  3. Connect Serial Gateway to Openwrt routers TX RX pins
12 Posts 4 Posters 5.9k Views 3 Watching
  • D Offline
    derrij
    It is possible to connect Serial Gateway to router's TX RX pins?
    Will be nice not using router's usb port, and leave it for someone else.
    Would like to use MySensors wit Domoticz installed on router.
    Right now WiFi Gateway used.
    J 1 Reply Last reply
    • D Offline
      derrij
      found some thing - How to terminate console on serial port (UART)
      am i on right direction?
      • P Offline
        P Offline
        pansen
        Does the MySensors gateway + domoticz already run on your router? Then I would say yes, just tell mysgw that your serial gateway is /dev/ttyXXX (whatever your router serial port is).
        Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
        • T Offline
          T Offline
          tbowmo
          @derrij
          I think that you always get debug messages from uBoot on the router serial port. But this is only during booting.
          The kernel debug messages should be possible to disable (with the information from the link that you provided)
          • D Offline
            derrij
            MySensors and Domoticz are the best!
            I did not think it would be so easy.
            I did not have to make changes to the router's firmware.
            All i need set speed in serial gateway
            #define MY_BAUD_RATE 115200
            On router make
            ln -s /dev/ttyS0 /dev/ttyUSB1
            • D derrij
              J Offline
              J Offline
              Jan Gatzke
              • D Offline
                derrij
                it works, but now i see it unstable. a lot of garbage received
                2;5;1;0;35;184.367
                ;0.13;1;1;013;6;1;0;16;1
                ;4;1;0;24;121056
                2;4;1;0;35;121.056```
                • D derrij
                  2;5;1;0;35;184.367
                  ;4;1;0;24;121056
                  J Offline
                  J Offline
                  Jan Gatzke
                  @derrij
                  Did you try it with a lower baud rate? 9600?
                  • D Offline
                    derrij
                    I tried 57600. Right now i tried on Padavan firmware on Xiaomi router 3.
                    And i can't compile firmware with lower than 57600
                    But I start domoticz with -verbose 0 -loglevel 0, and it working better. Need to test more.
                    • D derrij
                      J Offline
                      J Offline
                      Jan Gatzke
                      @derrij
                      Are you sure you need to set the rate in the code and recompile? Shouldn't it be enough to change it in config.h and domoticz? The uart of the router should be able to change the speed at runtime like other Linux devices, right?
                      • D Offline
                        derrij
                        I tried set rate in domoticz and by stty -F /dev/ttyS0 9600 clocal cread cs8 -cstopb -parenb
                        but after a time it come back to rate what set in
                        cat /proc/cmdline
                        console=ttyS0,115200n8 root=/dev/mtdblock4 rootfstype=squashfs
                        it looks like i need to recompile firmware.
                        • D derrij
                          cat /proc/cmdline
                          J Offline
                          J Offline
                          Jan Gatzke
                          wrote on last edited by Jan Gatzke
                          @derrij
                          The console paramter needs to be removed completely. You cannot use the uart for domoticz and as serial console at the same time.
                          https://wiki.openwrt.org/doc/recipes/terminate.console.on.serial
                          12.2k
