  2. Announcements
  3. 💬 Infrared Sender and Receiver
45 Posts 26 Posters 25.6k Views 26 Watching
  • R Reza
    this module ( ir transmitter ) is weak in transmit . for more than 2 or 3 meter distance dont work . also for less than 1 meter we must direct connection exactly.
    i think this is related to power or noise or problem of module ?!
    can you guidance me ?
    C
    C
    chuckconnors
    I'm thinking of building this but am concerned about limited range. I'd like it to work 10ft/3m. Can someone confirm that this does not work at these distances? If so, is there a way to increase the range?
    • W
      W
      Wackid
      So how can is set this node in learnmode?? V_IR_RECORD in the Serial of Arduino?
      How do i store codes in the Eprom. SO i can use them in Domoticz
      W 1 Reply Last reply
      • W Wackid
        W
        W
        Wackid
        @Wackid
        I know how to read out the IR signals. And to put it in the sketch manually. But I really like to make use of the record function.
        Where and how do I make the node to set it in learn function.
        • tianaT
          tianaT
          tiana
          I send command from remote control arduino read this command (i can see this in serial monitor) but this commands are not sending to gateway, my radio is working the sensor connect to gateway and controller. I use example Sketch given up in this page without changing anything.
          Any idea whats wrong in my setup?
          • W
            W
            Wackid
              Mihai
              I use this IR transmitter toward my LG Tv and it works at a distance of ~3.5 m, but IR LED must be well pointed to the Tv, otherwise it doesn't work.
              • Talat KeleÅŸT Talat KeleÅŸ
                @Reza said:
                is this a learning mode module ?
                how use this module for learn my ir codes ?
                This node decodes IR remote codes, print protocol and hex value to serial monitor and send it to gateway. Then controller can do logic on that to do some stuff.
                The sample code also receive on/off command from controller and emits IR signal depending on it.
                I use this node to turn on/off sony sound system (15bit sony protocol) and benq projector (NEC protocol) together beside htpc(via wol). Openhab rule send 8byte IR codes as V_IR_Send to node and node emits the required IR codes.
                ramoncarranzaR
                ramoncarranzaR
                ramoncarranza
                @Talat-KeleÅŸ
                Hi, I am having an issue compiling the sketch and was wondering if you had any input or could help me out, This is what I get back when I try to compile;
                0_1483733093476_upload-fba9c55f-1a02-4b17-b7ff-bc75aadb47d1
                Talat KeleÅŸT P 2 Replies Last reply
                • ramoncarranzaR ramoncarranza
                  @Talat-KeleÅŸ
                  Talat KeleÅŸT
                  Talat KeleÅŸT
                  Talat KeleÅŸ
                  wrote on last edited by Talat KeleÅŸ
                  #22
                  @ramoncarranza
                  Compiler complains about not understanding decode_type_t. It should be defined in .h file or maybe you defined it in sketch but there is a problem definetly.
                  Can you post whole sketch and IR library and error message if any other so we can check and test.
                  By the way, I installed IRremote.h (v2.1.0) via library manager, and default sketch compiled without error on IDE 1.6.5 win7 and IDE 1.6.10 linux mint 17.
                  • tmn103T
                    tmn103T
                    tmn103
                    Re: 💬 Infrared Sender and Receiver
                    How do you enter the raw IR codes, i.e. those that aren't covered in the sketch? I have one through the receiver in the format - 23784 1800 -800 950 -1700 1800 -850 900 -850 950 -1700 1800 -850 900 -850 900 -850 950 -800 950 -850 900
                      @Talat-KeleÅŸ
                      P
                      P
                      pete1450
                      @ramoncarranza When I went and looked where the library manager installed the IRremote lib(for me C:\Users\User\Documents\Arduino\libraries), it had given it an odd name like arduino_294267. I renamed it to IRremote and the issue went away.
                      • H
                        H
                        hashem25
                        I am confused i see the decode in my com monitor and i see the ir node in my domoticz but there is no data???
                        • W
                          W
                          wilson64
                          Can I use MQTT & Node Red to make this work, if yes can somebody show me how
                          • Mitja BlazinsekM
                            Mitja BlazinsekM
                            Mitja Blazinsek
                            ok i record ir code 240E4F17 from my AC remote hov can i sent this code from my controler to IR node and request from node to sent that code (on/off) AC i was trying with raw mesage but i dot know what to send (Type/ Sub type , Acknowledge/ Payload)
                            • dbemowskD
                              dbemowskD
                              So, I am thinking of building this and I noticed that the documentation says that you may need a mega to do this. Is a mega required, or will the code work with a nano or an uno?
                              • N
                                N
                                Newzwaver
                                Hi Running this code I get the following errors anyone know why?
                                Arduino: 1.6.5 (Windows 8.1), Board: "Arduino Nano, ATmega328"
                                Using library SPI in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
                                Using library MySensors in folder: C:\Users\Audrey\Documents\libraries\MySensors
                                Using library Robot IR Remote in folder: C:\Program Files (x86)\Arduino\libraries\RobotIRremote
                                C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10605 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI -IC:\Users\Audrey\Documents\libraries\MySensors -IC:\Program Files (x86)\Arduino\libraries\RobotIRremote\src C:\Users\Audrey\AppData\Local\Temp\build2205553450015260610.tmp\IRSendRec.cpp -o C:\Users\Audrey\AppData\Local\Temp\build2205553450015260610.tmp\IRSendRec.cpp.o
                                IRSendRec.ino:95:5: error: 'decode_type_t' does not name a type
                                IRSendRec.ino:114:1: error: 'IRsend' does not name a type
                                IRSendRec.ino:135:1: error: too many initializers for 'IRCode::<anonymous struct>'
                                IRSendRec.ino: In function 'byte lookUpPresetCode(decode_results*)':
                                IRSendRec.ino:246:38: error: 'struct IRCode::<anonymous>' has no member named 'type'
                                IRSendRec.ino:256:38: error: 'struct IRCode::<anonymous>' has no member named 'type'
                                IRSendRec.ino: In function 'bool storeRCCode(byte)':
                                IRSendRec.ino:300:30: error: 'struct IRCode::<anonymous>' has no member named 'type'
                                IRSendRec.ino:302:49: error: 'class decode_results' has no member named 'address'
                                IRSendRec.ino: In function 'void sendRCCode(byte)':
                                IRSendRec.ino:322:39: error: 'struct IRCode::<anonymous>' has no member named 'type'
                                IRSendRec.ino:84:38: note: in definition of macro 'Type2String'
                                IRSendRec.ino:84:50: note: in definition of macro 'Type2String'
                                IRSendRec.ino:323:18: error: 'struct IRCode::<anonymous>' has no member named 'type'
                                IRSendRec.ino:328:10: error: 'irsend' was not declared in this scope
                                IRSendRec.ino:331:24: error: 'struct IRCode::<anonymous>' has no member named 'type'
                                IRSendRec.ino:338:10: error: 'irsend' was not declared in this scope
                                IRSendRec.ino:341:23: error: 'struct IRCode::<anonymous>' has no member named 'type'
                                IRSendRec.ino:342:8: error: 'irsend' was not declared in this scope
                                IRSendRec.ino:344:24: error: 'struct IRCode::<anonymous>' has no member named 'type'
                                IRSendRec.ino:345:8: error: 'irsend' was not declared in this scope
                                IRSendRec.ino:347:24: error: 'struct IRCode::<anonymous>' has no member named 'type'
                                IRSendRec.ino:348:8: error: 'irsend' was not declared in this scope
                                IRSendRec.ino:352:24: error: 'struct IRCode::<anonymous>' has no member named 'type'
                                IRSendRec.ino:353:8: error: 'irsend' was not declared in this scope
                                IRSendRec.ino:355:24: error: 'struct IRCode::<anonymous>' has no member named 'type'
                                IRSendRec.ino:355:32: error: 'SAMSUNG' was not declared in this scope
                                IRSendRec.ino:356:8: error: 'irsend' was not declared in this scope
                                IRSendRec.ino:358:24: error: 'struct IRCode::<anonymous>' has no member named 'type'
                                IRSendRec.ino:358:32: error: 'WHYNTER' was not declared in this scope
                                IRSendRec.ino:359:8: error: 'irsend' was not declared in this scope
                                IRSendRec.ino:361:24: error: 'struct IRCode::<anonymous>' has no member named 'type'
                                IRSendRec.ino:361:32: error: 'AIWA_RC_T501' was not declared in this scope
                                IRSendRec.ino:362:8: error: 'irsend' was not declared in this scope
                                IRSendRec.ino:364:24: error: 'struct IRCode::<anonymous>' has no member named 'type'
                                IRSendRec.ino:364:32: error: 'LG' was not declared in this scope
                                IRSendRec.ino:364:48: error: 'struct IRCode::<anonymous>' has no member named 'type'
                                IRSendRec.ino:364:75: error: 'struct IRCode::<anonymous>' has no member named 'type'
                                IRSendRec.ino:368:24: error: 'struct IRCode::<anonymous>' has no member named 'type'
                                IRSendRec.ino:372:12: error: 'irsend' was not declared in this scope
                                IRSendRec.ino:375:24: error: 'struct IRCode::<anonymous>' has no member named 'type'
                                IRSendRec.ino:376:8: error: 'irsend' was not declared in this scope
                                IRSendRec.ino:380:24: error: 'struct IRCode::<anonymous>' has no member named 'type'
                                IRSendRec.ino:380:32: error: 'DENON' was not declared in this scope
                                IRSendRec.ino:381:8: error: 'irsend' was not declared in this scope
                                IRSendRec.ino: In function 'void dump(decode_results*)':
                                IRSendRec.ino:403:29: error: 'class decode_results' has no member named 'address'
                                • N Newzwaver
                                  @Newzwaver see @pete1450's post above (5 posts above yours).
                                  • korttomaK
                                    korttomaK
                                    korttoma
                                    Trying to compile the Infrared Sender and Receiver sketch to be used on a WeMos D1 Mini Pro (ESP8266) but I get the following error:
                                    Seems like the saving/reading to/from Eeprom is handled differently when it comes to ESP8266.
                                    So what do I need to change in order to get the sketch to compile?
                                    Sketch:
                                     * Version 1.0 - Changed for MySensors usage by Bart Eversdijk
                                     * Version 1.1 - Added option to record manual presets up to 240
                                     * Version 2.0 - Migrated to MySensrors version 2.0
                                     * IRrecord: record and play back IR signals as a minimal
                                     * An IR detector/demodulator must be connected to the input RECV_PIN.
                                     * An IR LED must be connected to the output PWM pin 3.
                                     * The logic is:
                                     * If a V_IR_RECORD is received the node enters in record mode and once a valid IR message has been received
                                     * it is stored in EEPROM. The first byte of the V_IR_RECORD message will be used as preset ID
                                     * If a V_IR_SEND the IR message beloning to the preset number of the first message byte is broadcasted
                                     * Version 0.11 September, 2009
                                     * Copyright 2009 Ken Shirriff
                                     * http://arcfn.com
                                    // Enable debug prints
                                    #define MY_NODE_ID      5
                                    //#include <IRremote.h>  // https://github.com/z3t0/Arduino-IRremote/releases
                                    // OR install IRRemote via "Sketch" -> "Include Library" -> "Manage Labraries..."
                                    // Search for IRRemote b shirif and press the install button
                                    #include <IRremoteESP8266.h>  // From https://github.com/markszabo/IRremoteESP8266/
                                    #include <IRsend.h>  // Needed if you want to send IR commands.
                                    #include <IRrecv.h>  // Needed if you want to receive IR commands.
                                    #include <IRutils.h>
                                    // Define IR pins
                                    uint16_t SEND_PIN = D1; //an IR LED is connected to D1
                                    uint16_t RECV_PIN = D4; //an IR detector/demodulator is connected to D4
                                    // Arduino pin to connect the IR receiver to
                                    //int RECV_PIN     = 8;
                                    //int SEND_PIN     = 3;
                                    #define CHILD_ID  2
                                    #define MY_RAWBUF  50
                                    const char * TYPE2STRING[] = {
                                        "UNKONWN",
                                        "RC5",
                                        "RC6",
                                        "NEC",
                                        "Sony",
                                        "Panasonic",
                                        "JVC",
                                        "SAMSUNG",
                                        "Whynter",
                                        "AIWA RC T501",
                                        "LG",
                                        "Sanyo",
                                        "Mitsubishi",
                                        "Dish",
                                        "Sharp",
                                        "Denon"
                                    #define Type2String(x)   TYPE2STRING[x < 0 ? 0 : x]
                                    #define AddrTxt          F(" addres: 0x")
                                    #define ValueTxt         F(" value: 0x")
                                    #define NATxt            F(" - not implemented/found")
                                    // Raw or unknown codes requires an Arduino with a larger memory like a MEGA and some changes to store in EEPROM (now max 255 bytes)
                                    // #define IR_SUPPORT_UNKNOWN_CODES
                                    typedef union
                                      struct
                                        decode_type_t type;            // The type of code
                                        uint32_t      value;           // The data bits if type is not raw
                                        uint8_t      len;             // The length of the code in bits
                                        uint8_t      address;         // Used by Panasonic & Sharp [16-bits]
                                      } code;
                                    #ifdef IR_SUPPORT_UNKNOWN_CODES
                                      struct
                                        uint16_t  codes[MY_RAWBUF];
                                        byte          count;           // The number of interval samples
                                      } raw;
                                    } IRCode;
                                    #define           MAX_STORED_IR_CODES     10
                                    IRCode            StoredIRCodes[MAX_STORED_IR_CODES];
                                    IRrecv            irrecv(RECV_PIN);
                                    IRsend            irsend(SEND_PIN);
                                    decode_results    ircode;
                                    #define           NO_PROG_MODE 0xFF
                                    byte              progModeId       = NO_PROG_MODE;
                                    // Manual Preset IR values -- these are working demo values
                                    // VERA call: luup.call_action("urn:schemas-arduino-cc:serviceId:ArduinoIr1", "SendIrCode", {Index=15}, <device number>)
                                    // One can add up to 240 preset codes (if your memory lasts) to see to correct data connect the Arduino with this plug in and
                                    // look at the serial monitor while pressing the desired RC button
                                    IRCode PresetIRCodes[] = {
                                        { { RC5, 0x01,       12, 0 }},  // 11 - RC5 key "1"
                                        { { RC5, 0x02,       12, 0 }},  // 12 - RC5 key "2"
                                        { { RC5, 0x03,       12, 0 }},  // 13 - RC5 key "3"
                                        { { NEC, 0xFF30CF,   32, 0 }},  // 14 - NEC key "1"
                                        { { NEC, 0xFF18E7,   32, 0 }},  // 15 - NEC key "2"
                                        { { NEC, 0xFF7A85,   32, 0 }},  // 16 - NEC key "3"
                                        { { NEC, 0xFF10EF,   32, 0 }},  // 17 - NEC key "4"
                                        { { NEC, 0xFF38C7,   32, 0 }},  // 18 - NEC key "5"
                                        { { RC6, 0x800F2401, 36, 0 }},  // 19 - RC6 key "1" MicroSoft Mulitmedia RC
                                        { { RC6, 0x800F2402, 36, 0 }}   // 20 - RC6 key "2" MicroSoft Mulitmedia RC
                                    #define MAX_PRESET_IR_CODES  (sizeof(PresetIRCodes)/sizeof(IRCode))
                                    #define MAX_IR_CODES (MAX_STORED_IR_CODES + MAX_PRESET_IR_CODES)
                                    MyMessage msgIrReceive(CHILD_ID, V_IR_RECEIVE);
                                    MyMessage msgIrRecord(CHILD_ID, V_IR_RECORD);
                                      // Tell MYS Controller that we're NOT recording
                                      send(msgIrRecord.set(0));
                                      Serial.println(F("Recall EEPROM settings"));
                                      recallEeprom(sizeof(StoredIRCodes), (byte *)&StoredIRCodes);
                                      // Start the ir receiver
                                      irrecv.enableIRIn();
                                      Serial.println(F("Init done..."));
                                    void presentation ()
                                      sendSketchInfo("IR Rec/Playback", "2.0");
                                      // Register a sensors to gw. Use binary light for test purposes.
                                      present(CHILD_ID, S_IR);
                                      if (irrecv.decode(&ircode)) {
                                          dump(&ircode);
                                          if (progModeId != NO_PROG_MODE) {
                                             // If we are in PROG mode (Recording) store the new IR code and end PROG mode
                                             if (storeRCCode(progModeId)) {
                                                Serial.println(F("Stored "));
                                                // If sucessfull RC decode and storage --> also update the EEPROM
                                                storeEeprom(sizeof(StoredIRCodes), (byte *)&StoredIRCodes);
                                                // Tell MYS Controller that we're done recording
                                             // If we are in Playback mode just tell the MYS Controller we did receive an IR code
                                             if (ircode.decode_type != UNKNOWN) {
                                                 if (ircode.value != REPEAT) {
                                                   // Look if we found a stored preset 0 => not found
                                                   byte num = lookUpPresetCode(&ircode);
                                                   if (num) {
                                                       // Send IR decode result to the MYS Controller
                                                       Serial.print(F("Found code for preset #"));
                                                       Serial.println(num);
                                                       send(msgIrReceive.set(num));
                                        // Wait a while before receive next IR-code (also block MySensors receiver so it will not interfere with a new message)
                                        delay(500);
                                        // Start receiving again
                                        irrecv.resume();
                                        //Serial.print(F("New message: "));
                                        //Serial.println(message.type);
                                       if (message.type == V_IR_RECORD) { // IR_RECORD V_VAR1
                                          // Get IR record requets for index : paramvalue
                                          progModeId = message.getByte() % MAX_STORED_IR_CODES;
                                          // Tell MYS Controller that we're now in recording mode
                                          send(msgIrRecord.set(1));
                                          Serial.print(F("Record new IR for: "));
                                          Serial.println(progModeId);
                                       if (message.type == V_IR_SEND) {
                                          // Send an IR code from offset: paramvalue - no check for legal value
                                          Serial.print(F("Send IR preset: "));
                                          byte code = message.getByte() % MAX_IR_CODES;
                                          if (code == 0) {
                                            code = MAX_IR_CODES;
                                          Serial.print(code);
                                          sendRCCode(code);
                                       // Start receiving ir again...
                                    byte lookUpPresetCode (decode_results *ircode)
                                        // Get rit of the RC5/6 toggle bit when looking up
                                        if (ircode->decode_type == RC5)  {
                                            ircode->value = ircode->value & 0x7FF;
                                        if (ircode->decode_type == RC6)  {
                                            ircode->value = ircode->value & 0xFFFF7FFF;
                                        for (byte index = 0; index < MAX_STORED_IR_CODES; index++)
                                          if ( StoredIRCodes[index].code.type  == ircode->decode_type &&
                                               StoredIRCodes[index].code.value == ircode->value       &&
                                               StoredIRCodes[index].code.len   == ircode->bits)      {
                                              // The preset number starts with 1 so the last is stored as 0 -> fix this when looking up the correct index
                                              return (index == 0) ? MAX_STORED_IR_CODES : index;
                                        for (byte index = 0; index < MAX_PRESET_IR_CODES; index++)
                                          if ( PresetIRCodes[index].code.type  == ircode->decode_type &&
                                               PresetIRCodes[index].code.value == ircode->value       &&
                                               PresetIRCodes[index].code.len   == ircode->bits)      {
                                              return ((index == 0) ? MAX_PRESET_IR_CODES : index) + MAX_STORED_IR_CODES;
                                        // not found so return 0
                                        return 0;
                                    // Stores the code for later playback
                                    bool storeRCCode(byte index) {
                                      if (ircode.decode_type == UNKNOWN) {
                                          Serial.println(F("Received unknown code, saving as raw"));
                                          // To store raw codes:
                                          // Drop first value (gap)
                                          // As of v1.3 of IRLib global values are already in microseconds rather than ticks
                                          // They have also been adjusted for overreporting/underreporting of marks and spaces
                                          byte rawCount = min(ircode.rawlen - 1, MY_RAWBUF);
                                          for (int i = 1; i <= rawCount; i++) {
                                            StoredIRCodes[index].raw.codes[i - 1] = ircode.rawbuf[i]; // Drop the first value
                                          return true;
                                          return false;
                                       if (ircode.value == REPEAT) {
                                           // Don't record a NEC repeat value as that's useless.
                                           Serial.println(F("repeat; ignoring."));
                                           return false;
                                       // Get rit of the toggle bit when storing RC5/6
                                       if (ircode.decode_type == RC5)  {
                                            ircode.value = ircode.value & 0x07FF;
                                       if (ircode.decode_type == RC6)  {
                                            ircode.value = ircode.value & 0xFFFF7FFF;
                                       StoredIRCodes[index].code.type      = ircode.decode_type;
                                       StoredIRCodes[index].code.value     = ircode.value;
                                       StoredIRCodes[index].code.address   = ircode.address;      // Used by Panasonic & Sharp [16-bits]
                                       StoredIRCodes[index].code.len       = ircode.bits;
                                       Serial.print(F(" value: 0x"));
                                       //Serial.println(ircode.value, HEX);
                                       return true;
                                    void sendRCCode(byte index) {
                                       IRCode *pIr = ((index <= MAX_STORED_IR_CODES) ? &StoredIRCodes[index % MAX_STORED_IR_CODES] : &PresetIRCodes[index - MAX_STORED_IR_CODES - 1]);
                                       if(pIr->code.type == UNKNOWN) {
                                          // Assume 38 KHz
                                          irsend.sendRaw(pIr->raw.codes, pIr->raw.count, 38);
                                          Serial.println(F("Sent raw"));
                                          return;
                                       Serial.print(F(" - sent "));
                                       Serial.print(Type2String(pIr->code.type));
                                       if (pIr->code.type == RC5) {
                                           // For RC5 and RC6 there is a toggle bit for each succesor IR code sent alway toggle this bit, needs to repeat the command 3 times with 100 mS pause
                                           pIr->code.value ^= 0x0800;
                                           for (byte i=0; i < 3; i++) {
                                             if (i > 0) { delay(100); }
                                             irsend.sendRC5(pIr->code.value, pIr->code.len);
                                        else if (pIr->code.type == RC6) {
                                           if (pIr->code.len == 20) {
                                                  pIr->code.value ^= 0x10000;
                                             irsend.sendRC6(pIr->code.value, pIr->code.len);
                                       else if (pIr->code.type == NEC) {
                                           irsend.sendNEC(pIr->code.value, pIr->code.len);
                                        else if (pIr->code.type == SONY) {
                                           irsend.sendSony(pIr->code.value, pIr->code.len);
                                        else if (pIr->code.type == PANASONIC) {
                                           irsend.sendPanasonic(pIr->code.address, pIr->code.value);
                                           Serial.print(AddrTxt);
                                           Serial.println(pIr->code.address, HEX);
                                        else if (pIr->code.type == JVC) {
                                           irsend.sendJVC(pIr->code.value, pIr->code.len, false);
                                        else if (pIr->code.type == SAMSUNG) {
                                           irsend.sendSAMSUNG(pIr->code.value, pIr->code.len);
                                        else if (pIr->code.type == WHYNTER) {
                                           irsend.sendWhynter(pIr->code.value, pIr->code.len);
                                        else if (pIr->code.type == AIWA_RC_T501) {
                                           irsend.sendAiwaRCT501(pIr->code.value);
                                        else if (pIr->code.type == LG || pIr->code.type == SANYO || pIr->code.type == MITSUBISHI) {
                                           Serial.println(NATxt);
                                           return;
                                        else if (pIr->code.type == DISH) {
                                          // need to repeat the command 4 times with 100 mS pause
                                          for (byte i=0; i < 4; i++) {
                                               irsend.sendDISH(pIr->code.value, pIr->code.len);
                                        else if (pIr->code.type == SHARP) {
                                           irsend.sendSharp(pIr->code.address, pIr->code.value);
                                        else if (pIr->code.type == DENON) {
                                           irsend.sendDenon(pIr->code.value, pIr->code.len);
                                        else {
                                          // No valid IR type, found it does not make sense to broadcast
                                          return;
                                        Serial.print(" ");
                                        Serial.println(pIr->code.value, HEX);
                                    // Dumps out the decode_results structure.
                                    void dump(decode_results *results) {
                                        int count = results->rawlen;
                                        Serial.print(F("Received : "));
                                        Serial.print(results->decode_type, DEC);
                                        Serial.print(F(" "));
                                        Serial.print(Type2String(results->decode_type));
                                        if (results->decode_type == PANASONIC) {
                                          Serial.print(results->address,HEX);
                                          Serial.print(ValueTxt);
                                        //Serial.print(results->value, HEX);
                                        Serial.print(F(" ("));
                                        Serial.print(results->bits, DEC);
                                        Serial.println(F(" bits)"));
                                        if (results->decode_type == UNKNOWN) {
                                          Serial.print(F("Raw ("));
                                          Serial.print(count, DEC);
                                          Serial.print(F("): "));
                                          for (int i = 0; i < count; i++) {
                                            if ((i % 2) == 1) {
                                              Serial.print(results->rawbuf[i]*USECPERTICK, DEC);
                                            else {
                                              Serial.print(-(int)results->rawbuf[i]*USECPERTICK, DEC);
                                            Serial.print(" ");
                                          Serial.println("");
                                    // Store IR record struct in EEPROM
                                    void storeEeprom(byte len, byte *buf)
                                        saveState(0, len);
                                        for (byte i = 1; i < min(len, 100); i++, buf++)
                                           saveState(i, *buf);
                                    void recallEeprom(byte len, byte *buf)
                                        if (loadState(0) != len)
                                           Serial.print(F("Corrupt EEPROM preset values and Clear EEPROM"));
                                               *buf = 0;
                                               storeEeprom(len, buf);
                                           return;
                                           *buf = loadState(i);
                                    Error:
                                    C:\Users\Tomas\Documents\Arduino\WeMosIRRemote\WeMosIRRemote.ino: In function 'void storeEeprom(byte, byte*)':
                                    WeMosIRRemote:444: error: 'min' was not declared in this scope
                                    C:\Users\Tomas\Documents\Arduino\WeMosIRRemote\WeMosIRRemote.ino:444:38: note: suggested alternative:
                                    In file included from c:\users\tomas\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits\char_traits.h:39:0,
                                                     from c:\users\tomas\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\string:40,
                                                     from c:\users\tomas\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\stdexcept:39,
                                                     from c:\users\tomas\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\array:38,
                                                     from c:\users\tomas\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\tuple:39,
                                                     from c:\users\tomas\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\functional:55,
                                                     from C:\Users\Tomas\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/Schedule.h:4,
                                                     from C:\Users\Tomas\Documents\Arduino\libraries\MySensors/core/MyMainESP8266.cpp:22,
                                                     from C:\Users\Tomas\Documents\Arduino\libraries\MySensors/MySensors.h:340,
                                                     from C:\Users\Tomas\Documents\Arduino\WeMosIRRemote\WeMosIRRemote.ino:54:
                                    c:\users\tomas\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algobase.h:239:5: note:   'std::min'
                                         min(const _Tp& __a, const _Tp& __b, _Compare __comp)
                                    C:\Users\Tomas\Documents\Arduino\WeMosIRRemote\WeMosIRRemote.ino: In function 'void recallEeprom(byte, byte*)':
                                    WeMosIRRemote:455: error: 'min' was not declared in this scope
                                    C:\Users\Tomas\Documents\Arduino\WeMosIRRemote\WeMosIRRemote.ino:455:41: note: suggested alternative:
                                    WeMosIRRemote:462: error: 'min' was not declared in this scope
                                    C:\Users\Tomas\Documents\Arduino\WeMosIRRemote\WeMosIRRemote.ino:462:38: note: suggested alternative:
                                    exit status 1
                                    • Tomas
                                    • P
                                      P
                                      pjjarzembowski
                                      This sketch does't work. I have tried it with arduino nano and arduino mega. It works only as a ir reader with monitor.
                                      • P
                                        P
                                        pjjarzembowski
                                        In this code domoticz says that there is a problem with presenting the child. I have change the code in order to present it properly in domoticz.
                                        //MyMessage msgIrReceive(CHILD_ID, V_IR_RECEIVE);
                                        //MyMessage msgIrRecord(CHILD_ID, V_IR_RECORD);
                                        MyMessage msgIrReceive(CHILD_ID, S_IR);
                                        MyMessage msgIrRecord(CHILD_ID, S_IR);
                                        All dependencys of V_IR_RECEIVE and V_IR_RECORD should also be changed. Just search the code for V_IR_RECEIVE and V_IR_RECORD, then replace it with S_IR.
                                          Mash
                                          I am having trouble doing IRSensor with domoticz.
                                          After pouring the scketch into the arduino, saved my codes and
                                          to check that it worked well with MYSController, here's what
                                          I obey when I activate the device under Domoticz:
                                          "error sending command to the switch, please verify device/hardware"
                                          My material in place:
                                          Domoticz V. 3.8153 sur Raspberry PI 3
                                          Gateway USB MySensor V. 2.1.1 on Arduino Nano
                                          IRSensor V. 2.0.0 on Arduino Nano
                                          For information in the domoticz log:
                                          -The node is well detected
                                          2017-12-28 09:07:12.553 MySensors: Node: 7, Sketch Name: IR Rec/Playback
                                          2017-12-28 09:07:12.554 MySensors: Node: 7, Sketch Version: 2.0
                                          -When I send a pre-recorded order with the remote control
                                          2017-12-28 09:07:59.346 (MySensor) Light/Switch (IR Command)
                                          -When I activate the device in Domoticz
                                          2017-12-28 09:08:29.835 User: Admin initiated a switch command (149/IR Command/Off)
                                          2017-12-28 09:08:29.836 Error: MySensors: Light command received for unknown node_id: 6
                                          Someone would have any idea?
                                          Thanks for your help.
                                          Mash
                                          sorry for my English
