  3. [SOLVED] W5100 Ethernet gateway with RFM69 Radio fails at init
31 Posts 9 Posters 14.5k Views 7 Watching
  • Frédéric GrandjeanF
    Frédéric GrandjeanF
    Frédéric Grandjean
    Perfect, thank you.
    That solved all issues! Now working super fine.
    • Jonathan CaesJ
      Jonathan CaesJ
      Jonathan Caes
      Hi, Frédéric Grandjean
      I'm also trying to build an ethernet gateway with the rfm69 radio's. But also have some errors when testing the code. Also I'm not sure I connected everything the right way, because there's not that info about those modules.
      Since you have this al working now, is it possible for me to take a look at your code and maybe show me how you connected everything?
      Thank you!
      Jonathan
        Frédéric GrandjeanF
        Frédéric Grandjean
        Hi Jonathan,
        Before I show my code, please check:
        • Connect W5100 and radio like this
        Arduino - Radio - Ethernet
        13      - SCK   - SCK
        12      - MISO  - MISO/SO
        11      - MOSI  - MOSI/SI
        10      - NSS (CS)
        7       -       - SS/CS
        2       - DIO0  -
        Be sure to power the W5100 with 5V and the radio with 3v3!
        Then, you need to modify the w5100.h file to disable radio interruption during SPI use:
        Find
          inline static void initSS()    { DDRB  |=  _BV(2); };
          inline static void setSS()     { PORTB &= ~_BV(2); };
          inline static void resetSS()   { PORTB |=  _BV(2); };
        and replace with
        #elif defined(W5100SPIPATCH)
          inline static void initSS()    { DDRD  |=  _BV(7); };
          inline static void setSS()     { cli(); PORTD &= ~_BV(7); };
          inline static void resetSS()   { PORTD |=  _BV(7); sei(); };
        Then, downgrade the board manager "Arduino AVR boards" to version 1.6.11 and rebuild.
        Finally, here is my working code:
         * Version 1.0 - Henrik EKblad
         * LED purposes:
        #define MY_RADIO_RFM69
        // La définition des PIN ci dessous n'est pas nécessaire, car c'est celle de base
        //#define MY_RF69_IRQ_PIN 2
        //#define MY_RF69_SPI_CS 10
        #define MY_GATEWAY_W5100
        #define MY_IP_ADDRESS 192,168,0,22
        #define MY_PORT 5003
        // Enable inclusion mode
        // Flash leds on rx/tx/err
        // Set blinking period
        #define MY_DEFAULT_ERR_LED_PIN 4  // Error led pin
        #define MY_DEFAULT_RX_LED_PIN  5  // Receive led pin
        #define MY_DEFAULT_TX_LED_PIN  6  // Transmit led pin
        #if defined(MY_USE_UDP)
          #include <EthernetUdp.h>
        #include <Ethernet.h>
        Hope it helped
        Fred
        Jonathan CaesJ 2 Replies Last reply
        • Frédéric GrandjeanF Frédéric Grandjean
          Hi Jonathan,
          13      - SCK   - SCK
          12      - MISO  - MISO/SO
          11      - MOSI  - MOSI/SI
          10      - NSS (CS)
          7       -       - SS/CS
          2       - DIO0  -
          Find
          and replace with
           * LED purposes:
          Hope it helped
          Fred
          Jonathan CaesJ
          Jonathan CaesJ
          Jonathan Caes
          @Frédéric-Grandjean
          Thank you for replying so quickly!
          I`m going to try this as quickly as possible and let you know how it went.
            Hi Jonathan,
            13      - SCK   - SCK
            12      - MISO  - MISO/SO
            11      - MOSI  - MOSI/SI
            10      - NSS (CS)
            7       -       - SS/CS
            2       - DIO0  -
            Find
            and replace with
             * LED purposes:
            Hope it helped
            Fred
            Jonathan CaesJ
            Jonathan CaesJ
            Jonathan Caes
            @Frédéric-Grandjean Have to wait untill my level converters are arriving.. also don't have enough transistors laying around to make one my self.. did you use a level converter, probably you did?
              Frédéric GrandjeanF
              Frédéric Grandjean
              Yes of course I used a level converter. Ordered the one proposed on the radio page. Works well!
                Jonathan CaesJ
                Jonathan CaesJ
                Jonathan Caes
                @Frédéric-Grandjean
                Hey, I'm finally working on the gateway.
                But the problem is that I can't seem to find the w5100.h file.. :s
                Can you maybe tell me where I can find it?
                Greetings
                  Jonathan CaesJ
                  Jonathan CaesJ
                  Jonathan Caes
                  @Frédéric-Grandjean
                  Hi again, because I'm a mac user didn't find the w5100.h file. after I took my laptop and searched for the file I found it.
                  after I replaced the code in the w5100.h file and changed the gateway code and complied I got these errors: 0_1484422292389_upload-59769e3e-1f23-4376-a3df-2c902afcdbeb
                  and it went on.
                  but when I changed the code in the w5100.h file from this:
                  To this:
                  #else	//This doesn't work => elif defined(W5100SPIPATCH)
                  it compiled without any errors.
                  So I uploaded the code and opened the serial debugging window in which I get this:
                  0_1484423132127_upload-e0346356-c42c-4039-add5-612525c85127
                  I don't know how to fix this, do you know maybe?
                  Thanks!!
                  Greetings!
                  A 1 Reply Last reply
                  • T
                    Tris
                    Jonathan Caes - i used your amended #else code in W5100.h file, along with wiring/pinout from Frédéric Grandjean, and example Mysensors MQTTClientGateway sketch and got a ProMiniMQTTW5100Gateway working.
                    You are trying Ethernet gateway (not MQTT like me), but i think you may have a radio problem - i used 10uF and 1uF caps for the RFM69 radio and separate 3.3V supply (havent tried powering radio directly from ProMini VCC though.
                    Jonathan CaesJ 1 Reply Last reply
                    • Jonathan CaesJ Jonathan Caes
                      @Frédéric-Grandjean
                      and it went on.
                      To this:
                      Thanks!!
                      Greetings!
                      abrasha
                      @Jonathan-Caes @Frédéric-Grandjean
                      if i use w5100 shield on uno - so i cant connect the pins how i want - means w5100 cs stays on pin 10.
                      what should i do?
                      • T
                        Tris
                        For W5100 shield on Uno with RF69 as a Gateway, i used:
                        DI00 - Pin 2
                        NSS - Pin 4 (3.3v level shifter)
                        MOSI - Pin A1 (3.3v level shifter)
                        MISO - Pin A2
                        SCK - Pin A0 (3.3v level shifter)
                        Leave as pins 14/15/16 in MyConfig.h file - the Uno uses digital pins 14-16 physically as A0-A3.
                        Using a level shifter makes the ProMini more viable as it is 3.3v and you dont need a shifter.
                        • T Tris
                          DI00 - Pin 2
                          MISO - Pin A2
                          abrasha
                          @Tris with or without w5100. H mod?
                          • T
                            Tris
                            I THINK with the W5100.h file amended.
                            try using Mysensors ClearEepromConfig too
                            A 2 Replies Last reply
                            • T Tris
                              abrasha
                              @Tris thanks a lot. I'll check it on Sunday.
                              Btw i use adafruit rfm69hw breakout so no level shifter needed, but i need to post my fix for it because it needs my transport.h mod
                              • T Tris
                                Jonathan CaesJ
                                Jonathan CaesJ
                                Jonathan Caes
                                @Tris But I don't necessarily have to use the mqttw5100gateway, do I? Because I don't really know what you can do with mqtt, what the advantage is of that.
                                I'm also using seperate 3.3V and a 4.7µF capacitor for the radio.
                                Here is my schematic I used. I etched my own pcb for this and I think everything looks correct.
                                0_1484907018198_upload-9caf576c-a61e-4bf4-90ba-e108c51e4a94
                                • T
                                  Tris
                                  The Ethernet and MQTT wiring is the same (according to main MySesnors instructions).
                                  As far as protocols go, I choose the MQTT route because its simple and lightwieght, tipped to be a big player in IoT.
                                  Im not a Mysensors expert, more of a hardware guy, but briefly looking at your diagram - i havent grounded the reset pin on the RFM69 like you have.
                                  Try cutting that track so it floats
                                  Jonathan CaesJ 3 Replies Last reply
                                  • T Tris
                                    Jonathan CaesJ
                                    Jonathan CaesJ
                                    Jonathan Caes
                                    @Tris That can indeed be the fault, because i was looking at the hoop up page from sparfun (https://learn.sparkfun.com/tutorials/rfm69hcw-hookup-guide#hardware-overview) and thought I read that you have to connect the reset to ground, but that might be not true after reading it again. So i'll try doing that and see what happens.
                                    Thanks!!
                                    • T Tris
                                      Jonathan CaesJ
                                      Jonathan CaesJ
                                      Jonathan Caes
                                      @Tris Cut the reset connection and tried again, did not work.. still getting the same debugging info.. :(
                                      • T Tris
                                        Jonathan CaesJ
                                        Jonathan CaesJ
                                        Jonathan Caes
                                        @Tris I also get the same debugging when using the MQTTclientgateway..
                                        • T
                                          Tris
                                          Only thing i can think of, is quite basic but i do it myself quite often.
                                          Remember to put the // lines back infront of the soft spi line in MyConfig.h file.
                                          You only need that for NRF24 W5100 setup
                                          Also define the new MI/MO/SCK pins in the sketch
                                          #define MY_SOFT_SPI_SCK_PIN 13
                                          #define MY_SOFT_SPI_MISO_PIN 12
                                          #define MY_SOFT_SPI_MOSI_PIN 11```
