  3. Signing ATSHA Key?
Signing ATSHA Key?
19 Posts 4 Posters 4.5k Views 3 Watching
  • TakeroT Takero
    Thanks! Now i am on the right way :-D
    Finaly i'f got a HMAC_KEY.
    On my Soft_Signing GW i have to enable USE_SOFT_SIGNING and STORE_SOFT_KEY (with the HMAC_KEY) and run the SercurePersonalizer.ino on my GW? Right?
    alexsh1A
    alexsh1A
    alexsh1
    Yes
    • alexsh1A
      alexsh1A
      alexsh1
      ATSHA204A and soft signing are very similar in the sketch. You have to enable/disable corresponding options
      TakeroT 1 Reply Last reply
      • alexsh1A alexsh1
        TakeroT
        TakeroT
        Takero
        @alexsh1 Thanks! I will try it later if my doughter is sleeping.
        • TakeroT
          TakeroT
          Takero
          Works :+1:
          • D
            DavidZH
            I'd like to ask a follow up question to this old topic:
            I have been able to create a set of keys using my GW on a Moteino (16MHz).
            Now I'd like to program the keys into a some nodes. A few of these are running a bare 328p at 1MHz as a battery sensor, but a baudrate of 115k is a bit high. I only get garbage in the serial window, so no checking if the keys are stored properly.
            Wouldn't it be wise to lower the baudrate of that sketch to be able to accomodate slow battery sensors. I have looked to try to do it myself, but was unable to find where.
            • D DavidZH
              @DavidZH I think you can add
              #define MY_BAUD_RATE 9600
              before including MySensors.h to set baud rate to 9600bps (change to even lower if you need to)
              • D
                DavidZH
                I had already tried that (I just did again, to be absolutely certain) but even at 4800 I still get garbage. I know 9600 baud works because of a test I had running before I tried the personalization sketch. I added the
                #define MY_BAUD_RATE 4800 before the inclusion of the MySensors.h file.
                • D DavidZH
                  @DavidZH 115200 seems to be hardcoded in the sketch. Try changing it. Search for 115200 https://github.com/mysensors/MySensors/blob/8e1ef13804f2737079298c63bd0d8aa7b82e7f73/examples/SecurityPersonalizer/SecurityPersonalizer.ino#L717
                  • D
                    DavidZH
                    Thanks a bunch! That did it! I always forget to use the "find" when I'm doing things like this. And the serial.begin was in line 881, I didn't expect it to be that far down.
                    • D DavidZH
                      @DavidZH great, thanks for verifying! I have created an issue on github https://github.com/mysensors/MySensors/issues/758
