  2. Announcements
  3. 💬 Security & Signing
137 Posts 20 Posters 46.5k Views 19 Watching
  • M macvictor
    Hi everybody :)
    Where I find information step by step how to run signing/security with one sensor and raspbery pi gateway and use mqtt (software signing without chip ATSHA)? I try understand this post, but I have problem.. I test example code but always my gw get normal information..
    AnticimexA
    AnticimexA
    Anticimex
    @macvictor https://www.mysensors.org/about/signing
    • AnticimexA Anticimex
      macvictor
      @Anticimex I read all text and I understand that I have add forth line to all my sensors.:
      #define MY_SIGNING_SOFT
      #define MY_SIGNING_NODE_WHITELISTING {{.nodeId = MOTION_SENSOR_ID,.serial = {0x12,0x34,0x56,0x78,0x90,0x12,0x34,0x56,0x78}}}
      In my gateway i must use this comand:
      ./configure --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-signing=software --my-signing-debug --my-signing-request-gw-signatures-from-all --my-mqtt-password=PASSWORD --my-mqtt-user=USER
      1. but I do not understand wher I create white list in gateway?
      2. how create serial for my mensors (eg. {0x12,0x34,0x56,0x78,0x90,0x12,0x34,0x56,0x78})?
      3. how to check if everything is working?
      4. how to use HMAC (how to create in my sensor, where save)?
      AnticimexA 1 Reply Last reply
      • M macvictor
        AnticimexA
        AnticimexA
        Anticimex
        @macvictor the raspberry specific things you need to check with @marceloaqno about, the other questions really are all answered in the link I sent.
          macvictor
          @Anticimex Ok. I read again this text. I have next question..
          1. I generated SOFT_HMAC_KEY, SOFT_SERIAL, AES_KEY in my gateway, so when I run SecurityPersonalizer.ino i must save this value from gw in MY_SOFT_HMAC_KEY, MY_SOFT_SERIAL, MY_AES_KEY or generate other value and save? Probably AES must by the same.. MY_SOFT_SERIAL is 'serial' in WHITELISTING so i think this must by different in node and gateway, and what with HMAC? I think that the HMAC must be the same..
          2. I looked for information where save whitelist in gw but i didn't found.. can you help my find solution?
          3. If I use for example 2 nodes-relays, 2 nodes-temperature and gateway. All relays communicate only with gateway but all are repeater. All node-temperature sensor connect with relay, so in nodes-relay in white list i must add temperature serial and gw serial. In temperature I does't add white list, in gateway I add relay and temperature nodes serial. That is all?
          PS. Thank you for you help :)
          • M macvictor
            AnticimexA
            AnticimexA
            Anticimex
            @macvictor
            1. Quotes from the documentation (link I sent):
              "In case you want to be able to "whitelist" trusted nodes (in order to be able to revoke them in case they are lost) you also need to take note of the serial number of the ATSHA device or the software value stored in EEPROM. This is unique for each device."
              "That mean that all nodes in your network share the same PSK" (this goes for both HMAC and AES (if you use encryption)).
            2. There is no difference. You specify your whitelists the same way in both gateway and nodes. Of course you have to have different whitelists but the format and way of storage is identical.
            3. All signing is end to end. Your nodes communicate with your gateway. It does not matter if they are relayed 50 times on the way to the gateway. Therefore, whitelists in gateway and node use the serial from the other part (gateway or node).
              Your relays are also nodes. If you send data explicitly to these nodes, you also need the serial for those (if you want signed communication with them) but your temp sensors and your gateway talk to each other. Signing does not care about relays.
              So you do NOT need to add gw and temperature serials to your node-relays just to have your gw and temperature sensors communicate with each other. You do not even have to enable signing in your relays. They are (possibly) just that; relays.
              Of course, this mean that you have to have your gw serial in your temperature node whitelist, and vice versa (if you use two way signing).
            • E
              E
              egadgetjnr
              Hi Guys,
              Long time reader and first time poster.
              Now a general disclaimer, I'm only fairly new to the IoT world of home automation sensors and am looking at the crypto side of signing devices as I thought if I'm going to do it, I'm going to do it right from the start with signing and utilizing OTA abilities.
              I have a quick question regarding the ATSHA204 component. I know that the SenseBender uses a ATSHA204-STUCZ (the Single-Wire interface config) but I can't get these sourced through my normal supplier.
              I am able to source ATSHA204A-SSHDA-B though, and was wondering if this would work instead, even though it's an I2C interface config instead. If not, how much work is involved to get it to work?
              Thanks Heaps
              • E egadgetjnr
                Hi Guys,
                Thanks Heaps
                AnticimexA
                AnticimexA
                Anticimex
                @egadgetjnr hi and welcome to the forum! It will require some work as the current driver only handles single wire interface and the I2C support in the chip has special requirements in the bus for sleep/wake states. I don't know how much work exactly is needed but it will not be insignificant.
                Also, what sources have you checked? It should be possible to source the single write variant online without problem.
                • E
                  E
                  egadgetjnr
                  @Anticimex said in 💬 Security & Signing:
                  Thanks heaps for your prompt reply!
                  I've looked at Mouser and Digi-Key and they have a $60 minimum for free postage (I don't want to order 100 for free shipping at this stage obviously as I'm only prototyping) and I can't bring myself to spending $25 on shipping for around $5.00 of modules :frowning:.
                  Which leaves me with my normal supplier of Element14 (formally Farnell) where I get free shipping regardless of order quantity. :wink: but they don't source the Single-Wire ones at all.
                  I was going to put a post over on the OTA Flash forum as well as I'm having issues sourcing the AT25DF512C (it's been discontinued) and was looking at an ATAES132A (Datasheet <here> using an SPI interface) as I accidentally ordered some of them for another project and thought maybe it would be possible to combine both the security signing and OTA flash in the one component (Which is a HUGE assumption as to its use). As mentioned earlier, I'm still fairly new to the engineering side of hardware so I may be way off the mark.
                  • TakeroT
                    TakeroT
                    Takero
                    @egadgetjnr where dit u come from?
                    • E egadgetjnr
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @egadgetjnr Ok, well, if you are up to it, feel free to make a PR with I2C support. I do not have the bandwidth to implement that myself I am afraid, and I don't feel the gains are worth the efforts. I2C will put constraints on which pins to use, and of course it would also require two pins and not one.
                      But I happily review any pull requests on the topic. If we get the support, it is just a bonus :)
                      Regarding flash, it is not crucial that you get the exact same part (or even the same supplier). The important thing is that the interface is the same and that they share the same JEDEC identifier.
                      • D
                        DavidZH
                        wrote on last edited by DavidZH
                        I had exactly the same issue. This UK eBay store sells them per 5. Not sure what they'll ask for sending them across the ocean.
                        I got them from here (4 days from UK to NL). Got one up in my gateway and that works with a soft signing node. Should be good.
                        • B
                          B
                          bilbolodz
                          Just to be sure: SOFT_HMAC_KEY, SOFT_SERIAL is used for signing, AES_KEY is used for encryption. SOFT_HMAC_KEY, AES_KEY should be the same across all network nodes, SOFT_SERIAL should be different for every node?
                          • B bilbolodz
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @bilbolodz this is quite clearly stated in the documentation, but in short yes. But AES and HMAC key should not be the same, as the encryption is not using initialization vectors so the key can be derived from analyzing the encrypted messages by someone with the adequate knowledge.
                            • B
                              B
                              bilbolodz
                              I'm trying to start play with ATSHA204A signing. I've ATSHA204A-SSHCZ-T chip (8-lead SOIC single wire). I've connected chip pins: 4 - GND, 8 - VCC (5v), 5 - A3, I've added 100nF between 4 and 8 and 4K7 resistor between 5 and 8. I've loaded "near clear" SecurityPersonalizer sketch (only added #define MY_SIGNING_ATSHA204_PIN A3 #define MY_SIGNING_ATSHA204) but I've got:
                              Failed to wake device. Response: E7
                              Halting!
                              any ideas?
                              AnticimexA t3chieT 2 Replies Last reply
                              • B bilbolodz
                                Halting!
                                any ideas?
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @bilbolodz hm, no. I have not tested on a 8-lead device. Should not be a difference but I can neither deny nor confirm. My best suggestion would be to have a look with an oscilloscope on the wire to confirm that the signal quality is good.
                                  melwinek
                                  Is SIGNING a RFM69_ENABLE_ENCRYPTION replacement? If so is it a better or worse solution? Maybe RFM69_ENABLE_ENCRYPTION is enough?
                                  mfalkviddM AnticimexA 2 Replies Last reply
                                  • M melwinek
                                    @melwinek encryption and signing have very different purpose.
                                    Signing prevents other people from sending messages to control your nodes. Without signing, anyone with the right skill or software can take control of your nodes.
                                    Encryption tries to hide the contents of the messages between your nodes. That does not prevent people from taking control of your nodes.
                                    • M melwinek
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @melwinek signing and encryption are two completely different things. And they can be enabled at the same time if so desired. Signing provides authentication and encryption provides obscurity.
                                        melwinek
                                        @Anticimex, @mfalkvidd But with the use of encryption so easily no one will take control, must break the code.
                                        So it is best to simultaneously encrypt (eg RFID tag serial number when opening the gate) and sign (eg gate open message)?
                                        • M melwinek
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @melwinek what prevents anyone from copying your encrypted message and record it. And then later send the same thing?
                                          Encryption provides obscurity. You need signing for authentication. Signed messages cannot be repeated because they are always unique. Encryption does not necessarily guarantee that.
