  3. Stepper wont work with Mysensors
6 Posts 2 Posters 2.5k Views 2 Watching
  • TON RIJNAARDT Offline
    TON RIJNAARD
    I try to run a stepper 28byj-48 with driver in mysensors. As soon as I Mysensors.h activate the stepper motor will not run. Can anyone help me what I do wrong. I use Int 4,5,6,7, above. Also at 3,4,5,6 not work I put too // for Mysensors the engine is running normally. Also burn without Mysensors all 4 LEDs. With Mysensors burn only 3 LEDs.
    • P Offline
      P Offline
      pansen
      we need
      • Schematic
      • Code
      • Relevant links to the used parts i.e. datasheets
      Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
        TON RIJNAARD
        wrote on last edited by TON RIJNAARD
        Here the image and the code that i wil use it a start. I am new to programm arduino.
        Schematic that i use this works without Mysensors.h (see the sketch)
        http://engyfun.blogspot.nl/2015/02/here-is-source-code-for-our-28byj48.html
        // =========================== Zet de serielle monitor aan ======================================
        // **************************** Einde Debug *****************************************************
        // =========================== Radio instelling RFM 69 ===========================================
        //#define MY_RADIO_NRF24
        #define MY_RADIO_RFM69
        //=========================== Node en Child infomatie =============================================
        #define MY_NODE_ID 17
        #define CHILD_ID 2
        //***************************** Einde Radio setup ***************************************************
        //#include <MySensors.h>
        #include <AccelStepper.h>
        #define HALFSTEP 8
        // ============================ Motor pin definitions ==================================================
        #define motorPin1  4                    // IN1 on the ULN2003 driver 1
        #define motorPin2  5                    // IN2 on the ULN2003 driver 1
        #define motorPin3  6                    // IN3 on the ULN2003 driver 1
        #define motorPin4  7                    // IN4 on the ULN2003 driver 1
        int CHILD_CURTAIN_ID =4;
        // Initialize with pin sequence IN1-IN3-IN2-IN4 for using the AccelStepper with 28BYJ-48
        AccelStepper stepper1(HALFSTEP, motorPin1, motorPin3, motorPin2, motorPin4);
        MyMessage msg_S_COVER_U(CHILD_CURTAIN_ID, V_UP);
        MyMessage msg_S_COVER_D(CHILD_CURTAIN_ID, V_DOWN);
        MyMessage msg_S_COVER_S(CHILD_CURTAIN_ID, V_STOP);
        MyMessage msg(CHILD_CURTAIN_ID,V_UP);
        // ==============================  Begin Setup ===========================================================
          stepper1.setMaxSpeed(18000.0);
          stepper1.setAcceleration(100.0);
          stepper1.setSpeed(400);
          stepper1.moveTo(20000);
        //****************************----- (Einde setup )---********************************************************
        // ==============================---- Begin Loop ----========================================================
          //Change direction when the stepper reaches the target position
          if (stepper1.distanceToGo() == 0)
            stepper1.moveTo(-stepper1.currentPosition());
          stepper1.run();
        // **************************** Eind Loop ==================================================================```)
        Sorry i can get the  code not in a nice black box.
        • P Offline
          P Offline
          pansen
          wrote on last edited by pansen
          Code looks good so far... (you misplaced the starting and ending ``` to mark code in a black box).
          What I can tell you from own, painful experience: If anything fails with the radio setup (also registration I think), loop() will never be executed. I was testing a LED library, working perfectly without MySensors.h but not doing anything with MySensors.h included.
          Later I realized my controller was switched off..after I switched it on everything worked. So ensure that MySensors can communicate properly. That means implementing presentation() and all other functions..
            TON RIJNAARD
            @Pansen,
            Thanks i give it a try.
              TON RIJNAARD
              @ Pansen It work now!
              When connect the radio then the 4e led and stepper is working.
              Thanks for the help.
              12.2k
