  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 677.3k Views 99 Watching
  • infragI infrag
    @TimO
    According to this:
    https://www.eclipse.org/smarthome/documentation/javadoc/org/eclipse/smarthome/core/thing/binding/ThingHandler.html#bridgeStatusChanged-org.eclipse.smarthome.core.thing.ThingStatusInfo-
    The old method of bridgeHandlerDisposed is Depreciated now.
    TimO
    Hey @infrag !
    Switch to the MySensors branch, the master branch is outdated. :-)
    infragI FutureCowF 2 Replies Last reply
    • T TimO
      Hey @infrag !
      infragI
      infragI
      infrag
      @TimO
      ah that explains it. Thanks! :)
      • T TimO
        Hey @infrag !
        FutureCowF
        FutureCowF
        FutureCow
        @TimO
        I'm trying to add a CO2 sensor. What is the sensor i need to select inside OpenHAB?
        TSP:MSG:SEND 70-70-0-0 s=0,c=1,t=37,pt=4,l=4,sg=0,ft=0,st=ok:1162
        CO2 level = 1162 ppm
        sketch:
        MyMessage msg(CHILD_ID_AIQ, V_LEVEL);
        present(CHILD_ID_AIQ, S_AIR_QUALITY);
        ? 1 Reply Last reply
        • FutureCowF FutureCow
          @TimO
          sketch:
          A Former User
          Hello everyone,
          In an OH2 environment with 2 nodes reporting temperature, one attached to the gateway and one on his own I receive the following error:
          [ERROR] [rs.internal.protocol.MySensorsReader] - (java.lang.IllegalStateException: Could not update state, because callback is missing) on reading from connection, message: class org.openhab.binding.mysensors.internal.protocol.serial.MySensorsSerialReader
          The node attached to the gateway works fine, his item gets updated but the other one not.
          The only code difference between their loop methods are calls to isTransportOK() and receiveTime() which are made by the latter node.
          Doesn't this version support those 2 methods or I'm missing something ?
          https://github.com/tobof/openhab2-addons/blob/MySensors/addons/binding/org.openhab.binding.mysensors/target/org.openhab.binding.mysensors-2.0.0-SNAPSHOT.jar
          Thx for all the hard work on this library :smiley:
          • ? A Former User
            Hello everyone,
            TimO
            Hey @frg !
            1. receiveTime() is supported by the binding and should work. In the binding log should appear a message like:
            I_TIME request received from 123, answering...
            Do you have some more log for me?
            1. isTransportOK() is only handled within the node, no message is send so there is nothing the binding could support. By the way, the method was renamed to isTransportReady() with the current version 2.1.0.
            Are there no updates from the second node? Did you check in the serial log of the node that messages were sent?
            • T TimO
              Hey @frg !
              A Former User
              @TimO
              Well this is bit of embarrassing...after changing the sleep time from 5 minutes to 1 minute for the troublesome node and re-uploading the sketch, it is reporting the temperature just fine. I tried all kinds of combinations trying to replicate the initial behavior, stopped the controller, rebooted the gateway, powered them off for while, moving back to 5 minutes sleep, to no avail, node registers and the temperature is reporting is showed in the paperui.
              On the other hand I don't see that I_TIME request received from... message in the logs (used log:set DEBUG org.openhab.binding.mysensors and log:tail) so I'm not sure if the receiveTime() is called.
              I suppose I can write something in the EEPROM when the callback function runs and check that.
              Thank you
              01:30:45.291 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
              01:30:50.280 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;0;1;0;0;22.0
              01:30:50.282 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 2 to 2017-01-06T01:30:50.281+0200
              01:30:50.285 [INFO ] [marthome.event.ItemStateChangedEvent] - TemperatureOutside_LastUpdate changed from 2017-01-06T01:28:52.282+0200 to 2017-01-06T01:30:50.281+0200
              01:30:53.550 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;1;1;0;0;23.1
              01:30:55.292 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
              01:31:05.293 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
              01:31:15.293 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
              01:31:25.294 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
              01:31:35.294 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
              01:31:45.295 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
              01:31:49.287 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;0;1;0;0;22.0
              01:31:53.541 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;1;1;0;0;23.1
              01:31:53.544 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 0 to 2017-01-06T01:31:53.543+0200
              01:31:53.552 [INFO ] [marthome.event.ItemStateChangedEvent] - TemperatureGateway_LastUpdate changed from 2017-01-06T01:29:53.559+0200 to 2017-01-06T01:31:53.543+0200
              01:31:55.295 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
              01:32:05.296 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
              01:32:15.296 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
              01:32:25.297 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
              01:32:35.298 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
              01:32:45.298 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
              01:32:48.283 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;0;1;0;0;22.0
              01:32:48.284 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 2 to 2017-01-06T01:32:48.284+0200
              01:32:48.290 [INFO ] [marthome.event.ItemStateChangedEvent] - TemperatureOutside_LastUpdate changed from 2017-01-06T01:30:50.281+0200 to 2017-01-06T01:32:48.284+0200
              01:32:53.532 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;1;1;0;0;23.1
              01:32:55.299 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
              Node 0 is gateway attached, Node 2 is battery run -TemperatureOutside.
              • ? A Former User
                @TimO
                Thank you
                TimO
                @frg Sometimes magic just happens. 😉
                I'm glad it is working now! :+1:
                • F
                  F
                  Fabien
                  I try to send ORP calibration value to my sensors but it doesn't work.
                  NODE_ID : 10, CHILD_NODE_ID : 0
                  When I'm recieve ORP from my sensors it's ok :
                  13:55:38.216 [DEBUG] [rs.internal.protocol.MySensorsReader] - 10;0;1;0;52;996.3
                  But when I change the value, the value is not send :
                  14:09:24.051 [INFO ] [marthome.event.ItemStateChangedEvent] - orp01 changed from 40 to 50
                  14:09:24.266 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'orp01' received command 60
                  14:09:24.266 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 10;0;1;0;0;
                  Item :
                  Number	orp01	"Redox [%.1f mV]" <faucet> (gPiscine) { channel="mysensors:waterQuality:gateway:orp01:orp"}
                  Sitemap :
                    sitemap test label="Main Menu" {
                      Frame label="Piscine" {
                  		Setpoint item=orp01 label="Calirabte ORP" minValue=0 maxValue=1000 step=10
                  • F Fabien
                    Item :
                    Sitemap :
                    TimO
                    @Fabien I need a little bit more time to reproduce this behaviour. I've opened an issue here: https://github.com/tobof/openhab2-addons/issues/50
                    • AndrewZA
                      AndrewZA
                      AndrewZ
                      wrote on last edited by AndrewZ
                      #349
                      Hello everyone
                      I'm slowly migrating to OH2, my small MySensors network generally works fine but I see some weird behavior with the binding configuration in Paper UI.
                      So far it looks like "Disable network sanity check" is reversed - I'm sliding it to the left which means for me 'not disabled', i.e. 'enabled', but in the log I see "Checker thread disabled".
                      2017-01-11 16:50:38.405 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;14;Gateway startup complete.
                      2017-01-11 16:50:38.408 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;0;0;18;2.1.0
                      2017-01-11 16:50:38.503 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                      2017-01-11 16:50:38.511 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;2;2.1.0
                      2017-01-11 16:50:38.512 [DEBUG] [col.serial.MySensorsSerialConnection] - Good,Gateway is up and running! (Ver:2.1.0)
                      2017-01-11 16:50:38.514 [INFO ] [col.serial.MySensorsSerialConnection] - Successfully connected to MySensors Bridge.
                      2017-01-11 16:50:38.515 [WARN ] [col.serial.MySensorsSerialConnection] - Network Sanity Checker thread disabled from bridge configuration
                      2017-01-11 16:50:48.516 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                      Is that ok?
                      • AndrewZA AndrewZ
                        Hello everyone
                        Is that ok?
                        TimO
                        @AndrewZ Don't worry about that message, the debug log looks good. The warning is confusing and we need to change that. :-)
                        AndrewZA 1 Reply Last reply
                        • T TimO
                          AndrewZA
                          AndrewZA
                          AndrewZ
                          @TimO Thanks, will keep it off in the GUI.
                          • Duncan PullenD
                            Duncan PullenD
                            Duncan Pullen
                            Hi @TimO
                            I've logged a job to include documentation about non-native OpenHAB 2.0 bindings in the official OH2 docs.
                            ThomDeitrich is looking to know why it's not yet in the official distro. Can provide some info?
                            https://github.com/openhab/openhab-docs/issues/188
                            • Duncan PullenD Duncan Pullen
                              Hi @TimO
                              TimO
                              Hey @Duncan-Pullen !
                              The main reason is: I'm waiting for suggestions / approval from the OH2 developers. :)
                              The MySensors binding has grown big and a review takes some time.
                                @TimO, thank you for all the effort you've put into this!
                                • FusedHe3F
                                  FusedHe3F
                                  FusedHe3
                                  wrote on last edited by FusedHe3
                                  #355
                                  Hi everyone,
                                  @TimO, thanks for everything you did here!
                                  I just made the 2.0 version (code in comments of respective post) of petewill's Simple Scene Controller and discovered that a Scene Controller is not yet implemented in the OpenHAB binding. Is there a possibility that it will be implemented in the future?
                                  For now, is it possible to get this working with CustomSensor or Text?
                                  • FusedHe3F FusedHe3
                                    Hi everyone,
                                    TimO
                                    Hi @FusedHe3 !
                                    My first thought was: that's easy, lets add this! But after a second thought ...
                                    I see one problem with S_SCENE_CONTROLLER: how do I map this in OpenHAB?
                                    In MySensors there is V_SCENE_ON and V_SCENE_OFF. The message contains the corresponding scene number.
                                    In OpenHAB I've: Number, Switch, Selection ...
                                    0_1484735515591_upload-dac7eae9-cec0-4cbd-95ec-a0428268441c
                                    In OpenHAB I may choose between Scene A, Scene B and so on, but I can't select between ON and OFF. Is Scene A switched off, when I select Scene B?
                                    I'm using scenes with a switch in OpenHAB. Something like "Christmas decoration ON". In OpenHAB I'm using a group for that gChristmasDecoration or a rule: switch light on, shutter to 33%, ..
                                    My approach in implementing a (hardware) scene controller would be a mapping of those switches. So I would define a switch / child for every button (scene) on the controller.
                                    I'm open for ideas on how to map V_SCENE_CONTROLLER in OpenHAB, so if you or someone else have and idea, shout it out. :D
                                    FusedHe3F 1 Reply Last reply
                                    • T
                                      TimO
                                      Ah, by the way, I forgot to mention: SmartSleep is supported since last week.
                                      0_1484736645455_upload-d9d8432b-4892-4c07-876a-3abd4def86a0
                                      • T TimO
                                        Hi @FusedHe3 !
                                        FusedHe3F
                                        FusedHe3F
                                        FusedHe3
                                        @TimO Thanks for the quick reply!
                                        I do think the ON/OFF switch for every scene would be the most logical solution. In that way it's fully compatibel with the MySensors Scene Controller and you can have multiple scenes active at the same time.
                                        • AndrewZA
                                          AndrewZA
                                          AndrewZ
                                          Just updated my OH2 installation from snapshot to RC/beta and immediately got an error with the binding:
                                          [ERROR] [rs.internal.protocol.MySensorsReader] - (java.lang.NumberFormatException: For input string: "Gateway startup complete.") on reading from connection, message: class org.openhab.binding.mysensors.internal.protocol.serial.MySensorsSerialReader
                                          But then the usual:
                                          What could be a problem? Do I need to perform some cleanup on my system? What exactly needs to be deleted?
