  3. UNO R3 + Prototyping Breadboard + W5100 Shield
16 Posts 4 Posters 4.4k Views 3 Watching
    If you remove the prototype shield everything works?
    • iotearoaI
      iotearoaI
      iotearoa
      Unfortunately no, I'll check if its the clone shield is at fault and let you know
      • iotearoaI iotearoa
        sundberg84S
        sundberg84S
        @iotearoa - I have had the exact same setup as well, default ethernet sketch and it did work.
        Do you have any serial output/debug?
        iotearoaI 1 Reply Last reply
        • sundberg84S sundberg84
          iotearoaI
          iotearoaI
          iotearoa
          @sundberg84 it was blank. I'll start with just simply the ethernet shield and use the DhcpChatServer sketch to rule out it's not the shield then move my way to the NRF. Thanks for the rapid response. I'm testing it now.
          • iotearoaI
            iotearoaI
            iotearoa
            It turns out the W5100 ethernet is working after using the sample sketch from Arduino.
            Now plumbed NRF directly on the W5100 shield:
            Now I'm getting this:
              Post your code please
                sundberg84S
                sundberg84S
                @iotearoa - put the capacitor as near the radio as possible, solder it directly over GND / VCC and not near the arduino.
                  iotearoaI
                  iotearoaI
                  iotearoa
                  @gohan copy pasted the one from here
                  https://raw.githubusercontent.com/mysensors/MySensors/master/examples/GatewayW5100/GatewayW5100.ino
                  thank you
                    iotearoaI
                    iotearoaI
                    iotearoa
                    @sundberg84
                    Hmm... no good.. I've basically moved a known working breadboard + 4.7uf from my other prototype below. I'm still getting the same error.
                    I'll triple check the wiring and replace all of them just in case.
                    • iotearoaI
                      iotearoaI
                      iotearoa
                      Found out that my W5100 clone is having serious auto-negotiation issues with my linksys switch. I jumped it earlier like this
                      • iotearoaI
                        iotearoaI
                        iotearoa
                        @sundberg84 @gohan its solved. Thanks for the help! Bad, 4.7uf, poor wiring and not to mention "a man look" on which pins I've used :)
                        Thanks again!
                          With all of that, no wonder it wasn't working :D
                          What kind of project are you running with those nodes?
                            iotearoaI
                            iotearoaI
                            iotearoa
                            @gohan
                            I'm measuring ambient lighting and motion sensor (Its directly using a 12v PIR ) at the moment in my room and using a
                            Mosquitto+Paho+MongoDB+SlamData for some analytics. I'm curious what analytics I'll get with this setup. Who knows right? :)
                            Then you'll notice there's an OLED. It's just simply a replacement for the serial() so I can see the debug than plugging the USB all the time.
