  3. 💬 2 channel in wall dimmer
mysensorsdimmer2 channel
5 Posts 4 Posters 2.8k Views 4 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/308/2-channel-in-wall-dimmer
    • RedguyR
      RedguyR
      Redguy
      Looks great !
      Have you measured what the minimum load is for the dimmer to function correctly ? I currently use X10 in wall modules but run in to trouble when switching to LED lights. The load is too small.
      • D
        Denke
        No i have not tested any minimum loads at the moment, this is one of the next steps
        RaspberryPi-Openhab
        • jeremushkaJ
          jeremushkaJ
          jeremushka
          Hello, nice project!
          does your system may work without neutral wire ?
          • D
            Denke
            The project does not work without neutral wire
            RaspberryPi-Openhab
