  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 676.6k Views 99 Watching
  • A
    Andrew Currie
    Further to my client ethernet gateway not working with the MySensors 2.1.1 library, I tried 2.0.0 and now go much further. The gateway does not keep restarting, talks to the openhab controller and at least reads the messages and tripped status from my motion sensor
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    IP: 192.168.1.9
    0;255;3;0;9;TSP:MSG:READ 1-1-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
    0;255;3;0;9;TSP:MSG:READ 1-1-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
    0;255;3;0;9;TSP:SANCHK:OK```
    I had to turn on the skipStartupCheck for the ethernet gateway to come online in openhab (and the gateway serial monitor did show the 0;0;3;0;2; and ethernet messages between openhab and the gateway)
    15:10:13.316 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Connecting to IP bridge [192.168.1.9:5003]
    15:10:13.819 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
    15:10:14.320 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
    15:10:15.320 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
    15:10:16.320 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
    15:10:17.321 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
    15:10:18.321 [ERROR] [al.protocol.ip.MySensorsIpConnection] - Cannot start reading/writing thread, probably sync message (I_VERSION) not received. Try set skipStartupCheck to true
    15:10:18.322 [ERROR] [al.protocol.ip.MySensorsIpConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:1)
    15:10:18.322 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Disconnecting from IP bridge ...
    15:10:18.323 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Stopping Writer thread
    15:10:18.324 [DEBUG] [rs.internal.protocol.MySensorsReader] - Stopping Reader thread
    15:10:18.324 [ERROR] [rs.internal.protocol.MySensorsWriter] - (java.lang.InterruptedException) on writing to connection, message: class org.openhab.binding.mysensors.internal.protocol.ip.MySensorsIpWriter
    15:10:18.325 [ERROR] [rs.internal.protocol.MySensorsReader] - (java.lang.InterruptedException: sleep interrupted) on reading from connection, message: class org.openhab.binding.mysensors.internal.protocol.ip.MySensorIpReader
    15:10:25.236 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Disposing of the MySensors bridge
    15:10:25.236 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Destroying connection
    15:10:25.236 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
    15:10:25.237 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache (given_ids) content: [1]
    15:10:25.237 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: [1]
    15:10:25.239 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
    15:10:25.239 [INFO ] [smarthome.event.ThingUpdatedEvent   ] - Thing 'mysensors:bridge-eth:cb1d6dd1' has been updated.
    15:10:25.240 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Set skip check on startup to: true
    15:10:25.240 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Enabling connection watchdog
    15:10:25.240 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
    15:10:25.241 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Connecting to IP bridge [192.168.1.9:5003]
    15:10:25.241 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache (given_ids) content: [1]
    15:10:25.241 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
    15:10:25.244 [WARN ] [al.protocol.ip.MySensorsIpConnection] - Skipping I_VERSION connection test, not recommended...
    15:10:25.244 [INFO ] [al.protocol.ip.MySensorsIpConnection] - Successfully connected to MySensors Bridge.
    I then got my motion sensor to come online in openhab
    15:13:24.300 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: nodeId 1, chiledId: 1, requestAck: false, revertState: false, smartSleep: false
    15:13:24.301 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 1-1 not registered yet, registering...
    15:13:24.305 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:motion:24559d07' changed from INITIALIZING to ONLINE```
    However the motion sensor (via gateway) and openhab controller are not talking to each other. Does skipping the startup check result in problems?
    Any ideas on how to progress with MySensors 2.0.0 library or do I need to wait for a fix to 2.1.1?
    Many Thanks...
    • A Andrew Currie
      @David-Link It looks like you have a similar issue to me re the ethernet gateway. I have also tried "everything" and then yesterday discovered an old bug that might have resurfaced. I just put the following up on github:
      https://github.com/mysensors/MySensors/issues/777
      It might help you..
      David Link
      @Andrew-Currie I think that is the same thing I am dealing with. I will take a look, thank you!
      I "cheated" and just hooked it up to my Pi that is running OpenHab and it works like a charm.
      • A Andrew Currie
        IP: 192.168.1.9
        Many Thanks...
        TimO
        @Andrew-Currie It should make no difference for the binding if you're using 2.0.0 or 2.1.1. I can't see any incoming messages in the debug log you've posted. If the gateway is properly connected you should see messages incoming, for example from your motion sensor. Could you please establish a telnet connection to the gateway at port 5003 and post the output? In parallel check the serial output of the gateway, there you should see the establishment of the telnet connection for example.
        A 1 Reply Last reply
        • T TimO
          Andrew Currie
          @TimO Thanks Tim for your feedback. Here is the log from the gateway. It receives messages from openhab re the ethernet connection and also from the motion sensor and gets a fail from one send
          IP: 192.168.1.9
          0;255;3;0;9;Eth: connect
          0;255;3;0;9;Eth: 0;0;3;0;2;
          0;255;3;0;9;Eth:
          0;255;3;0;9;Eth:
          0;255;3;0;9;Eth:
          0;255;3;0;9;Eth:
          0;255;3;0;9;Eth:
          0;255;3;0;9;Eth: disconnect
          0;255;3;0;9;Eth:
          0;255;3;0;9;Eth:
          0;255;3;0;9;Eth:
          0;255;3;0;9;Eth:
          0;255;3;0;9;Eth:
          0;255;3;0;9;TSP:MSG:READ 1-1-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
          0;255;3;0;9;TSP:MSG:BC
          0;255;3;0;9;TSP:MSG:FPAR REQ (sender=1)
          0;255;3;0;9;TSP:CHKUPL:OK
          0;255;3;0;9;TSP:MSG:GWL OK
          0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
          0;255;3;0;9;TSP:MSG:PINGED (ID=1, hops=1)
          0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
          0;255;3;0;9;!TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=fail:0100
          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=11,pt=0,l=13,sg=0:Motion Sensor
          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=1,c=0,t=1,pt=0,l=0,sg=0:
          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
          0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
          The telnet connection shows no action and the gateway device is on the local network
          $ telnet 192.168.1.9 5003
          Trying 192.168.1.9...
          Connected to 192.168.1.9.
          Escape character is '^]'.
          $ arp -a
          HPB482AF (192.168.1.2) at 28:92:4a:c0:c3:27 [ether] on wlan0
          WIZnet9FFEED (192.168.1.9) at de:ad:b1:9f:fe:ed [ether] on wlan0
          NB604N.Home (192.168.1.1) at 00:60:64:83:50:8b [ether] on wlan0
          HF-LPB100 (192.168.1.12) at f0:fe:6b:16:a1:4a [ether] on wlan0
          I have tried all sorts of ubuntu firewall settings to allow access to and from 192.168.1.9 port 5003 and also looked into the router settings with no joy.
          As another approach I tried the serial gateway and investigated the linux settings given in
          http://docs.openhab.org/installation/linux.html#privileges-for-common-peripherals
          The furthest I got with the serial gateway was as follows, first the debug log at startup and then when creating the gateway thing in the paper ui
          10:07:04.218 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={component.name=org.openhab.binding.mysensors.internal.factory.MySensorsHandlerFactory, component.id=197, service.id=340, service.bundleid=250, service.scope=bundle} - org.openhab.binding.mysensors
          10:07:04.219 [DEBUG] [org.openhab.binding.mysensors       ] - BundleEvent STARTED – org.openhab.binding.mysensors
          10:08:52.520 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=341, service.bundleid=250, service.scope=singleton} – org.openhab.binding.mysensors
          10:08:52.524 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
          10:08:52.526 [DEBUG] [col.serial.MySensorsSerialConnection] - Set skip check on startup to: false
          10:08:52.526 [DEBUG] [col.serial.MySensorsSerialConnection] - Enabling connection watchdog
          10:08:52.527 [DEBUG] [col.serial.MySensorsSerialConnection] - Connecting to ttyUSB1 [baudRate:115200]
          10:08:52.530 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
          10:08:52.531 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache (given_ids) content: []
          10:08:52.532 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
          testRead() open failed: /dev/ttyUSB1
          localClose: File Descriptor error, not closing
          10:08:52.545 [DEBUG] [col.serial.MySensorsSerialConnection] - Final port list: ttyUSB1:/dev/ttyUSB1
          testRead() open failed: ttyUSB1
          Failed to connect on port: ttyUSB1 exception:
          gnu.io.NoSuchPortException
          While my plan was to test on my ubuntu 16.04 laptop, I have gone ahead and ordered a Raspberry pi 3 and intend to install the openhabianpi img file. Hopefully better progress there...
          • B
            B
            balder88
            Hey guys, first message on this forum. Been reading alot before. But now I have a problem I just can't solve.
            It's about smartsleep with openhab 2.
            Im using wifi gw rfm 69.
            Regular messages works as it should both ways.
            But it almost seems like the smartsleep isn't enabled in the binding.
            Here are my configs and logs.
            Things file:
            Bridge mysensors:bridge-eth:gw69 [ ipAddress="192.168.1.235", tcpPort=5003, sendDelay=100, enableNetworkSanCheck=true ] {
            //  Anarduino
                humidity        AnHum   [ nodeId="66", childId="0" ]
                temperature     AnTemp  [ nodeId="66", childId="1" ]
                light           light02 [ nodeId="66", childId="3", smartSleep=true ]
            Items file:
            Switch  TestLight   "Test lampa" (Test) { channel="mysensors:light:gw69:light02:status" }
            Sketch: (Cleaned up the parts that dont matter, RTC and so on.)
            #define MY_RADIO_RFM69
            #define MY_IS_RFM69HW
            #define MY_NODE_ID 66
            #define MY_SMART_SLEEP_WAIT_DURATION_MS 1000
            #include <TimeLib.h>
            #include <MCP7940RTC.h>
            #define MCP7940_CTRL_ID 0x6F
            #define CSMEM_PIN 5
            #define LEDPIN 9
            long sleepIntervalSec=5;
            long loopCnt=0;
            uint8_t d[8];
            uint8_t dAlarm[8];
            int d1[8];
            #define DHT_DATA_PIN 6
            #define SENSOR_TEMP_OFFSET 0
            static const uint64_t UPDATE_INTERVAL = 5000;
            #define CHILD_ID_HUM 0
            #define CHILD_ID_TEMP 1
            #define CHILD_ID_MULTIMETER 2
            float lastTemp;
            float lastHum;
            uint8_t nNoUpdatesTemp;
            uint8_t nNoUpdatesHum;
            bool metric = true;
            MyMessage msgVolt(CHILD_ID_MULTIMETER, V_VOLTAGE);
            DHT dht;
            int oldBatteryPcnt = 0;
            int batteryBasement = 812;
            int batteryFull = 922;
            float batteryConstant = 100.0 / (batteryFull - batteryBasement);
            float lastbatteryV = 0;
            const int buzzer = 7; //buzzer to arduino pin 7
            #define RELAY_1  8  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
            void before()
              for (int sensor=3, pin=RELAY_1; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
                pinMode(pin, OUTPUT);
               analogReference(INTERNAL);
              pinMode(LEDPIN, OUTPUT);
              digitalWrite(LEDPIN, LOW);
              Wire.begin();
              pinMode(CSMEM_PIN, OUTPUT);
              digitalWrite(CSMEM_PIN, HIGH);
              sleepIntervalSec = dht.getMinimumSamplingPeriod();
              clearAlarm();
              delay(20);
              setNewAlarm();
              analogRead(BATTERY_SENSE_PIN);
               sendSketchInfo("Humidity sensor", "1.0");
               present(CHILD_ID_MULTIMETER, S_MULTIMETER, "VOLT", true);
               present(CHILD_ID_HUM, S_HUM, "HUMIDITY", true);
               present(CHILD_ID_TEMP, S_TEMP, "TEMP", true);
                present(sensor, S_BINARY);
              wait(100);
               #ifdef MY_DEBUG
               Serial.println(sensorValue);
               float batteryV  = sensorValue * 0.004551646;
               if(sensorValue < batteryBasement) {
                sensorValue = batteryBasement;
                batteryV = 0;
               else if (sensorValue > batteryFull) {
                sensorValue = batteryFull;
               int batteryPcnt = (sensorValue - batteryBasement) * batteryConstant;
                   if ((abs(oldBatteryPcnt - batteryPcnt) > 1)) {
                  oldBatteryPcnt = batteryPcnt;
               if(batteryV != lastbatteryV) {
               send(msgVolt.set(batteryV, 2));
               lastbatteryV = batteryV;
               #ifdef MY_DEBUG
               Serial.print(batteryV);
               Serial.println(" V");
               Serial.print(batteryPcnt);
               Serial.println(" %");
              dht.readSensor(true);
              if (isnan(temperature)) {
                lastTemp = temperature;
                if (!metric) {
                // Reset no updates counter
                nNoUpdatesTemp = 0;
                #ifdef MY_DEBUG
                Serial.print("T: ");
                nNoUpdatesTemp++;
              if (isnan(humidity)) {
                lastHum = humidity;
                nNoUpdatesHum = 0;
                #ifdef MY_DEBUG
                Serial.print("H: ");
                Serial.println(humidity);
                nNoUpdatesHum++;
            long sleepTime = UPDATE_INTERVAL;
            if (batteryPcnt < 50) {
              sleepTime = (sleepTime * 2);
              sleepIntervalSec = sleepTime / 1000;
              Serial.println();
              Serial.print("Setting new sleep time: ");
              Serial.print(sleepIntervalSec);
              Serial.println(" seconds.");
              clearAlarm();
              delay(20);
              setNewAlarm();
              smartSleep(sleepTime);
              if (message.type==V_STATUS) {
                // Change relay state
                // Store state in eeprom
            Sensor startup:
            3 MCO:BGN:BFR
            4 TSM:INIT
            5 TSF:WUR:MS=0
            8 TSM:INIT:TSP OK
            9 TSM:INIT:STATID=66
            11 TSF:SID:OK,ID=66
            13 TSM:FPAR
            143 TSF:MSG:SEND,66-66-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            524 TSF:MSG:READ,0-0-66,s=255,c=3,t=8,pt=1,l=1,sg=0:0
            529 TSF:MSG:FPAR OK,ID=0,D=1
            2150 TSM:FPAR:OK
            2151 TSM:ID
            2152 TSM:ID:OK
            2154 TSM:UPL
            2161 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
            2181 TSF:MSG:READ,0-0-66,s=255,c=3,t=25,pt=1,l=1,sg=0:1
            2186 TSF:MSG:PONG RECV,HP=1
            2189 TSM:UPL:OK
            2190 TSM:READY:ID=66,PAR=0,DIS=1
            2199 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
            2253 TSF:MSG:READ,0-0-66,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
            2310 TSF:MSG:SEND,66-66-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
            2366 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
            2403 TSF:MSG:READ,0-0-66,s=255,c=3,t=6,pt=0,l=1,sg=0:M
            2461 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=11,pt=0,l=15,sg=0,ft=0,st=OK:Humidity sensor
            2562 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
            2618 TSF:MSG:SEND,66-66-0-0,s=2,c=0,t=30,pt=0,l=4,sg=0,ft=0,st=OK:VOLT
            2757 !TSF:MSG:SEND,66-66-0-0,s=0,c=0,t=7,pt=0,l=8,sg=0,ft=0,st=NACK:HUMIDITY
            2777 TSF:MSG:SEND,66-66-0-0,s=1,c=0,t=6,pt=0,l=4,sg=0,ft=1,st=OK:TEMP
            2912 !TSF:MSG:SEND,66-66-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=NACK:
            2918 MCO:REG:REQ
            2974 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
            2991 TSF:MSG:READ,0-0-66,s=255,c=3,t=27,pt=1,l=1,sg=0:1
            2996 MCO:PIM:NODE REG=1
            2999 MCO:BGN:STP
            3154 MCO:SLP:MS=2000,SMS=0,I1=255,M1=255,I2=255,M2=255
            3160 MCO:SLP:TPD
            3161 MCO:SLP:WUP=-1
            3163 MCO:BGN:INIT OK,TSP=1
            Log Sensor: (This is when I press the button when the sensor is awake)
            It's sends away it's heartbeat correctly.
            125578 TSF:MSG:READ,0-0-66,s=3,c=1,t=2,pt=0,l=1,sg=0:0
            Setting new sleep time: 5 seconds.
            137926 MCO:SLP:MS=5000,SMS=1,I1=255,M1=255,I2=255,M2=255
            137939 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:134932
            Log Openhab: And the gateway receives heartbeat.
            18:21:37.174 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 66;3;1;0;2;0
            18:21:37.178 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'TestLight' received command OFF
            18:21:37.181 [INFO ] [marthome.event.ItemStateChangedEvent] - TestLight changed from ON to OFF
            18:22:15.416 [DEBUG] [rs.internal.protocol.MySensorsReader] - 66;255;3;0;22;134932
            18:22:16.372 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
            18:22:16.408 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;2;2.1.1
            Log Openhab: When the node sleeps..
            18:26:52.396 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 66;3;1;0;2;0
            18:26:52.397 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'TestLight' received command OFF
            18:26:52.399 [INFO ] [marthome.event.ItemStateChangedEvent] - TestLight changed from ON to OFF
            As you can see there is no mention in the openhab log file about buffering or smart sleep. Or a received heartbeat. Which it gets.
            What am I doing wrong?
            B 1 Reply Last reply
            • L
              L
              LastSamurai
              Hi, just a short question as I haven't found any up to date information about it: I am thinking about switching from domoticz to openHab 2 (as I really like the new UIs and the auto discovery). I am using an ESP8266 based MQTT gateway. Does openhab 2 on a raspi work with Mysensors using MQTT and does it support the new sensors/actor types added Mysensors 2 (specially RGBW)?
              Thank you!
              • F
                F
                Fabien
                Yes you can using proxy items and rules. see example here : https://github.com/mortommy/MySensorDioder
                But why not switching to ethernet/serial gateway with @TimO OH2 plugin ?
                • L
                  L
                  LastSamurai
                  Thanks @Fabien I have a serial gateway too, but I liked the idea of a MQTT gateway more because its much more flexible. Does Tims plugin not support MQTT? I wanted to use that.
                  andreacioniA 1 Reply Last reply
                  • L LastSamurai
                    andreacioniA
                    andreacioniA
                    andreacioni
                    Hi @LastSamurai , currently Timo is working on MQTT gateway but I don't know precisely when it will be available to all.
                    @Fabien Thank you for your feedback!
                    And: I've waited for that question according firmware updates to come up. :-D
                    I've looked into it and I'm very interested but till now there is only the implementation in the library, I've not seen an implementation in a binding. I'll continue to look at it, but with low priority. :-)
                    Current priority list is:
                    1. Include binding in OH2 repository.
                    2. Test and include the big refactoring from @andreacioni .
                    3. Add MQTT gateway (proof of concept working, full integration after refactoring).
                    4. Add little feature requests, add sensors ...
                    • L
                      L
                      LastSamurai
                      Ok, I will keep an eye on this one and stay with the serial gateway for now.
                      • A
                        Andrew Currie
                        After moving from my ubuntu laptop to RP3 I have had success!!
                        Flashed the sd card with the latest openhabian, waited for everything to auto install on the RP3 and could then install the my sensors (ethernet) gateway on the pi and also open a karaf console to log openhab2 via a remote/headless ssh. My remote browser could open the paper ui via openhabianpi:8080 and I added the ethernet gateway successfully. Adding the motion sensor needed the node id 2 and child id 1 as set by the Arduino sketch. The light level sensor was then turned on and it just showed up as my sensors (2,2) in the paper ui inbox so this level of discovery works! The sensors now show tripped status/light level in the paper ui control.
                        Looks like I can now progress to using My Sensors to control the mi-lights already working in openhab2.
                        Thanks Tim for all your work on the binding
                        • AndrewZA
                          AndrewZA
                          AndrewZ
                          @TimO , I just noticed a weird behavior - I've changed configuration for another binding and restarted it from the console but that killed mysensors binding:
                          2017-03-04 13:07:19.110 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'demo.things'
                          2017-03-04 13:07:19.123 [ERROR] [col.serial.MySensorsSerialConnection] - Interrupted reset time wait
                          2017-03-04 13:07:19.124 [WARN ] [col.serial.MySensorsSerialConnection] - Skipping I_VERSION connection test, not recommended...
                          2017-03-04 13:07:19.125 [INFO ] [col.serial.MySensorsSerialConnection] - Successfully connected to MySensors Bridge.
                          2017-03-04 13:07:19.125 [WARN ] [col.serial.MySensorsSerialConnection] - Network Sanity Checker thread disabled from bridge configuration
                          2017-03-04 13:07:21.141 [ERROR] [col.serial.MySensorsSerialConnection] - Can't connect to serial port. Wrong port?
                          2017-03-04 13:07:21.149 [ERROR] [col.serial.MySensorsSerialConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:0)
                          2017-03-04 13:07:33.161 [ERROR] [col.serial.MySensorsSerialConnection] - Can't connect to serial port. Wrong port?
                          2017-03-04 13:07:33.163 [ERROR] [col.serial.MySensorsSerialConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:1)
                          Complete stop/start of OH is the only solution so far.
                          • AndrewZA AndrewZ
                            andreacioniA
                            andreacioniA
                            andreacioni
                            Hi @AndrewZ , yes this is a known issue (I just openend an issue here) with the binding. Just out of curiosity, have you changed something in things file?
                            AndrewZA 1 Reply Last reply
                            • andreacioniA andreacioni
                              AndrewZA
                              AndrewZA
                              AndrewZ
                              @andreacioni thank you
                              Yes, it was a change in the .things file, but it was related to another binding.
                              • AndrewZA AndrewZ
                                andreacioniA
                                andreacioniA
                                andreacioni
                                @AndrewZ things file update trigger a reload of all binding declared inside it, nothing strange. ;) Follow the above link to keep track of the status of this issue.
                                • L
                                  L
                                  LastSamurai
                                  I just tried to get the openhab 2 binding up and running. I have a serial gateway and domoticz + openhab running on a pi. I stopped the domoticz service and installed the serial and mysensors addons for openhab like mentioned in the github readme (bundle:list showed them both). I also added the openhab user to the dialout group.
                                  I then created a demo.things file in config/things with
                                  Bridge mysensors:bridge-ser:gateway [ serialPort="/dev/ttyUSB0", sendDelay=200 ] {
                                  The log of openhab shows these errors though:
                                  2017-03-19 00:03:59.855 [ERROR] [col.serial.MySensorsSerialConnection] - Can't connect to serial port. Wrong port?
                                  2017-03-19 00:03:59.897 [ERROR] [col.serial.MySensorsSerialConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:46)
                                  Any idea why? This works just fine:
                                  cat /dev/ttyUSB0
                                  • L LastSamurai
                                    cat /dev/ttyUSB0
                                    AndrewZA
                                    AndrewZA
                                    AndrewZ
                                    wrote on last edited by AndrewZ
                                    #408
                                    @LastSamurai please check the group ownership
                                    $ ls -l /dev/ttyUSB0
                                    Make sure the port you're using is included in EXTRA_JAVA_OPTS as described here
                                    • L
                                      L
                                      LastSamurai
                                      Thank you, that helped! Should anyone ever face the same problem: after changing the EXTRA_JAVA_OPTS I also needed to restart openhab (more likely the java vm).
                                      • L
                                        L
                                        LastSamurai
                                        So openhab is running now and discovers my sensors when I restart them while scanning. My RGBW controller nodes pop up as RGBW sensors though. The on/off switch works, but what do I have to do to actually control the colors?
                                        I tried editing the 4 variables but that doesn't seem to change the lights.
                                        0_1490048386134_upload-9bf82cdd-ddd8-4249-973e-65bd30a3a959
                                        • T
                                          TimO
                                          wrote on last edited by TimO
                                          #411
                                          @LastSamurai : What does your sketch expect? One ASCII formated RGB code like described here: https://www.mysensors.org/download/serial_api_20 or a value between 0 and 100% per color (r,g,b,w)? I see different implementations (in openhab and in mysensors) and maybe we have to adjust the binding.
