  3. Motion detector with temperature and barometer function
temperaturepressuremotion sensor
1 Posts 1 Posters 1.9k Views 1 Watching
  • bgunnarbB
    bgunnarbB
    bgunnarb
    I have built an intrusion detector that also measures barometer pressure and indoor and outdoor temperatures.
    The pressure and indoor temperature is measured by a BMP280 and a number of DS18B20 sensors can be connected to measure the temperature in remote locations.
    When movement is detected two red LEDs flash during 20 sec.
    Everything is built into a frightening wooden mask, bought in Indonesia. The LEDs poke out through the nostrils.
    Here is the sketch:
     * File name: MotionSensor_LED_2_temp_baro_280
     * Version 1.0 - Henrik Ekblad
     * Version 2.1 - Gunnar Blockmar includes PMB280 temp/baro sensor and DS18B20 temp sensor
     * Now with 1 fading LEDs when sensor is triggered
     * Measuring temp and pressure with BMP 280. Local pressure
     * Measuring remote temp via DS18B20
    #include <Adafruit_BMP280.h>
    #include <Adafruit_Sensor.h>
    #include <OneWire.h>
    unsigned long SLEEP_TIME = 60000; // Sleep time between reports (in milliseconds)
    #define CHILD_ID_MOT 0   // Id of the motion sensor child
    #define CHILD_ID_ITEMP 1  // Id of indoor temperature sensor
    #define CHILD_ID_BARO 2  // Id of pressure sensor
    #define CHILD_ID_OTEMP 3  // Id of outdoor temperature sensor
    #define RED_LED 5    // Pin for LED
    #define RED_LED2 6  // Pin for LED2
    #define DELAY 40     // Wait for brightness change
    int fadeAmount = 5;   // brightness change per step
    #define ONE_WIRE_BUS 2 // Pin where dallas sensor is connected
    int numSensors=0;
    bool receivedConfig = false;
    const char *weather[] = { "Stabilt", "Bättre", "Sämre", "Ostadigt", "Åska!", "Okänt" };
    enum FORECAST
      STABLE = 0,     // "Stable Weather Pattern"
      SUNNY = 1,      // "Slowly rising Good Weather", "Clear/Sunny "
      CLOUDY = 2,     // "Slowly falling L-Pressure ", "Cloudy/Rain "
      UNSTABLE = 3,   // "Quickly rising H-Press",     "Not Stable"
      THUNDERSTORM = 4, // "Quickly falling L-Press",    "Thunderstorm"
      UNKNOWN = 5     // "Unknown (More Time needed)
    Adafruit_BMP280 bmp;      // Digital Pressure Sensor
    float lastPressure = -1;
    float lastTemp = -1;
    int lastForecast = -1;
    const int LAST_SAMPLES_COUNT = 5;
    float lastPressureSamples[LAST_SAMPLES_COUNT];
    // this CONVERSION_FACTOR is used to convert from Pa to kPa in forecast algorithm
    // get kPa/h by dividing hPa by 10
    #define CONVERSION_FACTOR (1.0/10.0)
    int minuteCount = 0;
    bool firstRound = true;
    // average value is used in forecast algorithm.
    float pressureAvg;
    // average after 2 hours is used as reference value for the next iteration.
    float pressureAvg2;
    float dP_dt;
    // #define MY_DEBUG
    #define MY_NODE_ID 41
    // Initialize motion message
    MyMessage msgm(CHILD_ID_MOT, V_TRIPPED);
    // Initialize temp baro and forecast messages
    MyMessage msgit(CHILD_ID_ITEMP, V_TEMP);
    MyMessage msgp(CHILD_ID_BARO, V_PRESSURE);
    MyMessage forecastMsg(CHILD_ID_BARO, V_FORECAST);
    MyMessage msgot(0, V_TEMP);
    bool metric = true;
    void before()
      sensors.begin();
      pinMode(RED_LED, OUTPUT);   // sets the pin for the LEDs as output
      pinMode(RED_LED2, OUTPUT);
      analogWrite(RED_LED, 0);    // make sure LEDs are OFF
      analogWrite(RED_LED2, 0);
      bmp.begin();
      if (!bmp.begin())
        Serial.println("Could not find a valid BMP280 sensor, check wiring!");
        while (1) {}
      sendSketchInfo("M. Sens_LED_2t/b/f 280", "2.2");
      present(CHILD_ID_MOT, S_MOTION);
      present(CHILD_ID_ITEMP, S_TEMP);
      present(CHILD_ID_BARO, S_BARO);
         present(i+CHILD_ID_OTEMP, S_TEMP);
      // Read digital motion value
      Serial.println(tripped);
      send(msgm.set(tripped?"1":"0"));  // Send tripped value to gw
      if (tripped) {
       int brightness = 0;   // brightness of LED
       int count = 0;  // number of half cycles to fade LED
       while (count < 12) {    // run 6 full fade cycles
          analogWrite(RED_LED, brightness);
          analogWrite(RED_LED2, brightness);
          brightness = brightness + fadeAmount;
          if (brightness == 0 || brightness == 255) {
            fadeAmount = -fadeAmount;  // change direction of fade
            count ++;
          wait (DELAY);  //wait to see brightness change
        analogWrite(RED_LED, 0);  // turn off LEDs
      int long pressure = bmp.readPressure() / 100;
      float temperature = bmp.readTemperature();
      int forecast = sample(pressure);
      send(msgit.set(temperature, 1));
      send(msgp.set(pressure, 0));
      send(forecastMsg.set(weather[forecast]));
      sleep (750);
      float otemperature = static_cast<float>(static_cast<int>((sensors.getTempCByIndex(i)) * 10.)) / 10.;
      // Only send data if no error
      if (otemperature != -127.00 && otemperature != 85.00) {
          send(msgot.setSensor(i+CHILD_ID_OTEMP).set(otemperature,1));
      // Sleep until interrupt comes in on motion sensor but send update every minute.
      tripped = false;  //reset tripped
      sleep(INTERRUPT,CHANGE, SLEEP_TIME);
    float getLastPressureSamplesAverage()
      float lastPressureSamplesAverage = 0;
      for (int i = 0; i < LAST_SAMPLES_COUNT; i++)
        lastPressureSamplesAverage += lastPressureSamples[i];
      lastPressureSamplesAverage /= LAST_SAMPLES_COUNT;
      return lastPressureSamplesAverage;
    // Algorithm found here
    // Pressure in hPa -->  forecast done by calculating kPa/h
    int sample(float pressure)
      // Calculate the average of the last n minutes.
      int index = minuteCount % LAST_SAMPLES_COUNT;
      lastPressureSamples[index] = pressure;
      minuteCount++;
      if (minuteCount > 185)
        minuteCount = 6;
      if (minuteCount == 5)
        pressureAvg = getLastPressureSamplesAverage();
      else if (minuteCount == 35)
        float lastPressureAvg = getLastPressureSamplesAverage();
        float change = (lastPressureAvg - pressureAvg) * CONVERSION_FACTOR;
          dP_dt = change * 2; // note this is for t = 0.5hour
          dP_dt = change / 1.5; // divide by 1.5 as this is the difference in time from 0 value.
      else if (minuteCount == 65)
          dP_dt = change; //note this is for t = 1 hour
          dP_dt = change / 2; //divide by 2 as this is the difference in time from 0 value
      else if (minuteCount == 95)
          dP_dt = change / 1.5; // note this is for t = 1.5 hour
          dP_dt = change / 2.5; // divide by 2.5 as this is the difference in time from 0 value
      else if (minuteCount == 125)
        pressureAvg2 = lastPressureAvg; // store for later use.
          dP_dt = change / 2; // note this is for t = 2 hour
          dP_dt = change / 3; // divide by 3 as this is the difference in time from 0 value
      else if (minuteCount == 155)
          dP_dt = change / 2.5; // note this is for t = 2.5 hour
          dP_dt = change / 3.5; // divide by 3.5 as this is the difference in time from 0 value
      else if (minuteCount == 185)
          dP_dt = change / 3; // note this is for t = 3 hour
          dP_dt = change / 4; // divide by 4 as this is the difference in time from 0 value
        pressureAvg = pressureAvg2; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
      int forecast = UNKNOWN;
        forecast = UNKNOWN;
      else if (dP_dt < (-0.25))
        forecast = THUNDERSTORM;
      else if (dP_dt > 0.25)
        forecast = UNSTABLE;
        forecast = CLOUDY;
        forecast = SUNNY;
      else if ((dP_dt >(-0.05)) && (dP_dt < 0.05))
        forecast = STABLE;
        forecast = UNKNOWN;
      // uncomment when debugging
      //Serial.print(F("Forecast at minute "));
      //Serial.print(minuteCount);
      //Serial.print(F(" dP/dt = "));
      //Serial.print(dP_dt);
      //Serial.print(F("kPa/h --> "));
      return forecast;
    and here are a couple of photos, front and back:
    ![alt text](0_1487498680609_upload-7deee0a5-263a-42b0-989a-55d1aae32cf4 image url)DSC_0669 (1).jpg
    ![alt text](0_1487498717047_upload-cd76f838-04f6-4fab-a4b8-e37823a7419c image url)DSC_0668 (1).jpg
    I have never been so busy since I retired!
