  3. Powering mote 24/7 using only a supercap and solar
239 Posts 10 Posters 134.7k Views 14 Watching
    I'm very curious to know what kind of sensor you would be able to run with this project. Of course a lot will depends on the size of solar panel and how much light it will get.
      #148
      @gohan
      Early tests indicate the 15F charges to 3.6v pretty fast on even ambient light. I realize that's a somewhat vague statement, but I hope to eventually quantify it better (charge time as a function of lux level, panel size, and nominal panel voltage). Nonetheless, based on early preliminary measurements, I'm pretty confident the answer is going to be fairly simple, namely: what can you do with 15F of charge?
      Before I began this project, I was quite worried that self discharge would strongly govern the answer, but this particular supercap (as contrasted to others I tested) seems to have a relatively low rate of self discharge. Early tests show the same also holds true for its bigger brother, the 90F supercap, in case the 15F isn't enough. The 15F supercap is rated for 100,000 charge/discharge cycles, so it won't be wearing out anytime soon if it's operated indoors under normal ambient temperature conditions. There are probably even more interesting supercaps out there, but for me this one's an existence proof and a fixed point I can gather data around.
      If anyone knows of even better supercaps to try, I'm all ears.
        So what can you realistically do with 15F of charge? I mean what kind of battery can you compare it to? Can you use the entire energy stored in the cap and and it keeps the voltage constant until it empty?
          Think of it like a battery whose voltage starts at 3.6v and then over time gradually drops to 1.8v. As presently configured, you would stop when the voltage gets to 1.8v, because both the atmega328p and the RFM69HW require a minimum 1.8v to operate.
          • mfalkviddM
            #151
            Is my math right if I calculate like this?
            15 * 1.8 / 3600 * 1000 = 7.5 mAh
              #152
              Not sure the answer to that. However, one thing's worth noting: these supercaps behave more like button cells than capacitors. By that I mean: they can have voltage droops and can even have voltage "recovery" after using them a bit. I really didn't expect that going into this, but it's a very significant effect.
                What do you mean that they behave more like cells?
                  #154
                  @gohan said in Powering mote 24/7 using only a supercap and solar:
                  An "ideal" capacitor doesn't behave like that.
                    Sorry but I don't understand, I'm not that much into this electronic deep knowledge. By voltage drops are you referring to the small energy drain that the capacitor has?
                      @gohan
                      We're getting off topic. I suggest you read some of the links already provided above.
                        #157
                        Good news! Last night I did some accelerated load testing on the supercap. First I charged it to 3.6v and then I hooked up an RFM69HW mote which woke up once a second to do 3 things: 1. check the voltage level, 2. turn on an LED for 1ms to simulate a sensor load, and 3. transmit a packet containing the voltage data using the RFM69HW.. Bottom line: 14,111 packets transmitted before running out of juice.
                        Not bad for a first attempt. :)
                        A 1 Reply Last reply
                          agdemars
                          @NeverDie Any updates on your progress? Have you received the new boards? Will you be publishing the gerber files?
                          • A agdemars
                            @agdemars said in Powering mote 24/7 using only a supercap and solar:
                            No, and for a host of reasons. The main reason is this: for most applications, it's overkill. Because this thread had become such a monolog, I continued to evolve the design offline, and along the way I've found that you can get perfectly good results with just an inexpensive mini solar panel, a capacitor, and a simple blocking diode. For the audience on this forum, that's all you really need.
                              You are kind of pioneering in the use of supercap and sensor nodes. I'd like to be part of the discussion, but unfortunately I'm not that good at electronics so I can't contribute much. Probably you are right at using a standard cap you can get comparable results, but I believe you get smaller size with our project
                                agdemars
                                @NeverDie Indeed, keeping it simple is usually the best approach. I am nonetheless interested in learning about the circuit you developed if you're willing to share your observations.
                                • mfalkviddM
                                  Would it be feasible to implement mppt in software? From what I understand, the atmega328 pwm works in power-save mode (but not in power-down). Power-save mode consumes 1uA. Could the charging speed be controlled by pwm and adjusted periodically by the mcu, to keep the load on the solar cell at maximum power?
                                    If I understood right NeverDie said that the supercap can be charged directly from the solar panel with just a blocking diode, then add a boost-buck dc-dc converter to have constant 3.3v
                                      #164
                                      @mfalkvidd said in Powering mote 24/7 using only a supercap and solar:
                                      Like you, I've also wondered what kind of MPPT might be built by leveraging an mcu and just simple components. There is a guy on youtube ( https://youtu.be/JXSRXUiUA6M ) who built his own arduino MPPT charge controller from scratch, though for a much bigger solar panel. For me, the real quesation is: why aren't there more chips that offer a proper MPPT? It seems like a rather bizarre gap in the market.
                                        Is that mppt really needed even if you are charging a capacitor?
                                          #166
                                          @gohan
                                          Let's put it this way: there's probably nothing I could achieve with MPPT that I couldn't achieve with a sufficiently bigger solar panel. So, if space isn't a concern, the economics tend to favor buying bigger mini solar panels, because mini solar panels are fairly cheap from China (cheaper than buying the BQ25504 chip). On the other hand, for large 100watt or above solar panels, it's more economic to add MPPT, because an MPPT charge controller is cheap compared to, say, doubling an already expensive solar panel.
                                          That said, there may be other features of the chip that you may want anyway, like charge termination or a "battery_OK" pin to power-on your atmega328p when the voltage gets to an acceptible level. So, you could create those by other means, or you could buy a package with those features and which also happens to have MPPT at some incremental cost.
                                          So, it's six of one, half a dozen of the other.
