  3. Ethernet Gateway not working with Vera..
3 Posts 1 Posters 1.1k Views 1 Watching
  • borgejeB
    borgejeB
    borgeje
    HI,
    This is my first time here, so bare with me if this has been discussed previously or if the question isnt that smart.
    I had working with my Vera a Serial gateway, but based on the issues I saw mentioned about its reliability, decided to build an ETHERNET GATEWAY. Using arduino UNO, W5100 Shield, and tried several radios, lately using the antena one for NRF24. The setup follows the latest news on the website, including the different pinout in the radio.
    Here is the issue: "MySensors plugin : Cannot send command - communications error" shows on my Vera. And when i hook up serial monitor to this on the computer, I keep getting the messages below over and over (seems werid), and it doesnt seem the sketch ever reaches the main loop..
    "0;255;3;0;9;Starting gateway (RNNGA-, 2.0.0)
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    IP: 192.168.1.98
    IP: 192.168.1.98
    IP: 192.168.1.98
    IP: 192.168.1.98
    IP: 192.168.1.98
    What can this be? The sketch is below
    • The MySensors Arduino library handles the wireless radio link and protocol
    • between your home built sensors/actuators and HA controller of choice.
    • The sensors forms a self healing radio network with optional repeaters. Each
    • repeater and gateway builds a routing tables in EEPROM which keeps track of the
    • network topology allowing messages to be routed to nodes.
    • Created by Henrik Ekblad henrik.ekblad@mysensors.org
    • Copyright (C) 2013-2015 Sensnology AB
    • Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
    • Documentation: http://www.mysensors.org
    • Support Forum: http://forum.mysensors.org
    • This program is free software; you can redistribute it and/or
    • modify it under the terms of the GNU General Public License
    • version 2 as published by the Free Software Foundation.
    • REVISION HISTORY
    • Version 1.0 - Henrik EKblad
    • Contribution by a-lurker and Anticimex,
    • Contribution by Norbert Truchsess norbert.truchsess@t-online.de
    • Contribution by Tomas Hozza thozza@gmail.com
    • DESCRIPTION
    • The EthernetGateway sends data received from sensors to the ethernet link.
    • The gateway also accepts input on ethernet interface, which is then sent out to the radio network.
    • The GW code is designed for Arduino 328p / 16MHz. ATmega168 does not have enough memory to run this program.
    • LED purposes:
      • To use the feature, uncomment WITH_LEDS_BLINKING in MyConfig.h
      • RX (green) - blink fast on radio message recieved. In inclusion mode will blink fast only on presentation recieved
      • TX (yellow) - blink fast on radio message transmitted. In inclusion mode will blink slowly
      • ERR (red) - fast blink on error during transmission error or recieve crc error
    • See http://www.mysensors.org/build/ethernet_gateway for wiring instructions.
    #define MY_DEBUG // Enable debug prints to serial monitor
    #define MY_GATEWAY_W5100 // Enable gateway ethernet module type
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #define MY_SOFT_SPI_SCK_PIN 16
    #define MY_SOFT_SPI_MISO_PIN 15
    #define MY_SOFT_SPI_MOSI_PIN 14
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    #ifndef MY_RF24_PA_LEVEL
    // Enable to UDP
    #define MY_USE_UDP
    #define MY_IP_ADDRESS 192,168,1,98 // If this is disabled, DHCP is used to retrieve address
    #define MY_PORT 5004
    // Note that most of the Ardunio examples use "DEAD BEEF FEED" for the MAC address.
    // Flash leds on rx/tx/err
    // Set blinking period
    #define MY_INCLUSION_MODE_FEATURE// Enable inclusion mode
    #define MY_INCLUSION_BUTTON_FEATURE// Enable Inclusion mode button on gateway
    #define MY_INCLUSION_MODE_DURATION 60 // Set inclusion mode duration (in seconds)
    #define MY_INCLUSION_MODE_BUTTON_PIN 3 // Digital pin used for inclusion mode button
    //#define MY_DEFAULT_ERR_LED_PIN 7 // Error led pin
    //#define MY_DEFAULT_RX_LED_PIN 8 // Receive led pin
    //#define MY_DEFAULT_TX_LED_PIN 9 // the PCB, on board LED
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    #include <DigitalIO.h>
    Serial.println("test");
    wait(200);
    pics of the harware
    ![alt text](image url)
    borgejeB 1 Reply Last reply
    • borgejeB borgeje
      HI,
      IP: 192.168.1.98
      IP: 192.168.1.98
      IP: 192.168.1.98
      IP: 192.168.1.98
      IP: 192.168.1.98
      • REVISION HISTORY
      • DESCRIPTION
      • LED purposes:
      #define MY_SOFTSPI
      // Enable to UDP
      #define MY_USE_UDP
      wait(200);
      pics of the harware
      borgejeB
      borgejeB
      borgeje
      @borgeje alt text
      • borgejeB
        borgejeB
        borgeje
        12.5k
