  3. MAX6675
MAX6675
temperature
14 Posts 5 Posters 11.0k Views 4 Watching
  • W
    W
    wthiess
    Hy i
    IDE upload:
    MySensors.h:328:2: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
    Bleas help
    lg
    Wolfgang
      Mrlynx
      example has to be converted to 2.x of mysensors.
      To do so you need at least to add
      remove all gw.
      please look at any 2.x example to see what have changed.
      http://www.sa2avr.se
      • W
        W
        wthiess
        I can not understand that!
        I have not Radio my Arduino ist connect per USB.
        AnticimexA 1 Reply Last reply
        • W wthiess
          AnticimexA
          AnticimexA
          Anticimex
          @wthiess How do you plan to communicate with any sensors/actuators if you have no radio/supported transport attached???
          • W
            W
            wthiess
            Paspberry > USB > Ardunino-max6675
            • W wthiess
              AnticimexA
              AnticimexA
              Anticimex
              @wthiess You need to use a supported transport.
              • W
                W
                wthiess
                USB / Serial
                /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A700RH5J-if00-port0@9600
                • W wthiess
                  USB / Serial
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @wthiess I suggest you read up on what MySensors is.
                  Here is a good start: https://www.mysensors.org/about/network
                    Mrlynx
                    If you are not going to use mysensors look at library example
                    https://github.com/mcleng/MAX6675-Library/blob/master/examples/read_temp/read_temp.pde
                    • W
                      W
                      wthiess
                      Error:
                      MAX6875Temp.ino: In function 'void loop()':
                      MAX6875Temp:24: error: 'class MAX6675' has no member named 'read_temp'
                      temperature = temp.read_temp();
