  3. UNO R3 + Prototyping Breadboard + W5100 Shield
16 Posts 4 Posters 4.4k Views 3 Watching
  • iotearoaI
    iotearoaI
    iotearoa
    Unfortunately no, I'll check if its the clone shield is at fault and let you know
    • iotearoaI iotearoa
      sundberg84S
      sundberg84S
      @iotearoa - I have had the exact same setup as well, default ethernet sketch and it did work.
      Do you have any serial output/debug?
      iotearoaI 1 Reply Last reply
      • sundberg84S sundberg84
        iotearoaI
        iotearoaI
        iotearoa
        @sundberg84 it was blank. I'll start with just simply the ethernet shield and use the DhcpChatServer sketch to rule out it's not the shield then move my way to the NRF. Thanks for the rapid response. I'm testing it now.
        • iotearoaI
          iotearoaI
          iotearoa
          It turns out the W5100 ethernet is working after using the sample sketch from Arduino.
          Now plumbed NRF directly on the W5100 shield:
          Now I'm getting this:
            Post your code please
              sundberg84S
              sundberg84S
              @iotearoa - put the capacitor as near the radio as possible, solder it directly over GND / VCC and not near the arduino.
                iotearoaI
                iotearoaI
                iotearoa
                @gohan copy pasted the one from here
                https://raw.githubusercontent.com/mysensors/MySensors/master/examples/GatewayW5100/GatewayW5100.ino
                thank you
                  iotearoaI
                  iotearoaI
                  iotearoa
                  @sundberg84
                  Hmm... no good.. I've basically moved a known working breadboard + 4.7uf from my other prototype below. I'm still getting the same error.
                  I'll triple check the wiring and replace all of them just in case.
                  • iotearoaI
                    iotearoaI
                    iotearoa
                    Found out that my W5100 clone is having serious auto-negotiation issues with my linksys switch. I jumped it earlier like this
                    • iotearoaI
                      iotearoaI
                      iotearoa
                      @sundberg84 @gohan its solved. Thanks for the help! Bad, 4.7uf, poor wiring and not to mention "a man look" on which pins I've used :)
                      Thanks again!
                        With all of that, no wonder it wasn't working :D
                        What kind of project are you running with those nodes?
                          iotearoaI
                          iotearoaI
                          iotearoa
                          @gohan
                          I'm measuring ambient lighting and motion sensor (Its directly using a 12v PIR ) at the moment in my room and using a
                          Mosquitto+Paho+MongoDB+SlamData for some analytics. I'm curious what analytics I'll get with this setup. Who knows right? :)
                          Then you'll notice there's an OLED. It's just simply a replacement for the serial() so I can see the debug than plugging the USB all the time.
