  3. Read voltage VCC, strange measurement[solved]
6 Posts 3 Posters 2.4k Views 3 Watching
  • F Offline
    F Offline
    flopp
    wrote on last edited by flopp
    I am using readVCC to read my battery node.
    ATMega328P-PU, like this , home made PCB, Fuses(BOD) is set to 1.8 V
    long readVcc() {
      gw.wait(2); // Wait for Vref to settle
      ADCSRA |= _BV(ADSC); // Convert
      result = ADCL;
      result |= ADCH<<8;
      result = 1126400L / result; // Back-calculate AVcc in mV
      //return result;
      batteryPcnt = (result - 3300) * 0.111111;
      batteryVolt = result/1000.000;
    it is working perfect on many of my nodes but one node have low battery compared to other nodes. They all have same battery type CR123A, 3 volt battery.
    On this node the volt level is 2.4 V. It was not new when I start to use it. It was starting at 2.5V.
    Last month it gives noise/jumping measurement. Going from 2.4 down to 1.9 see below. There are no measurements between 2.4 and 1.9.
    From start
    Anyone seen this before or know what it can be?
    • F flopp
      long readVcc() {
        result = ADCL;
        result |= ADCH<<8;
        //return result;
      From start
      @flopp coincells can drain very quickly if too much power is used or if they have low capacity left.
      Is the power consumption of the node approximately the same all the time or does the node sleep?
      If it does sleep, the answer is probably that the chemistry in the battery is able to recover after a while, but the battery does not have much power left.
      F 1 Reply Last reply
        F Offline
        F Offline
        flopp
        It is sleeping for 30 minutes. So it can be on the end of the battery life as you say.
        • F Offline
          F Offline
          flopp
          @mfalkvidd
          you where right.
          This graph will talk for itself :)
          Y 1 Reply Last reply
          • F flopp
            @mfalkvidd
            you where right.
            Y Offline
            Y Offline
            @flopp thanks for the feedback!
            Just wondering, how long did it take to get from full to this jumpy state?
            • Y Yveaux
              F Offline
              F Offline
              flopp
              @Yveaux
              I don't know because the battery was old when I started to use it.
              Home made pcb. Report every 30 minutes. No cap on battery.
              Take a look at this graph. This may be a new battery, don't remember. Has been running since 1/4 2016
