  3. Mysensors Gateway on OrangePi (Zero) (opi)
117 Posts 11 Posters 66.1k Views 11 Watching
  • T Tag
    @pansen,
    Not sure if this is useful but, checked this one:https://github.com/mysensors/MySensors/issues/719
    root@orangepizero:~/test# git clone https://github.com/marceloaqno/MySensors.git marceloaqno-spidev
    Cloning into 'marceloaqno-spidev'...
    remote: Counting objects: 13825, done.
    remote: Compressing objects: 100% (26/26), done.
    remote: Total 13825 (delta 4), reused 0 (delta 0), pack-reused 13799
    Receiving objects: 100% (13825/13825), 9.65 MiB | 3.27 MiB/s, done.
    Resolving deltas: 100% (8284/8284), done.
    Checking connectivity... done.
    root@orangepizero:~/test# cd marceloaqno-spidev/
    root@orangepizero:~/test/marceloaqno-spidev# git checkout spidev
    Branch spidev set up to track remote branch spidev from origin.
    Switched to a new branch 'spidev'
    root@orangepizero:~/test/marceloaqno-spidev# ;s
    -bash: syntax error near unexpected token `;'
    root@orangepizero:~/test/marceloaqno-spidev# ls
    configure Doxyfile initscripts Makefile README.md
    CONTRIBUTING.md drivers keywords.txt MyConfig.h tests
    core examples library.json MySensors.h
    Documentation examples_linux library.properties projects
    root@orangepizero:~/test/marceloaqno-spidev# ./configure
    [SECTION] Detecting GPIO driver.
    [OK] GPIO driver detected:SPIDEV.
    [OK] Finished.
    root@orangepizero:~/test/marceloaqno-spidev# make
    gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/log.c -o build/drivers/Linux/log.o
    g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
    g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
    g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
    g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
    g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
    In file included from drivers/Linux/Stream.cpp:24:0:
    ./drivers/Linux/Arduino.h:17:18: fatal error: GPIO.h: No such file or directory
    #include "GPIO.h"
    compilation terminated.
    Makefile:114: recipe for target 'build/drivers/Linux/Stream.o' failed
    make: *** [build/drivers/Linux/Stream.o] Error 1
    jirmJ
    jirmJ
    jirm
    wrote on last edited by jirm
    Hi @Tag
    We ( I and @pansen ) talked about that fork over mysensors github that @marceloaqno are doing to support Bananapi.
    Banana have same soc than OPI, so the issues are the same on both boards for compile mysensors at least at that point. Maybe own OPI GPIO library (If I remeber Wiringpi or similar name or so) will be needed added to the mysensors software, but hope this can be easily do it like one last point.
    Can you give a try on your OPI board and post results doing same commands than @eyesoft are doing for Banana on the forked github?
    Then we can see if the same solution than @marceloaqno are building for Banana can be directly applied to our OPI.
    I mean do this steps:
    git checkout spidev
    then...
    ./configure --my-gateway=ethernet --my-transport=nrf24 --my-rf24-irq-pin=15 --my-rf24-channel=119
    and last
    make
    • jirmJ jirm
      Hi @Tag
      git checkout spidev
      then...
      and last
      make
      Tag
      wrote on last edited by Tag
      @jirm
      Sure!, here you go:
      root@orangepizero:~# rm -r MySensors/
      root@orangepizero:~# git clone https://github.com/marceloaqno/MySensors.git marceloaqno-spidev
      Receiving objects: 100% (13825/13825), 9.65 MiB | 3.01 MiB/s, done.
      root@orangepizero:~# cd marceloaqno-spidev/
      root@orangepizero:~/marceloaqno-spidev# git checkout spidev
      root@orangepizero:~/marceloaqno-spidev# ./configure --my-gateway=ethernet --my-transport=nrf24 --my-rf24-irq-pin=15 --my-rf24-channel=119
      [OK] Finished.
      root@orangepizero:~/marceloaqno-spidev# make
      gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -DMY_RF24_CHANNEL=119 -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/log.c -o build/drivers/Linux/log.o
      g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -DMY_RF24_CHANNEL=119 -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
      g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -DMY_RF24_CHANNEL=119 -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
      g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -DMY_RF24_CHANNEL=119 -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
      g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -DMY_RF24_CHANNEL=119 -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
      g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -DMY_RF24_CHANNEL=119 -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
      g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -DMY_RF24_CHANNEL=119 -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
      g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -DMY_RF24_CHANNEL=119 -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
      g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -DMY_RF24_CHANNEL=119 -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
      g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -DMY_RF24_CHANNEL=119 -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
      g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -DMY_RF24_CHANNEL=119 -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
      ./MySensors.h:258:2: error: #error No support for nRF24 radio on this platform
      from ./MySensors.h:294,
      ./drivers/RF24/RF24.h:76:2: error: #error RF24 IRQ usage requires transactional SPI support
      In file included from ./MySensors.h:294:0,
      ./drivers/RF24/RF24.cpp:39:11: error: Not supported on linux-generic
      hwDigitalWrite(MY_RF24_CS_PIN, level);
      ./drivers/RF24/RF24.cpp:44:11: error: Not supported on linux-generic
      hwDigitalWrite(MY_RF24_CE_PIN, level);
      ./drivers/RF24/RF24.cpp:388:11: error: Not supported on linux-generic
      hwPinMode(MY_RF24_CE_PIN,OUTPUT);
      ./drivers/RF24/RF24.cpp:389:11: error: Not supported on linux-generic
      hwPinMode(MY_RF24_CS_PIN,OUTPUT);
      ./drivers/RF24/RF24.cpp:391:11: error: Not supported on linux-generic
      hwPinMode(MY_RF24_IRQ_PIN,INPUT);
      ./drivers/RF24/RF24.cpp:37:32: warning: unused parameter ‘level’ [-Wunused-parameter]
      LOCAL void RF24_csn(const bool level)
      ./drivers/RF24/RF24.cpp:42:31: warning: unused parameter ‘level’ [-Wunused-parameter]
      LOCAL void RF24_ce(const bool level)
      ./drivers/RF24/RF24.cpp: In function ‘bool RF24_initialize()’:
      ./drivers/RF24/RF24.cpp:403:75: error: ‘FALLING’ was not declared in this scope
      attachInterrupt(digitalPinToInterrupt(MY_RF24_IRQ_PIN), RF24_irqHandler, FALLING);
      ./drivers/RF24/RF24.cpp:403:82: error: ‘attachInterrupt’ was not declared in this scope
      In file included from ./MySensors.h:346:0,
      ./core/MyMainLinux.cpp: In function ‘void handle_sigint(int)’:
      ./core/MyMainLinux.cpp:44:33: error: ‘detachInterrupt’ was not declared in this scope
      detachInterrupt(MY_RF24_IRQ_PIN);
      Makefile:114: recipe for target 'build/examples_linux/mysgw.o' failed
      Thanks for all the time you guys put into this!! really appreciate it!!
      jirmJ 1 Reply Last reply
      • T Tag
        @jirm
        Sure!, here you go:
        [OK] Finished.
        jirmJ
        jirmJ
        jirm
        @Tag
        Thanks to you to make the effort to try our "suppositions" ...
        Mmmm...I see some interesting things on your results.
        First all your results on OPI really differ from @eyesoft posted on the github. That can mean that Banana are much different (on drivers aspect) than OPI and then same solution cannot be applied to both...bad thing for us.
        Then I see on make that the soc (and cpu) are bad seleected (I said this issue yesterday to @marceloaqno on general support post for mysensors gateway) because seems in the configure file have a bad selection about that specs when soc are a H3, and select a bad A53 type of cpu when is Armv7.
        Then I don't know if all subsequent errors raised are significant or simply derived from that initially bad cpu selection.
        Last I see that have issues on GPIO pins, but this is something we hoped would happen.
        Anyway, I'm not coder so maybe are totally grong on all my observations and we need some coder (preferible @marceloaqno ) help us to deal with all that.
        Regards and thanks to you !
        • jirmJ jirm
          @Tag
          jirmJ
          jirmJ
          jirm
          @Tag
          I just see than on your previous compilation for NRF24 build from Tmr24h that you confirm is working OK, the compilation have same "bad" cpu type A53 that I figure that is a bad selection for H3 and seems that is not any problem...so now I'dont understand nothing..
          Well mean only understand that we need a mysensor coder for help an guidance and if available make to it all the changes needed for OPI on mysenros.
          So we need help for all.
          Regards
          • jirmJ jirm
            @Tag
            Regards
            jirmJ
            jirmJ
            jirm
            @jirm
            As a side comment, posting interesting good info about Orange PI GPIO ports assignment and usage, that can help too:
            http://www.cnx-software.com/2015/09/26/status-of-orange-pi-boards-gpio-support/
            • pansenP
              pansenP
              pansen
              Great info indeed, thanks! I will join the effort again when the OPi+nRF24 arrived. Just compiling without any hardware feels like baking a cake and not eating it...
              Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
                mihai.aldea
                @Tag The RF24 won't work on the OPi out of the box. Since the GPIO numbering is different it will work but only after some tweaks. I'm not sure if you're familiar with:
                http://linux-sunxi.org/GPIO
                Once you get the pin numbering figured out you can use the TMRh20 library. I confirm that it works on my OPi PC. Didn't unboxed my OPi Zero yet :yum:
                However it's not very clear what sort of gateway you're trying to build. My project will have an OPi Zero running MyController, hooked up to an ATmega328 running the GatewaySerial sketch. The radio will be be connected to the ATmega328 chip. This way I wouldn't have to worry about GPIO pin numbering.
                • H
                  H
                  hausinger
                  wrote on last edited by hausinger
                  #24
                  I'm using a orangepi one and with your help I can compile it.
                  I tried it with a serial gateway. I connected a arduino nano with the gateway serial scath on it through USB to my orangepi one. DMESG say to me, that it is attached to ttyUSB0
                  So i tried to build the gateway with:
                  ./configure --my-gateway=serial --my-serial-port=/dev/ttyUSB0 --my-serial-baudrate=115200
                  make has no errors
                  after that, i tried to start it with:
                  sudo ./bin/mysgw -d
                  Is started but i get this problem:
                  Do you know whats wrong with it?
                  jirmJ M 2 Replies Last reply
                  • pansenP
                    pansenP
                    pansen
                    wrote on last edited by pansen
                    #25
                    @hausinger: try to change
                    ./configure --my-gateway=serial --my-serial-port=/dev/USB0 --my-serial-baudrate=115200
                    to
                    Be aware that USB devices are enumerated in the order they have been plugged in, so you cannot rely 100% on the arduino being "0".
                    @mihai-aldea: haha I didn't even consider this. are there any disadvantages except for the increased power consumption? (and slightly higher cost)
                    H 1 Reply Last reply
                    • H hausinger
                      make has no errors
                      sudo ./bin/mysgw -d
                      jirmJ
                      jirmJ
                      jirm
                      @hausinger
                      Hi again to all OPI users.
                      I like see that are great movements here.
                      I think main goal here is achieve that OPI board can run mysensors for herself connected radio boards.
                      Of course that can work OPI (or any board) if we attach over some port the radio board, because use of any "conventional" port (means usb, serial, eth) is the same for any hardware from the software view.
                      Said this, I would simplificate (and reduce all hardware to minimum) all things I can and with a powerful board I can concentrate much of the roles needed.
                      Attach directly (means through GPIO) all hardware the board can manage without issues is my goal, and I think other much people.
                      I think the error posted @hausinger for run mysgw seems derived from de main problem we see when try compile mysensors on OPI, and is that the need (maybe although not always necessary) that SPIDEV driver are up and working properly and mysensors software can not detect SPI bus (then fail SPIDEV) on OPI while is not being adapted all software stuff from some mysensor coder.
                      I hope some mysensors coder hear our call and soon can help here.
                      Regards
                      • pansenP pansen
                        to
                        H
                        H
                        hausinger
                        #27
                        to
                        ooh sorry. Sure, i wrote "ttyUSB0". It was a typing mistake here on the forum. In my configuration I already typed ttyUSB0
                        I edited my last post.
                        But the issue is still the same.
                        • M mihai.aldea
                          jirmJ
                          jirmJ
                          jirm
                          @mihai.aldea
                          Indeed good info about GPIO port.
                          I will be aware about your progress...seems your approach is a sure win.
                          • jirmJ jirm
                            @hausinger
                            Regards
                            H
                            H
                            hausinger
                            #29
                            @jirm said:
                            @hausinger
                            Regards
                            In my case, why should it be necessary to have a working spi bus? I wanted to connect a working arduino with the mysensors gw scetch on it throug USB to the OPI and use this as a ethernet gateway.
                            My last goal is to use a USB to RS485 converter on my OPI (works as a Gateway) without a connected arduino, because my whole mysensors communication should be over RS485.
                            • H hausinger
                              @jirm said:
                              @hausinger
                              Regards
                              jirmJ
                              jirmJ
                              jirm
                              #30
                              @hausinger
                              Of course you dont need any SPI bus.
                              And so sorry but before I checked so badly the error you posted.
                              Not seems any related working error for mysgw. I think you have mysgw working fine, seems only they can not connect/work with sensor node.
                              You seems only need check node communication and adjust node configuration to have your mysgw working.
                              I don't see you found so much trouble to make working from usb-rs485 adapter if you can do it with usb/serial node, it's only matter that the driver of adapter can work with mysgw without so much issues.
                              Regards
                              • jirmJ jirm
                                @hausinger
                                Regards
                                H
                                H
                                hausinger
                                @jirm said:
                                @hausinger
                                Regards
                                Thank you for your fast answer.
                                I try to answer it as best as I can.
                                I tried it once again:
                                connected the arduino to the USB port on my OPI
                                DMESG says it is port ttyUSB0
                                If i start the Gateway with:
                                sudo ./bin/mysgw -d
                                I got the same result as posted before. My CPU Usage is at 100% on one core.
                                if I kill the process of mysgw and start openhab2 (my used controller) it can connect direct to the Arduino (connected as USB as before) and it worked fine.
                                So my configuration of my nodes (currently only 1 for testing) is working fine through rs485.
                                Summary:
                                Connection node -> Arduino Gateway = OK
                                Connetion from openhab2 to Arduino Gateway = OK (openhab2 on same OPI as Arduino)
                                OPI as a Ethernet - Serial Gateway = NOT OK, Problem is shown on my screenshot.
                                USB-RS485:
                                I also tried this, but after my configuration:
                                ./configure --my-gateway=ethernet --my-port=5003 --my-transport=rs485 --my-rs485-serial-port=/dev/ttyUSB0 --my-rs485-baudrate=57600
                                I can do the "make" command.
                                After that I start it with:
                                sudo ./bin/mysgw -d
                                I only get this:
                                I can now type a new command in the console (Gateway quit itself)
                                • T
                                  Tag
                                  #32
                                  Hi All,
                                  Collected some info on the OPI zero CPU:
                                  root@orangepizero:/proc# more cpuinfo
                                  Processor : ARMv7 Processor rev 5 (v7l)
                                  processor : 0
                                  BogoMIPS : 2400.00
                                  processor : 1
                                  BogoMIPS : 2400.00
                                  processor : 2
                                  BogoMIPS : 2400.00
                                  processor : 3
                                  BogoMIPS : 2400.00
                                  Features : swp half thumb fastmult vfp edsp thumbee neon vfpv3 tls vfpv4 idiva idivt
                                  CPU implementer : 0x41
                                  CPU architecture: 7
                                  CPU variant : 0x0
                                  CPU part : 0xc07
                                  CPU revision : 5
                                  Hardware : sun8i
                                  Revision : 0000
                                  Serial : 2467783d034e20000098
                                  Dmesg Output:
                                  [ 0.000000] Initializing cgroup subsys cpu
                                  [ 0.000000] Linux version 3.4.113-sun8i (root@xenial) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.1) ) #50 SMP PREEMPT Mon Nov
                                  14 08:41:55 CET 2016
                                  [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
                                  [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
                                  [ 0.000000] Machine: sun8i
                                  It should be a H2+, but I have seen H3 (think that was with an FTDI interface on the debug port....
                                  • H hausinger
                                    @jirm said:
                                    @hausinger
                                    Regards
                                    sudo ./bin/mysgw -d
                                    Summary:
                                    USB-RS485:
                                    sudo ./bin/mysgw -d
                                    I only get this:
                                    marceloaqno
                                    Code Contributor
                                    @hausinger That shouldn't happen (gateway quitting itself). Could you submit the debug log with MY_DEBUG_VERBOSE_RF24 enabled?
                                    • M marceloaqno
                                      H
                                      H
                                      hausinger
                                      Yes i can check that, but how?
                                      I tried it to enable it in "example_linux" => mysgw.cpp (added the line "#define MY_DEBUG_VERBOSE_RF24")
                                      I also tried it in the file: "MyConfig.h" (also added the line "#define MY_DEBUG_VERBOSE_RF24")
                                      But my output is still the same in the console.
                                        mihai.aldea
                                        @Tag Just to make it clear, do you want to connect the RF24 radio directly on the OPi's GPIO pins? Or do you want to connect it first to an Arduino and then to the OPi?
                                        I haven't used the mysgw because so far I only played with EasyIoT (directly attached RF24 to RPi GPIO - doesn't work on OPi) and MyController (using an Arduino connected to the OPi's serial port).
                                        Since MySensors is open source you can definitely change the pin numbers to match the OPI's Sunxi pin numbering. I don't have a setup in place right now to point you in the exact direction but will cook one tomorrow and get back with the details.
                                        Meanwhile you can burn the GatewaySerial sketch on your Arduino and either use /bin/mysgw or:
                                        apt-get -y update
                                        apt-get -y install minicom
                                        minicom -D /dev/ttyUSB0
                                        It's likely that the minicom will scramble the text on your screen but you can:
                                        Ctrl+Z
                                        O
                                        Screen and Keyboard
                                        Esc
                                        Save setup as df1
                                        Close the minicom window then open it again and all should be fine.
                                        • M mihai.aldea
                                          apt-get -y update
                                          Ctrl+Z
                                          O
                                          Screen and Keyboard
                                          Esc
                                          Save setup as df1
                                          Tag
                                          #36
                                          @mihai.aldea
                                          Hi!, my idea is to have the NRF24 radio directly attached to the GPIO header on the OPI, (got this already working on my RPI system). So the idea is to run mysgw on the OPI system.
                                          (already got an extensive sensor network running with multiple arduinos and Mycontroller on thae RPI) On the RPI i had the arduino GW attached to USB and the NRF24 directly attached at the GPIO header at the same time, MyController saw 2 gateways :) )
                                          The other option like you already mentioned is to attach the arduino using USB read from /dev/ttyUSB0. I see this as a last resort only if mysgw will never run on the OPI zero.
                                          I read on the OPI website that the 26 pin header from the OPI is directly compatible with the RPI, however other sources of information tell me differently. So if you want to help out with the pin numbering this is greatly appreciated!
                                          but again mysgw on the OPI with the radio on the GPIO header would be great!!
                                          At this moment we try to build/compile mysgw on the OPI board, however that fails at the SPI part.
