  3. Sensebender Micro - Serial console - reading problem
5 Posts 2 Posters 2.1k Views 1 Watching
  • Viktor ZemanV Offline
    Viktor Zeman
    I was able to upload scetch to my Sensebender Micro (1MHz) board, but I'm not able to read from console.
    I read, that it is related to baud rate of console - I have tried to change the baud rate to many possible values, but none worked yet.
    Could somebody help to identify my problem?
    Here is the code:
    #include "i2c.h"
    #include "i2c_SI7021.h"
    SI7021 si7021;
        Serial.begin(9600);
        Serial.print("Probe SI7021: ");
        if (si7021.initialize()) {
          Serial.println("Sensor found!");
            Serial.println("Sensor missing");
            while(1) {};
        static float humi, temp;
        si7021.getHumidity(humi);
        si7021.getTemperature(temp);
        si7021.triggerMeasurement();
        Serial.print("TEMP: ");
        Serial.print(temp);
        Serial.print(" HUMI: ");
        Serial.print(humi);
        Serial.println("");
    Program size:
    A1.0.5: 6896b
    A1.5.7: 6590b
    A1.6.3: 6484b / 499b
    Here is output I see:
    This is what I see during compilation and uploading:
    /Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/viktor/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/viktor/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/viktor/Documents/Arduino/libraries -fqbn=MySensors:avr:MysensorsMicro:cpu=1Mhz -ide-version=10801 -build-path /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avrdude.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -verbose /Users/viktor/Documents/Arduino/i2c_SI7021-2/i2c_SI7021-2.ino
    /Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/viktor/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/viktor/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/viktor/Documents/Arduino/libraries -fqbn=MySensors:avr:MysensorsMicro:cpu=1Mhz -ide-version=10801 -build-path /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avrdude.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -verbose /Users/viktor/Documents/Arduino/i2c_SI7021-2/i2c_SI7021-2.ino
    Using board 'MysensorsMicro' from platform in folder: /Users/viktor/Library/Arduino15/packages/MySensors/hardware/avr/1.0.1
    Using core 'arduino' from platform in folder: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr
    Detecting libraries used...
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10801 -DARDUINO_AVR_MICRO8 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/viktor/Library/Arduino15/packages/MySensors/hardware/avr/1.0.1/variants/micro" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/sketch/i2c_SI7021-2.ino.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10801 -DARDUINO_AVR_MICRO8 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/viktor/Library/Arduino15/packages/MySensors/hardware/avr/1.0.1/variants/micro" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/sketch/i2c_SI7021-2.ino.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10801 -DARDUINO_AVR_MICRO8 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/viktor/Library/Arduino15/packages/MySensors/hardware/avr/1.0.1/variants/micro" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src" "-I/Users/viktor/Documents/Arduino/libraries/I2C-Sensor-Lib_iLib/src" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/sketch/i2c_SI7021-2.ino.cpp" -o "/dev/null"
    Using cached library dependencies for file: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src/Wire.cpp
    Using cached library dependencies for file: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src/utility/twi.c
    Using cached library dependencies for file: /Users/viktor/Documents/Arduino/libraries/I2C-Sensor-Lib_iLib/src/i2c.cpp
    Generating function prototypes...
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10801 -DARDUINO_AVR_MICRO8 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/viktor/Library/Arduino15/packages/MySensors/hardware/avr/1.0.1/variants/micro" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src" "-I/Users/viktor/Documents/Arduino/libraries/I2C-Sensor-Lib_iLib/src" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/sketch/i2c_SI7021-2.ino.cpp" -o "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/preproc/ctags_target_for_gcc_minus_e.cpp"
    "/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/preproc/ctags_target_for_gcc_minus_e.cpp"
    Compiling sketch...
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10801 -DARDUINO_AVR_MICRO8 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/viktor/Library/Arduino15/packages/MySensors/hardware/avr/1.0.1/variants/micro" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src" "-I/Users/viktor/Documents/Arduino/libraries/I2C-Sensor-Lib_iLib/src" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/sketch/i2c_SI7021-2.ino.cpp" -o "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/sketch/i2c_SI7021-2.ino.cpp.o"
    Compiling libraries...
    Compiling library "Wire"
    Using previously compiled file: /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/libraries/Wire/Wire.cpp.o
    Using previously compiled file: /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/libraries/Wire/utility/twi.c.o
    Compiling library "I2C-Sensor-Lib_iLib"
    Using previously compiled file: /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/libraries/I2C-Sensor-Lib_iLib/i2c.cpp.o
    Compiling core...
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc" -c -g -x assembler-with-cpp -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10801 -DARDUINO_AVR_MICRO8 -DARDUINO_ARCH_AVR   "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/viktor/Library/Arduino15/packages/MySensors/hardware/avr/1.0.1/variants/micro" "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/wiring_pulse.S" -o "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/wiring_pulse.S.o"
    Using previously compiled file: /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/WInterrupts.c.o
    Using previously compiled file: /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/hooks.c.o
    Using previously compiled file: /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/wiring.c.o
    Using previously compiled file: /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/wiring_analog.c.o
    Using previously compiled file: /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/wiring_digital.c.o
    Using previously compiled file: /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/wiring_pulse.c.o
    Using previously compiled file: /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/wiring_shift.c.o
    Using previously compiled file: /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/CDC.cpp.o
    Using previously compiled file: /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/HardwareSerial.cpp.o
    Using previously compiled file: /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/HardwareSerial0.cpp.o
    Using previously compiled file: /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/HardwareSerial1.cpp.o
    Using previously compiled file: /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/HardwareSerial2.cpp.o
    Using previously compiled file: /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/HardwareSerial3.cpp.o
    Using previously compiled file: /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/IPAddress.cpp.o
    Using previously compiled file: /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/PluggableUSB.cpp.o
    Using previously compiled file: /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/Print.cpp.o
    Using previously compiled file: /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/Stream.cpp.o
    Using previously compiled file: /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/Tone.cpp.o
    Using previously compiled file: /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/USBCore.cpp.o
    Using previously compiled file: /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/WMath.cpp.o
    Using previously compiled file: /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/WString.cpp.o
    Using previously compiled file: /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/abi.cpp.o
    Using previously compiled file: /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/main.cpp.o
    Using previously compiled file: /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/new.cpp.o
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-ar" rcs  "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/core.a" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/wiring_pulse.S.o"
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-ar" rcs  "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/core.a" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/WInterrupts.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-ar" rcs  "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/core.a" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/hooks.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-ar" rcs  "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/core.a" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/wiring.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-ar" rcs  "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/core.a" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/wiring_analog.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-ar" rcs  "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/core.a" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/wiring_digital.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-ar" rcs  "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/core.a" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/wiring_pulse.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-ar" rcs  "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/core.a" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/wiring_shift.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-ar" rcs  "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/core.a" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/CDC.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-ar" rcs  "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/core.a" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/HardwareSerial.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-ar" rcs  "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/core.a" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/HardwareSerial0.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-ar" rcs  "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/core.a" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/HardwareSerial1.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-ar" rcs  "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/core.a" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/HardwareSerial2.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-ar" rcs  "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/core.a" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/HardwareSerial3.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-ar" rcs  "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/core.a" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/IPAddress.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-ar" rcs  "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/core.a" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/PluggableUSB.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-ar" rcs  "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/core.a" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/Print.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-ar" rcs  "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/core.a" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/Stream.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-ar" rcs  "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/core.a" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/Tone.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-ar" rcs  "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/core.a" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/USBCore.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-ar" rcs  "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/core.a" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/WMath.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-ar" rcs  "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/core.a" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/WString.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-ar" rcs  "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/core.a" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/abi.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-ar" rcs  "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/core.a" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/main.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-ar" rcs  "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/core.a" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/new.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc" -w -Os -Wl,--gc-sections -mmcu=atmega328p  -o "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/i2c_SI7021-2.ino.elf" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/sketch/i2c_SI7021-2.ino.cpp.o" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/libraries/Wire/Wire.cpp.o" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/libraries/Wire/utility/twi.c.o" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/libraries/I2C-Sensor-Lib_iLib/i2c.cpp.o" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/core/core.a" "-L/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688" -lm
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0  "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/i2c_SI7021-2.ino.elf" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/i2c_SI7021-2.ino.eep"
    "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-objcopy" -O ihex -R .eeprom  "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/i2c_SI7021-2.ino.elf" "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/i2c_SI7021-2.ino.hex"
    Using library Wire at version 1.0 in folder: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire
    Using library I2C-Sensor-Lib_iLib at version 0.8.2 in folder: /Users/viktor/Documents/Arduino/libraries/I2C-Sensor-Lib_iLib
    Sketch uses 6406 bytes (20%) of program storage space. Maximum is 30720 bytes.
    Global variables use 499 bytes (24%) of dynamic memory, leaving 1549 bytes for local variables. Maximum is 2048 bytes.
    /Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbserial-AI050RV3 -b57600 -D -Uflash:w:/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/i2c_SI7021-2.ino.hex:i
    avrdude: Version 6.3, compiled on Dec 16 2016 at 13:32:25
             User configuration file is "/Users/viktor/.avrduderc"
             Using Port                    : /dev/cu.usbserial-AI050RV3
             Overriding Baud Rate          : 57600
             Programmer Type : Arduino
             Description     : Arduino
             Hardware Version: 3
             Firmware Version: 5.0
             Vtarget         : 0.3 V
             Varef           : 0.3 V
             Oscillator      : 28.800 kHz
             SCK period      : 3.3 us
    avrdude: reading input file "/var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/i2c_SI7021-2.ino.hex"
    avrdude: writing flash (6406 bytes):
    Writing | ################################################## | 100% 2.45s
    avrdude: 6406 bytes of flash written
    avrdude: verifying flash memory against /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/i2c_SI7021-2.ino.hex:
    avrdude: load data flash data from input file /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/i2c_SI7021-2.ino.hex:
    avrdude: input file /var/folders/zs/f1p3lxyn54g_bqr6kvdzgps00000gp/T/arduino_build_365688/i2c_SI7021-2.ino.hex contains 6406 bytes
    Reading | ################################################## | 100% 2.75s
    avrdude: verifying ...
    avrdude: 6406 bytes of flash verified
    avrdude done.  Thank you.
    This are my settings in Arduino IDE:
    Any idea what I should fix to be able see debug messages in console?
    Thank you for help.
    tbowmoT 1 Reply Last reply
    • Viktor ZemanV Viktor Zeman
      Here is the code:
      #include "i2c.h"
      SI7021 si7021;
          Serial.begin(9600);
              while(1) {};
          Serial.print(temp);
          Serial.print(humi);
          Serial.println("");
      Program size:
      A1.0.5: 6896b
      A1.5.7: 6590b
      Compiling sketch...
      Compiling core...
               Hardware Version: 3
               Vtarget         : 0.3 V
               Varef           : 0.3 V
               SCK period      : 3.3 us
      Thank you for help.
      tbowmoT Offline
      tbowmoT Offline
      tbowmo
      @Viktor-Zeman
      Have you reprogrammed the fuses, so it runs at 1Mhz and not 8Mhz?
      Default fuse settings in Sensebender Micro is 8Mhz
        Viktor Zeman
        Thank you for clarification, I have switched in Arduino IDE Processor to 8MHz and I can see the the serial console messages correctly now.
        BTW: can you point me to the right place how to reprogram fuses?
        • tbowmoT Offline
          tbowmoT Offline
          tbowmo
          @Viktor-Zeman
          Before you change the operating frequency, you need to find out if the sensornode will be sleeping most of the time, or if it will be active..
          If it's a sleeping node that will wake up once in a while, collect sensor data, and perhaps send it back to your controller, then it will not make that much difference if you run it at 1Mhz or at 8Mhz..
          If we look at the datasheet for atmega328 pages 336 and 337, there are a couple of graphs, showing the approximate active current, given at different frequencies / voltages..
          with a voltage of 2.7V, running at 1Mhz, the consumption is around 0.4mA, while running at 8Mhz, it's around 2mA. This seems to be a large difference, but let's take into account that the microprocessor is 8 times slower at running the same code when running at 1Mhz, than at 8Mhz, then in theory it is awake 8 times as long, when running at the lower frequency..
          If we then do a rough calculation, saying that a loop takes 1 second @8Mhz, it will take 8 seconds @1Mhz. if we "transform" this to mAh, it will give a rough data like
          running @1Mhz : (0.4 * 8 ) = 3.2
          running @8Mhz : 2.0 * 1 = 2
          And from this, we can see that running at 1Mhz, will (in theory) actually consume more power than running on 8Mhz, because the "high" current consumption will last longer at 1Mhz, than it will on 8Mhz.
          When that's said.. If you want to run at 1Mhz, you can use avrdude, and a avr ISP programming dongle to program fuses. Check out this tutorial
          Viktor ZemanV 1 Reply Last reply
          • tbowmoT tbowmo
            @Viktor-Zeman
            Viktor Zeman
            @tbowmo great answer! I agree, you are right, it has no sense to change frequency in my case. I want to measure temperature each few minutes and than sleep ...
            11.9k
            113.3k
