  3. MyController.org
  4. Serial Gateway and MQTT Broker
Scheduled Pinned Locked Moved MyController.org
31 Posts 7 Posters 12.3k Views 6 Watching
  • Diego BaravalleD Offline
    Diego Baravalle
    Hi everybody!
    I need to setup two or more "controllers" and a requeriment is to use serial gateway (Arduino as serial gateway connected to raspberry).
    Is it possible?
    Can I setup two controllers listening to same serial port?
    Can I use MyController configured with serial gateway and publish all messages to MQTT?
    Is there another alternative?
    barduinoB 1 Reply Last reply
    • J Offline
      J Offline
      jkandasa
      @Diego-Baravalle for now MyController will not push serial gateway messages to MQTT
      F 1 Reply Last reply
      • Diego BaravalleD Diego Baravalle
        Hi everybody!
        Is it possible?
        barduinoB Offline
        barduinoB Offline
        barduino
        @Diego-Baravalle
        In theory you could use nodeJS to read from serial and push to MQTT.
        From there you should be able to have 2 MQTT enabled controllers subscribing/publishing to broker.
        That should be an interesting experiment
          Diego Baravalle
          @jkandasa, @barduino
          Thanks for your answers.
          Use NodeJS is an interesting option.
          • J jkandasa
            F Offline
            F Offline
            Frank C
            @jkandasa is there a future feature to push serial-gateway messages with MyController's build in MQTT? It would a great feature.
            J gohanG 3 Replies Last reply
            • F Frank C
              J Offline
              J Offline
              jkandasa
              @Frank-C For now no plan
              • F Frank C
                @Frank-C
                It would be quite a redundant function because you can publish directly from the gateway if you use an ethernet shield, but it's not your case if I understood right
                • F Frank C
                  J Offline
                  J Offline
                  jkandasa
                  @Frank-C But I can write simple library to run independently to convert serial gateway messages to MQTT type. If you want.
                  • J jkandasa
                    F Offline
                    F Offline
                    Frank C
                    @jkandasa That would be fantastic if you could ? I think it would be a great feature :)
                    J 1 Reply Last reply
                    • F Frank C
                      J Offline
                      J Offline
                      jkandasa
                      @Frank-C Yes, I can. but you have to run it as separate service. I will create a separate project for this work. I am not going to include this on MyController project.
                      • J jkandasa
                        F Offline
                        F Offline
                        Frank C
                        @jkandasa As a seperate service is okay, it would be very helpful. Thank you
                          Diego Baravalle
                          @jkandasa Perfect!
                          • F Offline
                            F Offline
                            FotoFieber
                            Maybe this is enough for your requirement:
                            https://forum.mysensors.org/topic/4599/how-to-add-a-serial-device-to-use-in-node-red/10
                            • F FotoFieber
                              F Offline
                              F Offline
                              Frank C
                              @FotoFieber Thanks for the suggestion, I got that working. I have had to change MyController to read an MQTT gateway. Problem now is MyController can't read the MQTT format of this script. Any suggestions or tips ?
                              MyController does such a great job with handling MySensors' data, it would be a pity to loose that functionality.
                              • F Frank C
                                F Offline
                                F Offline
                                FotoFieber
                                @Frank-C
                                The script uses the serial protocol and should be compatible with the mysesnosrs mqtt-gateway. Are the pub/sub-topics set correct?
                                • F FotoFieber
                                  @Frank-C
                                  F Offline
                                  F Offline
                                  Frank C
                                  wrote on last edited by Frank C
                                  @FotoFieber MyController is getting the MQTT msg, but doesn't like it's format, i've had continuous error msg like below:
                                  2017-02-16 18:17:34,657 ERROR [Thread-4] [org.mycontroller.standalone.provider.mysensors.MySensorsProviderBridge:60] Unable to process this rawMessage:RawMessage(gatewayId=2, data=2;0;1;0;23;36, subData=mysensors/1/out/, isTxMessage=false, networkType=MY_SENSORS)
                                  org.mycontroller.standalone.message.RawMessageException: Unknown message format, Topic:mysensors/1/out/, PayLoad:2;0;1;0;23;36
                                  at org.mycontroller.standalone.provider.mysensors.MySensorsRawMessage.updateMQTTMessage(MySensorsRawMessage.java:114) ~[mycontroller-dist-standalone-0.0.3.Alpha2-single.jar:0.0.3.Alpha2]
                                  MyController is set up with the correct topic, as seen in above Topic:/mysensors/1/out/ (i've also tried without the ending /).
                                  • F Offline
                                    F Offline
                                    FotoFieber
                                    wrote on last edited by FotoFieber
                                    2;0;1;0;23;36 Is a correct message according to the serial API. I don't know anything about your controller...sorry
                                    Maybe the controller needs the ; translated to / in the topic?
                                    Have you tried to switch pub/sub topic?
                                    • F Frank C
                                      J Offline
                                      J Offline
                                      jkandasa
                                      @Frank-C Current approach of MyController on MQTT see only payload on message. Other data(nodeId, sensorIds, etc) from topic. Kindly create a request on MyController issue page. I will address this. If we address this I am not going to create separate service to parse serial-to-real-mqtt service type.
                                      • J jkandasa
                                        F Offline
                                        F Offline
                                        Frank C
                                        @jkandasa Thanks for the follow up. I can see MyController is modifying the serial message into a customized MQTT msg (as you have said).
                                        MyController works great with the serial so it would be good to keep that as is, and if we had an independent service to publish to a separate MQTT broker would be very helpful?
                                        • F Frank C
                                          J Offline
                                          J Offline
                                          jkandasa
                                          @Frank-C cool, we will go with independent service.
                                          12.1k
