  2. Announcements
  • jirmJ
    jirmJ
    jirm
    I´m in the same boat as you, because for the moment I choose OPI hardware for my HA (Home Automation) system.
    Agree with you that Armbian is much better OS than Raspbian in general terms and preferably the path to walk through for OPI, but in that case always we walk on a parallel side because Raspbian is today the most prefered OS for IoT on developments because Raspberry is the predominant hardware. So that means in future we need fight each installation.
    In that case, Armbian forums sure is necesary place that can help to solve that problem too, but I think first better post here on mysensors software forums to try to get some more light about that specific error about mysensors gateway install process, and then at least have more info to report to someone that can help in Armbian.
    I'm trying to find some help more about the issues you raise and if you maintain posting updates here will be so good for me and sure for others that can use OPI too now or on future.
    OPI´s I´m sure is in near future a very good hardware (because they're so good relation cost-performance and quality) that mucho more people would choose for next coming IoT projects.
    Regards
    jirmJ 1 Reply Last reply
    • jirmJ jirm
      Regards
      jirmJ
      jirmJ
      jirm
      wrote on last edited by jirm
      #188
      @aand
      The error you post seems because gcc compiler is not well supporting the processor, so maybe need substitute all gcc compiler version in the OS to solve the issue (that's I wanted say before with update).
      apt-get update/upgrade cannot substituting "any" software to other because doing this only can push to last version the existing installed branch on the yet installed software on the OS.
      So It's not any dependence error it's a gcc compiler error raised for some weird version incompatibility with the hardware installed. Strange error but this is seems means message error you posted. So seems needed reinstall all gcc compiler to avoid that.
      Hope I explain enough...sorry about my bad english ;-)
      See you...
        musthafa
        Can I install mysensors on a openhab installed RPi ?
        • Robinek70R Robinek70
          Hello everyone,
          I've been working gateway on RPi, but I don't know how to configure MY_SIGNING_SOFT .
          File mysgw.cpp contains MY_SIGNING_SOFT definition and I can uncomment it, but I don't know where and how I should define: SOFT_HMAC_KEY, SOFT_SERIAL and AES_KEY ?
          Could you give more details how to configure soft signing on RPi?
          thanks
          //Robert
          marceloaqno
          Code Contributor
          wrote on last edited by marceloaqno
          #190
          @Robinek70
          $ sudo mysgw -h
          Usage: mysgw [options]
          Options:
          To generate a soft hmac key, run:
          sudo mysgw --gen-soft-hmac-key
          and set it using:
          sudo mysgw  --set-soft-hmac-key=KEY
          For example:
          $ sudo mysgw --gen-soft-hmac-key
          SOFT_HMAC_KEY | 7F3F1A1C1EA32B72BF4BEDE2D16543971C26442F69572177D9CCDE393BFB8126
          The next line is intended to be used in SecurityPersonalizer.ino:
          #define MY_SOFT_HMAC_KEY 0X7F,0X3F,0X1A,0X1C,0X1E,0XA3,0X2B,0X72,0XBF,0X4B,0XED,0XE2,0XD1,0X65,0X43,0X97,0X1C,0X26,0X44,0X2F,0X69,0X57,0X21,0X77,0XD9,0XCC,0XDE,0X39,0X3B,0XFB,0X81,0X26
          To use this key, run mysgw with:
           --set-soft-hmac-key=7F3F1A1C1EA32B72BF4BEDE2D16543971C26442F69572177D9CCDE393BFB8126
          $ sudo mysgw --set-soft-hmac-key=7F3F1A1C1EA32B72BF4BEDE2D16543971C26442F69572177D9CCDE393BFB8126
          The same process applies to generate/set the other key types.
            marceloaqno
            Code Contributor
            #191
            @aand @Tag @jirm MySensors uses its own nrf24 drivers, and OrangePi is not currently supported. It will be in the future.
            jirmJ T 2 Replies Last reply
            • M marceloaqno
              jirmJ
              jirmJ
              jirm
              @marceloaqno
              You mean the error posted @aand is because that?
              You mean mysgw use own NRF24 drivers that is not supported on OPI although he have running Raspbian version?.
              In any case, if so will be really fine if mysgw software allowed (or provide information about how to do it) to use any NRF24 driver (ex. TMRh20 fork that is working fine on OPI) and maybe too Hope RFMXX (I´m most interested in this last transceivers) because I think that generally speaking make a rigidly link with a type of hardware is not the best thing that can be done to really give the best functionality to any application.
              Still keep waiting for anyone here than can help to install mysgw softw on OPI.
              Thanks for your information
              Best regards
              • Robinek70R
                Robinek70R
                Robinek70
                @marceloaqno, Thanks a lot
                luizrrochaL 1 Reply Last reply
                  luizrrochaL
                  luizrrochaL
                  luizrrocha
                  Ditto, @Robinek70 !
                  'nuff said.
                  Luiz Roberto
                  • jirmJ jirm
                    @marceloaqno
                    Best regards
                    marceloaqno
                    Code Contributor
                    @jirm If you try to use the nrf24h radio you will get the same error as the @Tag post:
                    ./MySensors.h:258:2: error: #error No support for nRF24 radio on this platform
                    For @aand error, it's what you mention in your early post, a gcc compiler issue.
                    MySensors nrf24 drivers uses the SPI interface to drive the module, it's the same driver for all supported platforms (RPi, esp8266, atmega328p, ...), this way it is easier to maintain.
                    I understand that it must have been frustrating to find out that it does not work for the OPi but there isn't much I can do to help you. I bought one too, still waiting to arrive.
                    • M musthafa
                      marceloaqno
                      Code Contributor
                      @musthafa I'll give it a try. What version of openhab are you using?
                      T M 2 Replies Last reply
                      • M marceloaqno
                        Tag
                        wrote on last edited by Tag
                        #197
                        @marceloaqno
                        Thank you for your help here!! would be great to have mysgw on the OPI!
                        I am using armbian on a OPI zero, so let me know if you need any further info.
                        (Also using an RPI, which runs mysgw with direct connected radio like a charm!)
                        Kind regards,
                        Tag
                        • aandA
                          aandA
                          aand
                          @marceloaqno said "MySensors uses its own nrf24 drivers, and OrangePi is not currently supported. It will be in the future."
                          I wish it worked now, but I don't mind waiting. Just to clarify where I'm coming from -- Orange Pi One hardware running Armbian. Thanks!
                          I'll be keeping watching the updates!
                          • M marceloaqno
                            musthafa
                            @marceloaqno
                            OpenHab 2
                            • M marceloaqno
                              jirmJ
                              jirmJ
                              jirm
                              #200
                              @marceloaqno
                              Really thanks a lot for your work and very much appreciate you try to help us on our "fight" with the OPI board.
                              Sadly in this moment I cannot work because I'm out of time to try install all softw stuff on my OPI and try help much more to push it working with mysgw and so on.
                              I don't understand so much why is not working out of the box and the driver issue found and/what hardware communication issue are only on OPI with that similar derived Raspbian OS like Raspberry, and too not understand why cannot work on OPI because that SPI bus issue you say.
                              @aand reported nrf24 module work very well with TMRh20 driver, so seems hardware are OK on OPI for the module and I suppose still only discover and hopefully make it work avoiding the driver issue you say to compile properly mysgw softw.
                              Anyway, I only hope that anyone can help mainly here to make work mysgw on OPI too, and adapt it to work on Armbian, because OPI is a really good choice for HA controller board and sure in near future much people use it.
                              Is there any chance to substitute own nfr24 driver mysgw with the TMR20h, at least for testing purposes on OPI?
                              If any mysgw "code" people are reading this maybe can try to help us with some idea to try workaround the compilation issue on OPI.
                              Best regards and again many thanks!
                              PD: Only for test SPI purposses on armbian this can help (post 248) :
                              https://forum.armbian.com/index.php/topic/617-wip-orange-pi-one-support-for-the-upcoming-orange-pi-one/page-9#entry5747
                              Only for info, other interesting post about how to make work nrf24l01 module on OPI and armbian:
                              https://forum.armbian.com/index.php/topic/3161-orange-pi-one-with-nrf24l01/
                              Another one interesting post OPI One with armbian using NRF24 module:
                              • M musthafa
                                @marceloaqno
                                OpenHab 2
                                marceloaqno
                                Code Contributor
                                #201
                                @musthafa Openhab2 works using mysgw configured as an ethernet gateway. This is the guide I used: https://github.com/tobof/openhab2-addons/wiki
                                • H
                                  H
                                  hausinger
                                  Hello.
                                  I'm also using a orangepi one and wanted to build the gateway on it. But i didn't want to use the nrf24 but a usb to rs485 converter. But if i want to compile it, i get also the same error with the nrf24 and that it is not supporting platform. Why?
                                  Also if i want to build a serial gateway with a connected arduino on usb port, i got the same error with the nrf24
                                  • M marceloaqno
                                    musthafa
                                    @marceloaqno thank you.
                                    I have already installed OpenHAB 2 on my RPi. Can I install mysgw on to the same RPi ?
                                    • aandA
                                      aandA
                                      aand
                                      @hausinger -- are you running armbian on your orange pi one?
                                      H 1 Reply Last reply
                                      • OliO
                                        OliO
                                        Oli
                                        How can I update MySensors Gateway from 2.1.0 beta to 2.1.0 stable/final release?
                                        • M musthafa
                                          marceloaqno
                                          Code Contributor
                                          @musthafa Yes, set the IP Address to 127.0.0.1 in your openhab for the ethernet gateway.
