  3. Still searching for a working Ethernet GW with RFM69
18 Posts 7 Posters 6.0k Views 6 Watching
  • SnobsS Offline
    SnobsS Offline
    Snobs
    Hallo,
    I stil ltry to setup an ethernet gateway with arduino nano, w5100 or w5550 (both are in my stock) and a RFM69 Modul.
    It is possible, that someone post his sketch and the wiering. I am despairing. It will not working :(
    Thank you and grettings from Germany.
    Sascha
    K 1 Reply Last reply
    • S Offline
      Hello
      have you taken a look at the docs on main site?
      In case, those docs will be helpful ;)
      • for connecting the radio https://www.mysensors.org/build/connect_radio
        It is important to note, that rfm69 needs level shifting if using nano (because on nano the mcu runs at 5v, and rfm69 is not 5v tolerant)
      • for the W5100 : https://www.mysensors.org/build/ethernet_gateway
      • or there is also the Sensebender GW which is complete and designed for this :) https://www.mysensors.org/hardware/sensebender-gateway
      • SnobsS Offline
        SnobsS Offline
        Snobs
        Yes I do, but some PINs you cant get twice and PIN 10 ist for the W5100 reserverd.
        ther is no discription how to connect RFM69 und W5100.
        I cant get it to work and ask for a working sketch with Pinout.
        BR
        Sascha
        • rejoe2R Offline
          rejoe2R Offline
          rejoe2
          Is this a SoftSPI problem (see https://forum.mysensors.org/topic/1810/no-softspi-support-for-rfm69)?
          Perhaps using the "normal" SPI-PINs for both modules in parallel may help, but don't forget to levelshift these and you may have to enable CS-PIN before trying to communicate via the WS5100. With some other SPI device, the following worked in a nRF setup at least in my first tests (CS1=10):
          void before() {
            pinMode (CS1, OUTPUT);
          digitalWrite(CS1, HIGH);
          Perhaps this is better placed in preHwInit() (?).
          • T Offline
            T Offline
            tbowmo
            @Snobs
            W5100 does not like to share the SPI bus with other devices, as it doesn't tri-state the MISO line when you disable it. This is why we use softspi for the NRF module when using W5100.
            I can't remember if someone actually have made softspi available for the RFM69, or if it is still a work in progress.. If it's still a work in progress, the easiest solution is to get a Sensebender Gateway, as stated by @scalz
            • K Offline
              K Offline
              korttoma
              T get the Ethernet GWworking with RFM69 please check out the instruktionsfrom @jpaulin from here -> https://forum.mysensors.org/topic/5109/solved-rfm69-based-nodes-unable-to-report-lib-version/25
              • Tomas
              • SnobsS Snobs
                Hallo,
                Sascha
                K Offline
                K Offline
                korttoma
                @Snobs did you manage to get this to work?
                • Tomas
                • SnobsS Offline
                  SnobsS Offline
                  Snobs
                  Nope, sorry for late response. Need a litte space, otherwise I throw it before frustration in the garbage.
                  I`ll edit the w5100.h file and it looks like so
                   /*inline static void initSS()    { DDRB  |=  _BV(2); };
                   inline static void setSS()     { PORTB &= ~_BV(2); };
                   inline static void resetSS()   { PORTB |=  _BV(2); }; */
                   inline static void setSS()     { cli(); PORTB &= ~_BV(2); };
                   inline static void resetSS()   { PORTB |=  _BV(2); sei(); };
                  It doesn't matter for me wich pin it is, so I`ll try pin 10 for w5100 and with
                  #define MY_RF69_SPI_CS 7
                  Switch default pin D10 from RFM68 to D7 and connect NSS from w5100 do D10.
                  First it looks good, but by any msg from a sending/working sensor the device restart and after some retries.
                  0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGA--,VER=2.1.0
                  0;255;3;0;9;TSM:INIT
                  0;255;3;0;9;TSF:WUR:MS=0
                  0;255;3;0;9;TSM:INIT:TSP OK
                  0;255;3;0;9;TSM:INIT:GW MODE
                  IP: 192.168.100.254
                  0;255;3;0;9;MCO:BGN:STP
                  0;255;3;0;9;TSF:MSG:READ,11-11-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                  0;255;3;0;9;TSF:MSG:SEND,0-0-11-11,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                  0;255;3;0;9;TSF:MSG:READ,11-11-0,s=2,c=1,t=0,pt=7,l=5,sg=0:22.3
                  IP: 192.168.100.254
                  0;255;3;0;9;TSF:MSG:READ,11-11-0,s=3,c=1,t=38,pt=7,l=5,sg=0:3.4
                  IP: 192.168.100.254
                  I use a FHEM Controller in germany with seperate other device like LaCrosse or Homematic.
                  Some ideas why it restart and only the msg is showing on serial output in IDE?
                  Thanks for help.
                  BR
                  Sascha
                  • SnobsS Offline
                    SnobsS Offline
                    Snobs
                    wrote on last edited by Snobs
                    Seeting up an blank, clean, new Domoticz Controller. Same Error if receiving data.
                    2017-03-09 19:33:29.101 MySensors: TCP/IP Worker stopped...
                    2017-03-09 19:33:30.103 MySensors: trying to connect to: 192.168.100.254:5003
                    2017-03-09 19:33:31.104 MySensors: connected to: 192.168.100.254:5003
                    2017-03-09 19:33:40.106 MySensors: Connection reset!
                    2017-03-09 19:33:40.106 TCP: Reconnecting in 30 seconds...
                    2017-03-09 19:34:10.110 TCP: Reconnecting...
                    2017-03-09 19:34:11.110 MySensors: connected to: 192.168.100.254:5003
                    2017-03-09 19:34:20.112 MySensors: Connection reset!
                    2017-03-09 19:34:20.112 TCP: Reconnecting in 30 seconds...
                    • SnobsS Offline
                      SnobsS Offline
                      Snobs
                      It is working!
                      The trick was, downgrade the AVR to Version to 1.6.11. After that the erstart/reboot dosent happen and it work :-)
                      Thank you for your support!
                      BR
                      Sascha
                      • K Offline
                        K Offline
                        korttoma
                        Nice! Greate that you found the solution to the rebooting on your own. Many have encountered the issue. Now we are at least 3 persons with a working RFM69 Ethernet GW.
                        • Tomas
                        • SnobsS Offline
                          SnobsS Offline
                          Snobs
                          Yes, the first 12 hours it is working without disconnect or reboot. So I tought post your result, hope that helps other people with the same problem and give back some information to this great forum :)
                          BR
                          Sascha
                          • R Offline
                            R Offline
                            rene_2k2
                            For those like me that have followed the intructions but cannot have their ethernet gateway to work with RFM69, that page may explain the source of the problem : some W5100 hardware modules do not have the logic allowing other SPI device to share the same bus (time to solder...).
                            Hope that can help others, saving them hours of tests and failures...
                            R 1 Reply Last reply
                            • R rene_2k2
                              R Offline
                              R Offline
                              rene_2k2
                              wrote on last edited by rene_2k2
                              Started some tests to drive W5100 Funduino module SPI_EN pin by a dedicated arduino output as it seems to be the goal of MY_W5100_SPI_EN but after some more failures (a LED on MY_W5100_SPI_EN pin does not blink as I would expect), I realize that I do not see any use of that pin definition in MQTT, only in the EthernetGateway sketch... Am I missing something ?
                              For those who manage to get their W5100 and RFM69 sharing the same SPI but ( @Snobs , @jpaulin , @korttoma ) what W5100 modules are you using ? Do you know how the Wiznet SPI_EN pin is driven (do you have the module schematic) ?
                              • K Offline
                                K Offline
                                korttoma
                                I am using this module with an arduino pro mini
                                #define MY_RADIO_RFM69
                                #define MY_RF69_SPI_CS 9
                                #define MY_GATEWAY_W5100
                                • Tomas
                                • R Offline
                                  R Offline
                                  rene_2k2
                                  Thanks @korttoma for your feedback ! Looks like the one I use. Did you manage to get this hardware working with MQTT sketch ?
                                  • R rene_2k2
                                    K Offline
                                    K Offline
                                    korttoma
                                    @rene_2k2 sorry I do not use MQTT
                                    • Tomas
                                    • G Offline
                                      G Offline
                                      gieemek
                                      It is possible to use RFM69 radio via SoftSPI which allow to build gateway with W5100 or ethernet shield. You need to change RFM69 driver and MyConfig.h configuration file.
                                      I put modified these files at github repository: https://github.com/gieemek/RFM69_softSPI-for-MySensors-2.1.1
                                      You can find instruction how to prepare gateway sketch at this repository too.
                                      My gateway (as MQTT client) with ethernet shield and RFM69 radio via SoftSPI is working for 10 days without any problems.
