  3. Battery Operated Door Magnet Sensor
8 Posts 5 Posters 6.0k Views 5 Watching
  • sghazaghS Offline
    sghazaghS Offline
    sghazagh
    wrote on last edited by sghazagh
    Hi guys,
    I have created a circuit base on this "https://forum.mysensors.org/topic/486/my-2aa-battery-sensor" and it works fine.
    However, I have changed the code slightly to only read the battery state to calculated the battery percentage only when status of door switch changed.
    I know I have to sleep the arduino and radio to save battery but don't know where I have sleep it.
    My code is attached can you please advise me how can I change the code to be able to read the status of door change as quick as possible without delay and also be able to read/calculate battery percentage as well.
    here is my code:
       DESCRIPTION
       Simple binary switch example
       Connect button or door/window reed switch between
       digitial I/O pin 3 (BUTTON_PIN below) and GND.
       http://www.mysensors.org/build/binary
    //Fixed NodeID in Domoticz
    #define MY_NODE_ID 8
    #define CHILD_ID 5
    #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
    Bounce debouncer = Bounce();
    int oldValue = -1;
    unsigned long SLEEP_TIME = 900000;  // sleep time between reads (seconds * 1000 milliseconds)
    int oldBatteryPcnt = 0;
        analogReference(INTERNAL1V1);
        analogReference(INTERNAL);
      // Setup the button
      pinMode(BUTTON_PIN, INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      sendSketchInfo("Enterance-Door-Sensor", "1.0");
      present(CHILD_ID, S_DOOR);
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
        // Send in the new value
        send(msg.set(value == HIGH ? 1 : 0));
        oldValue = value;
        BatteryMeasurment();
     ////// sleep(SLEEP_TIME);    //Can I add it here, in this case does the door sensor response quickly to any state change?
    void BatteryMeasurment(){
      // get the battery Voltage
      #ifdef MY_DEBUG
        Serial.println(sensorValue);
      #ifdef MY_DEBUG
        Serial.print(batteryV);
        Serial.println(" V");
        Serial.print(batteryPcnt);
        Serial.println(" %");
          // Power up radio after sleep
          oldBatteryPcnt = batteryPcnt;
    If it's wrong, how can I attach the pin 3 , which is door contact switch pin, to an interrupt to responds as soon as state changes?
    Please note that the radio IRQ is connected to pin 2 of Arduino already!
    Many thanks,
    • sghazaghS sghazagh
      Hi guys,
      here is my code:
         DESCRIPTION
      #define CHILD_ID 5
      int oldValue = -1;
        // Setup the button
        debouncer.update();
          oldValue = value;
        #ifdef MY_DEBUG
        #ifdef MY_DEBUG
      Many thanks,
      M Offline
      M Offline
      m26872
      @sghazagh You have to use sleep with interrupt but you can't use sleep at all with debounce library. Look at this example for how to do it: https://github.com/mysensors/MySensors/blob/development/examples/BinarySwitchSleepSensor/BinarySwitchSleepSensor.ino
      (The sleep(5) -debounce delay can be extende a bit in my opinion though.)
      sghazaghS 1 Reply Last reply
      • T Offline
        T Offline
        Takero
        wrote on last edited by Takero
        Look at my node: I used HW-Debounce and deep sleep.
        Sketch inside.
        https://www.openhardware.io/view/266/DoorWindow-Sensor
        • M m26872
          sghazaghS Offline
          sghazaghS Offline
          sghazagh
          @m26872 Thank you very much mate.
          I just added the battery reporting part and it works like a charm.
          Many many thanks...
          C T 2 Replies Last reply
            Many many thanks...
            C Offline
            C Offline
            carleki
            Many many thanks...
            Did you add 1MOhm resistor between the Input pin and the reed switch ?
            • C carleki
              Many many thanks...
              sghazaghS Offline
              sghazaghS Offline
              sghazagh
              @carmelo42 Yes, I did.
              See this page: https://forum.mysensors.org/topic/486/my-2aa-battery-sensor (Edit 2 image)
              I used this as a base. Except, instead of DH22, I used magnetic sensor connected to pin 3 and GND of Arduino Pro mini.
              • C Offline
                C Offline
                carleki
                Thanks a lot for your answer :)
                I must be an idiot but ... I can't compile your sketch ... Which version of MySensors lib are you using ? (I'm with 1.5.4)
                  Many many thanks...
                  T Offline
                  T Offline
                  tomix
                  @sghazagh Hi I am new. How to do reporting part of the battery.
