  2. Bug Reports
  3. [solved] RFM69 based nodes unable to report Lib Version
51 Posts 8 Posters 24.8k Views 5 Watching
  • korttomaK korttoma
    Updated now also 2 nodes in my "real" system and both now successfully reported Lib version. I did not update the GW. Maybe it is safe to say that the Lib reporting problem is solved now.
    Now I will try to look in to the sofSerial RFM69 solution that @scalz is working on, do you have any eta on when you will try to include our solution in the official MySensors development branch?
    Any recommendations for the wiring of an W5100/RFM69 Gateway?
    J
    J
    jpaulin
    @korttoma I have an up and running RFM69 GW with W5100 (actually a W5500, but it's the same). I'm not using softSerial in my setup. With this it is possible to integrate with eg. Moteino or Anarduino, which comes with the radio chip preinstalled on the Arduino compatible boards. But a standard arduino with a separate chip would work as well (lower price). The GW-RFM69 has been stable and flawless, as far as I can see, for quite some time. The SPI for the RFM69 and W5500 uses the following pins in my setup.
    RFM69W:
    • SCK = 13
    • MISO = 12
    • MOSI = 11
    • CS = 10
    • IRQ = 2
    W5500:
    • SCK = 13
    • MISO = 12
    • MOSI = 11
    • CS = 7
    I'll try to share wire diagrams and software setup later. I had to do some tweakings in the ethernet.h file to make it work.
    korttomaK 1 Reply Last reply
    • J jpaulin
      RFM69W:
      • SCK = 13
      • MISO = 12
      • MOSI = 11
      • CS = 10
      • IRQ = 2
      W5500:
      • SCK = 13
      • MISO = 12
      • MOSI = 11
      • CS = 7
      korttomaK
      korttomaK
      korttoma
      @jpaulin I am very interested in your solution. Could it work with a normal Arduino Pro mini 3,3V version? Just so that I know if I need to order some parts or can work with what I have.
      • Tomas
      J 2 Replies Last reply
        J
        J
        jpaulin
        @korttoma
        Yes, it should work with an Arduino Pro Mini 3.3V. Personally I'm using for the moment an Anarduino. But it's almost the same.
          J
          J
          jpaulin
          wrote on last edited by jpaulin
          #25
          @korttoma
          My RFM69 - Ethernet - GW has the following setup.
          On the RFM69 radio I'm using D10 as CS pin (Chip Select). This is because in my case the RFM69 radio is hard-wired to pin D10, as with eg. a Moteino or Anarduino. But this is not mandatory. If you use an Arduino Pro Mini you could select another pin for the RFM69 CS-pin on the Arduino, if you want.
          The Ethernet W5100 uses the Arduino IDE pre-installed library Ethernet.h. In the library the CS-pin is as well fixed to D10. CS of course has to be unique for each SPI slave device. I changed directly in the Ethenet.h library the CS pin to be D7. But D9, D8 or some other pin is ok to use as well.
          Take care, if none of your SPI Slave devices (radio and W5100) uses D10 as CS-pin. In this case make sure to set the D10 pin to OUTPUT in your sketch to keep the Arduino as SPI Master. On the ATmega328 the D10 pin is hard-wired to be the SS pin (Slave Select). The Arduino has to always be the SPI Master and the devices SPI Slaves on the SPI bus to get everything to work.
          Another consideration is:
          The RFM69 radio uses the SPI functions during the interrupt sequence (Pin D2). The Ethernet.h library won't work correctly if another device uses SPI signalling during an interrupt sequence. The fix I'm using is to block interrupts from the radio-unit during SPI usage of the W5100 unit. I haven't seen any flaws with this fix so far. I've found other people on the internet using the same fix too without issues.
          To use RFM69 CS=D10 pin and W5100 CS=D9 pin do the following change in the W5100.h that is part of the Ethernet library.
          If you use a Windows computer you'll find the file here:
          C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5100.h
          Look for the following lines at the end of the file.
            inline static void initSS()    { DDRB  |=  _BV(2); };
            inline static void setSS()     { PORTB &= ~_BV(2); };
            inline static void resetSS()   { PORTB |=  _BV(2); };
          If you use D9 as CS pin for the W5100 module change as follows:
            inline static void initSS()    { DDRB  |=  _BV(1); };
            inline static void setSS()     { cli(); PORTB &= ~_BV(1); };
            inline static void resetSS()   { PORTB |=  _BV(1); sei(); };
          If you uses, as I do, D7 as CS pin then change as follows:
            inline static void initSS()    { DDRD  |=  _BV(7); };
            inline static void setSS()     { cli(); PORTD &= ~_BV(7); };
            inline static void resetSS()   { PORTD |=  _BV(7); sei(); };
          If you want to keep D10 for the W5100 just add the cli(); and sei(); macros. (cli = clear interrupt. sei = set interrupt).
          If you want to use another SPI CS pin than D10 on the RFM69 radio (eg. D9) it should be safe to modify it directly in the sketch with the preprocessor constant:
          #define MY_RF69_SPI_CS 9
          For the MOSI, MISO and SCK pins use as mentioned above, they are as well hard-wired in the ATmega328 chip to D11,D12 and D13.
          If you have any doubts please let me know.
          • J jpaulin
            @korttoma
            korttomaK
            korttomaK
            korttoma
            Hi @jpaulin thanks for this, I will test it immediately.
            Would you mind sharing your complete sketch? The MySensors W5100 GW example has all this Soft SPI stuff, I might make a mistake clearing out all the unnecessary parts.
            Btw, do you see any problem with me adding some local "sensors" to this type of GW? I would like to add 4 relays and 4 buttons to it also.
            • Tomas
            • korttomaK
              korttomaK
              korttoma
              It is alive :D
              I managed to get a W5100 RFM69 Gateway working.
              I wanted minimal change to the w5100.h so I just added the cli(); and sei(); macros.
              (I would still like to see your sketch @jpaulin to compare)
              There are some random failures in the RF communication but these might be because of the breadboard setup. I just have one temp sensor sending in some value now to test with.
              • Tomas
              J 1 Reply Last reply
                It is alive :D
                J
                J
                jpaulin
                @korttoma
                Here's my sketch. It's an MQTT GW with LEDs.
                 * Version 1.0 - Henrik Ekblad
                 * The W5100 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
                 * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
                 * LED purposes:
                 * - RX (yellow) - blink fast on radio message recieved. In inclusion mode will blink fast only on presentation received
                 * - TX (green) - blink fast on radio message transmitted. In inclusion mode will blink slowly
                 * - ERR (red) - fast blink on error during transmission error or receive crc error
                //#define MY_RADIO_NRF24
                #define MY_RADIO_RFM69
                #define MY_RFM69_FREQUENCY   RF69_433MHZ
                #define MY_MQTT_PUBLISH_TOPIC_PREFIX "my_RFM69_gw1-out"
                #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "my_RFM69_gw1-in"
                // Set MQTT client id
                #define MY_MQTT_CLIENT_ID "mysensors_RFM69-1"
                //#define MY_W5100_SPI_EN 4
                // Enable these if your MQTT broker requires username/password
                #define MY_IP_ADDRESS 192,168,1,93
                #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 90
                #define MY_PORT 1883
                // Set blinking period
                #define MY_DEFAULT_LED_BLINK_PERIOD 50
                // Flash leds on rx/tx/err
                #define MY_DEFAULT_ERR_LED_PIN A3  // Error led pin
                #define MY_DEFAULT_RX_LED_PIN  A2  // Receive led pin
                #define MY_DEFAULT_TX_LED_PIN  A0  // Transmit led pin
                #include <Ethernet.h>    // modified for W5500 module and with CS pin = D7 (Default CS pin D10 is already used by RFM69W module)
                  #29
                  little side note about the rfm69 driver : it will use spitransaction which should solve this, with some noint/int should be ok. (https://www.arduino.cc/en/Tutorial/SPITransaction)
                  • J jpaulin
                    @korttoma
                     * LED purposes:
                    korttomaK
                    korttomaK
                    korttoma
                    @jpaulin Thanks, not much different from my sketch I see:
                    #define MY_GATEWAY_W5100
                    #define MY_IP_ADDRESS 192,168,1,25   // If this is disabled, DHCP is used to retrieve address
                    #define MY_PORT 5003
                    //#define MY_LEDS_BLINKING_FEATURE
                    // Enable inclusion mode
                    //#define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
                    #if defined(MY_USE_UDP)
                      #include <EthernetUdp.h>
                    void setup(){
                    It has been running for a few hours now without issues. Gona try adding the buttons and relays tomorrow.
                    • Tomas
                    • korttomaK
                      korttomaK
                      korttoma
                      #31
                      Adding the relays and buttons seems to work fine also. I will go with this setup now until there is a "Official" solution for the GatewayW5100RFM69.
                       * Version 1.0 - Henrik EKblad
                       * LED purposes:
                      #define SN "EthGW/RFM69 Rele Button"
                      #define SV "1.0"
                      //#define MY_W5100_SPI_EN 10
                      // radio on the same spi bus.
                      // Enable to UDP
                      //#define MY_USE_UDP
                      #define RELAY_ON 0                      // switch around for ACTIVE LOW / ACTIVE HIGH relay
                      #define RELAY_OFF 1
                      #define noRelays 4                     //2-4
                      const int relayPin[] = {14, 15, 16, 17};       //  switch around pins to your desire
                      const int buttonPin[] = {6, 7, 4, 5};   //  switch around pins to your desire
                      class Relay             // relay class, store all relevant data (equivalent to struct)
                        public:
                          int buttonPin;                   // physical pin number of button
                          int relayPin;             // physical pin number of relay
                          boolean relayState;               // relay status (also stored in EEPROM)
                      Relay Relays[noRelays];
                      Bounce debouncer[noRelays];
                      MyMessage msg[noRelays];
                        wait(100);
                        for (int i = 0; i < noRelays; i++) {
                          Relays[i].buttonPin = buttonPin[i];              // assign physical pins
                          msg[i].type = V_LIGHT;
                          wait(100);
                          Relays[i].relayState = loadState(i);                               // retrieve last values from EEPROM
                          digitalWrite(Relays[i].relayPin, Relays[i].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
                          send(msg[i].set(Relays[i].relayState ? true : false));                 // make controller aware of last status
                          wait(50);
                          debouncer[i].interval(30);
                          wait(50);
                        sendSketchInfo(SN, SV);
                        wait(100);
                          present(i, S_LIGHT);                               // present sensor to gateway
                        wait(100);
                        for (byte i = 0; i < noRelays; i++) {
                          if (debouncer[i].update()) {
                            if ( value == LOW) {
                              // save sensor state in EEPROM (location == sensor number)
                              saveState( i, Relays[i].relayState );
                        //wait(20);
                          if (message.sensor < noRelays) {          // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
                            digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
                            saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
                        wait(20);
                      • Tomas
                         * LED purposes:
                        #define SV "1.0"
                        // Enable to UDP
                        #define RELAY_OFF 1
                          public:
                          wait(100);
                            wait(100);
                            wait(50);
                            wait(50);
                          wait(100);
                          wait(100);
                          //wait(20);
                          wait(20);
                        J
                        J
                        jpaulin
                        @korttoma Excellent news. So now we are at least two with a stable RFM69-Ethernet-GW. :smiley:
                           * LED purposes:
                          #define SV "1.0"
                          // Enable to UDP
                          #define RELAY_OFF 1
                            public:
                            wait(100);
                              wait(100);
                              wait(50);
                              wait(50);
                            wait(100);
                            wait(100);
                            //wait(20);
                            wait(20);
                          J
                          J
                          jpaulin
                          #33
                          @korttoma Sharing a pair of photos of my gw. Became pretty neat, I think. It's parked permanently beside the WiFi Router.
                          • korttomaK
                            korttomaK
                            korttoma
                            I've seen pictures of your GW in another thread, it is very nice and professional @jpaulin
                            I stil have some parts missing from my GW build so I only have the breadboard setup right now.
                            • Tomas
                              #35
                              @TimO
                              Hi.
                              Sorry for delay, so much projects.
                              As you tried to make a push, when you'll have some time, could you tell me if SOFTSPI is working please ? i'm a bit lazy to make a w5100 setup, as i'm not using it.
                              https://github.com/scalz/Mysensors/tree/rfm69_update
                              Set of defines is
                              #define MY_RFM69_FREQUENCY   RFM69_868MHZ // RFM69_433MHZ for 433MHz, RFM69_868MHZ for default 868MHz or RF69_915MHZ for 915MHz
                              //#define MY_IS_RFM69HW // uncomment this if you're running the RFM69HW model
                              //#define MY_RFM69_TX_POWER_DBM (5) // default
                              //#define MY_RFM69_ATC_TARGET_RSSI_DBM	(-80) // default
                              //#define MY_RFM69_ATC_MODE_DISABLED
                              //#define MY_RFM69_NETWORKID     100  // default
                              //#define MY_RFM69_RST_PIN 9
                              //#define MY_RFM69_IRQ_PIN 5
                              //#define MY_RFM69_SPI_CS 23
                              // For Advanced users
                              //#define MY_RFM69_SPI_MAX_SPEED (4000000ul)
                              //#define MY_RFM69_BITRATE_MSB RFM69_BITRATEMSB_55555  // Bitrate is for users who knows what they're doing as it can impact your network reliabilty, and read the datasheet/registers.h file to get the right bitrate.
                              //#define MY_RFM69_BITRATE_LSB RFM69_BITRATELSB_55555  // So bitrates are hardwritten values
                              // Before radio sending, random delay, to be sure that two nodes which were waiting for free channel, doesn't send at same time and collide
                              // delay = MY_RFM69_CSMA_ADD_DELAY_BASE * random(1,MY_RFM69_CSMA_ADD_DELAY_COUNT)
                              //#define MY_RFM69_CSMA_ADD_DELAY_BASE 50  // default 50ms
                              //#define MY_RFM69_CSMA_ADD_DELAY_COUNT 10 // default max 10 counts
                              Note these are my defines for my ATSAM gw.
                              You can also send RSSI and powerlevel as internal msg by doing, like sendBattery function works.
                              Example:
                              Function: sendRadioStats
                              Purpose : Sends radio rssi and powerlevel values
                              Input   : - force : Forces transmission of a value (even if it's the same as previous measurement)
                                             - ack : boolean. true if ack needed
                              Output  : - true if transmission occured
                              Comments:
                              bool sendRadioStats(bool force, bool ack)
                                 static int16_t lastRssi=0;
                                 int16_t rssiVal = transportGetRSSI();
                                 uint8_t txPower = transportGetTxPower();
                                 if (abs(lastRssi - rssiVal) >= 10 || force == true) {
                                    force = sendSignalStrength(rssiVal, ack);
                                    force |= sendTXPowerLevel(txPower, ack);
                                    lastRssi = rssiVal;
                                 return force;
                              • scalzS scalz
                                @TimO
                                Hi.
                                Set of defines is
                                Example:
                                Comments:
                                      lastRssi = rssiVal;
                                   return force;
                                TimO
                                Hey @scalz !
                                My last test a few days ago was not successful with SoftSPI but I did not have the time to debug it. I'll give it another try!
                                  @TimO
                                  oki thx. Perhaps it was because of the w5100 CS define? i'll take a look.
                                  • scalzS scalz
                                    @TimO
                                    TimO
                                    @scalz
                                    Okay, I found a little bit time to test and to check the wiring I've build a breadboard version.
                                    Here's my sketch:
                                    // signing
                                    //#define MY_SIGNING_SOFT
                                      #define MY_SOFTSPI
                                      #define MY_SOFT_SPI_SCK_PIN A0
                                      #define MY_SOFT_SPI_MISO_PIN A2
                                      #define MY_SOFT_SPI_MOSI_PIN A1
                                    #define MY_RF69_SPI_CS 5
                                    #define MY_RF69_IRQ_PIN 2
                                    // Enable to UDP
                                    #define MY_IP_ADDRESS 192,168,2,222   // If this is disabled, DHCP is used to retrieve address
                                    #define MY_MAC_ADDRESS 0xDF, 0xCD, 0xCD, 0xAF, 0xFE, 0xED
                                    Nothing that fancy. Some defines are using RFM69 while others use RF69 (IRQ, CS PIN).
                                    The init is not working. I've inserted a serial print to see where it stops working. Here's the serial output:
                                    0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGA--,VER=2.1.0-beta
                                    0;255;3;0;9;TSM:INIT
                                    0;255;3;0;9;TSF:WUR:MS=0
                                    before
                                    0;255;3;0;9;TSM:FAIL:CNT=1
                                    0;255;3;0;9;TSM:FAIL:PDT
                                    0;255;3;0;9;TSM:FAIL:RE-INIT
                                    It stops there. No more retries, nothing more.
                                    Here's were the error seems to occure (line 116 of RFM69.cpp):
                                    setHighPower(_isRFM69HW); // called regardless if it's a RFM69W or RFM69HW
                                    	setMode(RF69_MODE_STANDBY);
                                    	start = millis();
                                    		Serial.println("before");
                                    	while (((readReg(REG_IRQFLAGS1) & RF_IRQFLAGS1_MODEREADY) == 0x00) && millis()-start < timeout) {
                                    		yield();
                                    	} // wait for ModeReady
                                    	if (millis()-start >= timeout) {
                                    		return false;
                                    		Serial.println("after");
                                    	attachInterrupt(_interruptNum, RFM69::isr0, RISING);
                                    	selfPointer = this;
                                    	_address = nodeID;
                                    	return true;
                                    The second debug output "after" is never reached.
                                    If I disable RFM69 in the sketch and upload it, the ethernet part comes up just fine. The gateway is reachable per ping and telnet.
                                    I've tested against my initial implementation: https://github.com/tobof/MySensors
                                    The gateway comes up and is able to receive messages.
                                    Here's the debug:
                                    0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGA--,VER=2.0.1-beta
                                    0;255;3;0;9;TSM:INIT:TSP OK
                                    0;255;3;0;9;TSM:INIT:GW MODE
                                    0;255;3;0;9;TSM:READY
                                    IP: 192.168.2.222
                                    0;255;3;0;9;MCO:BGN:STP
                                    0;255;3;0;9;MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
                                    0;255;3;0;9;TSF:MSG:READ,111-111-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                    0;255;3;0;9;TSF:MSG:BC
                                    0;255;3;0;9;TSF:MSG:FPAR REQ,ID=111
                                    0;255;3;0;9;TSF:CKU:OK,FCTRL
                                    0;255;3;0;9;TSF:MSG:GWL OK
                                    0;255;3;0;9;TSF:MSG:SEND,0-0-111-111,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    0;255;3;0;9;TSF:MSG:READ,111-111-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                    0;255;3;0;9;TSF:MSG:PINGED,ID=111,HP=1
                                    0;255;3;0;9;TSF:MSG:SEND,0-0-111-111,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                                    0;255;3;0;9;TSF:MSG:READ,111-111-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
                                    0;255;3;0;9;TSF:MSG:SEND,0-0-111-111,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                    0;255;3;0;9;TSF:MSG:READ,111-111-0,s=255,c=0,t=18,pt=0,l=5,sg=0:2.0.0
                                    0;255;3;0;9;TSF:MSG:READ,111-111-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                    0;255;3;0;9;TSF:MSG:READ,111-111-0,s=255,c=3,t=11,pt=0,l=5,sg=0:Relay
                                    0;255;3;0;9;TSF:MSG:READ,111-111-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                                    0;255;3;0;9;TSF:MSG:READ,111-111-0,s=1,c=0,t=3,pt=0,l=0,sg=0:
                                    0;255;3;0;9;TSF:MSG:READ,111-111-0,s=2,c=0,t=3,pt=0,l=0,sg=0:
                                    0;255;3;0;9;TSF:MSG:READ,111-111-0,s=3,c=0,t=3,pt=0,l=0,sg=0:
                                    0;255;3;0;9;TSF:MSG:READ,111-111-0,s=4,c=0,t=3,pt=0,l=0,sg=0:
                                    0;255;3;0;9;TSF:MSG:READ,111-111-0,s=5,c=0,t=3,pt=0,l=0,sg=0:
                                    0;255;3;0;9;TSF:MSG:READ,111-111-0,s=6,c=0,t=3,pt=0,l=0,sg=0:
                                    0;255;3;0;9;TSF:MSG:READ,111-111-0,s=7,c=0,t=3,pt=0,l=0,sg=0:
                                    0;255;3;0;9;TSF:MSG:READ,111-111-0,s=8,c=0,t=3,pt=0,l=0,sg=0:
                                    0;255;3;0;9;TSF:MSG:READ,111-111-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                                    0;255;3;0;9;TSF:MSG:SEND,0-0-111-111,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                                    0;255;3;0;9;TSF:PNG:SEND,TO=0
                                    So I suppose the wiring is okay. I hope this helps!
                                      #39
                                      @TimO
                                      Your screenshots are based on the old driver ;)
                                      You need to use "rfm69_update branch" on my repo. the whole repo. It's based on dev branch, few days ago, with the latest driver.
                                      Thx for your tests and feedbacks :)
                                      • scalzS scalz
                                        @TimO
                                        TimO
                                        @scalz dammit! :-(
                                        Okay, so this time the compiler is throwing errors.
                                        Here are the ones I ruled out:
                                        diff --git a/drivers/RFM69/RFM69.cpp b/drivers/RFM69/RFM69.cpp
                                        index 10d8369..f068ef1 100644
                                        --- a/drivers/RFM69/RFM69.cpp
                                        +++ b/drivers/RFM69/RFM69.cpp
                                        @@ -79,16 +79,20 @@ LOCAL void RFM69_prepareSPITransaction(void)
                                            // set RFM69 SPI settings
                                        +   #if !defined(MY_SOFTSPI) && defined(SPI_HAS_TRANSACTION)
                                            _SPI.setDataMode(RFM69_SPI_DATA_MODE);
                                            _SPI.setBitOrder(RFM69_SPI_DATA_ORDER);
                                            _SPI.setClockDivider(RFM69_SPI_MAX_SPEED); // decided to slow down from DIV2 after SPI stalling in some instances, especially visible on mega1284p when RFM69 and FLASH chip both present
                                        +   #endif
                                         LOCAL void RFM69_concludeSPITransaction(void)
                                        -#ifdef SPI_HAS_TRANSACTION
                                        -   _SPI.endTransaction();
                                        +#ifdef SPI_HAS_TRANSACTION
                                        +      _SPI.endTransaction();
                                        +   #endif
                                            // restore SPI settings to what they were before talking to RFM69
                                         #if defined (SPCR) && defined (SPSR)
                                        @@ -199,7 +203,9 @@ LOCAL bool RFM69_initialise(const float frequency)
                                            // IRQ
                                            pinMode(RFM69_IRQ_DIO_PIN, INPUT);
                                         #if defined (SPI_HAS_TRANSACTION) && !defined (ESP8266)
                                        -   _SPI.usingInterrupt(digitalPinToInterrupt(RFM69_IRQ_DIO_PIN));
                                        +      _SPI.usingInterrupt(digitalPinToInterrupt(RFM69_IRQ_DIO_PIN));
                                        +   #endif
                                            attachInterrupt(digitalPinToInterrupt(RFM69_IRQ_DIO_PIN), RFM69_interruptHandler, RISING);
                                        @@ -1120,4 +1126,4 @@ void readAllRegs(void)
                                        \ No newline at end of file
                                        diff --git a/drivers/RFM69/RFM69.h b/drivers/RFM69/RFM69.h
                                        index 433d6e1..8326f6e 100644
                                        --- a/drivers/RFM69/RFM69.h
                                        +++ b/drivers/RFM69/RFM69.h
                                        @@ -78,11 +78,13 @@
                                         #define RFM69_SPI_CS		(SS)
                                        +#define RFM69_SPI_DATA_MODE		SPI_MODE0		//!< SPI mode
                                         // SPI settings
                                         #if defined (ARDUINO) && !defined (__arm__) && !defined (_SPI)
                                         #if defined(MY_SOFTSPI)
                                        -SoftSPI<MY_SOFT_SPI_MISO_PIN, MY_SOFT_SPI_MOSI_PIN, MY_SOFT_SPI_SCK_PIN, MY_RFM69_SPI_DATA_MODE> _SPI;
                                        +SoftSPI<MY_SOFT_SPI_MISO_PIN, MY_SOFT_SPI_MOSI_PIN, MY_SOFT_SPI_SCK_PIN, RFM69_SPI_DATA_MODE> _SPI;
                                         #define _SPI SPI
                                        @@ -100,7 +102,7 @@ extern HardwareSPI SPI;		//!< SPI
                                         #define RFM69_SPI_DATA_ORDER	MSBFIRST		//!< SPI data order
                                        -#define RFM69_SPI_DATA_MODE		SPI_MODE0		//!< SPI mode
                                         #if !defined(MY_RFM69_SPI_MAX_SPEED)
                                         #define RFM69_SPI_MAX_SPEED		(2000000ul)	//!< SPI speed
                                        @@ -524,4 +526,4 @@ void readAllRegs(void);
                                        (I only have time for a diff, sorry)
                                        After the changes it gets stuck here:
                                        In file included from /home/toberfoe/Arduino/libraries/MySensors/MySensors.h:306:0,
                                                         from /home/toberfoe/ownCloud/workspace/Testumgebung/Gateway-5100-RFM69/GatewayW5100/GatewayW5100.ino:100:
                                        /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp:25:1: error: 'RFM69' does not name a type
                                         RFM69 _radio(MY_RF69_SPI_CS, MY_RF69_IRQ_PIN, MY_RFM69HW, MY_RF69_IRQ_NUM);
                                        /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp: In function 'bool transportInit()':
                                        /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp:32:6: error: '_radio' was not declared in this scope
                                          if (_radio.initialize(MY_RFM69_FREQUENCY, _address, MY_RFM69_NETWORKID)) {
                                        /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp: In function 'void transportSetAddress(uint8_t)':
                                        /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp:47:2: error: '_radio' was not declared in this scope
                                          _radio.setAddress(address);
                                        /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp: In function 'bool transportSend(uint8_t, const void*, uint8_t)':
                                        /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp:57:9: error: '_radio' was not declared in this scope
                                          return _radio.sendWithRetry(to,data,len);
                                        /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp: In function 'bool transportAvailable()':
                                        /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp:62:9: error: '_radio' was not declared in this scope
                                          return _radio.receiveDone();
                                        /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp: In function 'uint8_t transportReceive(void*)':
                                        /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp:73:28: error: '_radio' was not declared in this scope
                                          memcpy(data,(const void *)_radio.DATA, _radio.DATALEN);
                                        /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp: In function 'void transportPowerDown()':
                                        /home/toberfoe/Arduino/libraries/MySensors/core/MyTransportRFM69.cpp:85:2: error: '_radio' was not declared in this scope
                                          _radio.sleep();
                                        exit status 1
                                        I have no time to investigate it further till saturday. :-/
                                          this is because you have not completely updated your Mysensors folder.
                                          The driver only is not enough because there are changes in others files like MyTransportRFM69.cpp, MyConfig etc..
                                          T J 2 Replies Last reply
