  3. Signing ATSHA Key?
Signing ATSHA Key?
19 Posts 4 Posters 4.5k Views 3 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    Apologies for being brief but typing from the phone is no fun :anguished:
    Let us know how you get on
    • TakeroT
      TakeroT
      Takero
      No Prob, i hate phone typing too :-)
      I know it is possible to mix hard and soft. In my way i want to use hand signing only on my new nodes . . . i will not change all nodes yet.
      If i understood you right i have to generate the Key on my node (Lock Data is optional / i dont want to do that).
      Now i have a HARD Signing node, but Sign failed. So in my opinion i have to generate a Key on my GW too?! Right? Use this points, this the Random Key if i generate before?:
      If you do not have the ATSHA204A device and need to generate random keys:
      Enable USE_SOFT_SIGNING
      If you want to review existing EEPROM configuration to determine if anything needs to be updated:
      Make sure to disable any ATSHA204A update features if you use it (enable SKIP_KEY_STORAGE, disable LOCK_CONFIGURATION and LOCK_DATA)
      Disable STORE_SOFT_KEY
      Disable STORE_SOFT_SERIAL
      Disable STORE_AES_KEY
      After this, it it possible to communicate with the "old" Soft_Signing Nodes?
      alexsh1A 1 Reply Last reply
      • TakeroT Takero
        alexsh1A
        alexsh1A
        alexsh1
        @Takero Firstly, using debug for signing is a must to understand what's going on.
        In order to have signing you must have the same key on a node and the GW. For the first time, you can generate it, but later you have to put it in the sketch and use with every node or GW.
        If you do not have it on your GW signing will fail!!!
        • TakeroT
          TakeroT
          Takero
          Thanks! Now i am on the right way :-D
          Finaly i'f got a HMAC_KEY.
          On my Soft_Signing GW i have to enable USE_SOFT_SIGNING and STORE_SOFT_KEY (with the HMAC_KEY) and run the SercurePersonalizer.ino on my GW? Right?
          • alexsh1A
            alexsh1A
            alexsh1
            After you generated the keys and did your first node, do the following for soft signing:
            Enable LOCK_CONFIGURATION
            Enable STORE_SOFT_KEY - must be the same
            Enable STORE_SOFT_SERIAL - must be individual for each node/GW
            Enable STORE_AES_KEY - must be the same
            Below the options above you have to insert your keys.
            EDIT: just corrected what you should enable
            • TakeroT Takero
              alexsh1A
              alexsh1A
              alexsh1
              Yes
              • alexsh1A
                alexsh1A
                alexsh1
                ATSHA204A and soft signing are very similar in the sketch. You have to enable/disable corresponding options
                TakeroT 1 Reply Last reply
                • alexsh1A alexsh1
                  TakeroT
                  TakeroT
                  Takero
                  @alexsh1 Thanks! I will try it later if my doughter is sleeping.
                  • TakeroT
                    TakeroT
                    Takero
                    Works :+1:
                    • D
                      DavidZH
                      I'd like to ask a follow up question to this old topic:
                      I have been able to create a set of keys using my GW on a Moteino (16MHz).
                      Now I'd like to program the keys into a some nodes. A few of these are running a bare 328p at 1MHz as a battery sensor, but a baudrate of 115k is a bit high. I only get garbage in the serial window, so no checking if the keys are stored properly.
                      Wouldn't it be wise to lower the baudrate of that sketch to be able to accomodate slow battery sensors. I have looked to try to do it myself, but was unable to find where.
                      • D DavidZH
                        @DavidZH I think you can add
                        #define MY_BAUD_RATE 9600
                        before including MySensors.h to set baud rate to 9600bps (change to even lower if you need to)
                        • D
                          DavidZH
                          I had already tried that (I just did again, to be absolutely certain) but even at 4800 I still get garbage. I know 9600 baud works because of a test I had running before I tried the personalization sketch. I added the
                          #define MY_BAUD_RATE 4800 before the inclusion of the MySensors.h file.
                          • D DavidZH
                            @DavidZH 115200 seems to be hardcoded in the sketch. Try changing it. Search for 115200 https://github.com/mysensors/MySensors/blob/8e1ef13804f2737079298c63bd0d8aa7b82e7f73/examples/SecurityPersonalizer/SecurityPersonalizer.ino#L717
                            • D
                              DavidZH
                              Thanks a bunch! That did it! I always forget to use the "find" when I'm doing things like this. And the serial.begin was in line 881, I didn't expect it to be that far down.
                              • D DavidZH
                                @DavidZH great, thanks for verifying! I have created an issue on github https://github.com/mysensors/MySensors/issues/758
