  3. Sensebender Gateway with NRF24 PA and Hardsigning and Encryption
24 Posts 5 Posters 7.3k Views 4 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @meddie
    Which version of mysensors board definition files, and arduino ditto for SAMD do you have installed? (Have a look in the board manager)
    The newest Mysensors SAMD files (1.0.4) is only compatible up to Arduino SAMD 1.6.11, as the Arduino folks have made some changes again to their core again.
      meddie
      I have installed the 1.0.4 Version. But the Arduino IDE is 1.8.1
      • tbowmoT
        tbowmoT
        tbowmo
        @meddie
        Not the arduino IDE, but Arduino SAMD board support files.. These can be installed through the board manager.
        Sorry this was not made clear in the setup instructions..
          meddie
          Oh, ok i did not installed them. Just in moment i install the arduino sam Boards (32-bits ARM Cortex.m3) Version 1.6.11
          is that correct?
          • tbowmoT
            tbowmoT
            tbowmo
            @meddie
            No, you need to choose Arduino SAMD boards (32-bits ARM Cortex-M0) version 1.6.11
              meddie
              AAAAAH! I am so stupid! I read all the Time SAM and didnt seen the D at the end. Sorry sorry sorry.
              Yes it works now!!!
              Thank you very much!
                meddie
                wrote on last edited by meddie
                Ok, next problem:
                the sketch Gateway5100 can be compiled but i get an error on uploding them.
                I have a Win 10 PC, the GW is detected by os and in the device manager i can see a usb device Com Port 3. When i connect the GW to the PC and start the serial monitor i get some lines.
                I think the communication should work.
                This is the output:
                Arduino: 1.8.1 (Windows 10), Board: "Sensebender Gateway"
                C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\meddie\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\meddie\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\meddie\Documents\Arduino\libraries -fqbn=MySensors:samd:mysensors_gw_native -vid-pid=0X1209_0X6949 -ide-version=10801 -build-path C:\Users\meddie\AppData\Local\Temp\arduino_build_739214 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.openocd.path=C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.9.0-arduino -prefs=runtime.tools.CMSIS.path=C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.bossac.path=C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0 -prefs=runtime.tools.avrdude.path=C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino8 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0 -verbose C:\Program Files (x86)\Arduino\examples\MySensors\GatewayW5100\GatewayW5100.ino
                C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\meddie\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\meddie\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\meddie\Documents\Arduino\libraries -fqbn=MySensors:samd:mysensors_gw_native -vid-pid=0X1209_0X6949 -ide-version=10801 -build-path C:\Users\meddie\AppData\Local\Temp\arduino_build_739214 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.openocd.path=C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.9.0-arduino -prefs=runtime.tools.CMSIS.path=C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.bossac.path=C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0 -prefs=runtime.tools.avrdude.path=C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino8 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0 -verbose C:\Program Files (x86)\Arduino\examples\MySensors\GatewayW5100\GatewayW5100.ino
                Using board 'mysensors_gw_native' from platform in folder: C:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4
                Using core 'arduino' from platform in folder: C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11
                Detecting libraries used...
                "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions  -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0/CMSIS/Device/ATMEL/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\cores\arduino" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\sketch\GatewayW5100.ino.cpp" -o "nul"
                ..."C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions  -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0/CMSIS/Device/ATMEL/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\cores\arduino" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src" "-IC:\Program Files (x86)\Arduino\libraries\MySensors-master" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\Wire" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI" "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI\SPI.cpp" -o "nul"
                Generating function prototypes...
                "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions  -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0/CMSIS/Device/ATMEL/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\cores\arduino" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src" "-IC:\Program Files (x86)\Arduino\libraries\MySensors-master" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\Wire" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\sketch\GatewayW5100.ino.cpp" -o "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\preproc\ctags_target_for_gcc_minus_e.cpp"
                "C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\preproc\ctags_target_for_gcc_minus_e.cpp"
                Compiling sketch...
                "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0/CMSIS/Device/ATMEL/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\cores\arduino" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src" "-IC:\Program Files (x86)\Arduino\libraries\MySensors-master" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\Wire" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\sketch\GatewayW5100.ino.cpp" -o "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\sketch\GatewayW5100.ino.cpp.o"
                Compiling libraries...
                Compiling library "Ethernet"
                "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0/CMSIS/Device/ATMEL/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\cores\arduino" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src" "-IC:\Program Files (x86)\Arduino\libraries\MySensors-master" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\Wire" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI" "C:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src\Dhcp.cpp" -o "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\Dhcp.cpp.o"
                "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0/CMSIS/Device/ATMEL/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\cores\arduino" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src" "-IC:\Program Files (x86)\Arduino\libraries\MySensors-master" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\Wire" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI" "C:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src\Dns.cpp" -o "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\Dns.cpp.o"
                "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0/CMSIS/Device/ATMEL/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\cores\arduino" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src" "-IC:\Program Files (x86)\Arduino\libraries\MySensors-master" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\Wire" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI" "C:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src\Ethernet.cpp" -o "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\Ethernet.cpp.o"
                "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0/CMSIS/Device/ATMEL/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\cores\arduino" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src" "-IC:\Program Files (x86)\Arduino\libraries\MySensors-master" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\Wire" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI" "C:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src\EthernetClient.cpp" -o "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\EthernetClient.cpp.o"
                "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0/CMSIS/Device/ATMEL/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\cores\arduino" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src" "-IC:\Program Files (x86)\Arduino\libraries\MySensors-master" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\Wire" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI" "C:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src\EthernetServer.cpp" -o "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\EthernetServer.cpp.o"
                "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0/CMSIS/Device/ATMEL/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\cores\arduino" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src" "-IC:\Program Files (x86)\Arduino\libraries\MySensors-master" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\Wire" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI" "C:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src\EthernetUdp.cpp" -o "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\EthernetUdp.cpp.o"
                "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0/CMSIS/Device/ATMEL/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\cores\arduino" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src" "-IC:\Program Files (x86)\Arduino\libraries\MySensors-master" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\Wire" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI" "C:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src\utility\socket.cpp" -o "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\utility\socket.cpp.o"
                "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0/CMSIS/Device/ATMEL/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\cores\arduino" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src" "-IC:\Program Files (x86)\Arduino\libraries\MySensors-master" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\Wire" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI" "C:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src\utility\w5100.cpp" -o "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\utility\w5100.cpp.o"
                Compiling library "MySensors-master"
                Compiling library "Wire"
                "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0/CMSIS/Device/ATMEL/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\cores\arduino" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src" "-IC:\Program Files (x86)\Arduino\libraries\MySensors-master" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\Wire" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI" "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\Wire\Wire.cpp" -o "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Wire\Wire.cpp.o"
                Compiling library "SPI"
                "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0/CMSIS/Device/ATMEL/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\cores\arduino" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src" "-IC:\Program Files (x86)\Arduino\libraries\MySensors-master" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\Wire" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI" "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI\SPI.cpp" -o "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\SPI\SPI.cpp.o"
                Compiling core...
                "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0/CMSIS/Device/ATMEL/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\cores\arduino" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw" "C:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw\variant.cpp" -o "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\core\variant.cpp.o"
                "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-ar" rcs  "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\core\core.a" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\core\USB\USBCore.cpp.o"
                "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-gcc"  "-LC:\Users\meddie\AppData\Local\Temp\arduino_build_739214" -Os -Wl,--gc-sections -save-temps  "-TC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw/linker_scripts/gcc/flash_with_bootloader.ld" "-Wl,-Map,C:\Users\meddie\AppData\Local\Temp\arduino_build_739214/GatewayW5100.ino.map" --specs=nano.specs --specs=nosys.specs -mcpu=cortex-m0plus -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -o "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214/GatewayW5100.ino.elf" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\sketch\GatewayW5100.ino.cpp.o" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\Dhcp.cpp.o" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\Dns.cpp.o" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\Ethernet.cpp.o" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\EthernetClient.cpp.o" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\EthernetServer.cpp.o" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\EthernetUdp.cpp.o" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\utility\socket.cpp.o" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\utility\w5100.cpp.o" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Wire\Wire.cpp.o" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\SPI\SPI.cpp.o" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\core\variant.cpp.o" -Wl,--start-group "-LC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Lib/GCC/" -larm_cortexM0l_math -lm "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214/core\core.a" -Wl,--end-group
                "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-objcopy" -O binary  "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214/GatewayW5100.ino.elf" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214/GatewayW5100.ino.bin"
                "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom  "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214/GatewayW5100.ino.elf" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214/GatewayW5100.ino.hex"
                Multiple libraries were found for "Ethernet.h"
                 Used: C:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet
                 Not used: C:\Program Files (x86)\Arduino\libraries\Ethernet
                Using library Ethernet at version 1.1.2 in folder: C:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet
                Using library MySensors-master at version 2.1.1 in folder: C:\Program Files (x86)\Arduino\libraries\MySensors-master
                Using library Wire at version 1.0 in folder: C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\Wire
                Using library SPI at version 1.0 in folder: C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI
                Sketch uses 43960 bytes (16%) of program storage space. Maximum is 262144 bytes.
                An error occurred while uploading the sketch```
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @meddie
                  I'm not sure how things work on windows..
                    meddie
                    me again, today i installed the arduino ide on a other pc and it works now i could compile and upload the sketch. But when i user the Gateway5100 Sketch and put as ip Adresse 172.16.0.25 i could not ping the gateway.
                    Do i have to config the pins that connected to the ethernet modul? A similar problem i had with my nrf24 modul when i connect it the gateway dont start. (i dont get any data on the serial port)
                    Thank you a lot!
                    Greets Eddie
                      meddie
                      i did it! The gateway has worked fine all the time! When i have uploaded the GatewayW5100 Sketch and connected the Eternet Module and the NRF24 Modul, then i didnt get anythin on Serial Monitor but i think its correct so, because FHEM (my Controller) shows me that the Sensebender Gateway is connected and added one new Device.
                      Then i tried to upload the Sketch from second post, and get some errors, i had to delete this Line
                      #include <drivers/ATSHA204/ATSHA204.cpp>
                      then i could compile and upload the sketch but i get three warnings:
                      c:/users/meddie/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld.exe: warning: changing start of section .bss by 4 bytes
                      I dont know what this means, but it looks like the gateway is working. FHEM continues showing as connected!
                      Do you know what this warning does mean?
                      Thanks a lot!
                      • magpernM
                        magpernM
                        magpern
                        Is it correct, that if you want to enable ATSHA204A chip in gateway, you need to enable this in MyConfig.h?
                        //#define MY_SIGNING_ATSHA204
                        If I do, I get a lot of compile errors, see below, if I don't enable it, it compiles fine. It is development branch (I guess...). Setting up the environment is quite the trial and error
                        In file included from C:\Users\aaa\Documents\Arduino\libraries\MySensors\examples\SensebenderGatewaySerial\SensebenderGatewaySerial.ino:86:0:
                        C:\Users\aaa\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:6:16: error: redefinition of 'uint8_t device_pin'
                         static uint8_t device_pin;
                        In file included from C:\Users\aaa\Documents\Arduino\libraries\MySensors/MySensors.h:166:0,
                                         from C:\Users\aaa\Documents\Arduino\libraries\MySensors\examples\SensebenderGatewaySerial\SensebenderGatewaySerial.ino:84:
                        C:\Users\aaa\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:6:16: error: 'uint8_t device_pin' previously declared here
                        C:\Users\aaa\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'void swi_set_signal_pin(uint8_t)':
                        C:\Users\aaa\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:23:13: error: redefinition of 'void swi_set_signal_pin(uint8_t)'
                         static void swi_set_signal_pin(uint8_t is_high)
                        and a lot more...
                        AnticimexA 1 Reply Last reply
                        • magpernM magpern
                          and a lot more...
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @Magnus-Pernemark normally, you don't change MyConfig.h, you just use it as reference. And then you set your defines in your sketch prior to include mysensors.h.
                          I think there was a problem in the official release that the SenseBender gw sketch included some files for self testing that is not really needed (or more correctly, it included them without considering the atsha flag), so you can probably strip them from the sketch or conditionally include them. I believe it was fixed on beta. But perhaps it is still in there.
                          magpernM 1 Reply Last reply
                          • AnticimexA Anticimex
                            magpernM
                            magpernM
                            magpern
                            @Anticimex Ah, I was under the impression that the SenseBender Gateway, came with default serial sketch without signing and you had to enable signing by your self if you want it. And some how in MyConfig.h (not MySensors.h) this sounded like something that needs to be changed (comment said so).
                             * @def MY_SIGNING_ATSHA204
                            * For any signing related functionality to be included, this define or @ref MY_SIGNING_SOFT has to
                             * be enabled.
                            So after configuring the ATSHA chip and uploading the serialgateway to the GW, without altering any code, it will start using the ATSHA chip and reject those without?
                            Is it the same with Sensebender Micro? If it has a ATSHA chip it will use it, if it doesn't it will not?
                            I run the development branch code, 2.2.2-beta
                            • magpernM magpern
                               * be enabled.
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @Magnus-Pernemark no, it is not enabled by default. But the SenseBender gw sketch also include self test logic used in the factory that test atsha204a communication. But this code is always included, so if you do enable the signing using atsha204a, it includes some code twice. So the sketch would only include the atsha stuff if the define isn't set.
                                magpernM
                                magpernM
                                magpern
                                @Anticimex I'm sorry, my vacation brain just cannot comprehend all these terms (I don't think it would even if I wasn't on vecaction :) My four hour experience with c/c++ surely has its limits).
                                Is it safe to say, the GW sketch does not use the ATSHA chip, and the sketch needs some modification for it to start using it?
                                In the mean-time, I'll try it out with the default sketch. It looks like the GW and the bender are talking to each other
                                • magpernM magpern
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @Magnus-Pernemark no, I am saying that the sketch use the atsha by default for self testing. It is not using it by default for signing. And the problem is that if you want to use it for signing it has already included some code for self testing that it shouldn't in that case. If you are not able to code c i suggest hanging on some time for someone to fix the problem. I can't do it at the moment since I am on the road. Ping @tbowmo
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @Magnus-Pernemark
                                    You need to enable signing with
                                    This will make the sketch break though, as it includes the atsha204 driver already (and the library wants to include it as well)
                                    To remove the error comment out the following line (it's line 86 in the original source)
                                    (Reference to the line in github :
                                    https://github.com/mysensors/MySensors/blob/master/examples/SensebenderGatewaySerial/SensebenderGatewaySerial.ino#L86)
                                    As an alternative, you can load the standard GatewaySerial sketch.. The only difference to the SensebenderGatewaySerial, is that the later includes test routines used in the factory.
                                    @Anticimex I don't think that I made a PR for conditionally include the atsha driver, as the error still persists in dev branch..
                                    • tbowmoT tbowmo
                                      @Magnus-Pernemark
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @tbowmo no, but I remember that another user had the same issue and agreed to file a pr but perhaps he never got around to it. Should just be a matter of adding a ifndef though.
                                        magpernM
                                        magpernM
                                        magpern
                                        @Anticimex @tbowmo an #ifndef made it work and sketch compiled.
