  3. OpenHAB
  4. OpenHAB/MQTT Tips & Hints
40 Posts 17 Posters 66.8k Views 5 Watching
  • YveauxY Yveaux
    @kolaf said:
    Or does your server support sending items dated back to the sensor so that it knows whether the light is off or on currently?
    To make sure I understand you right, are both the switch & light located at the same node or do you have a sensor node (switch) and actuator node (light) ?
    K
    K
    kolaf
    The light is entirely separate from the switch. In my specific case it will typically be a Z-wave relay controlling the light, so I will have to map the toggle switch to the light relay in openhab. This is why I assume I have to use a rule to achieve this.
    • YveauxY
      @kolaf Here's my code to use one or two switches to dimm. I hope it gives you some inspiration to connect your zwave switch.
      MQTT topics (exposed by the MQTT perl script. Node 120 = switch sensor, node 119 = dimmable light):
      /mySensors/120/0/V_LIGHT           switch, reporting 1 when pressed, 0 when released
      /mySensors/120/1/V_LIGHT           switch, reporting 1 when pressed, 0 when released
      /mySensors/120/2/V_LIGHT           switch, reporting 1 when pressed, 0 when released
      /mySensors/119/0/V_DIMMER          dimmable light, accepting integer value between 0 and 100
      Items:
      Switch Switch_Up               {mqtt="<[server:/mySensors/120/0/V_LIGHT:state:MAP(switchFromMqtt.map)]"}
      Switch Switch_Down             {mqtt="<[server:/mySensors/120/1/V_LIGHT:state:MAP(switchFromMqtt.map)]"}
      Switch Switch_UpDown           {mqtt="<[server:/mySensors/120/2/V_LIGHT:state:MAP(switchFromMqtt.map)]"}
      Dimmer Light_Dimmed   (Lights) {mqtt=">[server:/mySensors/119/0/V_DIMMER:state:*:default]"}
      switchFromMqtt.map: (in transform folder)
      0=OFF
      1=ON
      Rules for 2-switch dimmer control (short press Switch_Up switches light on, short press Switch_Down switches light off, keep pressed to increase/decrease light level):
      val Long DimmerDelayMs = 333L
      rule "DimUp"
      when
        Item Switch_Up received update ON
      then
        var Boolean dimmed = false
        do
          Thread::sleep(DimmerDelayMs)
          if (Switch_Up.state == ON)
            sendCommand( Light_Dimmed, INCREASE )
            dimmed = true;
        } while (dimmed)
        if (!dimmed) sendCommand( Light_Dimmed, ON )
      end
      rule "DimDown"
      when
        Item Switch_Down received update ON
      then
        do
          if (Switch_Down.state == ON)
            sendCommand( Light_Dimmed, DECREASE )
            dimmed = true;
        } while (dimmed)
        if (!dimmed) sendCommand( Light_Dimmed, OFF )
      end
      Rules for 1-switch dimmer control (short press switches light on/off (depending on current state), keep pressed to increase/decrease light level):
      rule "DimUpDown"
      when
        Item Switch_UpDown received update ON
      then
        var Number percent = 0
        if (Light_Dimmed.state instanceof DecimalType) percent = Light_Dimmed.state as DecimalType
        do
          if (Switch_UpDown.state == ON)
            // Start cycling up/down until released
            var Boolean dimmUp = percent < 100
            do
              if (dimmUp) sendCommand( Light_Dimmed, INCREASE )
              else		sendCommand( Light_Dimmed, DECREASE )
              if (percent >= 100)	dimmUp = false;
              if (percent <= 0)	dimmUp = true;
              dimmed = true;
            } while (Switch_UpDown.state == ON)
        } while (dimmed)
        if (!dimmed)
          // Short press: switch on or off, depending on current state
          if (percent > 0)	sendCommand( Light_Dimmed, OFF )
          else				sendCommand( Light_Dimmed, ON )
      end
      Rule for the dimmable light:
      rule "MyDimmer0"
        when
          Item Light_Dimmed received command
        then
          if(Light_Dimmed.state instanceof DecimalType) percent = Light_Dimmed.state as DecimalType
          if(receivedCommand==INCREASE) percent = percent + 5
          if(receivedCommand==DECREASE) percent = percent - 5
          if(receivedCommand==ON) percent = 100
          if(receivedCommand==OFF) percent = 0
          if(percent<0)   percent = 0
          if(percent>100) percent = 100
          postUpdate(Light_Dimmed, percent)
      end
      Some stuff I'm still struggling with (any help/ideas appreciated):
      • Not sure if I can wrap (parts of) rules in a function to make re-use easier
      • Getting the current value of an item seems complicated first testing for DecimalType, then getting it. Maybe this can be done more efficient?
      • I use Thread::sleep to determine the timing of the buttons on the sensor node (pressed short/long). This will be influenced by the jitter on the sensor values received, but currently it seems to work fine. Furthermore Thread::sleep (probably) blocks whole rule processing, so this isn't a nice solution. The short/long presses can also be dermined on the sensor node and reported with different values, but then the sensor node is no longer a dumb switch and has to have knowledge of short/long presses....
      K 1 Reply Last reply
      • YveauxY Yveaux
        Items:
        0=OFF
        1=ON
        rule "DimUp"
        when
        then
          do
              dimmed = true;
          } while (dimmed)
        end
        rule "DimDown"
        when
        then
          do
              dimmed = true;
          } while (dimmed)
        end
        rule "DimUpDown"
        when
        then
          do
              do
                dimmed = true;
          } while (dimmed)
          if (!dimmed)
        end
        rule "MyDimmer0"
          when
          then
        end
        K
        K
        kolaf
        @Yveaux Excellent, this is just what I needed, thank you.
        I started looking at your Perl script since this seems like the most active solution for openhab integration. I have a couple questions if you don't mind.
        Why do you have two versions of the gateway script, and which version should I use as a basis when adding serial support?
        Does your gateway take care of node ID assignments? I guess I will figure out that by reading more of code :-)
        I'm thinking that I will fork your project to add a serial option to your script, controlled by some kind of commandline argument.
        • K kolaf
          Glad I could help!
          The serial format changed from MySensors 1.3 (protocol 1) to 1.4beta (protocol 2). I was lazy and just cloned the 1.3 version to add 1.4 support (the 2-version). Wouldn't be hard to support both, but I really wrote this script for my own usage. It's not documented and I tried to help Damme in the past to build MQTT support. I'm primarily on 1.4b btw, with some 1.3 setup for backwards sniffer support...
          If more people start using it I should do some things the nice way ;-)
          Not at the moment. Shouldn't be hard to implement though, but when you implement it you run into another issue of mapping the node-ID's onto the MQTT topic tree, or accessing the right topic from OpenHAB.
          Sticking to fixed Node ID's seemed to make more sense to me.
          Feel free to fork, but the current code is based on AnyEvent. Not that I like it, but it seemed to have the best MQTT support. There is some hacking in the script to get things working, for which I don't know how they behave when switching to serial.
          • YveauxY
            Btw. there's one important thing to understand when using the Perl script. When it receives values from a sensor node through the gateway it's easy to publish the value in the topic-tree.
            When a value has to be sent to an actuator node, the story is different as the script has to know which topic to subscribe to at the MQTT broker.
            Currently when a mysensor node requests a value from the gateway the script automagically translates this into a subscription of the corresponding topic with the MQTT broker. The dimmer node for example, calls gw.request(childID, V_DIMMER) from setup to subscribe itself to dimmer messages.
            Note that sometimes this request gets lost (CRC error or so) and the subscription fails. While not supported by the MySensors library, a robust implementation should wait for a response after requesting this value and retry when it doesn't come.
            The Perl script stores all current subscriptions persistent (file subscriptions.storage) so restarting the Perl script will not force you to restart all nodes to subscribe again.
            • YveauxY
              And another small one; an RGB dimmer!
              MQTT topics (exposed by the MQTT perl script. Node 118 = 3-channel dimmable light):
              /mySensors/118/0/V_DIMMER          dimmable light RED, accepting integer value between 0 and 100
              /mySensors/118/1/V_DIMMER          dimmable light GREEN, accepting integer value between 0 and 100
              /mySensors/118/2/V_DIMMER          dimmable light BLUE, accepting integer value between 0 and 100
              Items:
              Dimmer Light_R      {mqtt=">[server:/mySensors/118/0/V_DIMMER:state:*:default]"}
              Dimmer Light_G      {mqtt=">[server:/mySensors/118/1/V_DIMMER:state:*:default]"}
              Dimmer Light_B      {mqtt=">[server:/mySensors/118/2/V_DIMMER:state:*:default]"}
              Color Light_RGB 	"RGB Dimmer" 	(Lights)
              Rules to distribute colorwheel value over R,G,B dimmers:
              rule "Set RGB value"
              when
                      Item Light_RGB changed
              then
                      var HSBType hsbValue = Light_RGB.state as HSBType
                      postUpdate( Light_R, hsbValue.red.intValue )
                      postUpdate( Light_G, hsbValue.green.intValue )
                      postUpdate( Light_B, hsbValue.blue.intValue )
              end
              No button control here; just using the colorwheel and on/off buttons in the GUI.
              Enjoy!
              siodS E 2 Replies Last reply
              • YveauxY Yveaux
                This topic was split off http://forum.mysensors.org/topic/301/the-best-way-to-connect-to-openhab to discuss tips and hints specific to using MySensors together with MQTT middleware and OpenHAB.
                If you made something nice using this combination or have some questions/issues please post them in here!
                @kolaf I just started experimenting with openhab and find it quite hard to get started. There's some documentation ( far from complete, especially when you're just starting) but the general impression is that it's very powerful, mainly due to all the programming options. I'm quite sure you could directly talk to a mysensors gateway using the serial protocol, using e.g. rules, if you want.
                I doubt however if you want to write your own protocol handler...
                Anyway, I'm currently using an Ethernet gateway which tasks to a Perl script I wrote (https://github.com/Yveaux/MySensors_MQTTGateway) that does the conversion to and from MQTT. This script is a MQTT client that runs on the same server I run openhab and the mosquitto broker on. This is the only difference compared to @Damme solution who runs a broker on the gateway.
                I like the flexibility of storing & accessing all data through an MQTT broker which makes up for the apparent overkill going through MQTT just to connect mysensors to openhab.
                As long as your server has enough resources to run it all its not really worth the effort to directly talk to my sensors or create an openhab binding for it.
                DammeD
                DammeD
                Damme
                Code Contributor
                wrote on last edited by Damme
                rule to calculate absolute humidity and dew point from degree Celsius and rH%
                import java.lang.Math
                import java.lang.Integer
                import java.lang.Double
                rule "Calculate absolute humidity (g h2o / m3 air) and dew point"
                when
                    Item temp1 changed or
                    Item hum1 changed
                then
                    var temp = temp1.state as DecimalType
                    var hum = hum1.state as DecimalType
                    var t1 = (17.271*temp.floatValue) / (237.7+temp.floatValue) + Math::log(hum.floatValue*0.01)
                    var dew = (237.7 * t1) / (17.271 - t1)
                    var Number c1 = ((17.67*temp.floatValue)/(temp.floatValue+243.5))
                    var abs = (Math::pow(Math::E,c1.doubleValue)*6.112*2.1674*hum.floatValue) /(273.15+temp.floatValue)
                    Dewpoint1.postUpdate(dew)
                    AbsHum1.postUpdate(abs)
                end
                • DammeD Damme
                  when
                      Item hum1 changed
                  then
                  end
                  @Damme Nice calculation example! Thanks!
                  • D
                    Dany
                    Hi everyone!
                    I'm new in the topic. I find it very interesting the world of mysensors.
                    I would like to ask whether there is a description of someone that I can set my mqtt openHAB bindings eg .: an Arduino LED dimmer ?
                    I already read http://forum.mysensors.org/topic/303/mqtt broker-gateway
                    I made a Humidity sensor node, and Relay node, too.
                    It would be good if we had a basic description or example project for beginners from all sensor type. :)
                    • pgoP
                      pgoP
                      pgo
                      wrote on last edited by pgo
                      It is not rocket science to get the openHAB running w/MQTT gateway, see for example my post with DS/Light/Relay in http://forum.mysensors.org/topic/115/implementing-multiple-sensors/60
                      But sure, it would be great to put a wiki with all sensor settings for openHAB together on one page. I needed to read/search for some days to put the knowledge together...
                      Example of the openhab screenshots on mobile https://github.com/pgo-sk/mysensors/wiki/Home-automation-using-mysensors-and-openHAB
                      There you see also the mapping of the sensor
                      • A
                        adi32k
                        How can I make openhad respod to gw.request(sensor, V_HEATER_SW,0);
                        I have a relay actuator sketch and in setup() I have this
                        for (int sensor=1 ; sensor<=NUMBER_OF_RELAYS;sensor++)
                        gw.present(sensor, S_HEATER);
                        practically I would like openhab to respond to the gw.request with the actual state of the relay.
                        My item definition is the follwing. I am able to ON and OFF the relay, but I need to find a way to get the values from openhab of the relays when the relay actuator arduino reboots.
                        Switch Incalzire_Releu_GF_Living2 "Incalzire Releu Living 2" <heating> (Incalzire) {mqtt=">[mysensor:MyMQTT/3/2/V_HEATER_SW:command:ON:1],>[mysensor:MyMQTT/3/2/V_HEATER_SW:command:OFF:0]"}
                        • raditvR
                          raditvR
                          raditv
                          is there any sample code for controlling RGB led here?
                          • ChaoticC
                            ChaoticC
                            Chaotic
                            Sorry to Necro this thread but had a question,
                            I believe I read somewhere that you can use a serial gateway connected to a pi and have openhab/mqtt run on the pi?
                            How would one go about setting this up? Currently I have 2 Unos one running as the serial gateway. I plan to replace the serial gateway with a nano I'm still waiting on that.
                            I just got the pi last night so I'm still working on getting everything up and running on that but I'd rather just connect the gateway directly to the pi rather than have to get a wifi/ethernet module for one of the arduinos.
                            Also probably outside the scope of this thread (and thats fine) but anyone have a good guide for setting up the pi for openhab/MQTT?
                              mhortman
                              @Chaotic , Try this..
                              https://github.com/abouillot/HomeAutomation/tree/master/piGateway
                              Worked great for me
                              SweebeeS 1 Reply Last reply
                              • M mhortman
                                Worked great for me
                                SweebeeS
                                SweebeeS
                                Sweebee
                                @mhortman Didn't work for me:
                                sudo wget http://repo.mosquitto.org/debian/mosquitto-wheezy.list~
                                --2015-03-27 10:46:51--  http://repo.mosquitto.org/debian/mosquitto-wheezy.list~
                                Resolving repo.mosquitto.org (repo.mosquitto.org)... 85.119.83.194, 2001:ba8:1f1:f271::2
                                Connecting to repo.mosquitto.org (repo.mosquitto.org)|85.119.83.194|:80... connected.
                                HTTP request sent, awaiting response... 403 Forbidden
                                2015-03-27 10:46:51 ERROR 403: Forbidden.'
                                • Q
                                  Q
                                  quocanhcgd
                                  My house have 4 floor, i have plan build one gateway for each floor. Each floor has 4-5 sensors (temp, hum, relay, light, door, RF light). Each sensors use NRF24 to connect with gateway. Gateway connect to RAS by ethernet.
                                  My question:
                                  • Can i build 2 gateway mqtt connect to openhab?
                                    if not, what my solution to solve ?
                                  • R
                                    R
                                    rachmat aditiya27
                                    you can build more than 1 gateway for that, but rather than mqtt. I think it's better to use ethernet or serial gateway because mqtt gateway has lot of problem, I tried it for months. You can forward mqtt from fhem to mosquito.
                                    • YveauxY Yveaux
                                      Items:
                                      when
                                      then
                                      end
                                      Enjoy!
                                      siodS
                                      siodS
                                      siod
                                      @Yveaux
                                      could you please post your arduino code of controlling your RGB (I guess it´s a RGB LED Strip!?)?
                                      Thanks for your help!!
                                      still learning...
                                      • siodS
                                        siodS
                                        siod
                                        I build up a mqtt gateway and configured it in openhab.cfg. Now I would like to set up a mosquitto server on a raspberry pi, too. Is it possible to add this new MQTT server to the openhab.cfg beside the already set up MQTT gateway?
                                        still learning...
                                        • T
                                          tomkxy
                                          Why not setup the Mosquitto broker connect OpenHab to it and use the MQTTClientGateway which connects as a client to the Mosquitto broker. Has been discussed at several places in the forum already. You can find the MQTTClientGateway in the development branch.
                                          siodS 1 Reply Last reply
