  3. MyController.org
  4. Serial Gateway and MQTT Broker
Scheduled Pinned Locked Moved MyController.org
31 Posts 7 Posters 13.5k Views 6 Watching
  • J
    J
    jkandasa
    @Diego-Baravalle for now MyController will not push serial gateway messages to MQTT
    F 1 Reply Last reply
    • Diego BaravalleD Diego Baravalle
      Hi everybody!
      I need to setup two or more "controllers" and a requeriment is to use serial gateway (Arduino as serial gateway connected to raspberry).
      Is it possible?
      Can I setup two controllers listening to same serial port?
      Can I use MyController configured with serial gateway and publish all messages to MQTT?
      Is there another alternative?
      barduinoB
      barduinoB
      barduino
      @Diego-Baravalle
      In theory you could use nodeJS to read from serial and push to MQTT.
      From there you should be able to have 2 MQTT enabled controllers subscribing/publishing to broker.
      That should be an interesting experiment
      • Diego BaravalleD
        Diego BaravalleD
        Diego Baravalle
        @jkandasa, @barduino
        Thanks for your answers.
        Use NodeJS is an interesting option.
        • J jkandasa
          F
          F
          Frank C
          @jkandasa is there a future feature to push serial-gateway messages with MyController's build in MQTT? It would a great feature.
          J gohanG 3 Replies Last reply
          • F Frank C
            J
            J
            jkandasa
            @Frank-C For now no plan
            • F Frank C
              @Frank-C
              It would be quite a redundant function because you can publish directly from the gateway if you use an ethernet shield, but it's not your case if I understood right
              • F Frank C
                J
                J
                jkandasa
                @Frank-C But I can write simple library to run independently to convert serial gateway messages to MQTT type. If you want.
                • J jkandasa
                  F
                  F
                  Frank C
                  @jkandasa That would be fantastic if you could ? I think it would be a great feature :)
                  J 1 Reply Last reply
                  • F Frank C
                    J
                    J
                    jkandasa
                    @Frank-C Yes, I can. but you have to run it as separate service. I will create a separate project for this work. I am not going to include this on MyController project.
                    • J jkandasa
                      F
                      F
                      Frank C
                      @jkandasa As a seperate service is okay, it would be very helpful. Thank you
                      • Diego BaravalleD
                        Diego BaravalleD
                        Diego Baravalle
                        @jkandasa Perfect!
                        • FotoFieberF
                          FotoFieberF
                          FotoFieber
                          Maybe this is enough for your requirement:
                          https://forum.mysensors.org/topic/4599/how-to-add-a-serial-device-to-use-in-node-red/10
                          • FotoFieberF FotoFieber
                            F
                            F
                            Frank C
                            @FotoFieber Thanks for the suggestion, I got that working. I have had to change MyController to read an MQTT gateway. Problem now is MyController can't read the MQTT format of this script. Any suggestions or tips ?
                            MyController does such a great job with handling MySensors' data, it would be a pity to loose that functionality.
                            • F Frank C
                              FotoFieberF
                              FotoFieberF
                              FotoFieber
                              @Frank-C
                              The script uses the serial protocol and should be compatible with the mysesnosrs mqtt-gateway. Are the pub/sub-topics set correct?
                                @Frank-C
                                F
                                F
                                Frank C
                                wrote on last edited by Frank C
                                @FotoFieber MyController is getting the MQTT msg, but doesn't like it's format, i've had continuous error msg like below:
                                2017-02-16 18:17:34,657 ERROR [Thread-4] [org.mycontroller.standalone.provider.mysensors.MySensorsProviderBridge:60] Unable to process this rawMessage:RawMessage(gatewayId=2, data=2;0;1;0;23;36, subData=mysensors/1/out/, isTxMessage=false, networkType=MY_SENSORS)
                                org.mycontroller.standalone.message.RawMessageException: Unknown message format, Topic:mysensors/1/out/, PayLoad:2;0;1;0;23;36
                                at org.mycontroller.standalone.provider.mysensors.MySensorsRawMessage.updateMQTTMessage(MySensorsRawMessage.java:114) ~[mycontroller-dist-standalone-0.0.3.Alpha2-single.jar:0.0.3.Alpha2]
                                MyController is set up with the correct topic, as seen in above Topic:/mysensors/1/out/ (i've also tried without the ending /).
                                • FotoFieberF
                                  FotoFieberF
                                  FotoFieber
                                  wrote on last edited by FotoFieber
                                  2;0;1;0;23;36 Is a correct message according to the serial API. I don't know anything about your controller...sorry
                                  Maybe the controller needs the ; translated to / in the topic?
                                  Have you tried to switch pub/sub topic?
                                  • F Frank C
                                    J
                                    J
                                    jkandasa
                                    @Frank-C Current approach of MyController on MQTT see only payload on message. Other data(nodeId, sensorIds, etc) from topic. Kindly create a request on MyController issue page. I will address this. If we address this I am not going to create separate service to parse serial-to-real-mqtt service type.
                                    • J jkandasa
                                      F
                                      F
                                      Frank C
                                      @jkandasa Thanks for the follow up. I can see MyController is modifying the serial message into a customized MQTT msg (as you have said).
                                      MyController works great with the serial so it would be good to keep that as is, and if we had an independent service to publish to a separate MQTT broker would be very helpful?
                                      • F Frank C
                                        J
                                        J
                                        jkandasa
                                        @Frank-C cool, we will go with independent service.
                                        • J jkandasa
                                          F
                                          F
                                          Frank C
                                          @jkandasa :thumbsup:
