  3. Error : Reconnection the sensors when gateway was down and pass to up
1 Posts 1 Posters 431 Views 1 Watching
  • fsoleanskyF
    fsoleanskyF
    fsoleansky
    I found a defect when serial gateway pass to up to down and down to up.
    I have a serial gateway and 2 sensors.
    At first time :
    Gateway is up and I start sensors. result : Sensors is detect by gateway
    If gateway go down and go up after a few minutes, sensors are no longer detected after.
    If i made a reset on sensors, sensors are again detecting
    I had the idea to put a push button on the case to make a reset of the sensors but there is also the possibility of putting an Hall element AH44E on the pin reset so with a magnet able to do a reset without opening the case
    What do you think ?
    12.5k
