  3. MQTT Client Gateway / Node Controller / OTA
otamqtt
50 Posts 9 Posters 23.7k Views 10 Watching
    Samuel235
    I'm also here with this predicament. I use OpenHAB and W5100 client gateway and would like to be able to push OTA updates. I'm also not really liking the idea of having to disconnect OpenHAB and then connect MyController to just issue updates. Would we need to add each device into MyController manually to see them? I've been playing with it but i can't even get it to connect properly yet.
    Also, thinking about it, would we need to disconnect OpenHAB as its only on MQTT and technically doesn't interface with the gateway/mysensors other than taking readings off of MQTT topics, its not like a serial connection to the gateway or anything.....
    MySensors 2.1.1
    • maghacM
      maghacM
      maghac
      Yes, I was hoping that since the only interface to the gateway is actually through MQTT, the controller wouldn't "own" it and MyController could also connect to it.
      I didn't actually get as far as MyController since I never managed to burn the bootloader required for OTA updates and haven't had time to play with it more :)
      S 1 Reply Last reply
      • maghacM maghac
        Samuel235
        @maghac - i'm going to play with the bootloader later today, if i can get that on some nanos (just to test) then i will load up MyController and connect to the MQTT. If i can get this working i can't see any issues with this plan, as like we have both said, the controller isn't owning the gateway. So, I personally don't see any issues AS LONG AS we do not set any rules or anything to trigger on anything within the MyController environment. The moment we do that it will then conflict with OpenHAB (or any other controller for that matter).
        However, I may take a look around to see if we have any decent way of implementing an interface for tablets/scene controllers with MyController, if so this could even be an easier controller. Not sure if it has much capabilities like OpenHAB does with other protocols though. I run a Windows server at home so I'm okay with throwing that onto there if needs be. But i would like to stick with OpenHAB as I have learnt how it works (some what anyway).
        Do you know of any info or guides on MyController?
        I keep getting MyController and MYSController mixed up too, its a shame that MYSController doesn't support MQTT, that would have been perfect for our needs.
        MySensors 2.1.1
          So basically if we want to make ota updates we need to temporarily replace the mqtt gateway with another ethernet gateway, wait for the sensors to reconnect, run updates and restore back the mqtt, correct?
            Samuel235
            @gohan - If MyController is able to push OTA updates over MQTT (which i'm about to test, give me an hour or two) then no. My theory is that because MQTT doesn't connect the controller directly to the gateway then we shouldn't need to shut anything down, only start MyController up and push the updates.
            MySensors 2.1.1
            V 1 Reply Last reply
            • S Samuel235
              V
              V
              vikasjee
              @Samuel235 What are your results?
              • V vikasjee
                Samuel235
                @vikasjee - I've upgraded my gateway to MySensorsV2.1 and having some pretty bad results with just powering up. I'm waiting for people with V2.1 MQTT gateways to reply to threads. Do you run with MQTT gateways on V2.1 by any chance?
                MySensors 2.1.1
                • maghacM
                  maghacM
                  maghac
                  I am running a v2.1 MQTT Gateway on a NodeMCU (so it connects to the network with wifi) and it works fine.
                  It's a bit picky with the power supply but I think that's more a hardware than a software issue.
                  • maghacM maghac
                    Samuel235
                    @maghac - I'm not sure how that setup works, but are you able to see any sort of serial monitor to debug or anything?
                    MySensors 2.1.1
                    • maghacM
                      maghacM
                      maghac
                      Yes, when I program it with Arduino IDE I use the serial monitor like normal with other boards. Never had any problems with it.
                      If you go back to an older version, does it work then?
                      • maghacM maghac
                        Samuel235
                        @maghac I downgraded my boardDefs last night to 1.6.11 like advised on this forum. I'm about to install arduino IDE 1.6.11 and replace my latest install of Arduino and attempt to use this. What arduino IDE environment do you use, out of curiosity?
                        MySensors 2.1.1
                          Samuel235
                          Exact same behaviour is happening. This is what is being printed to the serial monitor:
                          IP: 192.168.0.22
                          0;255;3;0;9;MQTT connected
                          0;255;3;0;9;Sending message on topic: Gateway1-out/0/255/0/0/18
                          0;255;3;0;9;Message arrived on topic: Gateway1-in/4/1/1/0/2
                          0;255;3;0;9;!TSF:MSG:SEND,0-0-4-4,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:0
                          IP: 192.168.0.22
                          IP: 192.168.0.22
                          I'm not even certain that anything is wrong here. It just keeps reconnecting to the MQTT server, but it is actually working but i'm concerned about why its doing such inside of the serial monitor. I read somewhere that it does a 'touching base' case to keep it alive or something, but i also recall someone saying that was every 15 seconds or so, this is every 8 seconds (about). Do you happen to know what its sending to a MQTT topic 0/255/0/0/18 for, is this standard behaviour or just mine?
                          MySensors 2.1.1
                          • maghacM
                            maghacM
                            maghac
                            Not sure if mine did that, I can check later.
                            I'm using the latest Arduino IDE (1.8.1 or something like that)
                            • maghacM maghac
                              Samuel235
                              @maghac - The same as the one I've been using apart from the last test then. Thanks for confirming that.
                              If you wouldn't mind checking a serial output on your later, that would be really appreciated.
                              MySensors 2.1.1
                              • maghacM
                                maghacM
                                maghac
                                Type 18 is the heartbeat message type, I think this is the last element in your MQTT topic so it looks fine I think. Can you monitor the MQTT broker and see what messages are passing through it? (e.g if you can see something being sent by the sensors)
                                S 2 Replies Last reply
                                • maghacM maghac
                                  Samuel235
                                  @maghac - I know the sensors are sending messages, the gateway is responding as it should to them, i was just concerned about the gateway keep connecting itself to the MQTT server, i was a little worried in case there is a feature in Mosquitto broker that declines the connection if it detects any sort of brute force or anything like that.
                                  MySensors 2.1.1
                                  • maghacM maghac
                                    Samuel235
                                    #22
                                    @maghac
                                    On my MQTT server i'm sure enough receiving a message from the gateway every time it says its reconnected in the serial monitor, sending its version number to the server. By the looks of the serial monitor, its actually reconnecting and not just sending a new message to the MQTT topic. I'm confused to why this is doing this, I had just assumed that the heartbeat message is just a re-sending on a message on that topic. Would like to know if this is the normal behaviour of the gateway to keep constantly reconnecting.
                                    MySensors 2.1.1
                                    • maghacM
                                      maghacM
                                      maghac
                                      Mine doesn't reconnect. Here's the serial monitor on startup:
                                      0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGE--,VER=2.1.1
                                      0;255;3;0;9;TSF:LRT:OK
                                      0;255;3;0;9;TSM:INIT
                                      0;255;3;0;9;TSF:WUR:MS=0
                                      scandone
                                      state: 0 -> 2 (b0)
                                      state: 2 -> 3 (0)
                                      state: 3 -> 5 (10)
                                      add 0
                                      aid 14
                                      cnt
                                      connected with hacker, channel 9
                                      dhcp client start...
                                      0;255;3;0;9;TSM:INIT:TSP OK
                                      0;255;3;0;9;TSM:INIT:GW MODE
                                      f r0, scandone
                                      ....ip:192.168.1.215,mask:255.255.255.0,gw:192.168.1.1
                                      .IP: 192.168.1.215
                                      0;255;3;0;9;MCO:BGN:STP
                                      OTA init
                                      Ready
                                      IP address: 192.168.1.215
                                      IP: 192.168.1.215
                                      0;255;3;0;9;Sending message on topic: mysensors-out/0/255/0/0/18
                                      0;255;3;0;9;Message arrived on topic: mysensors-in/200/255/3/0/6
                                      0;255;3;0;9;!TSF:RTE:200 UNKNOWN
                                      0;255;3;0;9;!TSF:MSG:SEND,0-0-200-200,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=NACK:M
                                      0;255;3;0;9;Message arrived on topic: mysensors-in/254/255/3/0/6
                                      0;255;3;0;9;!TSF:MSG:SEND,0-0-254-254,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=NACK:M
                                      0;255;3;0;9;Message arrived on topic: mysensors-in/222/255/3/0/6
                                      0;255;3;0;9;!TSF:MSG:SEND,0-0-222-222,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=NACK:M
                                      0;255;3;0;9;Message arrived on topic: mysensors-in/222/255/3/0/1
                                      0;255;3;0;9;!TSF:MSG:SEND,0-0-222-222,s=255,c=3,t=1,pt=0,l=10,sg=0,ft=0,st=NACK:1485810579
                                      0;255;3;0;9;Message arrived on topic: mysensors-in/123/255/3/0/6
                                      0;255;3;0;9;!TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=NACK:M
                                      0;255;3;0;9;Message arrived on topic: mysensors-in/255/255/3/0/4
                                      0;255;3;0;9;TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=4,pt=0,l=3,sg=0,ft=0,st=OK:234
                                      0;255;3;0;9;Message arrived on topic: mysensors-in/227/255/3/0/6
                                      0;255;3;0;9;!TSF:MSG:SEND,0-0-227-227,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=NACK:M
                                      0;255;3;0;9;Message arrived on topic: mysensors-in/227/1/1/0/24
                                      0;255;3;0;9;!TSF:MSG:SEND,0-0-227-227,s=1,c=1,t=24,pt=0,l=3,sg=0,ft=0,st=NACK:102
                                      0;255;3;0;9;Message arrived on topic: mysensors-in/233/255/3/0/6
                                      0;255;3;0;9;!TSF:MSG:SEND,0-0-233-233,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=NACK:M
                                      0;255;3;0;9;Message arrived on topic: mysensors-in/234/255/3/0/6
                                      0;255;3;0;9;!TSF:MSG:SEND,0-0-234-234,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=NACK:M
                                      0;255;3;0;9;TSF:MSG:READ,227-227-0,s=1,c=1,t=17,pt=5,l=4,sg=0:7160
                                      0;255;3;0;9;Sending message on topic: mysensors-out/227/1/1/0/17
                                      0;255;3;0;9;TSF:MSG:READ,227-227-0,s=1,c=1,t=24,pt=5,l=4,sg=0:530
                                      0;255;3;0;9;Sending message on topic: mysensors-out/227/1/1/0/24
                                      0;255;3;0;9;TSF:MSG:READ,227-227-0,s=1,c=1,t=18,pt=7,l=5,sg=0:0.5300
                                      0;255;3;0;9;Sending message on topic: mysensors-out/227/1/1/0/18
                                      pm open,type:2 0
                                      0;255;3;0;9;TSF:MSG:READ,227-227-0,s=1,c=1,t=17,pt=5,l=4,sg=0:7175
                                      0;255;3;0;9;TSF:MSG:READ,227-227-0,s=1,c=1,t=24,pt=5,l=4,sg=0:570
                                      0;255;3;0;9;TSF:MSG:READ,227-227-0,s=1,c=1,t=18,pt=7,l=5,sg=0:0.5700
                                      After this, it's just continously getting data from sensor 227 (my power meter). My mosquitto broker is getting this:
                                      mysensors-out/0/255/0/0/18 2.1.1
                                      mysensors-out/227/1/1/0/17 7160
                                      mysensors-out/227/1/1/0/24 530
                                      mysensors-out/227/1/1/0/18 0.5300
                                      mysensors-out/227/1/1/0/17 7175
                                      mysensors-out/227/1/1/0/24 570
                                      mysensors-out/227/1/1/0/18 0.5700
                                      mysensors-out/227/1/1/0/17 7195
                                      etc etc - it's just the one message on startup.
                                      • maghacM maghac
                                        scandone
                                        state: 0 -> 2 (b0)
                                        state: 2 -> 3 (0)
                                        state: 3 -> 5 (10)
                                        add 0
                                        aid 14
                                        cnt
                                        f r0, scandone
                                        .IP: 192.168.1.215
                                        OTA init
                                        Ready
                                        IP: 192.168.1.215
                                        pm open,type:2 0
                                        Samuel235
                                        @maghac - Right okay. Atleast i now have someone else's to compare too. So, something is pushing it off the network OR it can't hold its connection.
                                        My start up sequence:
                                        IP: 192.168.0.22
                                        IP: 192.168.0.22
                                        IP: 192.168.0.22
                                        IP: 192.168.0.22
                                        IP: 192.168.0.22
                                        IP: 192.168.0.22
                                        IP: 192.168.0.22
                                        IP: 192.168.0.22
                                        IP: 192.168.0.22
                                        IP: 192.168.0.22
                                        IP: 192.168.0.22
                                        IP: 192.168.0.22
                                        The start is different to mine, that is probably because you're running that on a ESP8266, right?
                                        I have connected to the MQTT server with MQTTFX, which is a MQTT monitoring tool. Not too familiar with it right now but i can't see the server dropping any connections or anything, it almost seems like the gateway is stuck in a loop.
                                        MySensors 2.1.1
                                          Did you try to swap the mega for an arduino uno? Or swap the w5100 shield? Just to see if there is any difference, so we can exclude any hw issues
