  3. Possible to set up one RPi as a Gateway and a Controller?
4 Posts 4 Posters 1.6k Views 4 Watching
    Michael McGilton
    I've been looking around, but can't seem to actually find an answer. Is it possible to use one Raspberry Pi (likely model 1b) as both the (MySensors) Gateway, and as a (Home Assistant) controller? Additionally, can it ALSO take on the role of being an MQTT broker?
    S 1 Reply Last reply
    • T
      TimO
      If Home Assistant is able to run on RPi I see no problem in running a MySensors Gateway and an MQTT broker like Mosquitto in parallel. So: Yes!
      • rozpruwaczR
        rozpruwaczR
        rozpruwacz
        don't know about HA, but I'm running mysensors mqtt gateway with openhab on rpi 3 (and Mosquitto as a broker), works without any problems.
        • M Michael McGilton
          sja
          @Michael-McGilton
          I have a rpi running hass and a mqtt broker. Check bruh automation site for tutorials how tot install. I have a serial gateway attached, but I guess you can also run the gateway directly on the rpi. Haven't tried it myself.
