  3. MAX6675
MAX6675
temperature
14 Posts 5 Posters 11.0k Views 4 Watching
    Mrlynx
    wrote on last edited by Mrlynx
    I have gotten a maxim MAX6675 board and a K-type thermocouple for measuring high temperatures working with mysensors and thought I would share my sketch.
    board is off ebay http://www.ebay.com/itm/301283128770
    I have found a library written by ryan j mclaughlin on github https://github.com/ryanjmclaughlin/MAX6675-Library
    #include <MAX6675.h>
    uint8_t CS0 = 4;              // CS pin on MAX6675
    uint8_t SO = 3;              // SO pin of MAX6675
    uint8_t SCLK = 5;             // SCK pin of MAX6675
    uint8_t units = 1;            // Units to readout temp (0 = ˚F, 1 = ˚C)
    float temperature = 0.0;  // Temperature output variable
    float lastTemperature;
    unsigned long SLEEP_TIME = 30000;
    boolean metric = true;
    MyMessage msg(0,V_TEMP);
    // Initialize the MAX6675 Library for our chip
    MAX6675 temp0(CS0,SO,SCLK,units);
      // Startup and initialize MySensors library. Set callback for incoming messages.
      gw.begin();
      gw.sendSketchInfo("Max6675 Temperature Sensor", "1.0");
      gw.present(0, S_TEMP);
      // Process incoming messages (like config from server)
      temperature = temp0.read_temp();         // Read the temp
      if(temperature == -1) {                   // If there is an error with the TC, temperature will be -1
        Serial.println("Thermocouple Error!!"); // Temperature is -1 and there is a thermocouple error
        Serial.print("Current Temperature: ");
        Serial.println( temperature );          // Print the temperature to Serial
        if (temperature!=lastTemperature)
          gw.send(msg.setSensor(0).set(temperature,1));
        lastTemperature=temperature;
      gw.sleep(SLEEP_TIME);
    http://www.sa2avr.se
      Nice, thanks for the example.
      Please enclose the source code between 4 backtick characters to format it correctly in the forum.
      Backtick == ` x 4
      • Ezequiel TorresE
        Ezequiel TorresE
        Ezequiel Torres
        Can you share the wiring diagram ?
        • Ezequiel TorresE Ezequiel Torres
          Mrlynx
          @Ezequiel-Torres I did just connect pin 3,4,5 and vcc,gnd to module and sensor to module. Look in example code for directions.
          Example is made for mysensors 1.4 or 1.5 so may have to modify it a bit.
          • W
            W
            wthiess
            Hy i
            IDE upload:
            MySensors.h:328:2: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
            Bleas help
            lg
            Wolfgang
              Mrlynx
              example has to be converted to 2.x of mysensors.
              To do so you need at least to add
              remove all gw.
              please look at any 2.x example to see what have changed.
              • W
                W
                wthiess
                I can not understand that!
                I have not Radio my Arduino ist connect per USB.
                AnticimexA 1 Reply Last reply
                • W wthiess
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @wthiess How do you plan to communicate with any sensors/actuators if you have no radio/supported transport attached???
                  • W
                    W
                    wthiess
                    Paspberry > USB > Ardunino-max6675
                    • W wthiess
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @wthiess You need to use a supported transport.
                      • W
                        W
                        wthiess
                        USB / Serial
                        /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A700RH5J-if00-port0@9600
                        • W wthiess
                          USB / Serial
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @wthiess I suggest you read up on what MySensors is.
                          Here is a good start: https://www.mysensors.org/about/network
                            Mrlynx
                            If you are not going to use mysensors look at library example
                            https://github.com/mcleng/MAX6675-Library/blob/master/examples/read_temp/read_temp.pde
                            • W
                              W
                              wthiess
                              Error:
                              MAX6875Temp.ino: In function 'void loop()':
                              MAX6875Temp:24: error: 'class MAX6675' has no member named 'read_temp'
                              temperature = temp.read_temp();
