  3. Mysensors Gateway on OrangePi (Zero) (opi)
117 Posts 11 Posters 66.3k Views 11 Watching
  • pansenP
    pansenP
    pansen
    wrote on last edited by pansen
    #25
    @hausinger: try to change
    ./configure --my-gateway=serial --my-serial-port=/dev/USB0 --my-serial-baudrate=115200
    to
    ./configure --my-gateway=serial --my-serial-port=/dev/ttyUSB0 --my-serial-baudrate=115200
    Be aware that USB devices are enumerated in the order they have been plugged in, so you cannot rely 100% on the arduino being "0".
    @mihai-aldea: haha I didn't even consider this. are there any disadvantages except for the increased power consumption? (and slightly higher cost)
    Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
    H 1 Reply Last reply
    • H hausinger
      I'm using a orangepi one and with your help I can compile it.
      I tried it with a serial gateway. I connected a arduino nano with the gateway serial scath on it through USB to my orangepi one. DMESG say to me, that it is attached to ttyUSB0
      So i tried to build the gateway with:
      make has no errors
      after that, i tried to start it with:
      sudo ./bin/mysgw -d
      Is started but i get this problem:
      Do you know whats wrong with it?
      jirmJ
      jirmJ
      jirm
      @hausinger
      Hi again to all OPI users.
      I like see that are great movements here.
      I think main goal here is achieve that OPI board can run mysensors for herself connected radio boards.
      Of course that can work OPI (or any board) if we attach over some port the radio board, because use of any "conventional" port (means usb, serial, eth) is the same for any hardware from the software view.
      Said this, I would simplificate (and reduce all hardware to minimum) all things I can and with a powerful board I can concentrate much of the roles needed.
      Attach directly (means through GPIO) all hardware the board can manage without issues is my goal, and I think other much people.
      I think the error posted @hausinger for run mysgw seems derived from de main problem we see when try compile mysensors on OPI, and is that the need (maybe although not always necessary) that SPIDEV driver are up and working properly and mysensors software can not detect SPI bus (then fail SPIDEV) on OPI while is not being adapted all software stuff from some mysensor coder.
      I hope some mysensors coder hear our call and soon can help here.
      Regards
      • pansenP pansen
        to
        H
        H
        hausinger
        wrote on last edited by hausinger
        #27
        to
        ooh sorry. Sure, i wrote "ttyUSB0". It was a typing mistake here on the forum. In my configuration I already typed ttyUSB0
        I edited my last post.
        But the issue is still the same.
        • M mihai.aldea
          @Tag The RF24 won't work on the OPi out of the box. Since the GPIO numbering is different it will work but only after some tweaks. I'm not sure if you're familiar with:
          http://linux-sunxi.org/GPIO
          Once you get the pin numbering figured out you can use the TMRh20 library. I confirm that it works on my OPi PC. Didn't unboxed my OPi Zero yet :yum:
          However it's not very clear what sort of gateway you're trying to build. My project will have an OPi Zero running MyController, hooked up to an ATmega328 running the GatewaySerial sketch. The radio will be be connected to the ATmega328 chip. This way I wouldn't have to worry about GPIO pin numbering.
          jirmJ
          jirmJ
          jirm
          @mihai.aldea
          Indeed good info about GPIO port.
          I will be aware about your progress...seems your approach is a sure win.
          • jirmJ jirm
            @hausinger
            Regards
            H
            H
            hausinger
            #29
            @jirm said:
            @hausinger
            Regards
            In my case, why should it be necessary to have a working spi bus? I wanted to connect a working arduino with the mysensors gw scetch on it throug USB to the OPI and use this as a ethernet gateway.
            My last goal is to use a USB to RS485 converter on my OPI (works as a Gateway) without a connected arduino, because my whole mysensors communication should be over RS485.
            jirmJ 1 Reply Last reply
            • H hausinger
              @jirm said:
              @hausinger
              Regards
              jirmJ
              jirmJ
              jirm
              wrote on last edited by jirm
              #30
              @hausinger
              Of course you dont need any SPI bus.
              And so sorry but before I checked so badly the error you posted.
              Not seems any related working error for mysgw. I think you have mysgw working fine, seems only they can not connect/work with sensor node.
              You seems only need check node communication and adjust node configuration to have your mysgw working.
              I don't see you found so much trouble to make working from usb-rs485 adapter if you can do it with usb/serial node, it's only matter that the driver of adapter can work with mysgw without so much issues.
              Regards
              • jirmJ jirm
                @hausinger
                Regards
                H
                H
                hausinger
                @jirm said:
                @hausinger
                Regards
                Thank you for your fast answer.
                I try to answer it as best as I can.
                I tried it once again:
                connected the arduino to the USB port on my OPI
                DMESG says it is port ttyUSB0
                If i start the Gateway with:
                sudo ./bin/mysgw -d
                I got the same result as posted before. My CPU Usage is at 100% on one core.
                if I kill the process of mysgw and start openhab2 (my used controller) it can connect direct to the Arduino (connected as USB as before) and it worked fine.
                So my configuration of my nodes (currently only 1 for testing) is working fine through rs485.
                Summary:
                Connection node -> Arduino Gateway = OK
                Connetion from openhab2 to Arduino Gateway = OK (openhab2 on same OPI as Arduino)
                OPI as a Ethernet - Serial Gateway = NOT OK, Problem is shown on my screenshot.
                USB-RS485:
                I also tried this, but after my configuration:
                ./configure --my-gateway=ethernet --my-port=5003 --my-transport=rs485 --my-rs485-serial-port=/dev/ttyUSB0 --my-rs485-baudrate=57600
                I can do the "make" command.
                After that I start it with:
                sudo ./bin/mysgw -d
                I only get this:
                I can now type a new command in the console (Gateway quit itself)
                • T
                  Tag
                  wrote on last edited by Tag
                  #32
                  Hi All,
                  Collected some info on the OPI zero CPU:
                  root@orangepizero:/proc# more cpuinfo
                  Processor : ARMv7 Processor rev 5 (v7l)
                  processor : 0
                  BogoMIPS : 2400.00
                  processor : 1
                  BogoMIPS : 2400.00
                  processor : 2
                  BogoMIPS : 2400.00
                  processor : 3
                  BogoMIPS : 2400.00
                  Features : swp half thumb fastmult vfp edsp thumbee neon vfpv3 tls vfpv4 idiva idivt
                  CPU implementer : 0x41
                  CPU architecture: 7
                  CPU variant : 0x0
                  CPU part : 0xc07
                  CPU revision : 5
                  Hardware : sun8i
                  Revision : 0000
                  Serial : 2467783d034e20000098
                  Dmesg Output:
                  [ 0.000000] Initializing cgroup subsys cpu
                  [ 0.000000] Linux version 3.4.113-sun8i (root@xenial) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.1) ) #50 SMP PREEMPT Mon Nov
                  14 08:41:55 CET 2016
                  [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
                  [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
                  [ 0.000000] Machine: sun8i
                  It should be a H2+, but I have seen H3 (think that was with an FTDI interface on the debug port....
                  • H hausinger
                    @jirm said:
                    @hausinger
                    Regards
                    sudo ./bin/mysgw -d
                    Summary:
                    USB-RS485:
                    sudo ./bin/mysgw -d
                    I only get this:
                    marceloaqno
                    Code Contributor
                    @hausinger That shouldn't happen (gateway quitting itself). Could you submit the debug log with MY_DEBUG_VERBOSE_RF24 enabled?
                    • M marceloaqno
                      H
                      H
                      hausinger
                      Yes i can check that, but how?
                      I tried it to enable it in "example_linux" => mysgw.cpp (added the line "#define MY_DEBUG_VERBOSE_RF24")
                      I also tried it in the file: "MyConfig.h" (also added the line "#define MY_DEBUG_VERBOSE_RF24")
                      But my output is still the same in the console.
                        mihai.aldea
                        @Tag Just to make it clear, do you want to connect the RF24 radio directly on the OPi's GPIO pins? Or do you want to connect it first to an Arduino and then to the OPi?
                        I haven't used the mysgw because so far I only played with EasyIoT (directly attached RF24 to RPi GPIO - doesn't work on OPi) and MyController (using an Arduino connected to the OPi's serial port).
                        Since MySensors is open source you can definitely change the pin numbers to match the OPI's Sunxi pin numbering. I don't have a setup in place right now to point you in the exact direction but will cook one tomorrow and get back with the details.
                        Meanwhile you can burn the GatewaySerial sketch on your Arduino and either use /bin/mysgw or:
                        apt-get -y update
                        apt-get -y install minicom
                        minicom -D /dev/ttyUSB0
                        It's likely that the minicom will scramble the text on your screen but you can:
                        Ctrl+Z
                        O
                        Screen and Keyboard
                        Esc
                        Save setup as df1
                        Close the minicom window then open it again and all should be fine.
                        • M mihai.aldea
                          apt-get -y update
                          Ctrl+Z
                          O
                          Screen and Keyboard
                          Esc
                          Save setup as df1
                          Tag
                          #36
                          @mihai.aldea
                          Hi!, my idea is to have the NRF24 radio directly attached to the GPIO header on the OPI, (got this already working on my RPI system). So the idea is to run mysgw on the OPI system.
                          (already got an extensive sensor network running with multiple arduinos and Mycontroller on thae RPI) On the RPI i had the arduino GW attached to USB and the NRF24 directly attached at the GPIO header at the same time, MyController saw 2 gateways :) )
                          The other option like you already mentioned is to attach the arduino using USB read from /dev/ttyUSB0. I see this as a last resort only if mysgw will never run on the OPI zero.
                          I read on the OPI website that the 26 pin header from the OPI is directly compatible with the RPI, however other sources of information tell me differently. So if you want to help out with the pin numbering this is greatly appreciated!
                          but again mysgw on the OPI with the radio on the GPIO header would be great!!
                          At this moment we try to build/compile mysgw on the OPI board, however that fails at the SPI part.
                          • H hausinger
                            make has no errors
                            sudo ./bin/mysgw -d
                            marceloaqno
                            Code Contributor
                            @hausinger The problem you are having with your serial gateway (./configure --my-gateway=serial --my-serial-port=/dev/ttyUSB0 --my-serial-baudrate=115200) may be related to this bug:
                            https://github.com/mysensors/MySensors/issues/720#issuecomment-270712256
                              mihai.aldea
                              @Tag I made the test setup and retraced my steps from the previous experiment. While the TMRh20 is working, the problem indeed lies with the ** mysgw** compilation. I'm getting the same error.
                              After spending quite some time trying to mitigate the errors I hit a wall and I concluded that the problem is not the different pin numbering but the mysgw source code. I believe the problem is the lack of support for this architecture and with MySensors being so complex and my C++ skills so average, I'm afraid I can't help.
                              However, if someone can mitigate the source code to successfully compile, the radio should be initialized with:
                              RF24 radio(7, 0);
                              7 - CE pin
                              0 - CS pin
                              More details here: https://github.com/TMRh20/RF24/issues/257
                              • M mihai.aldea
                                RF24 radio(7, 0);
                                7 - CE pin
                                0 - CS pin
                                Tag
                                #39
                                Thanks for the confirmation!!, now lets hope that mysgw, will be fixed/ported to the OPI boards soon!
                                would be great to expand the number of systems it will run on..
                                R 1 Reply Last reply
                                • T Tag
                                  R
                                  R
                                  Reza
                                  @Tag
                                  Could you setup my sensors gateway on orange pi one? if you can please help me to build this . thank you
                                  • R Reza
                                    @Tag
                                    Tag
                                    #41
                                    @Reza
                                    Unfortunately the mysgw software does not run native on the OPI systems at this moment.The only option today is to add an arduino to the USB port running i.e the serial gateway sketch (if you do not want to use the USB port, an other option would be using an UART trough the GPIO header, you data will show up on i.e. /dev/ttyS1 if UART 1 is used)
                                    step 2 will be to install controller software.
                                    (i tested MyController on the OPI and that works like a charm, and looks pretty cool!)
                                    See this link on how to build a serial gateway on the arduino. Using this setup you can follow the RaspberryPI tutorials.
                                    Hopefully mysgw will run soon on the OrangePI systems! think this is work in progress......
                                      marceloaqno
                                      Code Contributor
                                      wrote on last edited by marceloaqno
                                      #42
                                      I'm trying to add support for Orange Pi to MySensors, this is the work-in-progress repository:
                                      https://github.com/marceloaqno/MySensors/tree/spidev
                                      It would be great if someone could test and submit results from the configure and make commands:
                                      git clone https://github.com/marceloaqno/MySensors marceloaqno-spidev
                                      cd marceloaqno-spidev
                                      git checkout spidev
                                      ./configure
                                      make
                                      T 2 Replies Last reply
                                      • M marceloaqno
                                        git checkout spidev
                                        ./configure
                                        make
                                        Tag
                                        @marceloaqno
                                        Hi!, really appreciate your hard work on this!!, below are the results,
                                        (I was not able to execute the 1st command :( but... tried something else..
                                        root@orangepizero:~# git clone https://github.com/marceloaqno/MySensors.git marceloaqno-spidev
                                        Cloning into 'marceloaqno-spidev'...
                                        remote: Counting objects: 13834, done.
                                        remote: Compressing objects: 100% (26/26), done.
                                        remote: Total 13834 (delta 2), reused 0 (delta 0), pack-reused 13808
                                        Receiving objects: 100% (13834/13834), 9.67 MiB | 3.16 MiB/s, done.
                                        Resolving deltas: 100% (8289/8289), done.
                                        Checking connectivity... done.
                                        root@orangepizero:~# cd marceloaqno-spidev
                                        root@orangepizero:~/marceloaqno-spidev# git checkout spidev
                                        Branch spidev set up to track remote branch spidev from origin.
                                        Switched to a new branch 'spidev'
                                        root@orangepizero:~/marceloaqno-spidev# ./configure
                                        [OK] Finished.
                                        root@orangepizero:~/marceloaqno-spidev# make
                                        gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                                        g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                                        g++ -MT build/drivers/Linux/GPIO.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/GPIO.cpp -o build/drivers/Linux/GPIO.o
                                        g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                                        g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                                        g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                                        g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                                        g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
                                        g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
                                        g++ -MT build/drivers/Linux/interrupt.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/interrupt.cpp -o build/drivers/Linux/interrupt.o
                                        g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
                                        g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
                                        g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                                        /tmp/ccVhf8xP.s: Assembler messages:
                                        /tmp/ccVhf8xP.s:14808: Warning: IT blocks containing 32-bit Thumb instructions are deprecated in ARMv8
                                        g++ -MT build/drivers/SPIDEV/SPI.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/SPIDEV/SPI.cpp -o build/drivers/SPIDEV/SPI.o
                                        g++ -pthread -o bin/mysgw build/drivers/Linux/log.o build/drivers/Linux/noniso.o build/drivers/Linux/GPIO.o build/drivers/Linux/Print.o build/drivers/Linux/EthernetClient.o build/drivers/Linux/SerialPort.o build/drivers/Linux/Stream.o build/drivers/Linux/IPAddress.o build/drivers/Linux/compatibility.o build/drivers/Linux/interrupt.o build/drivers/Linux/SoftEeprom.o build/drivers/Linux/EthernetServer.o build/examples_linux/mysgw.o build/drivers/SPIDEV/SPI.o
                                        root@orangepizero:~/marceloaqno-spidev# ll bin
                                        total 640
                                        -rwxr-xr-x 1 root root 654544 Jan 7 22:48 mysgw
                                        Seems we have a binary!!
                                        :D
                                        • M marceloaqno
                                          git checkout spidev
                                          ./configure
                                          make
                                          Tag
                                          #44
                                          @marceloaqno
                                          Just hooked up a radio to the GPIO header. (used this link for the model 1 RPI https://www.mysensors.org/build/raspberry and attached the interrupt pin also to pin 15)
                                          This is the result i get
                                          root@orangepizero:~/marceloaqno-spidev/bin# mysgw
                                          mysgw: Starting gateway...
                                          mysgw: Could not open /sys/class/gpio/gpio10/direction
                                          Illegal instruction
                                          M 2 Replies Last reply
