  3. Vera
  4. Showing N/A instead of last stored temperature
8 Posts 2 Posters 3.0k Views 2 Watching
  • A Offline
    A Offline
    Alexander Ivanov
    Sometimes my VeraPlus loses connection to temperature sensor. If it happens, I'd like to see N/A (or someth. similar) as temperature, instead of last stored value.
    Is there any way to change last stored temperature value to N/A if temperature sensor doesn't respond more than (say) 10 minutes?
    • A Offline
      A Offline
      Alexander Ivanov
      The purpose of my request is just to understand to see that sensors work correctly and haven't lost connection. Currently it's not obvious at all - I see last value which can be shown forever.
      • R Offline
        R Offline
        r-nox
        It would be nice to have a timestamp available.
        A 1 Reply Last reply
        • R r-nox
          A Offline
          A Offline
          Alexander Ivanov
          @r-nox, two issues:
          • timestamp is not shown in most mobile clients, can be easily missed.
          • there are timestamp for nodes, but it's not obvious what they mean, asked question here: https://forum.mysensors.org/topic/5882/last-update-node-field-in-vera-interface
          • R Offline
            R Offline
            r-nox
            Where are you seeing the timestamp? I've yet to see them in the Vera ui.
            • R r-nox
              A Offline
              A Offline
              Alexander Ivanov
              @r-nox, Device List scree, "Last update" field under each node (not device/sensor).
              • R Offline
                R Offline
                r-nox
                Thank you
                • R r-nox
                  Thank you
                  A Offline
                  A Offline
                  Alexander Ivanov
                  @r-nox but not clear what the time there really means.
                  12.0k
