  3. "Error sending switch command, check device/hardware !"
5 Posts 5 Posters 2.5k Views 3 Watching
  • S Offline
    sama
    hello .
    I have problem with switch command.i am using this sketch:
     * Version 1.0 - Henrik Ekblad
     * Example sketch for a "light switch" where you can control light or something
     * else from both HA controller and a local physical button
     * (connected between digital pin 3 and GND).
     * This node also works as a repeader for other nodes
     * http://www.mysensors.org/build/relay
    #define MY_REPEATER_FEATURE
    #define RELAY_PIN1  6  // Arduino Digital I/O pin number for relay
    #define BUTTON_PIN1  3  // Arduino Digital I/O pin number for button
    #define CHILD_ID1 1   // Id of the sensor child
    #define RELAY_PIN2  7  // Arduino Digital I/O pin number for relay
    #define BUTTON_PIN2  4  // Arduino Digital I/O pin number for button
    #define CHILD_ID2 2   // Id of the sensor child
    #define RELAY_PIN3  8  // Arduino Digital I/O pin number for relay
    #define BUTTON_PIN3  5  // Arduino Digital I/O pin number for button
    #define CHILD_ID3 3   // Id of the sensor child
    #define RELAY_ON 1
    #define RELAY_OFF 0
    Bounce debouncer1 = Bounce();
    int oldValue1 = 0;
    bool state1;
    Bounce debouncer2 = Bounce();
    int oldValue2 = 0;
    bool state2;
    Bounce debouncer3 = Bounce();
    int oldValue3 = 0;
    bool state3;
    MyMessage msg1(CHILD_ID1, V_LIGHT);
    MyMessage msg2(CHILD_ID2, V_LIGHT);
    MyMessage msg3(CHILD_ID3, V_LIGHT);
      // Setup the button
      pinMode(BUTTON_PIN1, INPUT);
      digitalWrite(BUTTON_PIN1, HIGH);
      pinMode(BUTTON_PIN2, INPUT);
      digitalWrite(BUTTON_PIN2, HIGH);
      pinMode(BUTTON_PIN3, INPUT);
      digitalWrite(BUTTON_PIN3, HIGH);
      debouncer1.attach(BUTTON_PIN1);
      debouncer1.interval(5);
      debouncer2.attach(BUTTON_PIN2);
      debouncer2.interval(5);
      debouncer3.attach(BUTTON_PIN3);
      debouncer3.interval(5);
      digitalWrite(RELAY_PIN1, RELAY_OFF);
      pinMode(RELAY_PIN1, OUTPUT);
      digitalWrite(RELAY_PIN2, RELAY_OFF);
      pinMode(RELAY_PIN2, OUTPUT);
      digitalWrite(RELAY_PIN3, RELAY_OFF);
      pinMode(RELAY_PIN3, OUTPUT);
      state1 = loadState(CHILD_ID1);
      digitalWrite(RELAY_PIN1, state1 ? RELAY_ON : RELAY_OFF);
      state2 = loadState(CHILD_ID2);
      digitalWrite(RELAY_PIN2, state2 ? RELAY_ON : RELAY_OFF);
      state3 = loadState(CHILD_ID3);
      digitalWrite(RELAY_PIN3, state3 ? RELAY_ON : RELAY_OFF);
    void presentation()  {
      present(CHILD_ID1, S_LIGHT);
      present(CHILD_ID2, S_LIGHT);
      present(CHILD_ID3, S_LIGHT);
    *  Example on how to asynchronously check for new messages from gw
      { debouncer1.update();
        // Get the update value
        int value1 = debouncer1.read();
        if (value1 != oldValue1 && value1 == 0) {
          send(msg1.set(state1 ? false : true), true); // Send new state and request ack back
        oldValue1 = value1;
      { debouncer2.update();
        if (value2 != oldValue2 && value2 == 0) {
        oldValue2 = value2;
      { debouncer3.update();
        int value3 = debouncer3.read();
        if (value3 != oldValue3 && value3 == 0) {
          send(msg3.set(state3 ? false : true), true); // Send new state and request ack back
        oldValue3 = value3;
      if (message.isAck()) {
        switch (message.sensor) {
          case 1:
            state1 = message.getBool();
            digitalWrite(message.sensor + 2, state1 ? RELAY_ON : RELAY_OFF);
          case 2:
            state2 = message.getBool();
            digitalWrite(message.sensor + 2, state2 ? RELAY_ON : RELAY_OFF);
          case 3:
            state3 = message.getBool();
            digitalWrite(message.sensor + 2, state3 ? RELAY_ON : RELAY_OFF);
    this is a 3 channel relay with button.
    some time commands sent and some time could not be sent and show "Error sending switch command, check device/hardware !" I did take steps in accordance site and use a 4.7uf capacitor between vcc and gnd in radio . now some time command sent . some time could not be sent and i wait for a time (1 min , 2 min and more) and again send command and this is ok ! also when for test i sent some consecutive command (on/off/on/off/on) so again i see "Error sending switch command, check device/hardware !" i wait again and after a while work again and ok !
    I did search between topics and i see some suggest to use this module:
    link text
    so i use this but the problem did not solve for me .
    also i use a repeater between node and gateway but...
    Does anyone a proposal for my problem ?
    Best Regards S_m .
    A 1 Reply Last reply
    • S sama
      hello .
      #define RELAY_ON 1
      #define RELAY_OFF 0
      int oldValue1 = 0;
      bool state1;
      int oldValue2 = 0;
      bool state2;
      int oldValue3 = 0;
      bool state3;
        // Setup the button
          oldValue1 = value1;
          oldValue2 = value2;
          oldValue3 = value3;
            case 1:
            case 2:
            case 3:
      link text
      Best Regards S_m .
      A Offline
      A Offline
      Anticimex
      @Reza just stop creating new accounts please.
      R 1 Reply Last reply
      • A Anticimex
        R Offline
        R Offline
        Reza
        @Anticimex
        when some people is living in a building so this is not all account are one person ! sama is my friend . i introduce mysensors to her . so he had problem and question about this with me and i told to her i dont know go and register a account or use my account ! i have just 2 account one account is this and another account is for when i lost my user pass (this ) after found i comeback to this account ....
        • S Offline
          @Reza
          looks funky but maybe..
          This is a problem you have already asked for..
          So the best you can do is:
          • remove your relays and connect leds instead
          • test this for few days.
          If there is no issues, it means that's on your hardware. And we can't scope it at distance. Can be a bad power supply input on your hardware (no filtering), parasites due to relay switch (better to use relay driver, tvs diode, capa for filtering) etc..
          I suggest you to read some docs on internet about this. That's the diy side, when using simple chinese relays modules.
          • N Offline
            N Offline
            novicit
            @sama, I had similar problems, always with relay nodes. The solution that has worked 100% of the time for me is to add a delay(100) as described by @kk02067 at the end of the forum thread of the same name:
            https://forum.mysensors.org/topic/4987/error-sending-switch-command-check-device-hardware
            Don't know if this will solve your problem, but worth a try.
