  3. why no one uses latching relays ?
41 Posts 14 Posters 22.2k Views 18 Watching
  • T
    TimO
    Are you searching for latching relays for your fuse box, like from Eltako, or latching relays for usage on a circuit board? I'm controlling the first mentioned in my fuse box with mysensors.
    • rozpruwaczR
      rozpruwaczR
      rozpruwacz
      I'm talking about micro relays for PCB.
      • rozpruwaczR rozpruwacz
        I'm preparing to desing some actuators for my new flat using MySensors. I will be using relays for switching lights and wall plugs. As I search for some ready to use projects I find that all of them are using relays that require continous current flow to stay in one of the states. And normaly those relays consume around 0.5 W of power ! I thought that one of the goals of home automation is to reduce unnecessary power consumption. Considering that one uses a lot of relays in such system, 0.5W of power for single relay is totaly unacceptable. The simplest solution is to use latching relay which consumes power only during switching (and propably very infrequently). But I can't find any latching relay modules to buy. Why is that ?
        @rozpruwacz
        The problem is how do determine if lights are on or off? I mean in case the arduino restarts after a power failure or unexpected reset, how can it knows what was the last state? A normal realy you can choose to either switch it on or off regardless of last state.
          @rozpruwacz
          TimO
          @gohan I'm using a ACS712 to get the power consumption.
            @rozpruwacz so far I've only seen cheap non-latching relay modules from China.
            Controlling latching relays can be a bit harder for the ones requiring an H-bridge. I've controlled some with a dual mosfet driver which works great.
            • rozpruwaczR
              rozpruwaczR
              rozpruwacz
              @gohan I don't get what is the problem. With latching relay, You can set the switch on/off regardless of the last state. I think that latching relays are even better in case of cpu failure (reset) because they holds their state. Additionally You can make some circuitry to indicate the current state to the cpu or store the state in the eeprom.
              @Yveaux how is using dual mosfet driver harder than an optoisolator that is in most of relay modules ?
              gohanG YveauxY 2 Replies Last reply
                @rozpruwacz
                Sure it keeps the state but how does the arduino or controller knows what is the current state if they lost it because of a reset/reboot? For example you have light on and a rule/scene/voice command that wants to turns light on/off and the system has just been rebooted so normally it would assume everything is off (while lights are still on because of the latching relay), so now you will get inverted logic when you tell your controller to switch lights; so unless you use, like TimO, something that gives you feedback about lights being on or off (like the AC712, but could it be also a light sensor, it doesn't matter as long as it can give feedback about light's status), you may eventually end up with the logic inverted
                  @rozpruwacz
                  @gohan no, it all depends on the type of latching relays used. Some have a dedicated control to open/close, which doesn't depend on the current state.
                  The main reason to use latching relays is to reduce power consumption. True that you can not retrieve the current state, but given the right relay you can always start from a defined situation after startup (e.g. Switched off as would be the case for most regular relays).
                  Another option is to store the current state of the relay somewhere after switching, e.g. in eeprom.
                    Ok for reducing power consumption, but a small 5v relay it is using less than 0.2W so unless you are using a battery operated node, that power usage is negligible
                    • rozpruwaczR
                      rozpruwaczR
                      rozpruwacz
                      show me a relay with 0.2W power consumption, I couldn't find one.
                      gohanG 1 Reply Last reply
                        @rozpruwacz We were talking relay modules (like this one) which normally only take supply and a single control signal.
                        Having to control the latching of the relay using an H-Bridge I find 'a bit harder' compared to just toggling an IO, regarding both software and hardware.
                        For reference, this is the schematic I use to control a latching relay:
                        0_1487085965612_upload-0a5788cc-27e7-4bf6-98a1-7c26962bf71f
                        It uses a MAX2226/4427/4428 or compatible MOSFET driver to drive the relay.
                        And a function to switch it:
                        #define RELAY_INA_PIN         (A0)
                        #define RELAY_INB_PIN         (A1)
                        #define RELAY_SET_TIME_MS     (30)
                        static void switchRelay( const bool on )
                            digitalWrite(RELAY_INA_PIN, on ? LOW : HIGH);
                            digitalWrite(RELAY_INB_PIN, on ? HIGH : LOW);
                            delay(RELAY_SET_TIME_MS);
                            digitalWrite(RELAY_INA_PIN, LOW);
                            digitalWrite(RELAY_INB_PIN, LOW);
                        ? 1 Reply Last reply
                        • rozpruwaczR
                          rozpruwaczR
                          rozpruwacz
                          You can make a circuit to control the latching relay just like normal relay, You don't have to use h-bridge. The simplest one would be to put a capacitor in series with the relay coil. Referring to your schematic, You could connect the A1 leg of the relay to a capacitor and that capacitor to the ground (leaving pin 5 of the IR4427S disconnected). That way, when you drive REALY_INA high, through the coil will flow the curent in one direction charging the capacitor. When capacitor will charge fully the curent will stop flowing. Then when you drive REALY_INA low, the capacitor will discharge and the curent will flow through the relay in reversed direction.
                          So if there are ways to drive the lathing relay circuit the same way as normal relays, there could be as well ready made module that has this circuit and from the point of view of the microcontroller they would appear as normal relay modules. So why there are no such modules ?
                          PS.
                          As I understand, your circuit needs to recieve pulses on RELAY_INA and RELAY_INB to properly work, and I think that this is dangerous because if the CPU will hang during relay shwitching it can damage the latch - because the latching relay has defined maximum pulse duration.
                            @rozpruwacz
                            I got an 8 channels relay board and according to specs it requires 20mA per channel, so 5v x 0.02A= 0.1 W if my math is correct
                            • rozpruwaczR
                              rozpruwaczR
                              rozpruwacz
                              You are talking about current driving the board input or current consumed by the relay ? What board ? what relay ?
                              • Anne van RossumA
                                Anne van RossumA
                                Anne van Rossum
                                If you drop me a message I can tell you what kind of bistable relays we are using in the Crownstones (http://crownstone.rocks). We switch 16A using a relays from Panasonic. It's one of the most expensive parts of our BOM.
                                • F
                                  F
                                  Fabien
                                  OMRON G5Q consume 0.2W : https://www.omron.com/ecb/products/pdf/en-g5q.pdf (125mW for 5V version). Very small packaging
                                  Anne van RossumA 1 Reply Last reply
                                  • F Fabien
                                    Anne van RossumA
                                    Anne van RossumA
                                    Anne van Rossum
                                    @Fabien just for completeness, that's specced for 10A. The Panasonic ones are not much bigger, http://eu.mouser.com/Electromechanical/Relays/General-Purpose-Relays/_/N-5g36?P=1z0z1s3, e.g. http://eu.mouser.com/ProductDetail/Panasonic-Industrial-Devices/ADW1212HLW/?qs=sGAEpiMZZMtSzCF3XBhmW2w01ZqnWsnJ%2FIRuNGt%252bt2Q%3D are specced for 16A.
                                    • dbemowskD
                                      dbemowskD
                                      I hear people's arguments that you do not know the last state of a latching relay on a power failure, but what if you stored the last state in the eeprom? I mean you store the node ID and other things that get remembered on a power failure, why not the relay state? Every time you change the state of the relay, store it. Doesn't seem that challenging.
                                      • dbemowskD dbemowsk
                                        @dbemowsk exactly what I wrote above "Another option is to store the current state of the relay somewhere after switching, e.g. in eeprom." ;-)
                                        • wallyllamaW
                                          wallyllamaW
                                          wallyllama
                                          There is a very minor edge case where you switch the relay and lose power before writing the state. Probably would never happen in reality. I think a bigger problem, which should be solvable) is if you lose power to your whole house, some relays would latched on and you could have surges or other problems. Hopefully latching relays are robust enough to handle it.
                                          Another solution to the state problem is to have a power up routine that set all relays to a predefined state, then you know. That may be annoying if you reboot the system while someone is reading and the lights go off. This could happen with the more common relays also. The state problem is a lesser worry. The bigger worry is what happens when power comes back, do the relays leave things in a safe state while things initialize.
                                          It comes down to trade offs, save some power and maybe have some imperfect behavior, or use a bit more and have fewer oddities. I think you almost have to decide for each relay.
