  3. Monitoring a wood boiler heating system
23 Posts 9 Posters 13.1k Views 10 Watching
  • tkarlssonT tkarlsson
    @mfalkvidd,
    Sure I can share some graphs. Unfortunately they are in Swedish though.
    This is a graph showing 7 out of 10 temperatures from this node.
    The graph is showing about 24 hrs and the wood boiler is fired up in the beginning.
    I guess you can see which curve is the smoke gas temp :)
    That one is the first to rise, then the boiler itself, later the sensors in the top-middle-bottom of the first accumulator tank and at last the top-bottom of the second tank. The tanks are connected in series (in the winter).
    As I wrote, I also try to calculate charge/discharge power, the accumulated energy in kWh and % in the accumulator tanks as good as I can using my 5 temp sensors. I consider room temp (22degreesC) as my zero kWh level and then I calculate the energy using temperatures and a certain water volume corresponding to each temperature sensor. This is a "kWh graph" from about the same period:
    All calculations are made in Domoticz and not in the Mysensor nodes.
    I happen to have copies of the sketches at another location so cannot share them at the moment. I am sure they are even a bit outdated by now (definitely pre 2.0).
    Perhaps, another day, I will click some photos of my installation. Nothing much to see, really. Part of it is behind a layer of insulation. But it is working great!
    /Tobias
    @tkarlsson very nice, great work! Thanks a lot for sharing.
    • R
      R
      RWoerz
      Great work how do you send error messages from a MySensors node. I'm building a solar hot water heater for my shop with temp sensors inside, outside, solar panel, storage tank, and the attic, I also have flow and pressures sensors in the tank pump solar panel and another tank pump and inside heat exchanger. Besides the pumps I also control attic, ceiling and roof louvers and fans. Needless to say there's lots that could go wrong. If you've got a way to send alarms I would love to see the Sketches. Thanks.
      I would also like to see pictures of setup I think many other would also.
      • korttomaK
        korttomaK
        korttoma
        Finally got a MAX31865 + PT100 on a breadboard set up and measuring the smoke temperature.
        But I seem to have an issue, either there is something wrong with the library I'm using or the sensor just cant handle the heat. If it gets hot enough I get negative values.
        The boileroom is not quite fit for debugging, would be nice to have a wireless serial port of some kind.
        EDIT: Maybe I can use a 470ohm potentiometer to debug this instead of the PT100?
        • Tomas
        bjacobseB enloE 2 Replies Last reply
        • korttomaK korttoma
          bjacobseB
          bjacobseB
          bjacobse
          @korttoma said in Monitoring a wood boiler heating system:
          Could it be something that you store your read value in a too small variable, so that you get variable rollover?
          • korttomaK
            korttomaK
            korttoma
            @bjacobse I hope so, I got it on my desk now. Just need to get the variable resistor today so I can start debugging.
             * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
             * http://www.mysensors.org/build/temp
            //#define MY_RFM69_FREQUENCY RF69_433MHZ
            // Define a static node address, remove if you want auto address assignment
            #define MY_NODE_ID 23
            #include <Adafruit_MAX31865.h>
            #define CHILD_ID 1
            // Use software SPI: CS, DI, DO, CLK
            //Adafruit_MAX31865 max = Adafruit_MAX31865(10, 11, 12, 13);
            // use hardware SPI, just pass in the CS pin
            Adafruit_MAX31865 max = Adafruit_MAX31865(8);
            // The value of the Rref resistor. Use 430.0!
            #define RREF 430.0
            #define TEMP_TRANSMIT_THRESHOLD 2
            float temperature;
            float lastTemperature = 10;
            float diffTemp = 1;
            unsigned long SLEEP_TIME = 20000; // Sleep time between reads (in milliseconds)
            bool receivedConfig = false;
            bool metric = true;
            MyMessage msg(CHILD_ID,V_TEMP);
            void before()
              max.begin(MAX31865_3WIRE);  // set to 2WIRE or 4WIRE as necessary
              sendSketchInfo("PT100 Temp", "1.0");
                 present(CHILD_ID, S_TEMP);
              uint16_t rtd = max.readRTD();
              Serial.print("RTD value: "); Serial.println(rtd);
              float ratio = rtd;
              ratio /= 32768;
              Serial.print("Ratio = "); Serial.println(ratio,8);
              Serial.print("Resistance = "); Serial.println(RREF*ratio,8);
              // Fetch temperature
              temperature = max.temperature(100, RREF);
              Serial.print("Temperature = "); Serial.println(temperature);
              diffTemp = abs(lastTemperature - temperature);
              Serial.print("DiffTemp = "); Serial.println(diffTemp);
                if (diffTemp > TEMP_TRANSMIT_THRESHOLD) {
                  send(msg.set(temperature,1));
              sleep(SLEEP_TIME);
            In the meantime I replaced it with a node that uses a K-Type thermocouple and this one works just fine.
            • Tomas
            • korttomaK
              korttomaK
              korttoma
              I can now confirm that the problem is in fact the PT100 sensor because if I "simulate" the sensor with a variable resistor everything works fine all the way up to 988.8 degrees and down to -241.3.
              Seems like I will have to use the K-Type sensor after all.
              • Tomas
              bjacobseB 1 Reply Last reply
                bjacobseB
                bjacobseB
                bjacobse
                @korttoma
                Glad that you found the rootcause + published your analysis
                  enloE
                  enloE
                  enlo
                  @korttoma just being curious: how did you install that smoke sensor? drill an hole into the chimney?
                  korttomaK bjacobseB 2 Replies Last reply
                  • enloE enlo
                    korttomaK
                    korttomaK
                    korttoma
                    @enlo there was a hole on the back of the wood boiler where the pipe goes to the chimney.
                    It looked like a bolt and when I unscrewed it with a 14mm wrench I found that it had 12mm (or 1/2") threading so the hole was quite big and I can fit most sensors in it..
                    Because the sensor is so close to the boiler it gets quite hot so it is actually not a surprise that the sensor could not handle it but the behaviour was quite strange. I thought that if it would fail it would also destroy the sensor but it just malfunctions and goes back to normal when it cools down.
                    The sensor claimed to have a measurement range of -200~500 Degrees like most of the sensors for sale.
                    The K-Type thermocouple I'm using now has "Operating Temperature: 0 – 800 °C" but the item on Ali is nolonger available. I looks like this one though ->
                    https://www.aliexpress.com/item/K-Type-2M-EGT-Thermocouple-WRNK-191-Probe-type-Exhaust-Probe-High-Temperature-Sensors-Threads-Stainless/32754224250.html
                    • Tomas
                    enloE 1 Reply Last reply
                    • enloE enlo
                      bjacobseB
                      bjacobseB
                      bjacobse
                      @enlo
                      I would assume to drill a hole in the metal chimney that is between the wood boiler and the brick chimney.
                      then depending of the K-type thermocouple
                      then there is a nut so you can secure this like this:
                      https://www.aliexpress.com/item/Newest-High-Temperature-100-To-1250-Degree-Thermocouple-K-Type-100mm-Stainless-Steel-Probe-Sensors/32786956791.html?spm=2114.40010308.4.1.LxioyK
                      Or else you can sealed with special heat resistant seal:
                      https://www.amazon.co.uk/Heat-Resistant-Sealant-1250-300ml/dp/B0046450C4
                      • korttomaK
                        korttomaK
                        korttoma
                        I just put the sensor through a 1cm sheet of heat resistant rockwool.
                        I bet that the draft of the chimney is enough to ensure that the fire does not find it's way through this little hole.
                        • Tomas
                          enloE
                          enloE
                          enlo
                          @korttoma Thanks for your explanation!
                          I am thinking about integrating a heat sensor too but I am not confident enough to manipulate the chimney - yet :)
                          • archiijsA
                            archiijsA
                            archiijs
                            wrote on last edited by archiijs
                            #23
                            Hi, all this is awesome, about the same what I would like to make as I'm heating the house with wood boiler (actually wood gasification boiler to be correct), and accumulation tank. Still working on hot water boiler, but that's not far.
                            For now, I got working Individually DS18b20 node (still with automatic addressing) and one node that reads the temperature in my boilers second burning chamber with a k-type thermocouple but still struggling to get them bout working with one node.
                            It would be very helpful for some guidance or example for this.
                            So my goal is to get 2x thermocouples (additional for smoke temperatures) and some 18b20s in one node + some standard stuff what I am not still sure about.
                            But for now big thanks to mysensors team and community for this.
