  3. temp sensor keep on loging status switch
10 Posts 2 Posters 2.4k Views 2 Watching
  • DickD Offline
    DickD Offline
    Dick
    wrote on last edited by Dick
    I have a working sensor that checks the temp om 2 places. If needed it wil switch on/of a Fan. That is all working perfect only this sensor logs continue the status of the switch. i am using Domoticz.
    the log looks like this:
    2017-01-05 19:24:18.747 EventSystem: Event triggered: ventilator aan/uit_2
    2017-01-05 19:24:18.741 (MySensors GW1) Temp (Temp serre)
    2017-01-05 19:24:18.960 (MySensors GW1) Lighting 2 (Temp Fan switch)
    2017-01-05 19:24:48.736 EventSystem: Event triggered: ventilator aan/uit_2
    2017-01-05 19:24:48.730 (MySensors GW1) Temp (Temp serre)
    2017-01-05 19:24:49.068 (MySensors GW1) Lighting 2 (Temp Fan switch)
    2017-01-05 19:26:49.032 EventSystem: Event triggered: ventilator aan/uit_2
    2017-01-05 19:26:49.027 (MySensors GW1) Temp (Temp binnen)
    2017-01-05 19:26:49.182 (MySensors GW1) Lighting 2 (Temp Fan switch)
    2017-01-05 19:27:49.049 EventSystem: Event triggered: ventilator aan/uit_2
    2017-01-05 19:27:49.044 (MySensors GW1) Temp (Temp serre)
    2017-01-05 19:27:49.291 (MySensors GW1) Lighting 2 (Temp Fan switch)
    2017-01-05 19:28:48.988 EventSystem: Event triggered: ventilator aan/uit_2
    2017-01-05 19:28:48.985 (MySensors GW1) Temp (Temp binnen)
    2017-01-05 19:28:49.401 (MySensors GW1) Lighting 2 (Temp Fan switch)
    2017-01-05 19:29:18.972 EventSystem: Event triggered: ventilator aan/uit_2 italicised text
    This is my code
    #include <OneWire.h>
    // Partie Température
    int numSensors=0;
    boolean receivedConfig = false;
    boolean metric = true;
    MyMessage msg(0,V_TEMP);
    // Partie Relay
    #define RELAY_PIN  A1  // Arduino Digital I/O pinnumber for relay
    #define BUTTON_PIN  A3   // Arduino Digital I/O pin number for button
    #define CHILD_ID 17   // Id of the sensor child
    #define RELAY_ON 1
    #define RELAY_OFF 0
    Bounce debouncer = Bounce();
    int oldValue=0;
    bool state;
    unsigned long previousMillis = 0;
    MyMessage msg2(CHILD_ID,V_LIGHT);
      sensors.begin();
      gw.sendSketchInfo("Relay & Button", "1.0");
      gw.sendSketchInfo("Temperature Sensor", "1.1");
      Serial.print(numSensors);
      Serial.println(" temperature sensors detected");
     // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
         gw.present(i, S_TEMP);
      gw.present(CHILD_ID, S_LIGHT);
      pinMode(RELAY_PIN, OUTPUT);
      state = gw.loadState(CHILD_ID);
    *  Example on how to asynchronously check for new messages from gw
      // Relay button
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue && value==0) {
          gw.send(msg2.set(state?false:true), true); // Send new state and request ack back
      oldValue = value;
      //int16_t conversionTime = sensors.millisToWaitForConversion(sensors.getResolution());
      // gw.wait(conversionTime);
      if (currentMillis - previousMillis >= SLEEP_TIME) {
        // save the last time you read temperature
          float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
          #if COMPARE_TEMP == 1
            gw.send(msg.setSensor(i).set(temperature,1));
      if (message.isAck()) {
         // Change relay state
         state = message.getBool();
         // Store state in eeprom
         gw.saveState(CHILD_ID, state);
    Does anyone know why it produce that large amount of logs?
    • F Offline
      F Offline
      flopp
      The nodes send the data every 30 second, the log is ok.
      You will get one line in the log very time a node report something.
      It look like you also have an Event that gets trigger every time one of the nodes send data.
      • DickD Offline
        DickD Offline
        Dick
        Yes you are right there is an Event. Do I have to add a timer or delay function in it or something else?
        • F Offline
          F Offline
          flopp
          Depends on what you want to do with these temp/relay?
          The log will still get all these lines even if you add a delay.
          • DickD Offline
            DickD Offline
            Dick
            this sensor only messure the temp on 2 different locations and as seen in the Event, if the temp inside (TEMP binnen temp) <- 20 and the temp in the glasshouse is >-26 the fan switch on and the second part of the Event only switch of the Fan if the temp inside is to high (>-26) or the temp in the glasshouse is <-27. that is all I want with this project. I only want the mesurement every 15 min for example
            • F Offline
              F Offline
              flopp
              Ok.
              Then change Sleeptime to 900000, today you have 30000
              900000 = 60000 * 15 minutes
              • DickD Offline
                DickD Offline
                Dick
                that was easy, I do it right away. Thanks for the support and this stopped me for changing other parts of the event of the code of the sensor.
                Have a nice day!
                • F Offline
                  F Offline
                  flopp
                  This is not a battery node, right?
                  Because this node never sleep, so it will consume battery all the time.
                  • DickD Offline
                    DickD Offline
                    Dick
                    no good to mention, That is a new project for me to build an efficience battery powered node. In this case it is powered by an external power source.
                    • F Offline
                      F Offline
                      flopp
                      :thumbsup:
