  3. [SOLVED] W5100 Ethernet gateway with RFM69 Radio fails at init
31 Posts 9 Posters 14.5k Views 7 Watching
  • Jonathan CaesJ Jonathan Caes
    @Frédéric-Grandjean
    Hi again, because I'm a mac user didn't find the w5100.h file. after I took my laptop and searched for the file I found it.
    after I replaced the code in the w5100.h file and changed the gateway code and complied I got these errors: 0_1484422292389_upload-59769e3e-1f23-4376-a3df-2c902afcdbeb
    and it went on.
    but when I changed the code in the w5100.h file from this:
    #elif defined(W5100SPIPATCH)
          inline static void initSS()    { DDRD  |=  _BV(7); };
          inline static void setSS()     { cli(); PORTD &= ~_BV(7); };
          inline static void resetSS()   { PORTD |=  _BV(7); sei(); };
    To this:
    #else	//This doesn't work => elif defined(W5100SPIPATCH)
    it compiled without any errors.
    So I uploaded the code and opened the serial debugging window in which I get this:
    0_1484423132127_upload-e0346356-c42c-4039-add5-612525c85127
    I don't know how to fix this, do you know maybe?
    Thanks!!
    Greetings!
    abrasha
    @Jonathan-Caes @Frédéric-Grandjean
    if i use w5100 shield on uno - so i cant connect the pins how i want - means w5100 cs stays on pin 10.
    what should i do?
    • T
      Tris
      For W5100 shield on Uno with RF69 as a Gateway, i used:
      DI00 - Pin 2
      NSS - Pin 4 (3.3v level shifter)
      MOSI - Pin A1 (3.3v level shifter)
      MISO - Pin A2
      SCK - Pin A0 (3.3v level shifter)
      Leave as pins 14/15/16 in MyConfig.h file - the Uno uses digital pins 14-16 physically as A0-A3.
      Using a level shifter makes the ProMini more viable as it is 3.3v and you dont need a shifter.
      A 1 Reply Last reply
      • T Tris
        DI00 - Pin 2
        MISO - Pin A2
        abrasha
        @Tris with or without w5100. H mod?
        • T
          Tris
          I THINK with the W5100.h file amended.
          try using Mysensors ClearEepromConfig too
          A 2 Replies Last reply
          • T Tris
            abrasha
            @Tris thanks a lot. I'll check it on Sunday.
            Btw i use adafruit rfm69hw breakout so no level shifter needed, but i need to post my fix for it because it needs my transport.h mod
            • T Tris
              Jonathan Caes - i used your amended #else code in W5100.h file, along with wiring/pinout from Frédéric Grandjean, and example Mysensors MQTTClientGateway sketch and got a ProMiniMQTTW5100Gateway working.
              You are trying Ethernet gateway (not MQTT like me), but i think you may have a radio problem - i used 10uF and 1uF caps for the RFM69 radio and separate 3.3V supply (havent tried powering radio directly from ProMini VCC though.
              Jonathan CaesJ
              Jonathan CaesJ
              Jonathan Caes
              @Tris But I don't necessarily have to use the mqttw5100gateway, do I? Because I don't really know what you can do with mqtt, what the advantage is of that.
              I'm also using seperate 3.3V and a 4.7µF capacitor for the radio.
              Here is my schematic I used. I etched my own pcb for this and I think everything looks correct.
              0_1484907018198_upload-9caf576c-a61e-4bf4-90ba-e108c51e4a94
              • T
                Tris
                The Ethernet and MQTT wiring is the same (according to main MySesnors instructions).
                As far as protocols go, I choose the MQTT route because its simple and lightwieght, tipped to be a big player in IoT.
                Im not a Mysensors expert, more of a hardware guy, but briefly looking at your diagram - i havent grounded the reset pin on the RFM69 like you have.
                Try cutting that track so it floats
                Jonathan CaesJ 3 Replies Last reply
                • T Tris
                  Jonathan CaesJ
                  Jonathan CaesJ
                  Jonathan Caes
                  @Tris That can indeed be the fault, because i was looking at the hoop up page from sparfun (https://learn.sparkfun.com/tutorials/rfm69hcw-hookup-guide#hardware-overview) and thought I read that you have to connect the reset to ground, but that might be not true after reading it again. So i'll try doing that and see what happens.
                  Thanks!!
                  • T Tris
                    Jonathan CaesJ
                    Jonathan CaesJ
                    Jonathan Caes
                    @Tris Cut the reset connection and tried again, did not work.. still getting the same debugging info.. :(
                    • T Tris
                      Jonathan CaesJ
                      Jonathan CaesJ
                      Jonathan Caes
                      @Tris I also get the same debugging when using the MQTTclientgateway..
                      • T
                        Tris
                        Only thing i can think of, is quite basic but i do it myself quite often.
                        Remember to put the // lines back infront of the soft spi line in MyConfig.h file.
                        You only need that for NRF24 W5100 setup
                        Also define the new MI/MO/SCK pins in the sketch
                        #define MY_SOFT_SPI_SCK_PIN 13
                        #define MY_SOFT_SPI_MISO_PIN 12
                        #define MY_SOFT_SPI_MOSI_PIN 11```
                        Jonathan CaesJ 1 Reply Last reply
                        • T Tris
                          Jonathan CaesJ
                          Jonathan CaesJ
                          Jonathan Caes
                          @Tris This is the code I used, it was sugested by Frédéric. With this I don't need to change anything to the myconfig.h file, or do I?
                           * Version 1.0 - Henrik EKblad
                           * LED purposes:
                          #define MY_RADIO_RFM69
                          // La définition des PIN ci dessous n'est pas nécessaire, car c'est celle de base
                          //#define MY_RF69_IRQ_PIN 2
                          //#define MY_RF69_SPI_CS 10
                          #define MY_GATEWAY_W5100
                          #define MY_IP_ADDRESS 192,168,0,22
                          #define MY_PORT 5003
                          // Enable inclusion mode
                          // Flash leds on rx/tx/err
                          // Set blinking period
                          #define MY_DEFAULT_ERR_LED_PIN 4  // Error led pin
                          #define MY_DEFAULT_RX_LED_PIN  5  // Receive led pin
                          #define MY_DEFAULT_TX_LED_PIN  6  // Transmit led pin
                          #if defined(MY_USE_UDP)
                            #include <EthernetUdp.h>
                          #include <Ethernet.h>
                          • T
                            Tris
                            • T
                              Tris
                              Try adding the pins to the sketch
                              • T Tris
                                abrasha
                                @Tris
                                ok it didnt work with the w5100.h amendment, so i reverted to the original config.
                                now im on your new pinout with the a0-a2 thing, and i got identification on domoticz log and ping throught win7 command line. everything looks fine, but when i try mockmysensors to see if it recieves any comminication i dont see anything.
                                also the serial log looks wierd:
                                IP: 192.168.254.204
                                0;255;3;0;9;MCO:BGN:STP
                                0;255;3;0;9;Eth: connect
                                0;255;3;0;9;Eth: 0;0;3;0;2;
                                0;255;3;0;9;Eth: 0;0;3;0;2;Get Version
                                0;255;3;0;9;Eth: 0;0;3;0;18;PING
                                and it goes on and on...
                                of course both nodes have gone eeprom clearing
                                • X
                                  X
                                  xefil
                                  I'm following this guide to try compile the MQTTClient on a RFM69 but it doesn't work :(
                                  I've Arduino UNO with Ethernet shield W5100 and RFM69. MySensors 2.2 API.
                                  All was working well via serial port (so it means that the connection are ok and the level shifter as well), but I need to migrate to an IP version, better if MQTTClient.
                                  I've used the @Frédéric-Grandjean patch and the @Jonathan-Caes modification on the #else error. I'm using arduino 1.8.2 software and I've downgraded the AVR Board to 1.6.11. It compiles fine, but the output is the following:
                                  0 MCO:BGN:INIT GW,CP=RRNGTSM:INIT:TSP FAIL
                                  10117 TSM:FAIL:CNT=2
                                  10119 TSM:FAIL:DIS
                                  10121 TSF:TDI:TSL
                                  0 MCO:BGN:INIT GW,CP=RRNGA---,VER=2.2.0
                                  3 TSM:INIT
                                  4 TSF:WUR:MS=0
                                  55 !TSM:INIT:TSP FAIL
                                  56 TSM:FAIL:CNT=1
                                  58 TSM:FAIL:DIS
                                  59 TSF:TDI:TSL
                                  10062 TSM:FAIL:RE-INIT
                                  10064 TSM:INIT
                                  10115 !TSM:INIT:TSP FAIL
                                  10119 TSM:FAIL:DIS
                                  10121 TSF:TDI:TSL
                                  This is my code:
                                  #define MY_MQTT_PUBLISH_TOPIC_PREFIX "mygateway2-out"
                                  #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mygateway2-in"
                                  #define MY_MQTT_CLIENT_ID "mysensors-2"
                                  #define MY_SOFTSPI
                                  #ifndef MY_RF24_CE_PIN
                                  #define MY_RF24_CE_PIN 5
                                  #ifndef MY_RF24_CS_PIN
                                  #define MY_RF24_CS_PIN 6
                                  #define MY_IP_ADDRESS 192,168,1,52
                                  #define MY_CONTROLLER_IP_ADDRESS 192,168,1,50
                                  #define MY_PORT 1883
                                  Thanks a lot for any help!!
                                  Simon
                                  • FalcogeorgeF
                                    FalcogeorgeF
                                    Falcogeorge
                                    Well I’m a complete Noob here and started off with a similar setup.
                                    I’m not going for an MQTT gateway, just Ethernet but my radio problems were similar with similar debug output.
                                    I have an Etherten board and Rfm69 radio.
                                    I’ve now got it working great. I didn’t change and code in w5100.h. What I did do was move the NSS from pin 10 down to pin 6 (7-9 was for the status LEDs)
                                    So the only changes I have are as follows..
                                    #define MY_RFM69_NEW_DRIVER
                                    #define MY_RF69_SPI_CS 6
                                    #define MY_RFM69_FREQUENCY (RFM69_433MHZ)
                                    I thought I’d go with the new driver from the outset. I don’t think I needed to define the IRQ pin but I did it anyway. Moving CS was the fix for me initially to get past the radio errors. Then the final key was defining the frequency. Before I did that everything looked good but I couldn’t get a node talking to the gateway. As soon as I defined the frequency it all started working.
                                    Now I just need to grow my hair back.
                                    • JohnRobJ
                                      JohnRobJ
                                      JohnRob
                                      @Falcogeorge
                                      I have an RFM69 on a Anarduino (basically a AT328p with solder pads for the RFM69. I started with MySensors V2.2.0 My RFM69 NSS is connected to D10. All works fine. My setup code is below.
                                      One note, the default debug baud is 115k. This is likely too fast for some with lower speed clocks.
                                      #define MY_BAUD_RATE (9600ul)
                                      // === Hardware / MySensors Initialization ================
                                      #define MY_RFM69_FREQUENCY RFM69_915MHZ
                                      // === Node Initialization ================================
                                      #define CHILD_ID 5
                                      #define sensortype S_MULTIMETER
                                      #define LEDPIN 9 //PB1 is pin 9 on ProMini
                                      #define LED_TST A0
                                      #define NODE_TXT "Counting_test_Node"
                                      uint8_t MyCount;
                                      uint8_t ACK_Result;
                                      uint8_t NACK_Count;
                                      MyMessage msg_Voltage(CHILD_ID, V_VOLTAGE);
