  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 676.6k Views 99 Watching
  • tademetT tademet
    @jogant
    I have added the config to the thing file.
    Bridge mysensors:bridge-eth:gateway [ ipAddress:"10.9.167.116", tcpPort=5003, sendDelay=200, imperial=true] {
    But still getting the error:
    08:10:25.214 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Connecting to IP bridge [null:5003]
    08:10:25.215 [ERROR] [al.protocol.ip.MySensorsIpConnection] - IP must be not null/empty
    08:10:25.216 [ERROR] [al.protocol.ip.MySensorsIpConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:3)
    08:10:25.217 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Disconnecting from IP bridge ...
    I changed the port and it recognized that change but is not recognizing ipAddress. Am I misspelling this?
    TimO
    @tademet there's a ":" instead of a "=" between ipAddress and the IP adress.
    • N
      N
      Nicklas Starkel
      Just stumbled across this binding great work!
      Until now I have used MQTT binding and MQTT gateway.
      Will try this later on.
      However, is there a reason why this binding is not part as downloadable from within OH2?
      Cheers :)
      • N Nicklas Starkel
        Cheers :)
        TimO
        Hey @Nicklas-Starkel !
        I hope it will work out for you! :-)
        It is not yet part of OH2 and downloadable within OH2 because my pull request is still open. A OH2 developer needs to look at it. :-)
        infragI K 2 Replies Last reply
        • T TimO
          infragI
          infragI
          infrag
          @TimO
          I've downloaded your code from github for this binding and tried to modify it a bit for my specific needs. However I'm having trouble compiling it. I've then gone back to basics and added in your unedited code to Eclipse. However it complains about:
          @Override
          public void bridgeHandlerDisposed(ThingHandler thingHandler, Bridge bridge)
          Saying : The method bridgeHandlerDisposed(Thinghandler,Bridge) of type MySensorsHandler must override or implement a supertype method.
          Do you have any advice for me on this? :)
          Thanks for your work on this!
          infragI 1 Reply Last reply
          • infragI infrag
            @TimO
            @Override
            infragI
            infragI
            infrag
            @TimO
            According to this:
            https://www.eclipse.org/smarthome/documentation/javadoc/org/eclipse/smarthome/core/thing/binding/ThingHandler.html#bridgeStatusChanged-org.eclipse.smarthome.core.thing.ThingStatusInfo-
            The old method of bridgeHandlerDisposed is Depreciated now.
            • infragI infrag
              @TimO
              According to this:
              TimO
              Hey @infrag !
              Switch to the MySensors branch, the master branch is outdated. :-)
              infragI FutureCowF 2 Replies Last reply
              • T TimO
                Hey @infrag !
                infragI
                infragI
                infrag
                @TimO
                ah that explains it. Thanks! :)
                • T TimO
                  Hey @infrag !
                  FutureCowF
                  FutureCowF
                  FutureCow
                  @TimO
                  I'm trying to add a CO2 sensor. What is the sensor i need to select inside OpenHAB?
                  TSP:MSG:SEND 70-70-0-0 s=0,c=1,t=37,pt=4,l=4,sg=0,ft=0,st=ok:1162
                  CO2 level = 1162 ppm
                  sketch:
                  MyMessage msg(CHILD_ID_AIQ, V_LEVEL);
                  present(CHILD_ID_AIQ, S_AIR_QUALITY);
                  ? 1 Reply Last reply
                  • FutureCowF FutureCow
                    @TimO
                    sketch:
                    A Former User
                    Hello everyone,
                    In an OH2 environment with 2 nodes reporting temperature, one attached to the gateway and one on his own I receive the following error:
                    [ERROR] [rs.internal.protocol.MySensorsReader] - (java.lang.IllegalStateException: Could not update state, because callback is missing) on reading from connection, message: class org.openhab.binding.mysensors.internal.protocol.serial.MySensorsSerialReader
                    The node attached to the gateway works fine, his item gets updated but the other one not.
                    The only code difference between their loop methods are calls to isTransportOK() and receiveTime() which are made by the latter node.
                    Doesn't this version support those 2 methods or I'm missing something ?
                    https://github.com/tobof/openhab2-addons/blob/MySensors/addons/binding/org.openhab.binding.mysensors/target/org.openhab.binding.mysensors-2.0.0-SNAPSHOT.jar
                    Thx for all the hard work on this library :smiley:
                    • ? A Former User
                      Hello everyone,
                      TimO
                      Hey @frg !
                      1. receiveTime() is supported by the binding and should work. In the binding log should appear a message like:
                      I_TIME request received from 123, answering...
                      Do you have some more log for me?
                      1. isTransportOK() is only handled within the node, no message is send so there is nothing the binding could support. By the way, the method was renamed to isTransportReady() with the current version 2.1.0.
                      Are there no updates from the second node? Did you check in the serial log of the node that messages were sent?
                      • T TimO
                        Hey @frg !
                        A Former User
                        @TimO
                        Well this is bit of embarrassing...after changing the sleep time from 5 minutes to 1 minute for the troublesome node and re-uploading the sketch, it is reporting the temperature just fine. I tried all kinds of combinations trying to replicate the initial behavior, stopped the controller, rebooted the gateway, powered them off for while, moving back to 5 minutes sleep, to no avail, node registers and the temperature is reporting is showed in the paperui.
                        On the other hand I don't see that I_TIME request received from... message in the logs (used log:set DEBUG org.openhab.binding.mysensors and log:tail) so I'm not sure if the receiveTime() is called.
                        I suppose I can write something in the EEPROM when the callback function runs and check that.
                        Thank you
                        01:30:45.291 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                        01:30:50.280 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;0;1;0;0;22.0
                        01:30:50.282 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 2 to 2017-01-06T01:30:50.281+0200
                        01:30:50.285 [INFO ] [marthome.event.ItemStateChangedEvent] - TemperatureOutside_LastUpdate changed from 2017-01-06T01:28:52.282+0200 to 2017-01-06T01:30:50.281+0200
                        01:30:53.550 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;1;1;0;0;23.1
                        01:30:55.292 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                        01:31:05.293 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                        01:31:15.293 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                        01:31:25.294 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                        01:31:35.294 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                        01:31:45.295 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                        01:31:49.287 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;0;1;0;0;22.0
                        01:31:53.541 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;1;1;0;0;23.1
                        01:31:53.544 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 0 to 2017-01-06T01:31:53.543+0200
                        01:31:53.552 [INFO ] [marthome.event.ItemStateChangedEvent] - TemperatureGateway_LastUpdate changed from 2017-01-06T01:29:53.559+0200 to 2017-01-06T01:31:53.543+0200
                        01:31:55.295 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                        01:32:05.296 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                        01:32:15.296 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                        01:32:25.297 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                        01:32:35.298 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                        01:32:45.298 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                        01:32:48.283 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;0;1;0;0;22.0
                        01:32:48.284 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 2 to 2017-01-06T01:32:48.284+0200
                        01:32:48.290 [INFO ] [marthome.event.ItemStateChangedEvent] - TemperatureOutside_LastUpdate changed from 2017-01-06T01:30:50.281+0200 to 2017-01-06T01:32:48.284+0200
                        01:32:53.532 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;1;1;0;0;23.1
                        01:32:55.299 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                        Node 0 is gateway attached, Node 2 is battery run -TemperatureOutside.
                        • ? A Former User
                          @TimO
                          Thank you
                          TimO
                          @frg Sometimes magic just happens. 😉
                          I'm glad it is working now! :+1:
                          • F
                            F
                            Fabien
                            I try to send ORP calibration value to my sensors but it doesn't work.
                            NODE_ID : 10, CHILD_NODE_ID : 0
                            When I'm recieve ORP from my sensors it's ok :
                            13:55:38.216 [DEBUG] [rs.internal.protocol.MySensorsReader] - 10;0;1;0;52;996.3
                            But when I change the value, the value is not send :
                            14:09:24.051 [INFO ] [marthome.event.ItemStateChangedEvent] - orp01 changed from 40 to 50
                            14:09:24.266 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'orp01' received command 60
                            14:09:24.266 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 10;0;1;0;0;
                            Item :
                            Number	orp01	"Redox [%.1f mV]" <faucet> (gPiscine) { channel="mysensors:waterQuality:gateway:orp01:orp"}
                            Sitemap :
                              sitemap test label="Main Menu" {
                                Frame label="Piscine" {
                            		Setpoint item=orp01 label="Calirabte ORP" minValue=0 maxValue=1000 step=10
                            • F Fabien
                              Item :
                              Sitemap :
                              TimO
                              @Fabien I need a little bit more time to reproduce this behaviour. I've opened an issue here: https://github.com/tobof/openhab2-addons/issues/50
                              • AndrewZA
                                AndrewZA
                                AndrewZ
                                wrote on last edited by AndrewZ
                                #349
                                Hello everyone
                                I'm slowly migrating to OH2, my small MySensors network generally works fine but I see some weird behavior with the binding configuration in Paper UI.
                                So far it looks like "Disable network sanity check" is reversed - I'm sliding it to the left which means for me 'not disabled', i.e. 'enabled', but in the log I see "Checker thread disabled".
                                2017-01-11 16:50:38.405 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;14;Gateway startup complete.
                                2017-01-11 16:50:38.408 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;0;0;18;2.1.0
                                2017-01-11 16:50:38.503 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                                2017-01-11 16:50:38.511 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;2;2.1.0
                                2017-01-11 16:50:38.512 [DEBUG] [col.serial.MySensorsSerialConnection] - Good,Gateway is up and running! (Ver:2.1.0)
                                2017-01-11 16:50:38.514 [INFO ] [col.serial.MySensorsSerialConnection] - Successfully connected to MySensors Bridge.
                                2017-01-11 16:50:38.515 [WARN ] [col.serial.MySensorsSerialConnection] - Network Sanity Checker thread disabled from bridge configuration
                                2017-01-11 16:50:48.516 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                                Is that ok?
                                • AndrewZA AndrewZ
                                  Hello everyone
                                  Is that ok?
                                  TimO
                                  @AndrewZ Don't worry about that message, the debug log looks good. The warning is confusing and we need to change that. :-)
                                  AndrewZA 1 Reply Last reply
                                  • T TimO
                                    AndrewZA
                                    AndrewZA
                                    AndrewZ
                                    @TimO Thanks, will keep it off in the GUI.
                                    • Duncan PullenD
                                      Duncan PullenD
                                      Duncan Pullen
                                      Hi @TimO
                                      I've logged a job to include documentation about non-native OpenHAB 2.0 bindings in the official OH2 docs.
                                      ThomDeitrich is looking to know why it's not yet in the official distro. Can provide some info?
                                      https://github.com/openhab/openhab-docs/issues/188
                                      • Duncan PullenD Duncan Pullen
                                        Hi @TimO
                                        TimO
                                        Hey @Duncan-Pullen !
                                        The main reason is: I'm waiting for suggestions / approval from the OH2 developers. :)
                                        The MySensors binding has grown big and a review takes some time.
                                          @TimO, thank you for all the effort you've put into this!
