_SPI_DATA_ORDER);
                          _SPI.setClockDivider(RFM69_SPI_MAX_SPEED); // decided to slow down from DIV2 after SPI stalling in some instances, especially visible on mega1284p when RFM69 and FLASH chip both present
                      +   #endif
                       LOCAL void RFM69_concludeSPITransaction(void)
                      -#ifdef SPI_HAS_TRANSACTION
                      -   _SPI.endTransaction();
                      +#ifdef SPI_HAS_TRANSACTION
                      +      _SPI.endTransaction();
                      +   #endif
                          // restore SPI settings to what they were before talking to RFM69
                       #if defined (SPCR) && defined (SPSR)
                      @@ -199,7 +203,9 @@ LOCAL bool RFM69_initialise(const float frequency)
                          // IRQ
                          pinMode(RFM69_IRQ_DIO_PIN, INPUT);
                       #if defined (SPI_HAS_TRANSACTION) && !defined (ESP8266)
                      -   _SPI.usingInterrupt(digitalPinToInterrupt(RFM69_IRQ_DIO_PIN));
                      +      _SPI.usingInterrupt(digitalPinToInterrupt(RFM69_IRQ_DIO_PIN));
                      +   #endif
                          attachInterrupt(digitalPinToInterrupt(RFM69_IRQ_DIO_PIN), RFM69_interruptHandler, RISING);
                      @@ -1120,4 +1126,4 @@ void readAllRegs(void)
                      \ No newline at end of file
                      diff --git a/drivers/RFM69/RFM69.h b/drivers/RFM69/RFM69.h
                      index 433d6e1..8326f6e 100644
                      --- a/drivers/RFM69/RFM69.h
                      +++ b/drivers/RFM69/RFM69.h
                      @@ -78,11 +78,13 @@
                       #define RFM69_SPI_CS		(SS)
                      +#define RFM69_SPI_DATA_MODE		SPI_MODE0		//!< SPI mode
                       // SPI settings
                       #if defined (ARDUINO) && !defined (__arm__) && !defined (_SPI)
                       #if defined(MY_SOFTSPI)
                      -SoftSPI<MY_SOFT_SPI_MISO_PIN, MY_SOFT_SPI_MOSI_PIN, MY_SOFT_SPI_SCK_PIN, MY_RFM69_SPI_DATA_MODE> _SPI;
                      +SoftSPI<MY_SOFT_SPI_MISO_PIN, MY_SOFT_SPI_MOSI_PIN, MY_SOFT_SPI_SCK_PIN, RFM69_SPI_DATA_MODE> _SPI;
                       #define _SPI SPI
                      @@ -100,7 +102,7 @@ extern HardwareSPI SPI;		//!< SPI
                       #define RFM69_SPI_DATA_ORDER	MSBFIRST		//!< SPI data order
                      -#define RFM69_SPI_DATA_MODE		SPI_MODE0		//!< SPI mode
                       #if !defined(MY_RFM69_SPI_MAX_SPEED)
                       #define RFM69_SPI_MAX_SPEED		(2000000ul)	//!< SPI speed
                      @@ -524,4 +526,4 @@ void readAllRegs(void);
                      (I only have time for a diff, sorry)
                      After the changes it gets stuck here:
                      In file included from /home/toberfoe/Arduino/libraries/MySensors/MySensors.h:306:0,
                                       from /home/toberfoe/ownCloud/workspace/Testumgebung/Gateway-5100-RFM69/GatewayW5100/GatewayW5100.ino:100:
                      /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp:25:1: error: 'RFM69' does not name a type
                       RFM69 _radio(MY_RF69_SPI_CS, MY_RF69_IRQ_PIN, MY_RFM69HW, MY_RF69_IRQ_NUM);
                      /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp: In function 'bool transportInit()':
                      /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp:32:6: error: '_radio' was not declared in this scope
                        if (_radio.initialize(MY_RFM69_FREQUENCY, _address, MY_RFM69_NETWORKID)) {
                      /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp: In function 'void transportSetAddress(uint8_t)':
                      /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp:47:2: error: '_radio' was not declared in this scope
                        _radio.setAddress(address);
                      /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp: In function 'bool transportSend(uint8_t, const void*, uint8_t)':
                      /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp:57:9: error: '_radio' was not declared in this scope
                        return _radio.sendWithRetry(to,data,len);
                      /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp: In function 'bool transportAvailable()':
                      /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp:62:9: error: '_radio' was not declared in this scope
                        return _radio.receiveDone();
                      /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp: In function 'uint8_t transportReceive(void*)':
                      /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp:73:28: error: '_radio' was not declared in this scope
                        memcpy(data,(const void *)_radio.DATA, _radio.DATALEN);
                      /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp: In function 'void transportPowerDown()':
                      /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp:85:2: error: '_radio' was not declared in this scope
                        _radio.sleep();
                      exit status 1
                      I have no time to investigate it further till saturday. :-/
                        this is because you have not completely updated your Mysensors folder.
                        The driver only is not enough because there are changes in others files like MyTransportRFM69.cpp, MyConfig etc..
                        T J 2 Replies Last reply
                        • scalzS scalz
                          TimO
                          @scalz I'm using a clone of your github repo and changed to rfm69_update branch. I have not replaced single files.
                            #43
                            @TimO
                            Oh my bad!
                            I didn't update MyTransportRFM69.cpp on my git (because i've two branch locally, and forgot about this one..). I've just pushed it. Downloaded my repo again, and it compiles fine now ;)
                            sorry for waste of time, pff :blush:
                            Also, if someone wants to try using W5100 and RFM69 on the same SPI bus (so not in softspi mode). I'm interested to know if it's working. As W5100 and the new RFM69 are using SPI transactions, and in RFM69 it now uses the spi.usinginterrupts , so it might work.
                            Note: as it's hardwritten in w5100 lib (not cool!), easier for tests to use
                            • D10 for your w5100 SPI CS
                            • what you want for your RFM69 SPI CS. example for D6, using #define MY_RFM69_SPI_CS 6
                            korttomaK J 2 Replies Last reply
                            • T
                              TimO
                              Okay, so next run. :D
                              I've pulled your repo and tested with the sketch above. The compile does not work for the GatewayW5100 example sketch either.
                              I have to apply the diff I've posted above to make it compile. With the diff applied the gateway starts, is pingable and reachable via telnet but does not receive any packets via RFM69.
                              My guess: SoftSPI has no methods "usingInterrupt()", "beginTransaction()", and "endTransaction()" and that's the reason why no packets are received. In the current implementation these methods were not used.
                              I suppose there needs to be an implementation without transactions for SoftSPI?
                              Here's the output of the compile without the diff applied:
                              n file included from /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp:36:0,
                                               from /home/toberfoe/Arduino/libraries/MySensors/MySensors.h:305,
                                               from /tmp/arduino_modified_sketch_920203/GatewayW5100.ino:116:
                              /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.h:85:74: error: 'MY_RFM69_SPI_DATA_MODE' was not declared in this scope
                              /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.h:85:96: error: template argument 4 is invalid
                              /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.h:85:102: error: invalid type in declaration before ';' token
                              In file included from /home/toberfoe/Arduino/libraries/MySensors/MySensors.h:305:0,
                              /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp: In function 'void RFM69_prepareSPITransaction()':
                              /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp:82:9: error: request for member 'setDataMode' in '_SPI', which is of non-class type 'int'
                              /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp:83:9: error: request for member 'setBitOrder' in '_SPI', which is of non-class type 'int'
                              /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp:84:9: error: request for member 'setClockDivider' in '_SPI', which is of non-class type 'int'
                              /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp: In function 'void RFM69_concludeSPITransaction()':
                              /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp:91:9: error: request for member 'endTransaction' in '_SPI', which is of non-class type 'int'
                              /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp: In function 'uint8_t RFM69_spiMultiByteTransfer(uint8_t, uint8_t*, uint8_t, bool)':
                              /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp:114:18: error: request for member 'transfer' in '_SPI', which is of non-class type 'int'
                                  status = _SPI.transfer(cmd);
                              /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp:117:24: error: request for member 'transfer' in '_SPI', which is of non-class type 'int'
                                        status = _SPI.transfer((uint8_t)0x00);
                              /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp:122:24: error: request for member 'transfer' in '_SPI', which is of non-class type 'int'
                                        status = _SPI.transfer(*current++);
                              /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp: In function 'bool RFM69_initialise(float)':
                              /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp:190:9: error: request for member 'begin' in '_SPI', which is of non-class type 'int'
                                  _SPI.begin();
                              /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp:202:9: error: request for member 'usingInterrupt' in '_SPI', which is of non-class type 'int'
                              /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp: In function 'void RFM69_interruptHandler()':
                              /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp:232:15: error: request for member 'transfer' in '_SPI', which is of non-class type 'int'
                                        _SPI.transfer(RFM69_REG_FIFO & RFM69_READ_REGISTER);
                              /home/toberfoe/Arduino/libraries/MySensors/drivers/RFM69/RFM69.cpp:239:31: error: request for member 'transfer' in '_SPI', which is of non-class type 'int'
                                           *current++ = _SPI.transfer((uint8_t)0x00);
                              exit status 1
                              Fehler beim Kompilieren für das Board Arduino Nano.
                              • scalzS scalz
                                @TimO
                                Oh my bad!
                                korttomaK
                                korttomaK
                                korttoma
                                @scalz both @jpaulin and I have had success with using W5100 and RFM69 on the same SPI bus. You can read about it earlier in this thread. I thing I will use this solution because I need the extra IO pins for local relays and buttons on the GW.
                                • Tomas
                                • scalzS scalz
                                  @TimO
                                  Oh my bad!
                                  J
                                  J
                                  jpaulin
                                  #46
                                  @scalz I downloaded your testbed and loaded a node with a basic script. It compiles ok, but I can't reach my gateway any longer. Do I have to update the gw as well? I'm using an ATmega328 with an RFM69W, CS=D10 and IRQ=D2 (Anarduino).
                                  Looks inspiring with ATC, debug_verbose, getRSSI() and other improvements.
                                  Script used:
                                  // Enable debug prints
                                  #define MY_RFM69_FREQUENCY   RFM69_433MHZ  // Note. New format
                                  #define MY_NODE_ID 7
                                  unsigned long SLEEP_TIME = 5000;         // Sleep time between reads (in milliseconds)
                                  #define CHILD_ID 1
                                  MyMessage msg(CHILD_ID, V_VAR1);
                                  int count = 0;
                                    sendSketchInfo("Test", "1.0");
                                    present(CHILD_ID, S_CUSTOM);
                                      send(msg.set(count));
                                      count++;
                                      if (count > 1000) {
                                        count=0;
                                    wait(SLEEP_TIME);                       //sleep a bit.
                                  Debug dump:
                                  0 MCO:BGN:INIT NODE,CP=RRNNA--,VER=2.1.0-beta
                                  4 TSM:INIT
                                  4 TSF:WUR:MS=0
                                  6 RFM69:INIT
                                  7 RFM69:IRQ PIN=2,CS PIN=10
                                  10 RFM69:PTX:LEVEL=5 dBm,reg=23
                                  13 TSM:INIT:TSP OK
                                  15 TSM:INIT:STATID=7
                                  16 TSF:SID:OK,ID=7
                                  18 TSM:FPAR
                                  19 RFM69:SWR:Sending,to=255,retry=0
                                  275 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  2282 !TSM:FPAR:NO REPLY
                                  2284 TSM:FPAR
                                  2285 RFM69:SWR:Sending,to=255,retry=0
                                  2691 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  4698 !TSM:FPAR:NO REPLY
                                  4700 TSM:FPAR
                                  4701 RFM69:SWR:Sending,to=255,retry=0
                                  5007 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  7014 !TSM:FPAR:NO REPLY
                                  7016 TSM:FPAR
                                  7017 RFM69:SWR:Sending,to=255,retry=0
                                  7173 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  9180 !TSM:FPAR:FAIL
                                  9181 TSM:FAIL:CNT=1
                                  9183 TSM:FAIL:PDT
                                  9185 RFM69:power down
                                  • scalzS scalz
                                    J
                                    J
                                    jpaulin
                                    #47
                                    @scalz Made some other tests and I get the same result.
                                    1. Testbed loaded in node only. No contact between gw and node.
                                    2. Testbed loaded in node and gw. No contact between gw and node.
                                    3. Testbed loaded in gw only. No contact between gw and node.
                                    4. @tekka RFM69DriverUpdate testbed loaded in node only. No contact between node and gw.
                                    5. Restoring node and gw with development branch. Everything goes back to normal.
                                    GW uses hardware SPI for the radio and Ethernet unit as mentioned further up in this thread.
                                      #48
                                      @TimO
                                      oki, i'm fixing this, about your compil issue. i'll push today.
                                      @korttoma
                                      I know about this ;) this is a problem related to the ethernet lib with pins hardwritten..
                                      Changes in new drivers should be able to handle hardware spi for w5100+radio on same bus. If taking care about the CS issue in ethernet lib. I've quickly looked and it seems that ethernet lib uses spi transaction, and rfm69 too now. So it should be ok in theory (for more infos, see spitransaction, and usinginterrupts).
                                      D10 is default for w5100 in ethernet lib, but if not setting any define in Mysensors for radio, then it will be on D10 too.
                                      • So if keeping W5100 D10, then we should have #define MY_RFM69_SPI_CS [your pin]
                                      • Or hack the w5100 lib, and you can keep default D10 CS Mysensors define for radio.
                                      So talking about this @jpaulin , could you tell me what are your CS pins? In your sketch above i don't see any define for this. So i assume you have modified the ethernet lib and keep Mysensors define for this, right ?
                                      • scalzS scalz
                                        @TimO
                                        @korttoma
                                        J
                                        J
                                        jpaulin
                                        @scalz
                                        On the test node CS = D10 (script above). On the gw the radio CS = D10 and the Ethernet CS = D7. D7 is set in the w5100.h file in the Ethernet library.
                                        Here's a debug dump with the RFM69 registers (from the test node):
                                        4 TSM:INIT
                                        4 TSF:WUR:MS=0
                                        6 RFM69:INIT
                                        9 RFM69:write register, reg=0x01, value=4
                                        13 RFM69:write register, reg=0x02, value=0
                                        17 RFM69:write register, reg=0x03, value=2
                                        21 RFM69:write register, reg=0x04, value=64
                                        24 RFM69:write register, reg=0x05, value=3
                                        28 RFM69:write register, reg=0x06, value=51
                                        32 RFM69:write register, reg=0x07, value=108
                                        36 RFM69:write register, reg=0x08, value=64
                                        40 RFM69:write register, reg=0x09, value=0
                                        45 RFM69:write register, reg=0x18, value=136
                                        48 RFM69:write register, reg=0x19, value=66
                                        52 RFM69:write register, reg=0x26, value=7
                                        56 RFM69:write register, reg=0x28, value=16
                                        60 RFM69:write register, reg=0x29, value=220
                                        64 RFM69:write register, reg=0x2e, value=136
                                        68 RFM69:write register, reg=0x2f, value=170
                                        72 RFM69:write register, reg=0x30, value=100
                                        76 RFM69:write register, reg=0x37, value=212
                                        80 RFM69:write register, reg=0x38, value=66
                                        83 RFM69:write register, reg=0x39, value=255
                                        88 RFM69:write register, reg=0x3a, value=255
                                        92 RFM69:write register, reg=0x3c, value=5
                                        96 RFM69:write register, reg=0x3d, value=16
                                        100 RFM69:write register, reg=0x6f, value=48
                                        104 RFM69:write register, reg=0x01, value=4
                                        108 RFM69:read register, reg=0x27, value=128
                                        112 RFM69:read register, reg=0x3d, value=16
                                        115 RFM69:write register, reg=0x3d, value=16
                                        119 RFM69:write register, reg=0x11, value=151
                                        123 RFM69:PTX:LEVEL=5 dBm,reg=23
                                        126 RFM69:read register, reg=0x02, value=0
                                        131 RFM69:read register, reg=0x03, value=2
                                        135 RFM69:read register, reg=0x04, value=64
                                        138 RFM69:read register, reg=0x05, value=3
                                        142 RFM69:read register, reg=0x06, value=51
                                        146 RFM69:read register, reg=0x07, value=108
                                        150 RFM69:read register, reg=0x08, value=64
                                        154 RFM69:read register, reg=0x09, value=0
                                        157 RFM69:read register, reg=0x30, value=100
                                        161 TSM:INIT:TSP OK
                                        163 TSM:INIT:STATID=7
                                        165 RFM69:write register, reg=0x39, value=7
                                        169 TSF:SID:OK,ID=7
                                        172 TSM:FPAR
                                        173 RFM69:SWR:Sending,to=255,retry=0
                                        427 RFM69:read register, reg=0x27, value=128
                                        431 RFM69:write register, reg=0x25, value=0
                                        434 RFM69:write register, reg=0x01, value=12
                                        441 RFM69:read register, reg=0x28, value=8
                                        441 RFM69:write register, reg=0x25, value=64
                                        441 RFM69:write register, reg=0x01, value=16
                                        442 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        2449 !TSM:FPAR:NO REPLY
                                        2451 TSM:FPAR
                                        2452 RFM69:SWR:Sending,to=255,retry=0
                                        2455 RFM69:read register, reg=0x24, value=195
                                        2859 RFM69:read register, reg=0x24, value=197
                                        2863 RFM69:write register, reg=0x01, value=4
                                        2866 RFM69:read register, reg=0x27, value=128
                                        2871 RFM69:write register, reg=0x25, value=0
                                        2874 RFM69:write register, reg=0x01, value=12
                                        2881 RFM69:read register, reg=0x28, value=8
                                        2881 RFM69:write register, reg=0x25, value=64
                                        2881 RFM69:write register, reg=0x01, value=16
                                        2882 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        4889 !TSM:FPAR:NO REPLY
                                        4891 TSM:FPAR
                                        4892 RFM69:SWR:Sending,to=255,retry=0
                                        4895 RFM69:read register, reg=0x24, value=189
                                        5199 RFM69:read register, reg=0x24, value=208
                                        5203 RFM69:write register, reg=0x01, value=4
                                        5207 RFM69:read register, reg=0x27, value=128
                                        5212 RFM69:write register, reg=0x25, value=0
                                        5215 RFM69:write register, reg=0x01, value=12
                                        5222 RFM69:read register, reg=0x28, value=8
                                        5222 RFM69:write register, reg=0x25, value=64
                                        5222 RFM69:write register, reg=0x01, value=16
                                        5223 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        7230 !TSM:FPAR:NO REPLY
                                        7232 TSM:FPAR
                                        7233 RFM69:SWR:Sending,to=255,retry=0
                                        7236 RFM69:read register, reg=0x24, value=222
                                        7390 RFM69:read register, reg=0x24, value=193
                                        7394 RFM69:write register, reg=0x01, value=4
                                        7397 RFM69:read register, reg=0x27, value=128
                                        7402 RFM69:write register, reg=0x25, value=0
                                        7405 RFM69:write register, reg=0x01, value=12
                                        7412 RFM69:read register, reg=0x28, value=8
                                        7412 RFM69:write register, reg=0x25, value=64
                                        7412 RFM69:write register, reg=0x01, value=16
                                        7413 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        9420 !TSM:FPAR:FAIL
                                        9421 TSM:FAIL:CNT=1
                                        9423 TSM:FAIL:PDT
                                        9425 RFM69:power down
                                        9427 RFM69:write register, reg=0x01, value=128
                                        • scalzS scalz
                                          @TimO
                                          @korttoma
                                          J
                                          J
                                          jpaulin
                                          #50
                                          @scalz I finally got it going. I had to clean out all settings in both my gw, ethernet lib and the test-node. But it's a rather shaky experience. There are a lot of re-transmissions and failed sent messages that I don't see happening in my current set-up (in the Ethernet gw the file w5100.h has sei(); and cli(); interrupt macros added , as mentioned above in this thread).
                                          As well there's an issue with the new ATC management. The transmission power is dropped 1 dB after every sent message in the test-node. Finally it ends up loosing contact with the gw using too low power. After automatic restart sequences it goes back to full power and starts again slowly dropping power until loosing contact again.
                                          I think I'll have to stay with my current set-up until it becomes more stable.
                                          Here's a debug-dump showing the re-transmissions and ATC power loss in the test-node:
                                          4 TSM:INIT
                                          4 TSF:WUR:MS=0
                                          6 RFM69:INIT
                                          13 TSM:INIT:TSP OK
                                          16 TSF:SID:OK,ID=7
                                          18 TSM:FPAR
                                          2284 TSM:FPAR
                                          3792 RFM69:RCV:Send ACK
                                          3794 RFM69:SAC:Send ACK to=0,RSSI=-56
                                          4100 TSF:MSG:READ,0-0-7,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                          4105 TSF:MSG:FPAR OK,ID=0,D=1
                                          4323 RFM69:RCV:Send ACK
                                          4325 RFM69:SAC:Send ACK to=0,RSSI=-57
                                          4482 TSF:MSG:READ,0-0-7,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                          4698 TSM:FPAR:OK
                                          4699 TSM:ID
                                          4700 TSM:ID:OK
                                          4702 TSM:UPL
                                          4703 RFM69:SWR:Sending,to=0,retry=0
                                          5009 !RFM69:SWR:NACK
                                          5010 RFM69:SWR:Sending,to=0,retry=1
                                          5517 !RFM69:SWR:NACK
                                          5518 RFM69:SWR:Sending,to=0,retry=2
                                          5925 !RFM69:SWR:NACK
                                          5926 RFM69:SWR:Sending,to=0,retry=3
                                          6434 !RFM69:SWR:NACK
                                          6435 RFM69:SWR:Sending,to=0,retry=4
                                          6892 RFM69:SWR:ACK from=0,SEQ=5,RSSI=-58
                                          6895 RFM69:ATC:ADJ TXL,cR=-58,tR=-80,TXL=4
                                          6899 RFM69:PTX:LEVEL=4 dBm,reg=22
                                          6902 TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                          6945 RFM69:RCV:Send ACK
                                          6947 RFM69:SAC:Send ACK to=0,RSSI=-56
                                          7053 TSF:MSG:READ,0-0-7,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                          7058 TSF:MSG:PONG RECV,HP=1
                                          7060 TSM:UPL:OK
                                          7062 TSM:READY:ID=7,PAR=0,DIS=1
                                          7065 RFM69:SWR:Sending,to=0,retry=0
                                          7171 !RFM69:SWR:NACK
                                          7172 RFM69:SWR:Sending,to=0,retry=1
                                          7680 !RFM69:SWR:NACK
                                          7681 RFM69:SWR:Sending,to=0,retry=2
                                          8088 !RFM69:SWR:NACK
                                          8089 RFM69:SWR:Sending,to=0,retry=3
                                          8596 !RFM69:SWR:NACK
                                          8597 RFM69:SWR:Sending,to=0,retry=4
                                          8654 RFM69:SWR:ACK from=0,SEQ=7,RSSI=-59
                                          8658 RFM69:ATC:ADJ TXL,cR=-59,tR=-80,TXL=3
                                          8662 RFM69:PTX:LEVEL=3 dBm,reg=21
                                          8665 TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                          9108 RFM69:RCV:Send ACK
                                          9110 RFM69:SAC:Send ACK to=0,RSSI=-56
                                          9266 TSF:MSG:READ,0-0-7,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                          9271 RFM69:SWR:Sending,to=0,retry=0
                                          9728 !RFM69:SWR:NACK
                                          9729 RFM69:SWR:Sending,to=0,retry=1
                                          10137 RFM69:SWR:ACK from=0,SEQ=9,RSSI=-60
                                          10141 RFM69:ATC:ADJ TXL,cR=-60,tR=-80,TXL=2
                                          10145 RFM69:PTX:LEVEL=2 dBm,reg=20
                                          10148 TSF:MSG:SEND,7-7-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.1.0-beta
                                          10156 RFM69:SWR:Sending,to=0,retry=0
                                          10612 !RFM69:SWR:NACK
                                          10614 RFM69:SWR:Sending,to=0,retry=1
                                          10720 RFM69:SWR:ACK from=0,SEQ=10,RSSI=-62
                                          10724 RFM69:ATC:ADJ TXL,cR=-62,tR=-80,TXL=1
                                          10728 RFM69:PTX:LEVEL=1 dBm,reg=19
                                          10731 TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                          12737 RFM69:SWR:Sending,to=0,retry=0
                                          13143 !RFM69:SWR:NACK
                                          13145 RFM69:SWR:Sending,to=0,retry=1
                                          13301 !RFM69:SWR:NACK
                                          13303 RFM69:SWR:Sending,to=0,retry=2
                                          13409 !RFM69:SWR:NACK
                                          13411 RFM69:SWR:Sending,to=0,retry=3
                                          13568 RFM69:SWR:ACK from=0,SEQ=11,RSSI=-63
                                          13572 RFM69:ATC:ADJ TXL,cR=-63,tR=-80,TXL=0
                                          13576 RFM69:PTX:LEVEL=0 dBm,reg=18
                                          13579 TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=11,pt=0,l=4,sg=0,ft=0,st=OK:Test
                                          13586 RFM69:SWR:Sending,to=0,retry=0
                                          13892 !RFM69:SWR:NACK
                                          13894 RFM69:SWR:Sending,to=0,retry=1
                                          14251 RFM69:SWR:ACK from=0,SEQ=12,RSSI=-64
                                          14255 RFM69:ATC:ADJ TXL,cR=-64,tR=-80,TXL=-1
                                          14259 RFM69:PTX:LEVEL=-1 dBm,reg=17
                                          14262 TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                                          14268 RFM69:SWR:Sending,to=0,retry=0
                                          14675 !RFM69:SWR:NACK
                                          14678 RFM69:SWR:Sending,to=0,retry=1
                                          14784 !RFM69:SWR:NACK
                                          14786 RFM69:SWR:Sending,to=0,retry=2
                                          15242 RFM69:SWR:ACK from=0,SEQ=13,RSSI=-64
                                          15246 RFM69:ATC:ADJ TXL,cR=-64,tR=-80,TXL=-2
                                          15249 RFM69:PTX:LEVEL=-2 dBm,reg=16
                                          15253 TSF:MSG:SEND,7-7-0-0,s=1,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=OK:
                                          15259 MCO:REG:REQ
                                          15260 RFM69:SWR:Sending,to=0,retry=0
                                          15717 !RFM69:SWR:NACK
                                          15719 RFM69:SWR:Sending,to=0,retry=1
                                          16125 RFM69:SWR:ACK from=0,SEQ=14,RSSI=-66
                                          16130 RFM69:ATC:ADJ TXL,cR=-66,tR=-80,TXL=-3
                                          16134 RFM69:PTX:LEVEL=-3 dBm,reg=15
                                          16137 TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                          16179 RFM69:RCV:Send ACK
                                          16182 RFM69:SAC:Send ACK to=0,RSSI=-56
                                          16337 TSF:MSG:READ,0-0-7,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                          16343 MCO:PIM:NODE REG=1
                                          16345 MCO:BGN:STP
                                          16347 MCO:BGN:INIT OK,TSP=1
                                          16349 RFM69:SWR:Sending,to=0,retry=0
                                          16706 !RFM69:SWR:NACK
                                          16708 RFM69:SWR:Sending,to=0,retry=1
                                          16814 RFM69:SWR:ACK from=0,SEQ=16,RSSI=-64
                                          16818 RFM69:ATC:ADJ TXL,cR=-64,tR=-80,TXL=-4
                                          16822 RFM69:PTX:LEVEL=-4 dBm,reg=14
                                          16825 TSF:MSG:SEND,7-7-0-0,s=1,c=1,t=24,pt=2,l=2,sg=0,ft=0,st=OK:0
                                          21831 RFM69:SWR:Sending,to=0,retry=0
                                          22337 !RFM69:SWR:NACK
                                          22339 RFM69:SWR:Sending,to=0,retry=1
                                          22445 !RFM69:SWR:NACK
                                          22447 RFM69:SWR:Sending,to=0,retry=2
                                          22553 RFM69:SWR:ACK from=0,SEQ=17,RSSI=-65
                                          22557 RFM69:ATC:ADJ TXL,cR=-65,tR=-80,TXL=-5
                                          22561 RFM69:PTX:LEVEL=-5 dBm,reg=13
                                          22564 TSF:MSG:SEND,7-7-0-0,s=1,c=1,t=24,pt=2,l=2,sg=0,ft=0,st=OK:1
                                          27571 RFM69:SWR:Sending,to=0,retry=0
                                          27727 !RFM69:SWR:NACK
                                          27729 RFM69:SWR:Sending,to=0,retry=1
                                          27835 !RFM69:SWR:NACK
                                          27837 RFM69:SWR:Sending,to=0,retry=2
                                          28080 RFM69:SWR:ACK from=0,SEQ=18,RSSI=-65
                                          28084 RFM69:ATC:ADJ TXL,cR=-65,tR=-80,TXL=-6
                                          28088 RFM69:PTX:LEVEL=-6 dBm,reg=12
                                          28091 TSF:MSG:SEND,7-7-0-0,s=1,c=1,t=24,pt=2,l=2,sg=0,ft=0,st=OK:2
                                          33097 RFM69:SWR:Sending,to=0,retry=0
                                          33253 !RFM69:SWR:NACK
                                          33255 RFM69:SWR:Sending,to=0,retry=1
                                          33461 !RFM69:SWR:NACK
                                          33463 RFM69:SWR:Sending,to=0,retry=2
                                          33569 RFM69:SWR:ACK from=0,SEQ=19,RSSI=-69
                                          33573 RFM69:ATC:ADJ TXL,cR=-69,tR=-80,TXL=-7
                                          33577 RFM69:PTX:LEVEL=-7 dBm,reg=11
                                          33581 TSF:MSG:SEND,7-7-0-0,s=1,c=1,t=24,pt=2,l=2,sg=0,ft=0,st=OK:3
                                          38587 RFM69:SWR:Sending,to=0,retry=0
                                          38693 !RFM69:SWR:NACK
                                          38695 RFM69:SWR:Sending,to=0,retry=1
                                          38852 RFM69:SWR:ACK from=0,SEQ=20,RSSI=-69
                                          38856 RFM69:ATC:ADJ TXL,cR=-69,tR=-80,TXL=-8
                                          38860 RFM69:PTX:LEVEL=-8 dBm,reg=10
                                          38863 TSF:MSG:SEND,7-7-0-0,s=1,c=1,t=24,pt=2,l=2,sg=0,ft=0,st=OK:4
                                          43870 RFM69:SWR:Sending,to=0,retry=0
                                          44076 !RFM69:SWR:NACK
                                          44078 RFM69:SWR:Sending,to=0,retry=1
                                          44284 !RFM69:SWR:NACK
                                          44286 RFM69:SWR:Sending,to=0,retry=2
                                          44544 RFM69:SWR:ACK from=0,SEQ=21,RSSI=-71
                                          44548 RFM69:ATC:ADJ TXL,cR=-71,tR=-80,TXL=-9
                                          44552 RFM69:PTX:LEVEL=-9 dBm,reg=9
                                          44555 TSF:MSG:SEND,7-7-0-0,s=1,c=1,t=24,pt=2,l=2,sg=0,ft=0,st=OK:5
                                          49561 RFM69:SWR:Sending,to=0,retry=0
                                          49967 !RFM69:SWR:NACK
                                          49969 RFM69:SWR:Sending,to=0,retry=1
                                          50275 !RFM69:SWR:NACK
                                          50277 RFM69:SWR:Sending,to=0,retry=2
                                          50734 RFM69:SWR:ACK from=0,SEQ=22,RSSI=-73
                                          50738 RFM69:ATC:ADJ TXL,cR=-73,tR=-80,TXL=-10
                                          50742 RFM69:PTX:LEVEL=-10 dBm,reg=8
                                          50745 TSF:MSG:SEND,7-7-0-0,s=1,c=1,t=24,pt=2,l=2,sg=0,ft=0,st=OK:6
                                          55751 RFM69:SWR:Sending,to=0,retry=0
                                          55957 !RFM69:SWR:NACK
                                          55959 RFM69:SWR:Sending,to=0,retry=1
                                          56366 RFM69:SWR:ACK from=0,SEQ=23,RSSI=-69
                                          56370 RFM69:ATC:ADJ TXL,cR=-69,tR=-80,TXL=-11
                                          56374 RFM69:PTX:LEVEL=-11 dBm,reg=7
                                          56377 TSF:MSG:SEND,7-7-0-0,s=1,c=1,t=24,pt=2,l=2,sg=0,ft=0,st=OK:7
                                          61383 RFM69:SWR:Sending,to=0,retry=0
                                          61539 !RFM69:SWR:NACK
                                          61541 RFM69:SWR:Sending,to=0,retry=1
                                          61690 RFM69:SWR:ACK from=0,SEQ=24,RSSI=-71
                                          61694 RFM69:ATC:ADJ TXL,cR=-71,tR=-80,TXL=-12
                                          61699 RFM69:PTX:LEVEL=-12 dBm,reg=6
                                          61702 TSF:MSG:SEND,7-7-0-0,s=1,c=1,t=24,pt=2,l=2,sg=0,ft=0,st=OK:8
                                          66708 RFM69:SWR:Sending,to=0,retry=0
                                          67064 !RFM69:SWR:NACK
                                          67066 RFM69:SWR:Sending,to=0,retry=1
                                          67322 !RFM69:SWR:NACK
                                          67324 RFM69:SWR:Sending,to=0,retry=2
                                          67781 RFM69:SWR:ACK from=0,SEQ=25,RSSI=-73
                                          67785 RFM69:ATC:ADJ TXL,cR=-73,tR=-80,TXL=-13
                                          67789 RFM69:PTX:LEVEL=-13 dBm,reg=5
                                          67792 TSF:MSG:SEND,7-7-0-0,s=1,c=1,t=24,pt=2,l=2,sg=0,ft=0,st=OK:9
                                          72799 RFM69:SWR:Sending,to=0,retry=0
                                          73056 !RFM69:SWR:NACK
                                          73058 RFM69:SWR:Sending,to=0,retry=1
                                          73314 RFM69:SWR:ACK from=0,SEQ=26,RSSI=-74
                                          73318 RFM69:ATC:ADJ TXL,cR=-74,tR=-80,TXL=-14
                                          73322 RFM69:PTX:LEVEL=-14 dBm,reg=4
                                          73325 TSF:MSG:SEND,7-7-0-0,s=1,c=1,t=24,pt=2,l=2,sg=0,ft=0,st=OK:10
                                          78331 RFM69:SWR:Sending,to=0,retry=0
                                          78787 !RFM69:SWR:NACK
                                          78789 RFM69:SWR:Sending,to=0,retry=1
                                          79195 RFM69:SWR:ACK from=0,SEQ=27,RSSI=-76
                                          79199 RFM69:ATC:ADJ TXL,cR=-76,tR=-80,TXL=-15
                                          79203 RFM69:PTX:LEVEL=-15 dBm,reg=3
                                          79206 TSF:MSG:SEND,7-7-0-0,s=1,c=1,t=24,pt=2,l=2,sg=0,ft=0,st=OK:11
                                          84212 RFM69:SWR:Sending,to=0,retry=0
                                          84319 !RFM69:SWR:NACK
                                          84321 RFM69:SWR:Sending,to=0,retry=1
                                          84827 !RFM69:SWR:NACK
                                          84829 RFM69:SWR:Sending,to=0,retry=2
                                          85285 RFM69:SWR:ACK from=0,SEQ=28,RSSI=-76
                                          85289 RFM69:ATC:ADJ TXL,cR=-76,tR=-80,TXL=-16
                                          85294 RFM69:PTX:LEVEL=-16 dBm,reg=2
                                          85297 TSF:MSG:SEND,7-7-0-0,s=1,c=1,t=24,pt=2,l=2,sg=0,ft=0,st=OK:12
                                          90303 RFM69:SWR:Sending,to=0,retry=0
                                          90459 !RFM69:SWR:NACK
                                          90461 RFM69:SWR:Sending,to=0,retry=1
                                          90567 !RFM69:SWR:NACK
                                          90569 RFM69:SWR:Sending,to=0,retry=2
                                          90676 !RFM69:SWR:NACK
                                          90678 RFM69:SWR:Sending,to=0,retry=3
                                          91034 RFM69:SWR:ACK from=0,SEQ=29,RSSI=-75
                                          91038 RFM69:ATC:ADJ TXL,cR=-75,tR=-80,TXL=-17
                                          91042 RFM69:PTX:LEVEL=-17 dBm,reg=1
                                          91045 TSF:MSG:SEND,7-7-0-0,s=1,c=1,t=24,pt=2,l=2,sg=0,ft=0,st=OK:13
                                          96052 RFM69:SWR:Sending,to=0,retry=0
                                          96508 !RFM69:SWR:NACK
                                          96510 RFM69:SWR:Sending,to=0,retry=1
                                          96818 !RFM69:SWR:NACK
                                          96820 RFM69:SWR:Sending,to=0,retry=2
                                          97226 RFM69:SWR:ACK from=0,SEQ=30,RSSI=-78
                                          97230 RFM69:ATC:ADJ TXL,cR=-78,tR=-80,TXL=-18
                                          97234 RFM69:PTX:LEVEL=-18 dBm,reg=0
                                          97238 TSF:MSG:SEND,7-7-0-0,s=1,c=1,t=24,pt=2,l=2,sg=0,ft=0,st=OK:14
                                          102244 RFM69:SWR:Sending,to=0,retry=0
                                          102700 !RFM69:SWR:NACK
                                          102702 RFM69:SWR:Sending,to=0,retry=1
                                          103158 !RFM69:SWR:NACK
                                          103160 RFM69:SWR:Sending,to=0,retry=2
                                          103566 !RFM69:SWR:NACK
                                          103568 RFM69:SWR:Sending,to=0,retry=3
                                          103874 !RFM69:SWR:NACK
                                          103876 RFM69:SWR:Sending,to=0,retry=4
                                          104232 !RFM69:SWR:NACK
                                          104235 !TSF:MSG:SEND,7-7-0-0,s=1,c=1,t=24,pt=2,l=2,sg=0,ft=0,st=NACK:15
                                          109241 RFM69:SWR:Sending,to=0,retry=0
                                          109347 !RFM69:SWR:NACK
                                          109349 RFM69:SWR:Sending,to=0,retry=1
                                          109706 !RFM69:SWR:NACK
                                          109708 RFM69:SWR:Sending,to=0,retry=2
                                          109914 !RFM69:SWR:NACK
                                          109916 RFM69:SWR:Sending,to=0,retry=3
                                          110322 !RFM69:SWR:NACK
                                          110324 RFM69:SWR:Sending,to=0,retry=4
                                          110780 !RFM69:SWR:NACK
                                          110782 !TSF:MSG:SEND,7-7-0-0,s=1,c=1,t=24,pt=2,l=2,sg=0,ft=1,st=NACK:16
                                          115788 RFM69:SWR:Sending,to=0,retry=0
                                          115894 !RFM69:SWR:NACK
                                          115896 RFM69:SWR:Sending,to=0,retry=1
                                          116202 !RFM69:SWR:NACK
                                          116204 RFM69:SWR:Sending,to=0,retry=2
                                          116410 !RFM69:SWR:NACK
                                          116412 RFM69:SWR:Sending,to=0,retry=3
                                          116768 !RFM69:SWR:NACK
                                          116770 RFM69:SWR:Sending,to=0,retry=4
                                          117176 !RFM69:SWR:NACK
                                          117178 !TSF:MSG:SEND,7-7-0-0,s=1,c=1,t=24,pt=2,l=2,sg=0,ft=2,st=NACK:17
                                          122184 RFM69:SWR:Sending,to=0,retry=0
                                          122690 !RFM69:SWR:NACK
                                          122692 RFM69:SWR:Sending,to=0,retry=1
                                          122798 !RFM69:SWR:NACK
                                          122800 RFM69:SWR:Sending,to=0,retry=2
                                          123206 !RFM69:SWR:NACK
                                          123208 RFM69:SWR:Sending,to=0,retry=3
                                          123464 !RFM69:SWR:NACK
                                          123466 RFM69:SWR:Sending,to=0,retry=4
                                          123972 !RFM69:SWR:NACK
                                          123974 !TSF:MSG:SEND,7-7-0-0,s=1,c=1,t=24,pt=2,l=2,sg=0,ft=3,st=NACK:18
                                          128980 RFM69:SWR:Sending,to=0,retry=0
                                          129337 !RFM69:SWR:NACK
                                          129339 RFM69:SWR:Sending,to=0,retry=1
                                          129795 !RFM69:SWR:NACK
                                          129797 RFM69:SWR:Sending,to=0,retry=2
                                          130203 !RFM69:SWR:NACK
                                          130205 RFM69:SWR:Sending,to=0,retry=3
                                          130711 !RFM69:SWR:NACK
                                          130713 RFM69:SWR:Sending,to=0,retry=4
                                          131169 !RFM69:SWR:NACK
                                          131171 !TSF:MSG:SEND,7-7-0-0,s=1,c=1,t=24,pt=2,l=2,sg=0,ft=4,st=NACK:19
                                          136177 RFM69:SWR:Sending,to=0,retry=0
                                          136584 !RFM69:SWR:NACK
                                          136586 RFM69:SWR:Sending,to=0,retry=1
                                          136792 !RFM69:SWR:NACK
                                          136794 RFM69:SWR:Sending,to=0,retry=2
                                          136900 !RFM69:SWR:NACK
                                          136902 RFM69:SWR:Sending,to=0,retry=3
                                          137158 !RFM69:SWR:NACK
                                          137160 RFM69:SWR:Sending,to=0,retry=4
                                          137267 !RFM69:SWR:NACK
                                          137269 !TSF:MSG:SEND,7-7-0-0,s=1,c=1,t=24,pt=2,l=2,sg=0,ft=5,st=NACK:20
                                          137275 !TSM:READY:UPL FAIL,SNP
                                          137278 TSM:FPAR
                                          137279 RFM69:SWR:Sending,to=255,retry=0
                                          137436 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=6,st=OK:
                                          139443 !TSM:FPAR:NO REPLY
                                          139445 TSM:FPAR
                                          139446 RFM69:SWR:Sending,to=255,retry=0
                                          139753 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          141760 !TSM:FPAR:NO REPLY
                                          141762 TSM:FPAR
                                          141763 RFM69:SWR:Sending,to=255,retry=0
                                          141920 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          142275 !TSF:SND:TNR
                                          143927 !TSM:FPAR:NO REPLY
                                          143929 TSM:FPAR
                                          143931 RFM69:SWR:Sending,to=255,retry=0
                                          144387 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          145031 RFM69:RCV:Send ACK
                                          145034 RFM69:SAC:Send ACK to=0,RSSI=-55
                                          145139 TSF:MSG:READ,0-0-7,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                          145144 TSF:MSG:FPAR OK,ID=0,D=1
                                          145561 RFM69:RCV:Send ACK
                                          145564 RFM69:SAC:Send ACK to=0,RSSI=-56
                                          145619 TSF:MSG:READ,0-0-7,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                          146391 RFM69:RCV:Send ACK
                                          146393 RFM69:SAC:Send ACK to=0,RSSI=-56
                                          146599 TSF:MSG:READ,0-0-7,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                          146605 TSM:FPAR:OK
                                          146607 TSM:ID
                                          146608 TSM:ID:OK
                                          146610 TSM:UPL
                                          146611 RFM69:SWR:Sending,to=0,retry=0
                                          146869 !RFM69:SWR:NACK
                                          146871 RFM69:SWR:Sending,to=0,retry=1
                                          147227 !RFM69:SWR:NACK
                                          147229 RFM69:SWR:Sending,to=0,retry=2
                                          147435 !RFM69:SWR:NACK
                                          147437 RFM69:SWR:Sending,to=0,retry=3
                                          147793 !RFM69:SWR:NACK
                                          147795 RFM69:SWR:Sending,to=0,retry=4
                                          148202 !RFM69:SWR:NACK
                                          148204 !TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                                          148210 !TSF:SND:TNR
                                          150211 TSM:UPL
                                          150212 RFM69:SWR:Sending,to=0,retry=0
                                          150468 !RFM69:SWR:NACK
                                          150470 RFM69:SWR:Sending,to=0,retry=1
                                          150827 !RFM69:SWR:NACK
                                          150829 RFM69:SWR:Sending,to=0,retry=2
                                          151285 !RFM69:SWR:NACK
                                          151287 RFM69:SWR:Sending,to=0,retry=3
                                          151743 !RFM69:SWR:NACK
                                          151745 RFM69:SWR:Sending,to=0,retry=4
                                          152281 !RFM69:SWR:NACK
                                          152283 !TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                                          153212 !TSF:SND:TNR
                                          154290 TSM:UPL
                                          154291 RFM69:SWR:Sending,to=0,retry=0
                                          154797 !RFM69:SWR:NACK
                                          154799 RFM69:SWR:Sending,to=0,retry=1
                                          154905 !RFM69:SWR:NACK
                                          154907 RFM69:SWR:Sending,to=0,retry=2
                                          155063 !RFM69:SWR:NACK
                                          155065 RFM69:SWR:Sending,to=0,retry=3
                                          155471 !RFM69:SWR:NACK
                                          155473 RFM69:SWR:Sending,to=0,retry=4
                                          155629 !RFM69:SWR:NACK
                                          155631 !TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                                          157638 TSM:UPL
                                          157639 RFM69:SWR:Sending,to=0,retry=0
                                          158095 !RFM69:SWR:NACK
                                          158097 RFM69:SWR:Sending,to=0,retry=1
                                          158203 !RFM69:SWR:NACK
                                          158205 RFM69:SWR:Sending,to=0,retry=2
                                          158562 !RFM69:SWR:NACK
                                          158564 RFM69:SWR:Sending,to=0,retry=3
                                          159020 !RFM69:SWR:NACK
                                          159022 RFM69:SWR:Sending,to=0,retry=4
                                          159178 !RFM69:SWR:NACK
                                          159180 !TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                                          159186 !TSF:SND:TNR
                                          161187 !TSM:UPL:FAIL
                                          161188 TSM:FPAR
                                          161190 RFM69:SWR:Sending,to=255,retry=0
                                          161548 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=4,st=OK:
                                          163555 !TSM:FPAR:NO REPLY
                                          163557 TSM:FPAR
                                          163558 RFM69:SWR:Sending,to=255,retry=0
                                          163965 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          164188 !TSF:SND:TNR
                                          165974 !TSM:FPAR:NO REPLY
                                          165976 TSM:FPAR
                                          165978 RFM69:SWR:Sending,to=255,retry=0
                                          166384 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          168391 !TSM:FPAR:NO REPLY
                                          168393 TSM:FPAR
                                          168394 RFM69:SWR:Sending,to=255,retry=0
                                          168651 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          169189 !TSF:SND:TNR
                                          170658 !TSM:FPAR:FAIL
                                          170660 TSM:FAIL:CNT=1
                                          170662 TSM:FAIL:PDT
                                          170664 RFM69:power down
                                          174190 !TSF:SND:TNR
                                          179191 !TSF:SND:TNR
                                          180668 TSM:FAIL:RE-INIT
                                          180670 TSM:INIT
                                          180671 RFM69:INIT
                                          180673 RFM69:IRQ PIN=2,CS PIN=10
                                          180677 RFM69:PTX:LEVEL=5 dBm,reg=23
                                          180680 TSM:INIT:TSP OK
                                          180682 TSM:INIT:STATID=7
                                          180685 TSF:SID:OK,ID=7
                                          180687 TSM:FPAR
                                          180688 RFM69:SWR:Sending,to=255,retry=0
                                          180795 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          182228 RFM69:RCV:Send ACK
                                          182231 RFM69:SAC:Send ACK to=0,RSSI=-55
                                          182337 TSF:MSG:READ,0-0-7,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                          182342 TSF:MSG:FPAR OK,ID=0,D=1
                                          182530 RFM69:RCV:Send ACK
                                          182532 RFM69:SAC:Send ACK to=0,RSSI=-56
                                          182588 TSF:MSG:READ,0-0-7,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                          182802 TSM:FPAR:OK
                                          182803 TSM:ID
                                          182805 TSM:ID:OK
                                          182806 TSM:UPL
                                          182808 RFM69:SWR:Sending,to=0,retry=0
                                          182914 !RFM69:SWR:NACK
                                          182916 RFM69:SWR:Sending,to=0,retry=1
                                          183322 RFM69:SWR:ACK from=0,SEQ=4,RSSI=-57
                                          183326 RFM69:ATC:ADJ TXL,cR=-57,tR=-80,TXL=4
                                          183330 RFM69:PTX:LEVEL=4 dBm,reg=22
                                          183333 TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                          183378 RFM69:RCV:Send ACK
                                          183380 RFM69:SAC:Send ACK to=0,RSSI=-55
                                          183737 TSF:MSG:READ,0-0-7,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                          183742 TSF:MSG:PONG RECV,HP=1
                                          183745 TSM:UPL:OK
                                          183746 TSM:READY:ID=7,PAR=0,DIS=1
                                          183888 RFM69:RCV:Send ACK
                                          183890 RFM69:SAC:Send ACK to=0,RSSI=-56
                                          184047 TSF:MSG:READ,0-0-7,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                          184052 !TSF:MSG:PONG RECV,INACTIVE
                                          184192 RFM69:SWR:Sending,to=0,retry=0
                                          184698 !RFM69:SWR:NACK
                                          184700 RFM69:SWR:Sending,to=0,retry=1
                                          185057 RFM69:SWR:ACK from=0,SEQ=7,RSSI=-59
                                          185061 RFM69:ATC:ADJ TXL,cR=-59,tR=-80,TXL=3
                                          185065 RFM69:PTX:LEVEL=3 dBm,reg=21
                                          185068 TSF:MSG:SEND,7-7-0-0,s=1,c=1,t=24,pt=2,l=2,sg=0,ft=0,st=OK:29
                                          190074 RFM69:SWR:Sending,to=0,retry=0
                                          190431 !RFM69:SWR:NACK
                                          190433 RFM69:SWR:Sending,to=0,retry=1
                                          190789 RFM69:SWR:ACK from=0,SEQ=8,RSSI=-60
                                          190793 RFM69:ATC:ADJ TXL,cR=-60,tR=-80,TXL=2
                                          190797 RFM69:PTX:LEVEL=2 dBm,reg=20
                                          190800 TSF:MSG:SEND,7-7-0-0,s=1,c=1,t=24,pt=2,l=2,sg=0,ft=0,st=OK:30
                                          195807 RFM69:SWR:Sending,to=0,retry=0
                                          195963 !RFM69:SWR:NACK
                                          195965 RFM69:SWR:Sending,to=0,retry=1
                                          196122 RFM69:SWR:ACK from=0,SEQ=9,RSSI=-61
                                          196126 RFM69:ATC:ADJ TXL,cR=-61,tR=-80,TXL=1
                                          196130 RFM69:PTX:LEVEL=1 dBm,reg=19
