  3. Office plant monitoring
223 Posts 39 Posters 228.1k Views 42 Watching
  • meanmrgreenM meanmrgreen
    I made a node with 1 fork and it works great!
    Any tips on how i can use more than one fork to monitor say 3-4 plants?
    Stric
    @meanmrgreen See my post a few up, I'm seeing some weird effects when connecting to more than one plant..
    meanmrgreenM 1 Reply Last reply
    • S Stric
      meanmrgreenM
      meanmrgreenM
      meanmrgreen
      @Stric
      Does reverse polarity really help with corrosion then? Maybe it has something to do with that.
      • meanmrgreenM
        meanmrgreenM
        meanmrgreen
        Small problem with my plant sensor. Used only the fork and the reverse polarity.
        But the sensor is reporting around 80-70% all the time, alltho the plant is pretty dry.
        When i remove the sensor from pot it shows 0% ?
        Can you calibrate the fork somehow?
          @meanmrgreen I calibrate by putting my finger in the soil. When the soil is too dry I note the current value and set a notification to trigger next time it reaches that level.
            meanmrgreenM
            meanmrgreenM
            meanmrgreen
            @mfalkvidd
            Ok :)
            But Its normal just to lower by a few percent in a few days time?
            • E
              E
              Eawo
              I'm going to try do this with the slim node and a cr2032 battery. Which cap do you recommend using to help battery?
                @mfalkvidd
                Ok :)
                It depends on the soil type, the plant, the temperature, if the plant gets direct sunlight and probably some more factors.
                • meanmrgreenM
                  meanmrgreenM
                  meanmrgreen
                  I need to check my node. It Constantly shows 80-90%. Have switched forks and plant same number. If I pull it out of the dirt it gets to 0%
                  Using only the fork no board in the middle with the alternate current sketch.
                  • Dennis van der WolfD
                    Dennis van der Wolf
                    Re: Office plant monitoring
                    Hello, i have build the sensor from the building page. I directly connect the fork to pin D6,D7. When i show the measurement i see strange values. anyone an idea what i did wrong?
                    09.02.2017 19:22:23	Multi Sensor (multi2)	SoilMoistPercentageSensor	3 %
                    09.02.2017 19:16:51	Multi Sensor (multi2)	SoilMoistPercentageSensor	0 %
                    09.02.2017 19:11:20	Multi Sensor (multi2)	SoilMoistPercentageSensor	3 %
                    09.02.2017 19:05:48	Multi Sensor (multi2)	SoilMoistPercentageSensor	5 %
                    09.02.2017 19:00:17	Multi Sensor (multi2)	SoilMoistPercentageSensor	-1 %
                    09.02.2017 18:54:46	Multi Sensor (multi2)	SoilMoistPercentageSensor	8 %
                    09.02.2017 18:48:41	Multi Sensor (multi2)	SoilMoistPercentageSensor	5 %
                    09.02.2017 18:43:10	Multi Sensor (multi2)	SoilMoistPercentageSensor	6 %
                    09.02.2017 18:37:38	Multi Sensor (multi2)	SoilMoistPercentageSensor	1 %
                    09.02.2017 18:32:07	Multi Sensor (multi2)	SoilMoistPercentageSensor	-1 %
                    09.02.2017 18:26:36	Multi Sensor (multi2)	SoilMoistPercentageSensor	-1 %
                    09.02.2017 18:21:04	Multi Sensor (multi2)	SoilMoistPercentageSensor	4 %
                    09.02.2017 18:15:33	Multi Sensor (multi2)	SoilMoistPercentageSensor	4 %
                    09.02.2017 18:10:02	Multi Sensor (multi2)	SoilMoistPercentageSensor	6 %
                    09.02.2017 18:03:57	Multi Sensor (multi2)	SoilMoistPercentageSensor	6 %
                    09.02.2017 17:58:26	Multi Sensor (multi2)	SoilMoistPercentageSensor	0 %
                    09.02.2017 17:52:54	Multi Sensor (multi2)	SoilMoistPercentageSensor	6 %
                    09.02.2017 17:46:50	Multi Sensor (multi2)	SoilMoistPercentageSensor	5 %
                    09.02.2017 17:41:19	Multi Sensor (multi2)	SoilMoistPercentageSensor	-1 %
                    09.02.2017 17:34:41	Multi Sensor (multi2)	SoilMoistPercentageSensor	6 %
                    09.02.2017 17:29:10	Multi Sensor (multi2)	SoilMoistPercentageSensor	-3 %
                    09.02.2017 17:23:39	Multi Sensor (multi2)	SoilMoistPercentageSensor	-11 %
                    J 1 Reply Last reply
                    • Dennis van der WolfD Dennis van der Wolf
                      J
                      J
                      Jan Gatzke
                      @Dennis-van-der-Wolf
                      Which sketch did you use? The one from this page needs the fork connected to analog input pins Ax.
                      Dennis van der WolfD 1 Reply Last reply
                      • J Jan Gatzke
                        Dennis van der Wolf
                        @Jan-Gatzke I have connected the fork to A0 and A1 of mine arduino nano. Now i have this result:
                        10.02.2017 12:17:35	Multi Sensor (multi2)	SoilMoistPercentageSensor	-182 %
                        10.02.2017 12:12:04	Multi Sensor (multi2)	SoilMoistPercentageSensor	-455 %
                        10.02.2017 12:06:33	Multi Sensor (multi2)	SoilMoistPercentageSensor	-317 %
                        10.02.2017 12:01:02	Multi Sensor (multi2)	SoilMoistPercentageSensor	255 %
                        10.02.2017 11:55:31	Multi Sensor (multi2)	SoilMoistPercentageSensor	-547 %
                        10.02.2017 11:49:26	Multi Sensor (multi2)	SoilMoistPercentageSensor	1169 %
                        10.02.2017 11:43:55	Multi Sensor (multi2)	SoilMoistPercentageSensor	40 %
                        10.02.2017 11:38:24	Multi Sensor (multi2)	SoilMoistPercentageSensor	-250 %
                        This is the sketch i use:
                         * Arduino soil moisture based on gypsum sensor/resistive sensor to avoid electric catalyse in soil
                         *  Required to interface the sensor: 2 * 4.7kOhm + 2 * 1N4148
                         * Gypsum sensor and calibration:
                         *    DIY: See http://vanderleevineyard.com/1/category/vinduino/1.html
                         *    Built: Davis / Watermark 200SS
                         *        http://www.cooking-hacks.com/watermark-soil-moisture-sensor?_bksrc=item2item&_bkloc=product
                         *        http://www.irrometer.com/pdf/supportmaterial/sensors/voltage-WM-chart.pdf
                         *        cb (centibar) http://www.irrometer.com/basics.html
                         *            0-10 Saturated Soil. Occurs for a day or two after irrigation
                         *            10-20 Soil is adequately wet (except coarse sands which are drying out at this range)
                         *            30-60 Usual range to irrigate or water (except heavy clay soils).
                         *            60-100 Usual range to irrigate heavy clay soils
                         *            100-200 Soil is becoming dangerously dry for maximum production. Proceed with caution.
                         * Connection:
                         *  D6, D7: alternative powering to avoid sensor degradation
                         * A0, A1: alternative resistance mesuring
                         *  Based on:
                         *  "Vinduino" portable soil moisture sensor code V3.00
                         *   Date December 31, 2012
                         *   Reinier van der Lee and Theodore Kaskalis
                         *   www.vanderleevineyard.com
                         * Contributor: epierre
                        // Copyright (C) 2015, Reinier van der Lee
                        // www.vanderleevineyard.com
                        // This program is free software: you can redistribute it and/or modify
                        // it under the terms of the GNU General Public License as published by
                        // the Free Software Foundation, either version 3 of the License, or
                        // any later version.
                        // This program is distributed in the hope that it will be useful,
                        // but WITHOUT ANY WARRANTY; without even the implied warranty of
                        // MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
                        // GNU General Public License for more details.
                        #include <math.h>       // Conversion equation from resistance to %
                        // Setting up format for reading 3 soil sensors
                        #define NUM_READS 10    // Number of sensor reads for filtering
                        #define CHILD_ID 0
                        MyMessage msg(CHILD_ID, V_LEVEL);
                        long buffer[NUM_READS];
                        int index;
                        /// @brief Structure to be used in percentage and resistance values matrix to be filtered (have to be in pairs)
                        typedef struct {
                            int moisture; //!< Moisture
                            long resistance; //!< Resistance
                        } values;
                        const long knownResistor = 4700;  // Constant value of known resistor in Ohms
                        int supplyVoltage;                // Measured supply voltage
                        int sensorVoltage;                // Measured sensor voltage
                        values valueOf[NUM_READS];        // Calculated moisture percentages and resistances to be sorted and filtered
                        int i;                            // Simple index variable
                            // initialize the digital pins as an output.
                            // Pin 6,7 is for sensor 1
                            // initialize the digital pin as an output.
                            // Pin 6 is sense resistor voltage supply 1
                            pinMode(6, OUTPUT);
                            // Pin 7 is sense resistor voltage supply 2
                            pinMode(7, OUTPUT);
                            sendSketchInfo("Soil Moisture Sensor Reverse Polarity", "1.0");
                            present(CHILD_ID, S_MOISTURE);
                            measure(6,7,1);
                            Serial.print ("\t");
                            Serial.println (average());
                            long read1 = average();
                            measure(7,6,0);
                            long read2= average();
                            long sensor1 = (read1 + read2)/2;
                            Serial.print ("resistance bias =" );
                            Serial.println (read1-read2);
                            Serial.print ("sensor bias compensated value = ");
                            Serial.println (sensor1);
                            Serial.println ();
                            //send back the values
                            send(msg.set((long int)ceil(sensor1)));
                            // delay until next measurement (msec)
                            sleep(SLEEP_TIME);
                        void measure (int phase_b, int phase_a, int analog_input)
                            // read sensor, filter, and calculate resistance value
                            // Noise filter: median filter
                            for (i=0; i<NUM_READS; i++) {
                                // Read 1 pair of voltage values
                                digitalWrite(phase_a, HIGH);                 // set the voltage supply on
                                delayMicroseconds(25);
                                supplyVoltage = analogRead(analog_input);   // read the supply voltage
                                digitalWrite(phase_a, LOW);                  // set the voltage supply off
                                delay(1);
                                digitalWrite(phase_b, HIGH);                 // set the voltage supply on
                                sensorVoltage = analogRead(analog_input);   // read the sensor voltage
                                digitalWrite(phase_b, LOW);                  // set the voltage supply off
                                // Calculate resistance
                                // the 0.5 add-term is used to round to the nearest integer
                                // Tip: no need to transform 0-1023 voltage value to 0-5 range, due to following fraction
                                long resistance = (knownResistor * (supplyVoltage - sensorVoltage ) / sensorVoltage) ;
                                delay(1);
                                addReading(resistance);
                                Serial.print (resistance);
                        // Averaging algorithm
                        void addReading(long resistance)
                            buffer[index] = resistance;
                            index++;
                            if (index >= NUM_READS) {
                                index = 0;
                        long average()
                            long sum = 0;
                            for (int i = 0; i < NUM_READS; i++) {
                                sum += buffer[i];
                            return (long)(sum / NUM_READS);
                        • ronnyandreR
                          ronnyandreR
                          ronnyandre
                          Thanks for this great solution @mfalkvidd! It works great when my Arduino Pro Mini is connected to the computer, but not when I try to run it off a battery pack.
                          I have a Pro Mini 3.3v connected to a 0.8-3.3v step up from a battery pack (2xAA; 3v). And then I have connected the radio and sensor to VCC on the Pro Mini. When the Pro Mini is connected to my iMac, Domoticz receives everything as it should. However, when I disconnect it from the computer and connect the battery source, all LEDs light as they should, indicitating that they have power, but it won't connect to Domoticz over NRF24.
                          I have used a multimeter to check the voltage and if the radio receives enough power, and it does. All power/ground pins show around 3.3v. Any ideas to debug what's wrong?
                          Newbie with RPi and Domoticz, trying to automate my home.
                          • J joshmosh
                            @mfalkvidd, @Nicklas-Starkel
                            similar problem here. I have a bare ATMega 328P, running @ 8 MHz internal oszillator. no LED, bod disabled, (if enabled, the ADC is running also during sleep, so this means additional power consumption), nothing else connected that could draw additional power.
                            I use mfalkvidd's sketch (BTW, thanks a lot for it !), but converted to mysensors 2.0. I see a voltage drop way higher than mfalkvidd, although I don't use a china clone ;-).
                            So it seems, that the higher power consumption may be due to mysensors V2 ? I cannot imagine a reason for that, because why should relatively low level functions like power save routines be different in 2.0 ?
                            Perhaps hek can comment ?
                            Fat FlyF
                            Fat FlyF
                            Fat Fly
                            @joshmosh said in Office plant monitoring:
                            Where i find mfalkvidd's sketch ?
                            • ronnyandreR ronnyandre
                              #207
                              @ronnyandre a multimeter is unfortunately not sensitive enough to display if there is enough power during the short bursts when the radio is active.
                              Most step-ups don't deliver power that is stable enough. You could try adding more/larger capacitors, but from what I have seen in the forum, people seldom get thing working reliably with a step-up. I have never tried using step-up myself, I use power directly from the batteries.
                              If you haven't checked already, see the troubleshooting chart at https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/
                              ronnyandreR 1 Reply Last reply
                              • Fat FlyF Fat Fly
                                At github, but be aware that this code is for MySensors 1.x. It does not work with MySensors 2.x.
                                  ronnyandreR
                                  ronnyandreR
                                  ronnyandre
                                  @mfalkvidd Thanks for the quick answer! I also read on the page for battery powered sensors that the step up generates alot of noise that can interfere with the radio, and that a solution might be to add capacitators (which I already tried), but also powering the radio directly from batteries. I'll try that later today. Thanks! :smiley:
                                  And thank you for the link to the troubleshooting. It's now bookmarked! :wink:
                                  • Fat FlyF
                                    Fat FlyF
                                    Fat Fly
                                    Please somebody help me add to skech one relay for water pump. I use this in Domoticz. I do not want build other hardware for this.It is possible ?
                                      Just copy the relay code from https://www.mysensors.org/build/relay and add it your sketch and make necessary changes to adapt it: like setting child_id in presentation
                                      Fat FlyF 1 Reply Last reply
                                        Fat FlyF
                                        Fat FlyF
                                        Fat Fly
                                        @gohan I make something this. Please look if all is right. My software writer skill is low. :) Some small errors. :)
                                        https://pastebin.com/8LWpgb8L
                                          because you are using old code, you need to convert it from libraries 1.5 to 2.x: there is a guide to do that
