  2. Announcements
  3. 💬 Temperature Sensor
171 Posts 40 Posters 106.8k Views 36 Watching
  • Vincent LgrdV
    Vincent LgrdV
    Vincent Lgrd
    Thanks, my radio modules are very close, they are on the same table for test. On of them may be damaged, I must receive others. I'm going in the troubleshooting section to avoid polluting this article.
    Thanks for your help
      Put them at least 2 meters apart, just to play safe.
      • Vincent LgrdV
        Vincent LgrdV
        Vincent Lgrd
        It's the same, I've even reversed the radio modules
        • D
          dantefff
          @gohan , I'm in the same situation as @Vincent-Lgrd. I'm powering my arduino UNO from usb (to test). Is that a possible problem?
            I use USB pretty much all the time and never had any issue. I had many problems in the beginning with radio modules that had the black blob instead of the ic and once I got the new ones everything started to work. I'm still working on increasing the range, probably because they are clones and not good quality.
            D 1 Reply Last reply
              dantefff
              @gohan I changed my getaway to an old good rpi model b, and the temperature node started to work, so I think that the problem was on de getaway wiring or in the getaway code itsef. Thanks
              • G
                G
                gewoonandre
                Is it also possible to upload the example code to a Arduino Nano, and connect it via USB to a Windows PC with Domoticz?
                Or will it only work with the radio modules (and extra gateway?)
                  I think you can use the serial gateway sketch and the sensor code in setup and loop
                  • C
                    C
                    CurtisMack
                    Thank you for posting this project!
                    Could like to suggest a small change to the sketch. There are several posts out there about this not running with the latest DallasTemperature library. The call to sensors.millisToWaitForConversion won't compile because the method is not public. From another post I learned that this method is very simple and could be included in the sketch. I would suggest changing the line
                    to read
                    int16_t conversionTime = millisToWaitForConversion(sensors.getResolution());
                    and add this function to the sketch:
                    int16_t millisToWaitForConversion(uint8_t bitResolution)
                    switch (bitResolution)
                    case 9:
                    return 94;
                    case 10:
                    return 188;
                    case 11:
                    return 375;
                    default:
                    return 750;
                    In any case, this might help the next person using this project.
                    • WoekaW
                      WoekaW
                      Woeka
                      I had some problems with Domoticz triggering an event based on a certain temperature. When using multiple DS18B20 it is a good idea to use the ID of the sensors to always get the same order of sensors. If one is not read, for example B of A, B, C then C becomes B. See: https://forum.mysensors.org/topic/4143/about-ds18b20-onewire for more info. You maybe need to adjust the sketch a bit for your number of sensors.
                      • R
                        R
                        Rene046
                        @CurtisMack
                        could you explain how to solve this ?
                        I'm no pro, and wanted to use 1 single DS1820 in a sketch and also got same message about :
                        Mysensors is hard hard nut to learn, specially because of a lot of changes in the newer version 2.1.0 ...(and im still learning to work with arduino software , i keep running often against old sketches i like to try as sample to use them in other sketches , (my way of learning) but than they dont work with latest version. because something changed.
                        but i love the mysensors functions.
                        p.s sorry for my bad english....
                        K 1 Reply Last reply
                        • R Rene046
                          @CurtisMack
                          K
                          K
                          kontrollable
                          @Rene046 The solution is here:https://forum.mysensors.org/topic/4828/temperature-sensor/46
                          • R
                            R
                            Rene046
                            I sofar got the sketch running and giving good data on serial and into domoticz
                            i only could use some help with how to sent my Temperature in Celsius to domoticz to
                            i tried to use:
                            send(msgTemp.set(insideThermometer ,2));
                            and
                            send(msgTemp.set(tempC,2));
                            both without luck, the first did transmit some data but wrong numbers
                            second did nothing think because with this i done i does not know what address the DS1820 is on.
                            Im learning every day something new....
                            Maybe someone could help,
                            G 1 Reply Last reply
                            • R
                              R
                              Rene046
                              forgot the sketch
                              #include <BH1750.h>
                              #include <OneWire.h>
                              // Data wire is plugged into port 3 on the Arduino
                              #define ONE_WIRE_BUS 3
                              // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
                              // Pass our oneWire reference to Dallas Temperature.
                              // arrays to hold device address
                              DeviceAddress insideThermometer;
                              unsigned long SLEEP_TIME = 180000; // Sleep time between reads (in milliseconds)
                              int SOLAR_SENSE_PIN = A1;  // select the input pin for the solar sense point
                              #define CHILD_ID_BATTERY 4
                              #define CHILD_ID_SOLAR 6
                              #define CHILD_ID_LIGHT 1
                              #define CHILD_ID_TEMP1 2
                              BH1750 lightSensor;
                              int oldBatteryPcnt = 0;
                              MyMessage msgTemp(CHILD_ID_TEMP1,V_TEMP);
                              MyMessage msgbatt(CHILD_ID_BATTERY, V_VOLTAGE);
                              MyMessage msgsolar(CHILD_ID_SOLAR, V_VOLTAGE);
                              uint16_t lastlux;  //lux
                              void setup(void)
                                analogReference(INTERNAL1V1);
                                analogReference(INTERNAL);
                                sendSketchInfo("Battery Meter", "2.0");
                                //Serial.begin(9600); // start serial port
                                Serial.print("Locating devices..."); // locate devices on the bus
                                sensors.begin(); // start reading sensor
                                Serial.print("Found ");
                                Serial.print(sensors.getDeviceCount(), DEC);
                                Serial.println(" devices.");
                                Serial.print("Parasite power is: "); // report parasite power requirements
                                if (sensors.isParasitePowerMode()) Serial.println("ON");
                                else Serial.println("OFF");
                              // assign address manually.  the addresses below will beed to be changed
                                // to valid device addresses on your bus.  device address can be retrieved
                                // by using either oneWire.search(deviceAddress) or individually via
                                // sensors.getAddress(deviceAddress, index)
                                //insideThermometer = { 0x28, 0x1D, 0x39, 0x31, 0x2, 0x0, 0x0, 0xF0 };
                                // Method 1:
                                // search for devices on the bus and assign based on an index.  ideally,
                                // you would do this to initially discover addresses on the bus and then
                                // use those addresses and manually assign them (see above) once you know
                                // the devices on your bus (and assuming they don't change).
                                if (!sensors.getAddress(insideThermometer, 0)) Serial.println("Unable to find address for Device 0");
                                // method 2: search()
                                // search() looks for the next device. Returns 1 if a new address has been
                                // returned. A zero might mean that the bus is shorted, there are no devices,
                                // or you have already retrieved all of them.  It might be a good idea to
                                // check the CRC to make sure you didn't get garbage.  The order is
                                // deterministic. You will always get the same devices in the same order
                                // Must be called before search()
                                //oneWire.reset_search();
                                // assigns the first address found to insideThermometer
                                //if (!oneWire.search(insideThermometer)) Serial.println("Unable to find address for insideThermometer");
                                // show the addresses we found on the bus
                                Serial.print("Device 0 Address: ");
                                printAddress(insideThermometer);
                                Serial.println();
                                // set the resolution to 9 bit (Each Dallas/Maxim device is capable of several different resolutions)
                                sensors.setResolution(insideThermometer, 9);
                                Serial.print("Device 0 Resolution: ");
                                Serial.print(sensors.getResolution(insideThermometer), DEC);
                                Serial.println();
                              // function to print the temperature for a device
                              void printTemperature(DeviceAddress deviceAddress)
                                // method 1 - slower
                                //Serial.print("Temp C: ");
                                //Serial.print(sensors.getTempC(deviceAddress));
                                //Serial.print(" Temp F: ");
                                //Serial.print(sensors.getTempF(deviceAddress)); // Makes a second call to getTempC and then converts to Fahrenheit
                                // method 2 - faster
                                float tempC = sensors.getTempC(deviceAddress);
                                Serial.print(tempC);
                                Serial.println(DallasTemperature::toFahrenheit(tempC)); // Converts tempC to Fahrenheit
                              void loop(void)
                                // call sensors.requestTemperatures() to issue a global temperature
                                // request to all devices on the bus
                                Serial.print("Requesting temperatures...");
                                sensors.requestTemperatures(); // Send the command to get temperatures
                                Serial.println("DONE");
                                // It responds almost immediately. Let's print out the data
                                printTemperature(insideThermometer); // Use a simple function to print out the data
                               // get the battery Voltage
                                int sensorValue2 = analogRead(BATTERY_SENSE_PIN);
                                delay(1000);
                                int sensorValue1 = analogRead(BATTERY_SENSE_PIN);
                                delay(100);
                                delay(1000);
                                int sensorValueS = analogRead(SOLAR_SENSE_PIN);
                                delay(1000);
                              #ifdef MY_DEBUG
                                Serial.print("Battery Voltage2: ");
                                Serial.println(sensorValue2);
                                Serial.print("Battery Voltage1: ");
                                Serial.println(sensorValue1);
                                Serial.println(sensorValue);
                                Serial.print("Solar Voltage: ");
                                Serial.println(sensorValueS);
                                const float vRef = 4.200/ 1.05/ 1023 ;
                                float batteryV  = sensorValue * 0.0042598 ; // 0.0038952294568380753114792412093 max 4,2 volt
                                float batteryS  = sensorValueS * 0.0102459 ; // 0.0038952294568380753114792412093 max 10 volt
                              #ifdef MY_DEBUG
                                Serial.print(batteryV);
                                Serial.println(" V");
                              send(msgbatt.set(batteryV ,2));
                                Serial.print(batteryS);
                              send(msgsolar.set(batteryS ,2));
                                Serial.print(batteryPcnt);
                                Serial.println(" %");
                                  // Power up radio after sleep
                                  oldBatteryPcnt = batteryPcnt;
                                Serial.println(lux);
                                if (lux != lastlux) {
                                    send(msg.set(lux));
                                    lastlux = lux;
                                sleep(SLEEP_TIME);
                              // function to print a device address
                              void printAddress(DeviceAddress deviceAddress)
                                for (uint8_t i = 0; i < 8; i++)
                                  if (deviceAddress[i] < 16) Serial.print("0");
                                  Serial.print(deviceAddress[i], HEX);
                              C 1 Reply Last reply
                              • R Rene046
                                forgot the sketch
                                #include <BH1750.h>
                                BH1750 lightSensor;
                                void setup(void)
                                  // Method 1:
                                  Serial.println();
                                  Serial.println();
                                void loop(void)
                                  delay(1000);
                                  delay(100);
                                  delay(1000);
                                  delay(1000);
                                #ifdef MY_DEBUG
                                #ifdef MY_DEBUG
                                      send(msg.set(lux));
                                      lastlux = lux;
                                  sleep(SLEEP_TIME);
                                C
                                C
                                CurtisMack
                                @Rene046 Your sketch doesn't show either of the send commands you say you are attempting. This makes it difficult to determine why it wouldn't be working. I am relative new to all of this as well, and use Vera not a Domoticz. On the first version that is sending a message, what data is getting through? I would try putting the "send" command someplace in the code where msgTemp has already been set. Then just call send(msgTemp).
                                • R
                                  R
                                  Rene046
                                  hi
                                  Then i would have placed this in the loop>
                                  The error i get then is :'TempC' was not declared in this scope
                                  #ifdef MY_DEBUG
                                  Serial.print("DS1820 Temperature: ");
                                    Serial.println(" C");
                                  send(msgTemp.set(tempC ,2));
                                  send(msgbatt.set(batteryV ,2));```
                                  • R
                                    R
                                    Rene046
                                    so far my result.
                                    had to use float TempC = 50.5 at the start
                                    but in my serial i get the right temperature,
                                    but using it in the loop gives me still wrong number 50.5 so gets not updated.
                                    #include <BH1750.h>
                                    BH1750 lightSensor;
                                    float TempC = 50.5;
                                    void setup(void)
                                      //insideThermometer = { 0x10, 0x9C, 0x04, 0x26, 0x01, 0x08, 0x0, 0x8C };
                                      // Method 1:
                                      Serial.println();
                                      Serial.println();
                                      float TempC = sensors.getTempC(deviceAddress);
                                      Serial.print(TempC);
                                      Serial.println(DallasTemperature::toFahrenheit(TempC)); // Converts tempC to Fahrenheit
                                    void loop(void)
                                      delay(1000);
                                      delay(100);
                                      delay(1000);
                                      delay(1000);
                                    #ifdef MY_DEBUG
                                    #ifdef MY_DEBUG
                                    send(msgTemp.set(TempC ,2));
                                          send(msg.set(lux));
                                          lastlux = lux;
                                      sleep(SLEEP_TIME);
                                    • R
                                      R
                                      Rene046
                                      here is my serial result.
                                      45651 MCO:SLP:WUP=-1
                                      Temp C: 17.87 Temp F: 64.18
                                      Battery Voltage2: 931
                                      Battery Voltage1: 926
                                      Battery Voltage: 927
                                      Solar Voltage: 393
                                      DS1820 Temperature: 50.50 C
                                      49545 TSF:MSG:SEND,2-2-0-0,s=2,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:50.50
                                      Battery Voltage: 3.95 V
                                      49557 TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.95
                                      Solar Voltage: 4.03 V
                                      49569 TSF:MSG:SEND,2-2-0-0,s=6,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:4.03
                                      Battery percent: 92 %
                                      49577 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                      49584 MCO:SLP:TPD
                                      • R
                                        R
                                        Rene046
                                        i dont know how but i got it now running perfect, and cleaned up a bid.
                                        for if anyone could use ....
                                        #include <BH1750.h>
                                        BH1750 lightSensor;
                                        float TempC = 50.5;
                                        MyMessage msgTempC(CHILD_ID_TEMP1,V_TEMP);
                                        void setup(void)
                                          //sensors.setResolution(insideThermometer, 9);
                                        void loop(void)
                                          delay(1000);
                                          delay(100);
                                          delay(1000);
                                          delay(1000);
                                        #ifdef MY_DEBUG
                                          float TempC = sensors.getTempC(insideThermometer);
                                        #ifdef MY_DEBUG
                                        send(msgTempC.set(TempC ,2));
                                              send(msg.set(lux));
                                              lastlux = lux;
                                          sleep(SLEEP_TIME);
                                        • CptSlowC
                                          CptSlowC
                                          CptSlow
                                          Can someone push me into the right direction.
                                          I followed the "tutorial" and setup a Serial Gateway. This seems to be running just fine.
                                          Now i want to add a node with a temperature sensor.
                                          Both are using the NRF24L radio.
                                          On my node i get an errors in the serial monitor.
                                          What did i do wrong?
                                          3 MCO:BGN:BFR
                                          63 TSM:INIT
                                          64 TSF:WUR:MS=0
                                          71 !TSM:INIT:TSP FAIL
                                          72 TSM:FAIL:CNT=1
                                          74 TSM:FAIL:PDT
                                          10077 TSM:FAIL:RE-INIT
                                          10079 TSM:INIT
                                          10085 !TSM:INIT:TSP FAIL
                                          10088 TSM:FAIL:CNT=2
                                          10089 TSM:FAIL:PDT
