  2. Announcements
  • M marceloaqno
    @aand @Tag @jirm MySensors uses its own nrf24 drivers, and OrangePi is not currently supported. It will be in the future.
    jirmJ
    jirmJ
    jirm
    @marceloaqno
    You mean the error posted @aand is because that?
    You mean mysgw use own NRF24 drivers that is not supported on OPI although he have running Raspbian version?.
    In any case, if so will be really fine if mysgw software allowed (or provide information about how to do it) to use any NRF24 driver (ex. TMRh20 fork that is working fine on OPI) and maybe too Hope RFMXX (I´m most interested in this last transceivers) because I think that generally speaking make a rigidly link with a type of hardware is not the best thing that can be done to really give the best functionality to any application.
    Still keep waiting for anyone here than can help to install mysgw softw on OPI.
    Thanks for your information
    Best regards
    • Robinek70R
      Robinek70R
      Robinek70
      @marceloaqno, Thanks a lot
      luizrrochaL 1 Reply Last reply
      • Robinek70R Robinek70
        luizrrochaL
        luizrrochaL
        luizrrocha
        Ditto, @Robinek70 !
        'nuff said.
        Luiz Roberto
        • jirmJ jirm
          @marceloaqno
          Best regards
          marceloaqno
          Code Contributor
          @jirm If you try to use the nrf24h radio you will get the same error as the @Tag post:
          ./MySensors.h:258:2: error: #error No support for nRF24 radio on this platform
          For @aand error, it's what you mention in your early post, a gcc compiler issue.
          MySensors nrf24 drivers uses the SPI interface to drive the module, it's the same driver for all supported platforms (RPi, esp8266, atmega328p, ...), this way it is easier to maintain.
          I understand that it must have been frustrating to find out that it does not work for the OPi but there isn't much I can do to help you. I bought one too, still waiting to arrive.
          jirmJ 1 Reply Last reply
          • M musthafa
            Can I install mysensors on a openhab installed RPi ?
            marceloaqno
            Code Contributor
            @musthafa I'll give it a try. What version of openhab are you using?
            T M 2 Replies Last reply
            • M marceloaqno
              Tag
              wrote on last edited by Tag
              #197
              @marceloaqno
              Thank you for your help here!! would be great to have mysgw on the OPI!
              I am using armbian on a OPI zero, so let me know if you need any further info.
              (Also using an RPI, which runs mysgw with direct connected radio like a charm!)
              Kind regards,
              Tag
              • aandA
                aandA
                aand
                @marceloaqno said "MySensors uses its own nrf24 drivers, and OrangePi is not currently supported. It will be in the future."
                I wish it worked now, but I don't mind waiting. Just to clarify where I'm coming from -- Orange Pi One hardware running Armbian. Thanks!
                I'll be keeping watching the updates!
                • M marceloaqno
                  musthafa
                  @marceloaqno
                  OpenHab 2
                  • M marceloaqno
                    jirmJ
                    jirmJ
                    jirm
                    wrote on last edited by jirm
                    #200
                    @marceloaqno
                    Really thanks a lot for your work and very much appreciate you try to help us on our "fight" with the OPI board.
                    Sadly in this moment I cannot work because I'm out of time to try install all softw stuff on my OPI and try help much more to push it working with mysgw and so on.
                    I don't understand so much why is not working out of the box and the driver issue found and/what hardware communication issue are only on OPI with that similar derived Raspbian OS like Raspberry, and too not understand why cannot work on OPI because that SPI bus issue you say.
                    @aand reported nrf24 module work very well with TMRh20 driver, so seems hardware are OK on OPI for the module and I suppose still only discover and hopefully make it work avoiding the driver issue you say to compile properly mysgw softw.
                    Anyway, I only hope that anyone can help mainly here to make work mysgw on OPI too, and adapt it to work on Armbian, because OPI is a really good choice for HA controller board and sure in near future much people use it.
                    Is there any chance to substitute own nfr24 driver mysgw with the TMR20h, at least for testing purposes on OPI?
                    If any mysgw "code" people are reading this maybe can try to help us with some idea to try workaround the compilation issue on OPI.
                    Best regards and again many thanks!
                    PD: Only for test SPI purposses on armbian this can help (post 248) :
                    https://forum.armbian.com/index.php/topic/617-wip-orange-pi-one-support-for-the-upcoming-orange-pi-one/page-9#entry5747
                    Only for info, other interesting post about how to make work nrf24l01 module on OPI and armbian:
                    https://forum.armbian.com/index.php/topic/3161-orange-pi-one-with-nrf24l01/
                    Another one interesting post OPI One with armbian using NRF24 module:
                    • M musthafa
                      @marceloaqno
                      OpenHab 2
                      marceloaqno
                      Code Contributor
                      wrote on last edited by marceloaqno
                      #201
                      @musthafa Openhab2 works using mysgw configured as an ethernet gateway. This is the guide I used: https://github.com/tobof/openhab2-addons/wiki
                      • H
                        H
                        hausinger
                        Hello.
                        I'm also using a orangepi one and wanted to build the gateway on it. But i didn't want to use the nrf24 but a usb to rs485 converter. But if i want to compile it, i get also the same error with the nrf24 and that it is not supporting platform. Why?
                        Also if i want to build a serial gateway with a connected arduino on usb port, i got the same error with the nrf24
                        • M marceloaqno
                          musthafa
                          @marceloaqno thank you.
                          I have already installed OpenHAB 2 on my RPi. Can I install mysgw on to the same RPi ?
                          • aandA
                            aandA
                            aand
                            @hausinger -- are you running armbian on your orange pi one?
                            H 1 Reply Last reply
                            • OliO
                              OliO
                              Oli
                              How can I update MySensors Gateway from 2.1.0 beta to 2.1.0 stable/final release?
                              • M musthafa
                                marceloaqno
                                Code Contributor
                                @musthafa Yes, set the IP Address to 127.0.0.1 in your openhab for the ethernet gateway.
                                • aandA aand
                                  H
                                  H
                                  hausinger
                                  Yes, I'm running on armbian on my orange pi one
                                  • aandA aand
                                    @jirm Thanks for the suggestion. I've downloaded the raspian image. To duplicate the path I used with armbian, I downloaded TMRh20's RF24 code so I can test the radio with code I've already had up and running on the hardware.. However, this version of raspbian is really bad. So far nothing compiles. Regular raspbian, and armbian on the orange pi one do not have this kind of problem out of the box; they compile a wide range of packages. I'll spend some more time on it to be diligent, but this distro looks like it needs to be put on the abandon pile.
                                    I tried compiling mysensors gateway too but no luck with that yet either. This is what I get:
                                    ./configure
                                    [OK] init system detected: sysvinit
                                    [OK] Finished.
                                    make
                                    gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RA
                                    DIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -c drivers/Linux/log
                                    .c -o build/drivers/Linux/log.o
                                    cc1: error: bad value (armv8-a) for -march switch
                                    cc1: error: bad value (cortex-a53) for -mtune switch
                                    Makefile:102: recipe for target 'build/drivers/Linux/log.o' failed
                                    jirmJ
                                    jirmJ
                                    jirm
                                    @aand
                                    Hi again!
                                    I spend some time seeing and reading some of the files from the mysensors github build and I see some things that can help to understand why the error raised to @aand trying to compile on OPI.
                                    First say that I´m not a coding expert, so please be nice with my if I´m wrong and say something stupid ;-)
                                    I see in the .configure file that the machine detection have H3 Soc and this are fine detected , but then I see that selecting type and CPU flags seems not properly selected to match OPI specs , because on OPI soc H3 have a cpu armv7 (not armv8) and is a A20 and not A53.
                                    So maybe that cpu "selection" is not correct for H3 soc , and is so easy try if anyone that have OPI and have time can change only that values in the config file and try to compile.
                                    All the values on the A20 line seems correct for the OPI H3 soc, so only needed copy them from the A20 line to the H3 line, and give a try.
                                    File Configure
                                    function gcc_cpu_flags {
                                    local soc=$1
                                    case $soc in
                                    BCM2835)
                                    flags="-march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard"
                                    BCM2836)
                                    flags="-march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard"
                                    AM33XX)
                                    flags="-march=armv7-a -mtune=cortex-a8 -mfpu=neon -mfloat-abi=hard"
                                    A10)
                                    A13)
                                    A20)
                                    H3)
                                    flags="-march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard"
                                    • M marceloaqno
                                      musthafa
                                      @marceloaqno Thank you!
                                      • eyesoftE
                                        eyesoftE
                                        eyesoft
                                        also on banana pi pro when i trie to compile i'm getting this :
                                        [OK] machine detected: SoC=A20, Type=unknown, CPU=armv7l.
                                        [OK] Finished.
                                        type i think must be BananaPro
                                        on make :
                                        -o build/examples_linux/mysgw.o
                                        from ./MySensors.h:294,
                                        compilation terminated.
                                        so Banana Pi Pro soc A20 it's also on wait list or never worked ?
                                        • eyesoftE eyesoft
                                          [OK] Finished.
                                          on make :
                                          jirmJ
                                          jirmJ
                                          jirm
                                          #211
                                          @eyesoft
                                          Yes...I see. That error is that said @marceloaqno about own mysensors NRF24 drivers and SPI bus adapt for Raspberry, because for now mysensors is only supported at Raspi and arduinos.
                                          On Banana CPU detection seems work better (I agree type seems not good...maybe you can change this on configure file and give a try to compile to see what happends) and I figure can work too on OPI too only changing that I said before, but then is raised NRF24 driver and SPI error.
                                          I see that mysensors RF24 driver are derivated from that https://github.com/mz-fuzzy/RF24 build that at same time last this is forked directly from http://tmrh20.github.io/RF24Installer/RPi/install.sh that we know are working fine on OPI and armbian, so I figure that maybe it´s not so much hard to modify mysensors RF24 to adapt to work on OPI.
                                          Hope any mysensors "coder" ear our call and cand give us some hand to make the changes on the mysensors build and we can compile the mysgw to OPI soon.
